[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)
Re: [Plugin Beta] Curviloft 1.0b - 11 Jul 10 (Loft & Skinnin
Postby mariocha » Thu Aug 05, 2010 11:43 pm
Thanks TIG,
So I tried it on the PC side of my MAC, and it worked just fine.
frustrated me :cry:
Strange, cause other curves were ok.
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby fredo6 » Sat Aug 07, 2010 12:19 pm
mariocha wrote:Testing the beta, the skin command cannot complete this file, attached.
EEbyrails does it well tought.
Mariocha,
I think I know what it is and why it is specific to Mac. I'll publish a fix soon with a new release.
By the way, you can adjust the density of meshing by using the Interpol and OverSampling boxes. If you deactivate both, then you get a mesh strictly built on the original contour vertices.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby mariocha » Sat Aug 07, 2010 4:29 pm
A new relase ? Great !! :thumb: :thumb: :thumb:
And Oversampling & Interpol will be so usefull for designing !
C'est vraiment super !
as I'm working on a tensile structure these days.
Mario C.
mariocha
Premium Member
Premium Member
Help with Skinning
Postby cmeed » Wed Aug 18, 2010 9:32 am
help.
I see skinning videos posted within this thread but i can't get this shape to work. it seems so simple.....
I click contours, click space, i then repeat until all three lines are coloured and click the tick button or open space. i get a PLEASE WAIT then nothing happens.
Am I doing something wrong, is it Because i'm on a mac?
the last picture is tig's rails but i have to make a 4th rail for it to work.
cmeed
Premium Member
Premium Member
Postby TIG » Wed Aug 18, 2010 11:23 am
Should work with the 3 curves in either Fredo's or mine. With EEbyRails Pick the curve as the profile then the 2 side rails and then re-pick the profile again as the melding-profile - it will end with a point and triangular faces opposite the profile's end, as desired...
Global Moderator
Postby cmeed » Wed Aug 18, 2010 11:45 am
Thank you for your speedy reply. Tig your plugin is working great (i didn't know about going back to my first curve to make three curves work, cheers)
what i'm making is a field of 800 tents - the ones you can put up in 3 seconds. So i need a way of using the contours and keeping the the polys down.
see pic tent - I used the loft by spline to get this but its not that great, Skinning didn't work.
i wanted to used fredos to get the polys down.
cmeed
Premium Member
Premium Member
Postby TIG » Wed Aug 18, 2010 11:49 am
Reduce the number of segments in the arcs for the profiles/rails for EEbyRails with Entity Info [before scaling or making a 'non-arc'] ?
Global Moderator
Postby cmeed » Wed Aug 18, 2010 11:58 am
Thank you Tig. damn ! i knew that.... mmmm
cmeed
Premium Member
Premium Member
Re: Help with Skinning
Postby fredo6 » Wed Aug 18, 2010 5:31 pm
cmeed wrote:help.
COuld you please post your model so that I can have a look and see what is going wrong.
fredo
fredo6
PluginStore Author
PluginStore Author
Postby cmeed » Wed Aug 18, 2010 5:41 pm
Here you go...Thanks for looking...
I am almost sure it will work for you. Its so simple a shape.
cmeed
Premium Member
Premium Member
Postby fredo6 » Wed Aug 18, 2010 10:32 pm
cmeed wrote:Here you go...Thanks for looking...
This bug, specific to Mac, has been corrected, but I did not publish the fix yet (due to work on the Loft Along Path). I'll do soon.
It was already mentioned by Mariocha (see http://forums.sketchucation.com/viewtopic.php?f=323&t=28586&start=210#p262564)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Wed Aug 18, 2010 11:14 pm
By the way, I forgot to mention that, when Skinning shapes, you can swap rails and profiles, which may be useful when the surface to generate is made from 3 contours.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby utiler » Thu Aug 19, 2010 12:00 am
Fredo, this tool is quite incredible! I just haven't had time to play with it yet but have been following with much interest!! You really have 'user operation' high on your list.
Incredibly well done!!
utiler
Top SketchUcator
Re: [Plugin Beta] Curviloft 1.0c - 20 Aug 10 (Loft & Skinnin
Postby fredo6 » Fri Aug 20, 2010 10:51 pm
New Beta version of Curviloft 1.0c and LibFredo6 3.5c - 20 Aug 10
see Main Post for download
This is an interim version whose purpose is to fix some bugs signaled by users and to prepare a next release which will be more functional. Again, thanks to all users for their help and contribution.
1) Skinning: Bug on Mac preventing to Skin even simple shapes. Thanks to Mariocha and to Cmeed for signaling
2) Skinning: Pre-selection mode should work with more shapes. Thanks to Daniel S. for providing some good examples.
3) Loft Along Path: Still not finished. At least I have tried to improve the single-contour mode (kind of Follow Me, but accepting contours even non perpendicualr to the rail).
By the way, I noticed some differences with the native SU FollowMe tool.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Rich O Brien » Fri Aug 20, 2010 11:42 pm
Thank You Fredo, great update :thumb:
Rich O Brien
Administrator
Postby EarthMover » Sat Aug 21, 2010 2:21 am
Awesome. Thanks Fredo!
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby Daniel S » Sat Aug 21, 2010 2:29 am
This new beta is amazing!!! :sketchstatic: :sketchstatic: :sketchstatic:
The skin works with all the shapes that I tried... only one not work... Seems that there is a problem when you put arcs with tangent ar vertex..
I have no idea how to explain this.. so I take the definition from the sketchup help:
"Tangent at Vertex: The Tangent at Vertex inference indicates an arc whose vertex is tangent to a previously drawn arc's vertex. The Tangent at Vertex inference is represented by a cyan arc"
Also I include quick shapes that I made to recreate and show this.
Thank you Fredo!!!
Daniel S
EDIT: I delete the attachment because it can cause confusion.
Daniel S
Postby mariocha » Sat Aug 21, 2010 4:08 am
Soon as I heard the good news, I gave a quick try to the new 1.0c
It worked just great on the file causing problems before (on Mac). :berserk: :thumb:
I will give it a more thorough spin tomorow.
and find the donation menu ...
mille merci !!
Mario C.
mariocha
Premium Member
Premium Member
Postby grim » Sat Aug 21, 2010 5:03 am
fredo and Danial s
i have installed the latest uptate and tested it on the tangent at vertex skp and the tent1 skp
in chosing on of the tangent at vertex outlines and the skinning command the programe runs and then flashes between thick line to thin line with the green tick floating after 2 hrs it said it was done in 2 second and showed no meshing i tryed this on all shapes in the file and no luck in getting a skin,
what might the problem be here.
in testing it in the tent1 skp i se no change in the result from the previous version and get a better result in using tigs rail plug in.
not sure if it is just me or has anyone else had a similar result
regards
grim
grim
Premium Member
Premium Member
Postby Daniel S » Sat Aug 21, 2010 3:27 pm
grim wrote:i have installed the latest uptate and tested it on the tangent at vertex skp (...)
Hi grim...
The "tangent at vertex.skp" is a file that I upload to show that is not working for this kind of shapes...
It can cause confusion so I remove it.
In the latest version... Fredo fix some issues and now is working for more shapes...
Try skin with this ones to see if it is working for you.
Daniel S
PS. I think it will be a good idea to add a test .skp file next to the download link of the plugin... so people download and can test the plugin inmediately.
There are a lot of good examples on this posts, but perhaps not everyone wants to read all the pages.
Daniel S
Postby ken » Sat Aug 21, 2010 4:13 pm
Fredo6
Will I have downloaded the latest version of Curviloft and I get a complete shutdown of Sketchup, no error message, just a program shutdown. Note, I am not sure if I had this shut down problem with your earlier versions, as I have been re-installing, with great care all my plugins, trying to limit or remove the graying out problems I had in the past.
So I removed all plugins expect for your new version. Works great. Started reloading plugins in alphabet order. Found that the plugin "Sunposition.rb" was the guilty party, causing some kind of conflict. Not sure what the conflict is, however your program works without this program loading, and with Sunposition.rb loaded, you program shuts down Sketchup. Note, I am not implying your program or the sunpostion plugin are at fault, just that they will not work together.
Just thought I would pass this along. Now does anyone know of a sun positioning program that will not cause problems?
Again thanks for all your plugins.
Ken
ken
Premium Member
Premium Member
Postby fredo6 » Sat Aug 21, 2010 7:39 pm
Ken wrote:Fredo6
Ken
Ken,
Could you give me a link to this SunPosition script so that I have a look at the possible conflicts.
In principle if there is one, it should also exist with the previous version 1.0b
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Rich O Brien » Sat Aug 21, 2010 8:08 pm
Here for the sunposition.rb
Rich O Brien
Administrator
Postby fredo6 » Sun Aug 22, 2010 6:25 am
ABOUT A CONFLICT BETWEEN sunposition.rb and Curviloft
There is a known problem which causes a crash of Sketchup when both Curviloft and sunposition.rb are installed.
I am contacting Gabriel Miller on his site (he is the author of the sunposition script).
In the mean time:
- either take the attached modified version of sunposition
sunposition.rb
- or comment out lines 45 to 50 (by putting a # in front of each line)
Then both Curviloft and sunposition should work fine.
Fredo
PS: sunposition.rb overwrites and extends some Ruby built-in classes (precisely Float#round), which causes the problem. This may affect other scripts than just Curviloft.
fredo6
PluginStore Author
PluginStore Author
[Plugin Beta] Curviloft 1.0c - 20 Aug 10 (Loft & Skinning)
Postby fredo6 » Sun Aug 22, 2010 11:38 pm
Just a precision on some issues mentioned in the previous posts. Curviloft may have problem to identify the right contours in PRE-SELECTION mode.
However, you can always default to the MANUAL selection mode, where you have options to select curves only, or even the contours edge-by-edge.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby jeff hammond » Mon Aug 23, 2010 4:39 am
Fredo6 wrote:Just a precision on some issues mentioned in the previous posts. Curviloft may have problem to identify the right contours in PRE-SELECTION mode.
Fredo
oh nice. thanks for clearing that up.
i keep finding all these little options and i gotta admit, i'm very impressed..
for one, the spline lofting is great.. at first, i was set on skinning and trying to form all of the encompassing curves but in many cases, it seems as if loft will actually make my life way easier.. especially once i started experimenting with the different spline methods.. namely, the two junction by orthogonal curve methods..
i'm sure i'll have some questions soon about what's actually happening with those but for now, i'll continue experimenting with them.
dotdotdot
jeff hammond
Global Moderator
Postby cmeed » Mon Aug 23, 2010 8:49 am
Thanks fredo6 for the latest update. letting you know that the Tent1.skp happily skinned on my mac
cheers
cmeed
Premium Member
Premium Member
Postby fredo6 » Mon Aug 23, 2010 9:10 pm
Jeff Hammond wrote:especially once i started experimenting with the different spline methods.. namely, the two junction by orthogonal curve methods..
Jeff,
Note that these two methods, by arc of ellipse and by arc of Bezier, are correct for straight junctions, but I still need to work out the case where you end up with an S-curve (I only implemented an approximate solution, due to lack of time).
I am interested in your evaluation, because I added the methods just for trial, not being sure this corresponds to real situations.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby jeff hammond » Mon Aug 23, 2010 10:10 pm
Fredo6 wrote:Jeff,
Fredo
here's a simple example.. i've added some notes to the skp showing things that aren't possible with other sketchup lofting/skinning plugins and i've only seen them in rhino.
i'll compile a few other examples a little bit later that show some of the problems and other advantages i've seen..
[edit - the lofted surface in the attached skp was formed using the two curves on the left side with the spline method set to ortho bezier]
dotdotdot
jeff hammond
Global Moderator
Postby fredo6 » Mon Aug 23, 2010 11:07 pm
Jeff,
It seems the S-curves are working fine in your case (contours are in parallel planes).
The two methods are designed to ensure tangential continuity between contours, so that you can chain them in one block. Below is your model, slightly amended, where the whole shape is generated in one pass.
Fredo
fredo6
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: bharathsodad, jjuliano1 , leon06, tejasree, vonne94 and 14 guests
