by kate-art » Mon Oct 25, 2010 2:52 pm
As i'm relatively new to SketchUp i'm keen to find out which plugins you guys use to get the most out of SketchUp. There are no shortage to choose from but if you could only insall 3 what would they be and why?
my top 3 are: Fur Round corners Shaderlight (of course!)
kate-art
- Shaderlight
- Name: kate-art
by solo » Mon Oct 25, 2010 3:00 pm
SDS (Subdivide and smooth) Cleanup round corner
(used most often)
solo
- Global Moderator
- Name: solo
- Operating system: Windows
- SketchUp version: 2017
- License type: Pro
- SketchUp use: other
by Rich O Brien » Mon Oct 25, 2010 3:04 pm
Fredoscale
Bezier Tools
Thea Exporter
Rich O Brien
- Administrator
- Name: Rich O'Brien
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Advanced
by thomthom » Mon Oct 25, 2010 3:05 pm
- Selection Toys
- Tools On Surface
- Plan Tools
- PluginStore Author
- Name: Thomas Thomassen
- SketchUp version: 2019
- License type: Pro
by boofredlay » Mon Oct 25, 2010 3:12 pm
Weld Round Corners Joint Push Pull
(Subdivide and Smooth) Honorable mention.
boofredlay
- Global Moderator
- Name: Eric Lay
- SketchUp version: 2018
- License type: Pro
- SketchUp use: architecture
by ely862me » Mon Oct 25, 2010 3:14 pm
SDS JPP TOS
Elisei (sketchupper) ____________________________________________________________ Before no life was done on Earth it was THE LIFE ITSELF... GOD Come and See EliseiDesign
ely862me
- Top SketchUcator
- Name: Elisei
- SketchUp version: 2016
- License type: Pro
by charly2008 » Mon Oct 25, 2010 3:21 pm
- Curviloft - Extrusion Tools - Kerkythea Exporter
charly2008
- Name: KHA
- SketchUp version: 8
- License type: Pro
- SketchUp use: hobby
by Daniel S » Mon Oct 25, 2010 3:30 pm
* Round Corners * Curviloft * SketchyPhysics
Daniel S
- SketchUp version: 2015
- License type: Pro
- SketchUp use: product design
by JuanV.Soler » Mon Oct 25, 2010 3:35 pm
2D Tools Work Plane Colour Edge ________________ field of use : architecture
_,_)))_,_
JuanV.Soler
- Name: Juan Víctor
- SketchUp version: 2013
- License type: Pro
- SketchUp use: landscape architecture
by Burkhard » Mon Oct 25, 2010 3:47 pm
Round Corners CleanUp Delete Cons ( Seems I worked to much with Lines and points )
Burkhard
- Premium Member
- Name: Burkhard
- License type: Pro
- SketchUp use: interior design
by rv1974 » Mon Oct 25, 2010 3:53 pm
1.extrude line 2.extrude along path 3.mirror
rv1974
- Name: rv1974
- License type: Pro
by thomthom » Mon Oct 25, 2010 4:03 pm
Burkhard wrote:Delete Cons ( Seems I worked to much with Lines and points )
It deletes construction lines and points? That's a native function...
- License type: Pro
by Chris Fullmer » Mon Oct 25, 2010 4:04 pm
ely862me wrote:SDS JPP TOS
To translate that - SubDivide and Smooth, Joint PushPull, and Tools On Surface. Mine are: Weld Make Faces Repeat Copy
- SketchUp Team
- Name: Chris Fullmer
- License type: Pro
by TIG » Mon Oct 25, 2010 4:06 pm
thomthom wrote:Burkhard wrote:Delete Cons ( Seems I worked to much with Lines and points )
But the built-in one is brutal and removes all - some such as this erase all cpoints/clines in the current context only ?
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
by TIG » Mon Oct 25, 2010 4:08 pm
My three most commonly used tools:
Weld Make Face Mirror ...
- Global Moderator
- Name: TIG
- License type: Pro
by mitcorb » Mon Oct 25, 2010 4:09 pm
Fredo PushPull--Joint,Vector,Normal Mirror Selection FredoScale,Taper,Bend
mitcorb
- Top SketchUcator
- Name: mitcorb
- License type: Pro
by Krisidious » Mon Oct 25, 2010 4:32 pm
Weld Curviloft Thom's Curve Select
Krisidious
- Name: Krisidious
- License type: Pro
by tfdesign » Mon Oct 25, 2010 5:04 pm
This is a good thread, as I was also about to ask the same question- but for ten plugins(!).
Three is a good number, but what still confuses me, and probably others too, who are new to SketchUp is why.
Why do you use these plugins, and what advantages to they give you over the current set of tools, and what is your main objective, taking into account, your chosen subject? For eg, are you an architect? A product designer or just a general modeller? Why are these three so important?
I've started to experiment with Fredo6's Bezierspline plugin, mainly because it is impossible to draw bezier curves by any other way in SketchUp, and bezier curves come in hand for many things, both architectural and product-wise.
I'll probably also add Fredo6's Curviloft plugin too, because the creation of organic surfaces that morph from one shape to another can also have its use, especially when modelling Victorian rendering- such as plaster.
One more only would be very hard to suggest, as many are so brilliant and useful!
Tom
My book " Let's SketchUp!" Download from here
tfdesign
- Top SketchUcator
- Name: Tom
by Dave R » Mon Oct 25, 2010 5:13 pm
Weld CutList BZ Spline
- Global Moderator
- Name: Dave R
- License type: Pro
- SketchUp use: woodworking
by tfdesign » Mon Oct 25, 2010 5:19 pm
Why?
tfdesign
- Top SketchUcator
- Name: Tom
by Dave R » Mon Oct 25, 2010 5:31 pm
Weld: To weld line segments so they behave as single entities for selection purposes and to reduce the need to soften/smooth edges. CutList: Nearly every project I draw these days is a plan for a piece of furniture or cabinets and my clients require cut lists so they can quote for materials. I could do it manually but Cut List takes only a couple of seconds. BZ Spline: For drawing non-circular curves.
- Global Moderator
- Name: Dave R
- License type: Pro
by tfdesign » Mon Oct 25, 2010 5:42 pm
Cheers Dave
tfdesign
- Top SketchUcator
- Name: Tom
by Pixero » Mon Oct 25, 2010 5:49 pm
I dont know if my most used plugins are my favorites but anyway: Put on layer (I use it ALL the time to keep my file organised.) Weld (I've edited it so I have it under the right click menu) Joint pushpull (Could also be Extrude edge by vector)
Pixero
- Name: Pixero
- License type: Pro
by gullfo » Mon Oct 25, 2010 6:21 pm
my top 3: House Builder (imperial and metric) Extrusion Tools Weld
gullfo
- Name: Glenn Stanton
- License type: Pro
by pilou » Mon Oct 25, 2010 6:33 pm
The 3 more fun  (for me Grow by Tig perfect for iteration volumes with multiple size, Move, rotate Protrude by Jim Foltz funny automatic exotic generations Random Painter by Chris Fullmer for some joyous variations of colors 3 in the same time  exo.jpg
- Top SketchUcator
- Name: Pilou
- License type: Free/Make
by tfdesign » Mon Oct 25, 2010 7:24 pm
Wow Pilou! That's beautiful!
tfdesign
- Top SketchUcator
- Name: Tom
by EscapeArtist » Mon Oct 25, 2010 7:57 pm
Based on use:
Weld Remove unused edges BZ spline (all)
Based on coolest/usefulness (IMO)
SD&S Curviloft JPP
All of the above make SU easier and better to use.
EscapeArtist
- Top SketchUcator
- Name: EscapeArtist
- License type: Pro
by blajnov » Mon Oct 25, 2010 8:03 pm
blajnov
- Name: yura
by mitcorb » Mon Oct 25, 2010 8:53 pm
I already gave you three--for this week. I also like to see how well I can do some operations from scratch. However, I don't think Weld has a native substitute.
mitcorb
- Top SketchUcator
- Name: mitcorb
- License type: Pro
by kate-art » Tue Oct 26, 2010 10:24 am
Great feedback guys - thanks. I find it interesting how everyone likes something different. This short thread has generated a list of 30+ plugins!
kate-art
- Shaderlight
- Name: kate-art
- Robot
Return to Plugins
