[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)
Re: [Plugin Beta] Curviloft 1.0b - 11 Jul 10 (Loft & Skinnin
Postby xrok1 » Sun Jul 11, 2010 7:55 pm
:shock: :ecstatic:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby Daniel S » Sun Jul 11, 2010 9:10 pm
Great update Fredo! Very powerful!! :sketchstatic: :sketchstatic:
If you select all and then apply skin there are still issues with this type of geometry:
skin not work right.skp
Daniel S
Daniel S
Postby fredo6 » Sun Jul 11, 2010 9:37 pm
Daniel S wrote:If you select all and then apply skin there are still issues with this type of geometry:
Daniel S
Daniel,
Thanks for this contribution. There are issues, for sure. I will have a close look.
In the meantime, it is recommended to use the method of explicitly putting small segments to indicate where to cut cell contours.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby DIEGO-RODRIGUEZ » Sun Jul 11, 2010 10:46 pm
hi fredo.
ruby console, a new error:
D:/Archivos de programa/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:2166: warning: Object#id will be deprecated; use Object#object_id
Could you fix it.
I´m use:
windows xpSp3 Spanish
sketchup last version in Spanish
thank you very much
DIEGO-RODRIGUEZ
Banned
Postby fredo6 » Mon Jul 12, 2010 7:21 am
DIEGO-RODRIGUEZ wrote:hi fredo.
Could you fix it.
It is just a warning, but I'll fix it for the next release
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby cam youds » Wed Jul 14, 2010 7:50 am
I must be slow in the head but I keep getting this msg
Cannot load plugin Curviloft because the script cannot create DEFPARAM_Dir folder in:
/Library/Application Support/Google SketchUp 7/SketchUp/Plugins
Please create it manually, respecting the case
What am I doing wrong?????????????????????????????????????????????????
cam youds
Postby fredo6 » Wed Jul 14, 2010 8:20 am
cam youds wrote:I must be slow in the head but I keep getting this msg
It may be that your system folder is protected by some security rules preventing to create folders there by program.
So just create the folder DEFPARAM_Dir manually in the directory: /Library/Application Support/Google SketchUp 7/SketchUp/Plugins and this should work.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby cam youds » Wed Jul 14, 2010 10:44 am
It works....Life changing!...no more rhino or soild works!!!!!!
cam youds
Postby DIEGO-RODRIGUEZ » Thu Jul 15, 2010 4:59 am
frequently, I have a little problem.
does not generate the geometry.
if I open the ruby console and run the plugins. Sketchup is labeled.
and generate this error:
DIEGO-RODRIGUEZ
Banned
Postby fredo6 » Thu Jul 15, 2010 7:20 am
DIEGO-RODRIGUEZ wrote:frequently, I have a little problem.
does not generate the geometry. if I open the ruby console and run the plugins. Sketchup is labeled.
Diego,
The two shapes in your attached file work fine by pre-selecting all contours.
But I did not find the small shapes where you seem to have troubles (the one with color edges on your picture).
For the warning in the Ruby console, do not worry. This is harmless and I have already fixed it for the next release.
fredo
fredo6
PluginStore Author
PluginStore Author
Postby DIEGO-RODRIGUEZ » Sun Jul 18, 2010 6:41 pm
hi fredo.
thanks for your response.
already solved the problem.
Reinstall sketchup, in another partition of my hard disk and found that the problem is a file called MSVCRT-ruby18.dll
upload the file.
file size 853kb not works
file size 792kb works
DIEGO-RODRIGUEZ
Banned
Postby pep75 » Wed Jul 28, 2010 8:48 pm
:berserk: Thanks Fredo! Brilliant update!! Thanks so much!!
grtzzz
Pep
pep75
Postby olishea » Wed Aug 04, 2010 3:27 pm
this really is a different league of plugin!!
something i've been wanting for a LONG time. how come you don't charge? its amazing
oli
olishea
Premium Member
Premium Member
Postby mariocha » Thu Aug 05, 2010 7:17 pm
Testing the beta, the skin command cannot complete this file, attached.
EEbyrails does it well tought.
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby TIG » Thu Aug 05, 2010 9:12 pm
Both work for me... but there are more facets in CurviLoft's result...
Global Moderator
Postby mariocha » Thu Aug 05, 2010 11:43 pm
Thanks TIG,
So I tried it on the PC side of my MAC, and it worked just fine.
frustrated me :cry:
Strange, cause other curves were ok.
Mario C.
mariocha
Premium Member
Premium Member
Postby fredo6 » Sat Aug 07, 2010 12:19 pm
mariocha wrote:Testing the beta, the skin command cannot complete this file, attached.
Mariocha,
I think I know what it is and why it is specific to Mac. I'll publish a fix soon with a new release.
By the way, you can adjust the density of meshing by using the Interpol and OverSampling boxes. If you deactivate both, then you get a mesh strictly built on the original contour vertices.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby mariocha » Sat Aug 07, 2010 4:29 pm
A new relase ? Great !! :thumb: :thumb: :thumb:
And Oversampling & Interpol will be so usefull for designing !
C'est vraiment super !
as I'm working on a tensile structure these days.
Mario C.
mariocha
Premium Member
Premium Member
Help with Skinning
Postby cmeed » Wed Aug 18, 2010 9:32 am
help.
I see skinning videos posted within this thread but i can't get this shape to work. it seems so simple.....
I click contours, click space, i then repeat until all three lines are coloured and click the tick button or open space. i get a PLEASE WAIT then nothing happens.
Am I doing something wrong, is it Because i'm on a mac?
the last picture is tig's rails but i have to make a 4th rail for it to work.
cmeed
Premium Member
Premium Member
Postby TIG » Wed Aug 18, 2010 11:23 am
Should work with the 3 curves in either Fredo's or mine. With EEbyRails Pick the curve as the profile then the 2 side rails and then re-pick the profile again as the melding-profile - it will end with a point and triangular faces opposite the profile's end, as desired...
Global Moderator
Postby cmeed » Wed Aug 18, 2010 11:45 am
Thank you for your speedy reply. Tig your plugin is working great (i didn't know about going back to my first curve to make three curves work, cheers)
what i'm making is a field of 800 tents - the ones you can put up in 3 seconds. So i need a way of using the contours and keeping the the polys down.
see pic tent - I used the loft by spline to get this but its not that great, Skinning didn't work.
i wanted to used fredos to get the polys down.
cmeed
Premium Member
Premium Member
Postby TIG » Wed Aug 18, 2010 11:49 am
Reduce the number of segments in the arcs for the profiles/rails for EEbyRails with Entity Info [before scaling or making a 'non-arc'] ?
Global Moderator
Postby cmeed » Wed Aug 18, 2010 11:58 am
Thank you Tig. damn ! i knew that.... mmmm
cmeed
Premium Member
Premium Member
Re: Help with Skinning
Postby fredo6 » Wed Aug 18, 2010 5:31 pm
cmeed wrote:help.
COuld you please post your model so that I can have a look and see what is going wrong.
fredo
fredo6
PluginStore Author
PluginStore Author
Postby cmeed » Wed Aug 18, 2010 5:41 pm
Here you go...Thanks for looking...
I am almost sure it will work for you. Its so simple a shape.
cmeed
Premium Member
Premium Member
Postby fredo6 » Wed Aug 18, 2010 10:32 pm
cmeed wrote:Here you go...Thanks for looking...
This bug, specific to Mac, has been corrected, but I did not publish the fix yet (due to work on the Loft Along Path). I'll do soon.
It was already mentioned by Mariocha (see http://forums.sketchucation.com/viewtopic.php?f=323&t=28586&start=210#p262564)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Wed Aug 18, 2010 11:14 pm
By the way, I forgot to mention that, when Skinning shapes, you can swap rails and profiles, which may be useful when the surface to generate is made from 3 contours.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby utiler » Thu Aug 19, 2010 12:00 am
Fredo, this tool is quite incredible! I just haven't had time to play with it yet but have been following with much interest!! You really have 'user operation' high on your list.
Incredibly well done!!
utiler
Top SketchUcator
Re: [Plugin Beta] Curviloft 1.0c - 20 Aug 10 (Loft & Skinnin
Postby fredo6 » Fri Aug 20, 2010 10:51 pm
New Beta version of Curviloft 1.0c and LibFredo6 3.5c - 20 Aug 10
see Main Post for download
This is an interim version whose purpose is to fix some bugs signaled by users and to prepare a next release which will be more functional. Again, thanks to all users for their help and contribution.
1) Skinning: Bug on Mac preventing to Skin even simple shapes. Thanks to Mariocha and to Cmeed for signaling
2) Skinning: Pre-selection mode should work with more shapes. Thanks to Daniel S. for providing some good examples.
3) Loft Along Path: Still not finished. At least I have tried to improve the single-contour mode (kind of Follow Me, but accepting contours even non perpendicualr to the rail).
By the way, I noticed some differences with the native SU FollowMe tool.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Rich O Brien » Fri Aug 20, 2010 11:42 pm
Thank You Fredo, great update :thumb:
Rich O Brien
Administrator
PreviousNext
Return to Plugins
Users browsing this forum: No registered users and 21 guests
