[Plugin] SUClock - v3.0a - 19 May 20 - Tracking time in SU
Re: [Plugin] SUClock - v1.3a - 08 Oct 11 - Tracking time in
Postby rv1974 » Mon Sep 03, 2012 8:23 am
Is there way to permanently hide 'check plugins for update' window (the small yellow one with ruby)?
rv1974
Postby mwm5053 » Mon Sep 03, 2012 10:21 am
You should only see it every 15 days or so, good to have if there have been updates, bug fixes and such.
2011 iMac
SU 2015 Pro, 2017 Make
V2 Twilight
macOS Sierra 10.12.5
mwm5053
Premium Member
Premium Member
Postby thomthom » Mon Sep 03, 2012 10:28 am
rv1974 wrote:Is there way to permanently hide 'check plugins for update' window (the small yellow one with ruby)?
That's part of LibFredo. Set the frequency to 999 to disable.
PluginStore Author
PluginStore Author
Postby Dave R » Mon Sep 03, 2012 10:32 am
If you really don't want to see it every 15 days, go to window>LibFredo6 Settings>Default Parameters and change it.
As Walt says, though, it doesn't hurt to have it pop up. It makes it easy to check for updates.
Global Moderator
Postby JFought » Thu Jan 31, 2013 4:33 pm
really having a problem installing this. I could use some help.
JFought
Postby Dave R » Thu Jan 31, 2013 5:30 pm
Is there any chance you could describe the problem?
Global Moderator
Postby Krisidious » Thu Jan 31, 2013 6:32 pm
Love the plugin updater...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Lana » Wed Sep 25, 2013 12:54 pm
:fecstatic: It's is new for me. Thankssssssss :ecstatic:
Lana
Re: [Plugin] SUClock - v1.5a - 27 Nov 13 - Tracking time in
Postby fredo6 » Wed Nov 27, 2013 9:53 pm
NEW RELEASE: SUClock v1.5a - 27 Nov 13
SUClock 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby paul.wacko » Fri Jan 17, 2014 4:06 am
I am getting this error message when I am trying to start s clock to an existing file
paul.wacko
Postby fredo6 » Fri Jan 17, 2014 8:22 am
You need to choose a file with .suclock extension, not skp.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby paul.wacko » Fri Jan 17, 2014 8:29 am
Thanks for that.
I had worked it out and felt rather stupid not realising the skp extension.
However it would be nice to have the option to edit the session time or add session times for additional things such as Photoshop PP etc...
Paul
paul.wacko
Postby fredo6 » Fri Jan 17, 2014 9:05 am
The only thing you can do currently is to export to Excel and then add other duration items.
SUClock is only aware of the activiy in SU and the Ruby API does not allow making a difference between being idle in SU and being in another applications.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rythm » Mon Feb 03, 2014 11:25 pm
Hi Fredo6,
I just downloaded your SUClock plugin and would love to try it out but when I try to attach an existing file (after clicking the little clock icon) to it I get the image attached.
I also tried attaching different files, and tried to attach a new project and get the same results.
I have Macbook Pro, OS X, 10.7.5 and plenty of power behind it.
Any thoughts? Solutions?
Thanks,
-R
rythm
Postby fredo6 » Tue Feb 04, 2014 10:43 am
The files created and manipulated by SUClock have extension .suclock, not .skp. Please refer to the documentation.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby lucap90 » Tue Jul 08, 2014 3:42 pm
hello. I have a problem with suclock. I installed everything and when i turn on the program and press the clock icon nothing happens, no icon like this download/file.php?id=67045 have you got some idea for this problem?
lucap90
Postby Dave R » Tue Jul 08, 2014 5:19 pm
Perhaps you missed installing LibFredo6?
Global Moderator
Postby lucap90 » Wed Jul 09, 2014 3:45 pm
Of course I installed LibFredo...
lucap90
Postby Dave R » Wed Jul 09, 2014 7:59 pm
How did you install them? Exact steps, please.
Global Moderator
Postby lucap90 » Thu Jul 10, 2014 12:05 pm
well...first I downloaded Fredo6_SUClock - v1.5a - 27 Nov 13.zip and LibFredo6 5.4b. Then I unzipped both files and put them to the folder: Program Files (x86)\Google\Google SketchUp 8\Plugins. After that I ran the sketchup and It was white small clock icon like this http://jroot.sketchucation.com/pluginre ... UClock.png When I clicked this icon opened a window with project 'Tracking of the Model in Project' and I tried to use 'Attach to New Project' or 'Attach to an existing Project' and finally when I clicked 'done' nothing happened. I think that then should be small icon download/file.php?id=67045 to time count. I don't know what i'm doing wrong....
lucap90
Postby Dave R » Thu Jul 10, 2014 1:45 pm
The plugin clearly works in SketchUp 8 so it must be something on your end. Historically, the most common reason that plugins fail to work correctly when installed from the ZIP file is that the user extracted the contents incorrectly and destroyed the file structure. This is the reason for the RBZ files for plugins. Go into the Plugins folder and delete all of the files and folders related to this plugin. Download the RBZ file and use Install Extension from Preferences>Extensions to install it. Then try the plugin again.
Even better would be to install the Sketchucation PluginStore and use it to automatically install plugins.
Global Moderator
Re: [Plugin] SUClock - v1.6a - 20 Oct 14 - Tracking time in
Postby fredo6 » Mon Oct 20, 2014 7:31 am
NEW RELEASE: SUClock v1.6a - 20 Oct 14
SUClock 1.6a is required for the support of usernames with non-ascii characters in Sketchup 2014
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby smartsizer » Thu Oct 23, 2014 8:40 pm
I'm having a similar problem. I am using a Dell Precision T3400, running Windows Vista Business SP2, with Sketchup 14.1.1282.
I have deleted old versions of SUclock and LibFredo, and re-installed fresh versions of both of these from Sketchucation just yesterday. The installation seemed to go normally. When I open a new file and save it, I can then use SUclock normally. If I then close the file and re-open it, when I click on the SUclock icon, nothing happens. If I select all entities, copy them and paste into a new file, the SUclock will work (the first time). After saving and closing, the SUclock will not work.
Any tips on how to fix this?
smartsizer
Premium Member
Premium Member
Postby fredo6 » Thu Oct 23, 2014 8:49 pm
Could you open the Ruby Console and check if there are messages when launching SUClock.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby smartsizer » Thu Oct 23, 2014 9:36 pm
Nothing at all shows up in the Ruby Console windows.
smartsizer
Premium Member
Premium Member
Re: [Plugin] SUClock - v1.7a - 24 Oct 14 - Tracking time in
Postby fredo6 » Fri Oct 24, 2014 9:50 pm
NEW RELEASE: SUClock v1.7a - 24 Oct 14
SUClock 1.7a fixes a major bug which was introduced as a side effect of the load-on-the-fly approach of LibFredo6 6.2 and above. Basically, the clock would not display automatically if you open straight a file which is tracked (unless you open first a web dialog box in my scripts)
The good news is that the time was properly tracked for the models. So you won't lose any data normally.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby RCD » Tue Feb 17, 2015 11:32 pm
No Auto-install option at Extension Warehouse for SU 2015 - link is broken for SU Clock , says it dosn't exist?
RC
RCD
Postby Dave R » Tue Feb 17, 2015 11:38 pm
Really?
Most of Fredo's extensions are hosted here. Not the Extension Warehouse.
Global Moderator
Postby derei » Tue Jun 09, 2015 3:05 pm
SUClock BUG with Su2015 ?
I don't know if SU2015 is to blame, or my project files, but after linking 2 SU files to the same project, i can't open any of them anymore (bugsplat). In order to open it, I have to rename the .suclock file so the app won't recognize it (i am altering its extension). Then, the SU files open normally. After opening, if i rename the extension back to .suclock , it will link properly and work as intended.
DESIGNER AND ARTIST DEREI.UK
derei
Postby derei » Fri Jul 10, 2015 8:06 pm
If this forum is still read, especially by Fredo, I would like to thank him for this plugin at first, then to ask if a small addition to it would be possible to be made.
I was thinking to a kind of "time splitting" like in lap stopwatch. This feature should be used for sequential billing, but without the need to reset the total time of work on a project.
The idea would be to have a button (inside settings menu is fine, to be less accessible) and when that button is pressed, then "lap timer" would be reset and the user would have the total time spent to the project until that moment. The work that will follow will be counted from zero, but still the main counter will work undisturbed.
So, let's say every week or when enough working hours have built together for a payment, the "lap" is reset, the client has the invoice for those hours and then the work can continnue, then reset again after a while, invoice sent and so on. And after each reset, the "lap timer" should reset to zero, but the general timer should continue.
What I had in mind is simple, but I am afraid I over complicated it with explanations. I hope it makes sense anyway.
Would be really nice to have this. Thank you very much.
derei
PreviousNext
Return to Plugins
Users browsing this forum: felipemunozz and 11 guests
