[Plugin] SUClock - v3.0a - 19 May 20 - Tracking time in SU
Re: [Plugin] SUClock - v2.0a - 31 Oct 18 - Tracking time in
Postby fredo6 » Thu Jan 03, 2019 11:01 am
simMonster wrote:Is it possible to modify your code to allow your plugin to determine the time spent on an older sketchup file? I am very anxious to hear from you.
What do you mean by 'older'?
fredo6
PluginStore Author
PluginStore Author
Postby db11 » Mon Jan 14, 2019 6:17 pm
Hi Fredo —
I'm having a problem with the plugin under SU Pro 2015: It works fine in 2018, but now doesn't work properly in 2015.
Specifically, I can't pull up the configuration window, either from the menu or by clicking the toolbar button.
Everything worked fine in 2015 up until either my installation of 2018, or the last SUClock update (both were around the same time).
Any thoughts on what's going on and how to fix it? Love the plugin and depend on it for my project time-tracking.
Thanks.
db11
Postby fredo6 » Mon Jan 14, 2019 10:10 pm
Difficult for me to tell, as I don't have a Mac.
At least I could test that it works fine on Windows and SU2015.
Can you open the Ruby console before you launch SUClock and check if there are error messages.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby db11 » Tue Jan 15, 2019 11:01 pm
I did as you asked, and no error message on the Ruby console. The window flashes open when I hit the toolbar button, but disappears immediately after. (it's visible for a fraction of a second)
db11
Postby fredo6 » Tue Jan 15, 2019 11:10 pm
db11 wrote:I did as you asked, and no error message on the Ruby console. The window flashes open when I hit the toolbar button, but disappears immediately after. (it's visible for a fraction of a second)
Could you make sure you use the latest version of LibFredo6 (v8.7f), as I fixed some bugs related to dialog boxes on Mac.
fredo6
PluginStore Author
PluginStore Author
Postby db11 » Wed Jan 16, 2019 6:37 pm
fredo6 wrote:Could you make sure you use the latest version of LibFredo6 (v8.7f), as I fixed some bugs related to dialog boxes on Mac.
Just updated and it seems to have done the trick. Thanks!
db11
Postby fredo6 » Wed Jan 16, 2019 7:29 pm
db11 wrote:Just updated and it seems to have done the trick. Thanks!
The problem was there for other dialog boxes on Mac. As a general advice, it is always good to update to latest versions of LibFredo6, because this library holds a lot of common code used across all my plugins.
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] SUClock - v3.0a - 19 May 20 - Tracking time in
Postby fredo6 » Tue May 19, 2020 4:21 pm
NEW RELEASE: SUClock - v3.0a - 19 May 20
SUClock 3.0a fixes a major bug for display of the clock window.
Note also that, from v3.0a onward, SUClock is only supported for SU2017 and above.
See SUClock plugin home page for Download.
See also main post of this thread for User Discussion.
fredo6
PluginStore Author
PluginStore Author
Previous
Return to Plugins
cron
Users browsing this forum: mkurmanalinova and 9 guests
