[Plugin] SUClock - v3.0a - 19 May 20 - Tracking time in SU
Re: [Plugin] SUClock - v1.1b - 19 May 11 - Tracking time in
Postby halroach » Sun May 22, 2011 9:05 pm
For all those times when you worked hard on a model but forgot to track the time you've spent on it... and really wished you had...
You could have a little check in the plugin preferences to 'track time for untitled projects'.
This would generally eliminate all time spent with Sketchup, that is unaccounted for. great for spying too when you think about it...
a step further could be to have an option to rename the untitled time/projects in retrospect and assign that time to an existing or new project.
What do you think?
halroach
Postby halroach » Sun May 22, 2011 9:12 pm
Just thought of another use.
At my modeling and rendering department, we generally tend to share the work on models between us. It would be nice to have a worker ID or computer ID which would be assigned for each time track.
Then we could see how much time each of us spent on the same project.
I really like this plugin!
halroach
Postby fredo6 » Sun May 22, 2011 9:25 pm
Halroach wrote:Just thought of another use.
SUClock is not really designed for concurrent multi-user on a network, because it uses local temporary files to track the information.
One possibility is that I give the option to put all files on a shared drive
Another possibility is that each user has his own .suclock files, but I give the option to issue statistics on a several .suclock files. Note however that you can already do this with the Excel exports.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby COSEDIMARCO » Mon May 30, 2011 2:02 pm
Hi Fredo,
I've two request for future realeses, if possible.
- had the opportuny to export statistics in other formats such as HTML or tabbed TXT? I'd like to paste them in my blog posts.
- Track usage of all your plugins.
At last, great plugins like all of yours :berserk:
COSEDIMARCO
Postby fredo6 » Mon May 30, 2011 4:13 pm
COSEDIMARCO wrote:- had the opportuny to export statistics in other formats such as HTML or tabbed TXT? I'd like to paste them in my blog posts.
No problem, this is simple to do.
COSEDIMARCO wrote:- Track usage of all your plugins.
SUClock only tracks 'interactive' plugins, that is those based on the Sketchup::Tools class, typically where you can click and do things in the screenport UI.
All my plugins are enabled in their latest version.
By the way, interactive scripts written by other writers can easily be tracked too.
They just need to insert a single line of code in the activate() method of their tool
Code: Select all
def activate
   LibFredo6.register_ruby 'Name of the Plugin' if defined?(LibFredo6.register_ruby)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby COSEDIMARCO » Mon May 30, 2011 4:32 pm
Ok. Thanks a lot. :D
COSEDIMARCO
Re: [Plugin] SUClock - v1.2a - 03 Jun 11 - Tracking time in
Postby fredo6 » Fri Jun 03, 2011 3:59 pm
NEW RELEASE: SUCLOCK 1.2a - 03 Jun 11
This release adds some functional enhancements and problem fixing based on feedback received from users
Alarm to Target:
The principle is to set a target time and an alarm threshold for the project, so that you are warned when the effective time spent is close and then above the target time.
The clock will indicate visually where you stand in the achievement of your target. Say that you set a target time at 4h, with a threshold of 75%:
Statistics reports:
I included the possibility to generate reports in several formats (I may add more).
HTML is not implemented yet. I need to made changes to LibFredo6, so it will be available in a next release. You can set up the default format in the Default Parameters dialog box.
Cropping of the clock window :
As the exact rendering of the clock window depends from too many settings (Operating system, browser version, etc…), I simply made the height of the clock window a parameter that you can change in the Default Parameters dialog box. Default height is 50 pixels.
Multi-user environment:
If you wish several users to work on the same projects across the network, then you need to configure SUClock with a temporary directory located on a shared drive (as well as the suclock files indeed).
You can set the network path of the temporary directory in the Default Parameters dialog box.
Reset projects and Import data from another project:
You can reset a project to Zero. This will erase all data irreversibly.
You can import data from another project into the current project. Optionally, you can then reset to zero this other project.
CAUTION: In version 1.2, I did not provision an Undo for these two functions. So please use with care!
Update is published in main post.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby SketchUpNoobie » Fri Jun 03, 2011 4:11 pm
Fredo6 wrote:NEW RELEASE: SUCLOCK 1.2a - 03 May 11
Nice! Thanks. :thumb:
It's June though. ;)
SketchUpNoobie: the complete noob in all things SketchUp.
SketchUpNoobie
Postby spence » Fri Jun 03, 2011 8:05 pm
Fredo,
Thank you for the plugin, this is fantastic :D This will come in very handy. This type of time tracking should be build into all productive software programs. It would be nice to be able to track your time, then again in some ways it's bad, It may prove I'm not that productive :roll:
Spence
spence
Premium Member
Premium Member
Postby rastus127 » Sat Jun 04, 2011 1:30 am
Great looking plugin Fredo!! But I'm having trouble loading it into S8 plugins folder. I keep getting an error that says "The item SUClock%201 can not be moved because "Sketchup" cannot be modified". But it loaded itself at the bottom of the list of folders. I'm on a Mac and have loaded other plugins most times with success, sometimes not. Maybe its just me. if you know what I'm doing wrong I'd rely appreciated any help you can give. Thanks.
Paul
rastus127
Postby fredo6 » Sat Jun 04, 2011 8:33 am
rastus127 wrote:Great looking plugin Fredo!! But I'm having trouble loading it into S8 plugins folder. I keep getting an error that says "The item SUClock%201 can not be moved because "Sketchup" cannot be modified". But it loaded itself at the bottom of the list of folders. I'm on a Mac and have loaded other plugins most times with success, sometimes not. Maybe its just me. if you know what I'm doing wrong I'd rely appreciated any help you can give. Thanks.
Paul
Paul,
The presence of the "%20" indicates that you probably downloaded or unzipped the files with a tool that does not convert properly file names (%20 is the the replacement for Space). Can try with a different tool.
You may also have some permission access issues on your Mac
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby publied » Sat Jun 04, 2011 11:19 am
thank You! very nice and useful script!
publied
Postby COSEDIMARCO » Sun Jun 05, 2011 3:22 pm
Thanks for export! :)
:berserk:
COSEDIMARCO
Postby halroach » Mon Jun 06, 2011 12:42 pm
Hi Fredo,
Now that the plugin works over the network, do you think it can be possible to assign, in the default parameters/in the main menu, a Username.
It could be username for each computer or you could even have multiple usernames for one computer, though I think that wouldn't be necessary.
The idea would be to track time for a project with the ability to see how much time each user spent on it and at what time during the project each user was involved... would be great for a gantt chart...
halroach
Postby COSEDIMARCO » Mon Jun 06, 2011 6:52 pm
Hi Fredo
attached there's the Italian Translation for SuClock
I think i've found a couple english mistakes:
"Threshold when clock in displayed in warning mode" --> "Threshold when clock is displayed in warning mode
"ERROR: you can import data from the same current project
" --> "ERROR: you can't import data from the same current project
SUClock_IT.zip
COSEDIMARCO
Re: [Plugin] SUClock - v1.3a - 08 Oct 11 - Tracking time in
Postby fredo6 » Sat Oct 08, 2011 7:44 am
NEW RELEASE: SUCLOCK 1.3a - 08 Oct 11
This release fixes problems encountered with Mac OSX Lion and Safari 5.1 (no images in the clock window)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Krisidious » Wed Jan 04, 2012 1:49 am
how does one go about adding time to a model? I already worked on it and forgot to hit the SUClock?
is there a way to auto start SUClock with every new model?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby TIG » Fri Jan 06, 2012 2:53 pm
Fredo
I have a'SUClock' related issue. :roll:
If I deactivate the 'SUClock' Extension and restart Sketchup then when I try to run some of your tools [BezierCurve and RoundCorner] - I get a Ruby Console error like this Error: #<NoMethodError: undefined method `register_ruby' for SUClock:Module>
C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:496:in `activate'
I deduce that this is because those two tools' test for the definition? of 'SUClock', which returns 'true', because IT IS defined, and partially loaded, but because it's inactive with the Extension being disabled, then the relevant 'register_ruby' method isn't available - so I get the error.
If I have SUClock loading at all, then I must always have it active in the Extensions list, otherwise it breaks your other two tools when try to use them.
Of course stopping SUClock loading all together avoids this, as then it's then never 'defined?'.
But this is awkward, this Extension should be capable of being simply deactivated, as I do not use it that often: the whole point of an Extension is you load it as it is needed.
Your two problem tools need their code recasting, for example using something like this that prevents the failure being an issue...
(begin;SUClock.register_ruby('BezierSpline');rescue;end)if defined?(SUClock) needed in two lines.
(begin;SUClock.register_ruby('RoundCorner');rescue;end)if defined?(SUClock) needed once.
this works fine for me, but it really ought to be 'built-in' ;)
Global Moderator
Postby fredo6 » Fri Jan 06, 2012 3:59 pm
TIG wrote:Fredo
If I deactivate the 'SUClock' Extension and restart Sketchup then when I try to run some of your tools [BezierCurve and RoundCorner] - I get a Ruby Console error like this [ruby]Error: #<NoMethodError: undefined method `register_ruby' for SUClock:Module>
TIG,
This is fixed (actually the method call is nomore to SUClock but to LibFredo6).
However, I am not sure I published it for BezierSpline and RoundCorner. I'll check
Thanks for signaling
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Rich O Brien » Fri Jan 06, 2012 4:51 pm
I also notice that when exporting to 'Tabbed Text' the '%%' column can be one tab off in certain columns.
Rich O Brien
Administrator
Postby Krisidious » Fri Jan 06, 2012 9:11 pm
ummm adding time to the clock?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby guanjin » Mon Apr 16, 2012 6:09 am
Fredo Hello, statistics clock can join FredoTools1.1m you? Only an icon, taken together, easy to manage, thank you!
I come from China, is to learn
guanjin
Postby tomvokurka » Wed Jul 04, 2012 4:25 pm
Hi.
I have a small problem with this plugin. I found it really usefull, but somehow I can't set it up.
When I click on a clock icon, select "Attach to a New Project", then type a name of .suclock file and save it in a file with my SU model (with a same name as model) I can't see any .suclock file in explorer. It even doesn't start counting time, no clock appears at all. Can anyone help me? Some advices?
I've got SU 8 and Win 7.
Thanks a lot!
tomvokurka
Postby fredo6 » Wed Jul 04, 2012 8:41 pm
tomvokurka wrote:Hi.
Thanks a lot!
Strange. However on Windows 7 there are by default many security rules preventing to create files by script so it may just be that issue of security (actually the file may be created in a security zone, but not writable).
I would suggest that you redo the operation, opening before the Ruby console. Also, do you get a message from SuClock?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Wed Jul 04, 2012 10:45 pm
Fredo, have you found a solution to Vista, Win7 putting files you write out in SU Ruby into the Virtualstore?
PluginStore Author
PluginStore Author
Postby fredo6 » Wed Jul 04, 2012 10:56 pm
thomthom wrote:Fredo, have you found a solution to Vista, Win7 putting files you write out in SU Ruby into the Virtualstore?
No. From Ruby you don't see anything, except that the file is created or not created.
Actually, I don't understand very well how this virtualstore works and what is the intention.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Thu Jul 05, 2012 12:05 am
Fredo
I found I could detect if a file was in VirtualStore or not. But if I wanted to create a file I cannot work out in advance if it will appear in VirtualStore or not.
If I edit a file in the Plugins folder everything is fine, but creating new one will stuff it in VS. Very troublesome since I'm trying to make a plugin installer. Might I actually need to write a C Extension? ...might do, might make one that actually writes unicode files as well.
PluginStore Author
PluginStore Author
Postby kierovnick » Thu Jul 05, 2012 12:28 pm
Oh my God! I mean.. oh my Fredo6!
How could i miss this one?
I was waiting for it so long and somehow it slipped past my nose until today.
There's not many plugins that are MUST HAVE for me, but most of them are of your autorship.
My plugin library will look like My plugin library +1 from now on :)
I am sure i will donate, so you could buy some coffe to work on Your next plugins :)
Thank You.
kierovnick
Postby Dave R » Sun Sep 02, 2012 10:07 pm
Greetings Fredo,
I just had an e-mail from a Mac user saying that despite downloading the new maintenance release of SketchUp, he's still getting black text boxes with this plugin. Thoughts or ideas?
Thanks.
Global Moderator
Postby mwm5053 » Sun Sep 02, 2012 10:58 pm
I'm using OSX 10.7.4 latest Lion release, SU 8 latest release and LIbFredo6 4.6 just so you could see I also just found this very useful Thanks
2011 iMac
SU 2015 Pro, 2017 Make
V2 Twilight
macOS Sierra 10.12.5
mwm5053
Premium Member
Premium Member
PreviousNext
Return to Plugins
cron
Users browsing this forum: mkurmanalinova and 9 guests
