[Plugin] Radial Lines
Postby TIG » Thu Sep 23, 2010 12:49 pm
(c) TIG 2010
Permission to use, copy, modify, and distribute this software for
any purpose and without fee is hereby granted, provided that the above
copyright notice appear in all copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
___________________________________________________________________________
radiallines.rb >>> ../Plugins/ folder
Usage:
Select one guide-point [cpoint] and some edges and/or faces
then run Plugins menu 'Radial Lines...' sub-menu items...
    Lines- draws a line from the cpoint to each vertex.
    Lines [layered]- draws a line from the cpoint to each vertex, on Layer.
    Guides- draws a guide-line from the cpoint to each vertex.
    Guides with Lengths - draws a guide-line from the cpoint to each vertex,
      and adds central text to it showing its length,
      in current units.
Donations:
by PayPal to info @ revitrev.org
Version:
1.0 20100923 First release.
1.1 20100923 Line [layered] option added.
radiallines.rb
User avatar
Global Moderator
Re: [Plugin] Radial Lines
Postby pilou » Thu Sep 23, 2010 1:09 pm
Like this works like a charm ;) :thumb:
What about for have lines with a same lenght given on each lines? (say 2.23 m )
Speedy Galerie
User avatar
Top SketchUcator
Postby TIG » Thu Sep 23, 2010 1:14 pm
Pilou wrote:Like this works like a charm ;) :thumb:
Explain better... please
Mieux expliquer...SVP
User avatar
Global Moderator
Postby pilou » Thu Sep 23, 2010 1:23 pm
I wish the red lines ;)
They will have all the same length!(2.23 m)
Speedy Galerie
User avatar
Top SketchUcator
Postby davidlouis » Thu Sep 23, 2010 1:24 pm
Working great but i see that is no layer functionality on the line only option :(
Please can you put it in so that one could have control over the generated entities for easy selection, visibility switches and deletion etc etc...
Otherwise great work.... as always :thumb:
Dave
davidlouis
Postby TIG » Thu Sep 23, 2010 1:33 pm
Here's v1.1 viewtopic.php?p=273614#p273614
It now has an additional option 'Lines [layered]' - with this the Lines are put on their own layer rather than Layer0...
User avatar
Global Moderator
Postby TIG » Thu Sep 23, 2010 1:35 pm
Pilou wrote:I wish the red lines ;)
I think I see...
So if you used the 'Line' option the line would stop at a set length...
I'll think about it... :geek:
User avatar
Global Moderator
Postby pilou » Thu Sep 23, 2010 1:40 pm
Many thx by advance :enlight: :thumb:
Ps It's not possible to select also extremity points (like faces and segments)
Speedy Galerie
User avatar
Top SketchUcator
Postby TIG » Thu Sep 23, 2010 1:50 pm
It will draw lines to both ends of any selected edges - you'll need to erase the unwanted lines...
User avatar
Global Moderator
Postby TIG » Thu Sep 23, 2010 1:55 pm
There's now a separate script for drawing fixed length radial lines viewtopic.php?p=273654#p273654
User avatar
Global Moderator
Postby pilou » Thu Sep 23, 2010 2:23 pm
Damned you have a speedy coding method ! :fro:
(I will use :eraser: for the extremities not wanted if not too numerous :mrgreen:
Speedy Galerie
User avatar
Top SketchUcator
Postby mitcorb » Thu Sep 23, 2010 5:39 pm
How do you place the cpoint or guide point?
Error message keeps asking for this.
I thought by using measuring tape you could get a guide point.
Something I am not doing? Can't get this script to acknowledge the guide point, because it then wants a vertex?
User avatar
mitcorb
Top SketchUcator
Postby pilou » Thu Sep 23, 2010 5:43 pm
Use the tools bar Projection by Didier Bur
There is a CPoint inside and some very useful tools!
Speedy Galerie
User avatar
Top SketchUcator
Postby Dave R » Thu Sep 23, 2010 5:45 pm
mitcorb, the Tape Measure tool is the way to set a guidepoint or at least one way. After setting the guidepoint, select it and edges with vertices or ends and run the tool.
TIG, thank you for this. I'm not sure where I'll use it but I wouldn't be surprised if it comes in handy one day.
User avatar
Global Moderator
Postby pilou » Thu Sep 23, 2010 5:47 pm
then a vertex
How dow you select one vertex from a single segment in the space? (extremity)
Speedy Galerie
User avatar
Top SketchUcator
Postby mitcorb » Thu Sep 23, 2010 5:52 pm
Thanks, Dave.
But I do not understand the conditions for guidepoint only. I usually get guidelines.
Thanks Pilou, I forgot about Didier's Projections. I have it on my home computer, but not here.
User avatar
mitcorb
Top SketchUcator
Postby Dave R » Thu Sep 23, 2010 6:00 pm
A guide point is created when you measure off a point, vertex, intersection, etc. A guideline is created when you click on a line, edge or axis first.
There are also some plugins like Point at Center and the Point cloud plugin that create guidepoints.
User avatar
Global Moderator
Postby jeff hammond » Thu Sep 23, 2010 6:04 pm
re: construction point
pay four bucks for the privilege of placing one
http://www.smustard.com/script/AddConstructionPoint
:roflmao:
personally, i use projections and keep only the CPoint icon in my toolbar (next to draw construction lines which is another way to get a cpoint)
with :tape:, start the measurement on an entity then click in blank space and you'll get a cpoint as well.
[edit]- another way to get one without adding any rubies is to turn on 'ruby script examples' in the extensions preferences.. draw an arc the right-click on it and you'll have the option "Point at Center" in the context menu.. that will give a cpoint that can be moved around.
User avatar
Global Moderator
Postby Ben Ritter » Thu Sep 23, 2010 6:06 pm
Dave R wrote:I'm not sure where I'll use it but I wouldn't be surprised if it comes in handy one day.
Dave, you hit the nail on the head. Remembering that when the time comes, you have such a helpful tool available.
How do you all keep track of all the tools available in your SU arsenal, if they're not used on a regular basis?
Ben
Ben Ritter
Postby Ben Ritter » Thu Sep 23, 2010 6:07 pm
TIG, thank you very much. Again.
Ben Ritter
Postby Dave R » Thu Sep 23, 2010 6:09 pm
Ben Ritter wrote:How do you all keep track of all the tools available in your SU arsenal, if they're not used on a regular basis?
Ben
I gave up a long time ago, Ben. Periodically I look through my Plugins folder to see what treasures I've forgotten about. :roll: :lol:
User avatar
Global Moderator
Postby pilou » Thu Sep 23, 2010 6:09 pm
You have no keep The icone Extrude lines along a vector? :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby Krisidious » Thu Sep 23, 2010 6:11 pm
do you ever sleep?
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby jeff hammond » Thu Sep 23, 2010 6:12 pm
You have no keep Extrude lines along a vector?
i use TIG's version in the extrude edges suite.. i keep that entire toolbar turned on.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
cron
Who is online
Users browsing this forum: fredo6, marcelpikak, matheusmartinsmm, max100n, mukeshbhadrecha, renjiano, steva and 23 guests
Visit our sponsors:
