[Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
Re: [Plugin] CurviShear (to make ramps) - 25 Jun 10
Postby thomthom » Wed Sep 22, 2010 8:39 am
Pilou wrote:If some modifications are made for the V8, what are the results for the previous versions?
Should be none - Ruby 1.8.6 has stricter parsing which has been the biggest cause of the incompatibility.
PluginStore Author
PluginStore Author
Postby fredo6 » Wed Sep 22, 2010 1:18 pm
grim wrote:fredo
i realise this was just a quickie ruby but it is a good one that i use
however i am haveing trouble in SU8 is there a problem and does it need updating
regards
grim
CurviShear should work in SU8.
Do you experience problems?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby monkeybss » Wed Sep 22, 2010 5:47 pm
Thanks, I very much needed this, life is going to be easier now...
monkeybss
Postby grim » Wed Sep 22, 2010 11:54 pm
fredo
yes i seem to have a problem see image attached , with a single arc it works fine, with a double arc and weld plugin used i get a mess
regerds grim
grim
Premium Member
Premium Member
Postby fredo6 » Thu Sep 23, 2010 7:47 am
grim wrote:fredo
regerds grim
Could you post the skp file so that I have a look
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Tue Oct 26, 2010 11:50 am
Hi fredo!
Please take a look at this:
http://www.scriptspot.com/3ds-max/scripts/ant-stitcher-fast-and-easy-way-to-connect-two-meshes-in-3ds-max
If only you could add a similar feature it'd become a mega hit!
rv1974
Postby arjunmax09 » Mon Dec 27, 2010 4:50 pm
I'm trying to make a ramp using curvishear and curviloft but not getting the desired result. I've attached a video of what exactly happens during the process
when you fail at something....you haven't really failed...you've found one way the thing will not work out
arjunmax09
Banned
Postby jeff hammond » Mon Dec 27, 2010 5:33 pm
arjun,
try using the 3rd icon in curviloft.. skinning of shapes
dotdotdot
jeff hammond
Global Moderator
Postby arjunmax09 » Mon Dec 27, 2010 5:56 pm
Jeff Hammond wrote:arjun,
i tried using that but nothing happens..can you post a video or some screenshots?? I've uploaded the model btw..
arjunmax09
Banned
Postby Daniel S » Mon Dec 27, 2010 6:53 pm
Works for me...
Like Jeff said.. try using the 3rd icon... not the first one:
Here I attach the result:
rr5 low.skp
Daniel S
Daniel S
Postby arjunmax09 » Tue Dec 28, 2010 5:33 am
Daniel S wrote:Works for me...
Daniel S
Daniel...i used the same button for making the ramp...i select all the edges but nothing happens..Please upload screenshots or a video of how you actually make the ramp...I'm using SU 8 Pro..??
arjunmax09
Banned
Postby Daniel S » Tue Dec 28, 2010 1:07 pm
Just select the ramp and click the button. A small video showing how the skinning of the ramp is made:
I´m using SU8 Pro too.
Do you have the latests versions of Curviloft and LibFredo6?
For checking the latest version of curviloft go to "Tools>Fredo6 Collection>Curviloft>About..." should say Curviloft v1.0c.
For checking the latest version of LibFredo6 go to "Window>LibFredo6 Settings>About..." should say LibFredo6 v3.5c.
If you don´t have that versions you can download them from here: viewtopic.php?f=323&t=28586
If you have the correct ones, try to make the ramp with the ruby console open (go to Window>Ruby Console). Perhaps the ruby console shows an error that you can copy and paste here.
Daniel S
Daniel S
Postby arjunmax09 » Tue Dec 28, 2010 3:19 pm
I had the recent versions. I just checked the way you told. But I overwrote the files with freshly downloaded ones anyway. Eventually I was able to make the ramp that you made. That file had another ramp too. I can't make that one.. I've made a new file of that ramp and a video of what exactly happens. Please check and tell me what to do.
arjunmax09
Banned
Postby Daniel S » Tue Dec 28, 2010 4:30 pm
arjunmax09 wrote:I had the recent versions. I just checked the way you told. But I overwrote the files with freshly downloaded ones anyway. Eventually I was able to make the ramp that you made. That file had another ramp too. I can't make that one.. I've made a new file of that ramp and a video of what exactly happens. Please check and tell me what to do.
Here you have to use another plugin called weld.rb (you can download it at http://www.smustard.com/script/Weld)
I attach a video showing how to make it work and .skp files.
Daniel S
Daniel S
Postby arjunmax09 » Wed Dec 29, 2010 12:56 pm
Thanks Daniel...I'm finally able to make the ramp :) .. But for selecting the linear edges along one axis for welding is there a faster way rather than selecting them one by one??
arjunmax09
Banned
Postby Daniel S » Wed Dec 29, 2010 5:36 pm
You can try with Fredo6´s Hoverselect plugin (viewtopic.php?f=323&t=18916). But it´s not working for me. Perhaps is a SketchUp 8 issue.
Daniel S
Daniel S
Postby kathecasta » Tue Feb 15, 2011 8:33 pm
i'm following these same instructions, and it works at creating the ramp for me, so long as i don't click "reverse curve orientation" but i need it to be reversed!
When I try to skin it using the "reverse orientation" it doesn't create the top plane for the ramp, just the sides for some reason....
anyone have any idea why this is happening?
thanks!!
Daniel S wrote:Just select the ramp and click the button. A small video showing how the skinning of the ramp is made:
Daniel S
kathecasta
Postby ghassan » Tue Jun 21, 2011 3:17 pm
wow
ghassan
Postby Tobobo » Tue Jun 21, 2011 5:40 pm
I cant believe i havent found this till now. This would have saved hours of time. :berserk:
Thank you :berserk: :berserk:
Toby
Philippians 4:13
Tobobo
Postby deprezzar » Fri Oct 28, 2011 6:50 pm
tanks Fredo!!!brilliant!!!
deprezzar
Re: [Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
Postby ddtaylor » Sun Sep 23, 2012 7:18 am
thanks for sharing :sketchstatic:
ddtaylor
Postby keea1111 » Mon Sep 24, 2012 4:21 pm
Can someone help me install this plug in? I am on Mac and I put the whole FredoTools folder in my plugins folder, but it is not active or even visible in SU? Much thanks, Keea
KEEA
keea1111
Postby mwm5053 » Mon Feb 11, 2013 12:57 pm
Great plugin but I'm doing something wrong here I'm sure. Coming up with the same results as grim earlier in this thread. Thanks for the help
2011 iMac
SU 2015 Pro, 2017 Make
V2 Twilight
macOS Sierra 10.12.5
mwm5053
Premium Member
Premium Member
Postby thanesuan » Tue Jun 25, 2013 4:44 am
thx a lot :ecstatic:
thanesuan
Postby Bertil » Sun Aug 25, 2013 7:48 pm
cant get it to work on Mac
Bertil
Postby cotty » Mon Aug 26, 2013 6:30 am
Bertil wrote:cant get it to work on Mac
We will need some more information to help you ...
cotty
Top SketchUcator
Postby wishiyyl » Wed Nov 13, 2013 10:35 pm
Looks awesome Fredo! Congrats yet again,
wishiyyl
Postby urjuan » Wed Feb 12, 2014 11:10 am
Hi Everyone,
Could someone help me..is this plugin only works for curves? how bout straight ramps with curve edges only?
Thanks.
urjuan
Postby fredo6 » Wed Feb 12, 2014 6:20 pm
urjuan wrote:Could someone help me..is this plugin only works for curves? how bout straight ramps with curve edges only?
Thanks.
Curvishear only requires that the contour is given as Sketchup 'curves' (as shown in the Entity Info panel).
Please post a picture or the skp file for what you have in mind.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby mohsen » Thu Dec 25, 2014 4:39 pm
How can I create this model? What is the plug?
mohsen
PreviousNext
Return to Plugins
Users browsing this forum: kunalmokasdar and 12 guests
