[Plugin] Groups to Components
Re: [Plugin] Groups to Components
Postby irwanwr » Fri Jul 25, 2014 6:03 pm
I thought there's already Group to Components function in Selection Toys, isn't it?
irwanwr
Postby thomthom » Fri Jul 25, 2014 6:06 pm
irwanwr wrote:I thought there's already Group to Components function in Selection Toys, isn't it?
It's somewhat different. Selection Toys got a function to convert group copies to component instance while ensuring each instance isn't made unique.
This small extension had a special purpose for preserving naming in a special way by request of some user.
PluginStore Author
PluginStore Author
Postby bsfranza » Mon Sep 29, 2014 9:50 am
hi there,
could it be that its not yet updated for su 2014???
its not showing in any menue :(
bsfranza
Postby Dave R » Mon Sep 29, 2014 10:54 am
bsfranza wrote:hi there,
No. It works fine n SketchUp 2014. How did you install it? If installed correctly, it will appear in the Plugins menu.
Global Moderator
Postby koliboti » Mon Feb 02, 2015 9:05 pm
Hi, do you guys have plugin that makes components to groups, that work wit SU2015?
koliboti
Postby TIG » Mon Feb 02, 2015 11:04 pm
koliboti wrote:Hi, do you guys have plugin that makes components to groups, that work wit SU2015?
I assume you mean to make component-instances into groups ?
This one liner processed a selection. Making any component-instances into groups, using the same name/layer/material/attributes as the original...
Code: Select all
m=Sketchup.active_model;a=m.active_entities;s=m.selection;m.start_operation('!');s.grep(Sketchup::ComponentInstance).each{|i|g=a.add_group();e=g.entities;n=e.add_instance(i.definition, i.transformation);n.explode;g.name=i.definition.name;g.layer=i.layer;g.material=i.material;i.attribute_dictionaries.each{|d|d.each_pair{|k,v|g.add_attribute(d.name,k,v)}}if i.attribute_dictionaries;i.erase!;};m.commit_operation
Global Moderator
Postby koliboti » Tue Feb 24, 2015 9:50 pm
Code: Select all
Thank you very-very much TIG! it works perfect also with imported 3ds objects. :bounce:
koliboti
Postby camilo_caicedo » Wed Mar 11, 2015 12:39 am
Hi thomthom.
Your conversion tool changes all groups in the selection to components, one component for each group where the group's name is transferred to the component's definition's name.
Please, do you know about some plugin which changes all groups in the selection to a single component (the groups should be a copy of a single group), so you obtain one component for each group, where the component definition name of each component is the same?
People often forget to make a component instead of a group, so if you repeat a group, and then you rotate or move that group to diferent places many times, it would be hard to make a component and then repeat it, rotate or move it many times again. A tool to convert those groups to one component would allow you to go on with your job.
Thank's
camilo_caicedo
Postby thomthom » Wed Mar 11, 2015 6:23 pm
If the group haven't been modified (or even opened) then Selection Toys can convert such groups to components. But if the user has performed any kind of action that makes SU kick in the make-unique then it won't be able to detect that.
You can force replace with Component Replacer, but you need to pick out which ones to replace with what.
PluginStore Author
PluginStore Author
Postby rv1974 » Fri Jan 27, 2017 7:02 am
Thomthom, may I request this tool to keep the object(s) selected after conversion?
rv1974
Postby YCL furniture » Wed Aug 21, 2019 2:59 pm
Hello, Thom
maybe have any plugin to convert components to groups? without losing the component name
YCL furniture
Postby Dave R » Wed Aug 21, 2019 3:23 pm
YCL furniture wrote:Hello, Thom
Why convert components to groups?
Global Moderator
Postby YCL furniture » Wed Aug 21, 2019 7:05 pm
Because I design furniture with components. After designing the furniture, I use the ABF solutions plugin to make report list of furniture panels cutting and edges bandings. This plugin only works with groups.
Maybe you know of another plugin that make report list of furniture panels and edges banding?
I made a video where I showed what features I need (https://www.youtube.com/watch?v=85djT5KbnZw)
YCL furniture
Postby Dave R » Wed Aug 21, 2019 7:09 pm
You are using SketchUp 2016 Make for your business?
There are numerous cutlist extensions that work with components.
Global Moderator
Postby YCL furniture » Thu Aug 22, 2019 7:21 pm
Dave R wrote:You are using SketchUp 2016 Make for your business?
There are many extensions that calculate report list of furniture panels cuttings. But none of them count the edges banding
YCL furniture
Postby fortyonethirty » Tue May 12, 2020 6:25 pm
Thanks! :thumb:
fortyonethirty
Previous
Return to Plugins
Users browsing this forum: phcbritto, x095760 and 10 guests
