[Plugin] ChrisP_ColorEdge
Re: [Plugin] ChrisP_ColorEdge
Postby boofredlay » Fri Jun 02, 2017 2:29 pm
I understand this is an old plugin. Maybe someone has a quick fix but if not no problem.
I am experiencing the lines being drawn outside the group or component being edited. See attached.
User avatar
boofredlay
Global Moderator
Postby Frederik » Fri Jun 02, 2017 6:40 pm
What happens if you mark them
Cut them to the clipboard
Open the model group and paste them back where you want them...?
Cheers
Kim Frederik
User avatar
Frederik
Thea Render Support
Thea Render Support
Postby boofredlay » Fri Jun 02, 2017 10:20 pm
That works just fine, which is what I did most of the day (large building with joint lines). But it is an extra step not needed if they were drawn inside the group/component.
Edit: If I had started it the other way (draw default lines in a separate group and just painted the group) I might have saved some time today. However, once down a path...
User avatar
boofredlay
Global Moderator
Postby Skatepark » Sun Apr 22, 2018 10:13 am
Hey Chris, I am having trouble modifying colours on mac. I am clicking TAB but the color menu doesn't open so it's on default all the time... Any suggestions?
Cheers
Skatepark
Postby hygicell » Mon Apr 23, 2018 9:19 am
how do I install the other icons ?
hygicell
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: ltowl and 16 guests
Visit our sponsors:
