[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)
Re: [Plugin Beta] Curviloft 1.0a (Loft by Spline)
Postby halroach » Sun Jul 04, 2010 7:39 am
As all of your wonderful plugins!
Very nice fredo!
halroach
Postby dolphus » Sun Jul 04, 2010 7:51 am
Fredo I am a big fan of your work, i hang my head in shame and confess that i cannot get the Curvilot to work when i start uo SU i get the following message " Module Curviloft requires LibFredo6 version greater than 35. Current version is 34" but i do have Version 35 in the plugin dir as well as 34 if i remove the 34 many of my other Fredo plugins work is it possible for anyone to diagnose my problem?
Thanks in anticipation
dolphus
Postby fredo6 » Sun Jul 04, 2010 8:04 am
grim wrote:fredo and charly
this tool is fantastic, however after reviewing the examples posted by charly i was eager to try them out for myself but when it came time to try step 3 if found that the curviloft menue did not display the same information nor did the black backround profile menu appear i have sinced removed all rubies and reloaded only the latest from you posting to see if i had installed it incorrectly however i get the same responce
can you enlighten me as to the problem or is there somthing i am over looking
thanks
Maybe you just need to click on a junction to get the floating palette appear, if it is your problem.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Sun Jul 04, 2010 8:07 am
dolphus wrote:Fredo I am a big fan of your work, i hang my head in shame and confess that i cannot get the Curvilot to work when i start uo SU i get the following message " Module Curviloft requires LibFredo6 version greater than 35. Current version is 34" but i do have Version 35 in the plugin dir as well as 34 if i remove the 34 many of my other Fredo plugins work is it possible for anyone to diagnose my problem?
Check out if you have a subfolder named LIBFREDO6_Dir_35 in the Plugins directory. Normally, the script automatically select the latest version of LibFredo6
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby grim » Sun Jul 04, 2010 8:59 am
fredo
thanks for the pointers, they work... there seems to be a lot more to using this tool than i realise, i am getting the hang of it slowly :berserk:
grim
Premium Member
Premium Member
Postby dolphus » Sun Jul 04, 2010 9:47 am
Thank you for the quick reply, I thought i had put the folder in i have now and it works :fecstatic:
Thank you very much
dolphus
Re: [Plugin Preview] Curviloft 1.0 (Loft and Skinning)
Postby fredo6 » Sun Jul 04, 2010 9:55 pm
Daniel S wrote:Here I make another quick test for loft feature. It´s simple but y really want to know if it would work in this cases.
Daniel S
I missed this one.
Here is the result, with Loft by Spline
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Daniel S » Sun Jul 04, 2010 11:00 pm
The idea was a result like this for that model:
Is better to make the loft in parts and not all togheter in a lot of cases.
For example, I´m making a shape where two contours share edges.
it is better to make a loft between 1-2-3, then explode and after that make the loft 4-5 for better results:
I attach the skp to show that if you make a loft of 1-2-3-4-5 the results are not good in this case.
Daniel S
Daniel S
Postby grim » Sun Jul 04, 2010 11:51 pm
danial
tried you shape file and came up with very different results see attached file
can you enlighten me as to where i am going wrong as i followed your instructions as well as trying one of my own
regards
david
grim
Premium Member
Premium Member
Postby Daniel S » Mon Jul 05, 2010 1:08 am
You can select all the contours to make the loft:
You will see that there is a problem with the default method.. try to change it with the toolbar for different results:
Or you can make it in two parts (for this model I wanted this result):
Daniel S
Daniel S
Postby fredo6 » Mon Jul 05, 2010 10:49 am
Daniel S wrote:The idea was a result like this for that model:
Daniel S
For the pencil, use the regular Bezier method (first method) instead of Cubic Bezier (default method).
Fredo
PS: for the other shape, there are still some issues when curves are partially overlapping. But it is a good example I can work from.
fredo6
PluginStore Author
PluginStore Author
Postby thomthom » Mon Jul 05, 2010 11:06 am
I've yet to try out this plugin for myself - but is there a linear option as well? Or is it just beziers? It seems to be that the pencil would require a linear morphing to get the shape of the tip.
PluginStore Author
PluginStore Author
Postby fredo6 » Mon Jul 05, 2010 3:22 pm
thomthom wrote:I've yet to try out this plugin for myself - but is there a linear option as well? Or is it just beziers? It seems to be that the pencil would require a linear morphing to get the shape of the tip.
The Linear option will be available in the next release (along with other spline methods). I came to that conclusion too.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Bob James » Mon Jul 05, 2010 8:26 pm
Just came across this wonderful and amazing new tool.
I'm pretty much speechless: incredible :bounce:
This opens up soooo many possibilities. Thank you for this great tool :berserk:
Bob James
Premium Member
Premium Member
Postby KarinaGM » Tue Jul 06, 2010 11:46 am
I haven't even had time to use it and I am already in love with this plugin.
Thanks Fredo :fecstatic:
"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
-Benjamín Franklin.
KarinaGM
Postby pilou » Tue Jul 06, 2010 1:17 pm
A little use of it ;)
Grow by Tig
Curviloft by Fredo6
FredoScale by Fredo6
Speedy Galerie
Top SketchUcator
Postby charly2008 » Tue Jul 06, 2010 9:34 pm
I tried with Curviloft the to make the ornaments in this historic door . But it does not look good. I have to try other shapes. In the rendered image it looks like a Crab.
charly2008
Postby notareal » Tue Jul 06, 2010 11:28 pm
Fredo
You cannot stop amaze! This already is a true gem. Wonder to what it will grow...
notareal
Thea Render Support
Thea Render Support
Postby charly2008 » Thu Jul 08, 2010 10:37 pm
I have further experimented with Curivloft. But for those stone sculptures, it seems to be less suitable. The current forms I have generated by the standard tools, the Freehand tool, Push Pull and Subdivide and Smooth.
charly2008
Postby Daniel S » Thu Jul 08, 2010 10:59 pm
I just see:
viewtopic.php?f=18&t=29374#p256698
And made me wonder... would be possible something like this?
Daniel S
Daniel S
Postby charly2008 » Fri Jul 09, 2010 1:52 pm
In this design I get some errors. The idea was to create a road profile. I have selected the faces one by one. Maybe Fredo can find the error. Even in a straight line this error will appear.
Charly
charly2008
Postby thomthom » Fri Jul 09, 2010 1:54 pm
Notice that the numbers for each profile alternates throughout your pre-selecting.
PluginStore Author
PluginStore Author
Postby TIG » Fri Jul 09, 2010 2:16 pm
I would think Fredo's tool superior to my EEbyLoft... BUT mine works with some componentizing and exploding etc !
Fredo, please borrow whatever ideas work in my tool for yours !
curviloft5.skp
Global Moderator
Postby massimo » Fri Jul 09, 2010 2:28 pm
Charly, try like this:
-Select, lets say, four profiles. Explode them and press the loft button;
-Do the same with other four and so on;
-Select the two profiles on the ends of two stumps and press loft. Do that for all the stumps;
-Delete the unwanted original profiles.
That's all. ;)
massimo
Postby mitcorb » Fri Jul 09, 2010 3:21 pm
In Fredo6's discussion in the first post, I saw something that suggested to leave open a tiny segment in the profile to be lofted. Perhaps to prevent the twisting?
mitcorb
Top SketchUcator
Postby charly2008 » Fri Jul 09, 2010 5:10 pm
Dear TIG and Massimo,
thank you for your advices. The background for my experiments with a winding road is the representation of the curve slope.
With EEbyLoft I have also tried. TIG, your EEbyL is also a great tool. I would not belittle your merits. But in this case it is difficult to find the correct level for the protractor because the Edges. With Curviloft i can use faces and I can change the faces more simple(made by Perpendiculare Faces) gradually at an specified angle and can construct the slope. And this worked in my first attempt (see pictures below).
You may have seen my posts with winding Roads in the forum. The disadvantage of these Roads was, that the road profile was shown only horizontal in the curves.
Charly
charly2008
Postby fredo6 » Sun Jul 11, 2010 8:17 am
Charly,
Thanks very much for your deep testing of Curviloft. It helps me find and hopefully fix the many bugs and imprecisions remaining in the script. This is why I judged that I had to go through a long beta phase with the users.
For the long and winding roads, I have found the issues and they should be adressed in the next release 1.0b.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Beta] Curviloft 1.0b - 11 Jul 10 (Loft & Skinnin
Postby fredo6 » Sun Jul 11, 2010 9:52 am
NEW BETA RELEASE
Curviloft 1.0b – LibFredo6 3.5b – 11 Jul 10: Second beta version, dedicated to Loft by Spline and Skinning (Loft Along Path is still not fully functional). Main changes are:
  • Skinning should better accept preselection of contours and make its way to create the mesh
  • Added some spline methods (Linear, Ortho-elliptic and ortho-spline)
  • For Skinning and Loft Along Path, you can over-sample the rails
  • For Skinning, you can swap the direction between contours and rails
  • Preview Mesh is normally black in SU7
  • Floating palette remembers its position across SU sessions
  • Spanish translation by Defisto
On top of potential bugs and geometry issues (including bugsplats), there are some limitations and unfinished work
  • VCB is not active
  • No interactive edition in the floating palette
  • B-Spline and F-Spline do not close nicely in loop mode
  • No later reedition of shape generated (this will come)
  • all texts and labels are not reviewed yet
see main post for download:http://forums.sketchucation.com/viewtopic.php?f=323&t=28586#p248195
fredo6
PluginStore Author
PluginStore Author
Postby dylan » Sun Jul 11, 2010 11:17 am
Thanks Fredo :thumb:
dylan
Postby charly2008 » Sun Jul 11, 2010 11:51 am
thanks Fredo,
you are great.
Charly
charly2008
PreviousNext
Return to Plugins
Users browsing this forum: BFA52, Laz B and 13 guests
