[Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinning)
Re: [Plugin Beta] Curviloft 1.8a - 31 Oct 18 (Loft & Skinnin
Postby fredo6 » Fri Jan 11, 2019 1:57 pm
Einstein wrote:I made a loft and added a forced pair for each vertex of profile. Now there are some unnecessary pairs (yellow ones) between vertices and I was thinking if it's possible to remove them before applying the loft.
In this case both profiles - upper and lower - are hexagons. So intuitively, pairs should be created between vertices only. Instead, Curviloft connected each vertex of lower profile to edge midpoint of upper profile, which created a lot of unnecessary edges. So I'm thinking if I could force the tool to always match vertex-to-vertex when profiles have the same number of verts.
I think there is an option to match vertex to vertex.
Anyway, the best would be to post your model so that I have a look.
Keep in mind that for a human brain, you see indeed two similar hexagons, but for the script, these are two curves to match in different planes.
User avatar
PluginStore Author
PluginStore Author
Postby Einstein » Sat Jan 12, 2019 11:46 am
I used default method "Match vertex to vertex (when possible)" but looks like the case was interpreted as "impossible" :P
Here's an example:
Einstein
Postby fredo6 » Sat Jan 12, 2019 7:11 pm
I understand. There is something wrong in the vertex matching, also in the Loft by Spline tool. I'll need to have a closer look.
User avatar
PluginStore Author
PluginStore Author
Postby reza1813 » Sat Feb 09, 2019 7:23 pm
Dear Fredo,
Hello, I kindly reach you to suggest some feature for the future update of Curviloft plugin.
1. I wonder to know why Curviloft doesn't create a surface when we have an Integrated curve. In fact, I always use the Soap Skin Bubble plugin in order to deal with this type of shape and unfortunately I have a problem to push surface properly. Would you mind any possibility to add this feature of Soap Skin Bubble plugin to the next version of Curviloft concerning to create the surface for all type of connected line and curve?
2. Furthermore, this is the FormZ software. I wonder to know, Is there any possibility to change the type of surface and also how it is pushed and pulled in the Curviloft with some icon in order to increase or decrease it like FormZ software? (I know that there is some option in the spline method)
Sincerely
Hamidreza
reza1813
Postby fredo6 » Sun Feb 10, 2019 12:14 pm
Well, there is space for several methods.
Curviloft does not use the same approach as Soap Skin & Bubble. When you have a continuous contour, you need to tell Curviloft where to break it in 3 or 4 pieces. You can use small segments for this, that is small standalone edges which you position along the contour.
For FormZ feature, this is also a different approach, based on Nurbs. The closest I see for this type of feature is Vertex Tools by Thomthom.
User avatar
PluginStore Author
PluginStore Author
Postby Moi_SU » Mon Jun 10, 2019 12:59 pm
Hi there,
I got so excited when I can accross this plugin, but sadly Curviloft is not working at all at the moment.
I have recently downloaded it - so it's a first time application.
Successfully installed LibFredo6 Version 8.9a and Curviloft 1.8a in SketchUp 2018. I can also load the CL toolset, but sadly it is not doing anything when clicking on the icons and following instructions.
Am I missing something?
Your help would be greatly appreciated!
Moi_SU
Postby Dave R » Tue Jun 11, 2019 5:47 pm
Moi_SU wrote:Am I missing something?
Most likely. Upload your model so we can see what you are working with.
User avatar
Global Moderator
Postby fredo6 » Tue Jun 11, 2019 9:59 pm
Moi_SU wrote:Successfully installed LibFredo6 Version 8.9a and Curviloft 1.8a in SketchUp 2018. I can also load the CL toolset, but sadly it is not doing anything when clicking on the icons and following instructions.
Just in case, could you open the Ruby Console to see if there are errors displaying.
User avatar
PluginStore Author
PluginStore Author
Postby Mousa_SA » Wed Aug 14, 2019 4:36 pm
Hello,
I have noticed a strange behavior when I use "Loft by Spline" With half circles, it is only works if I choose 3 arcs, is it a normal behavior?
User avatar
Mousa_SA
Postby fredo6 » Wed Aug 14, 2019 4:44 pm
Mousa_SA wrote:I have noticed a strange behavior when I use "Loft by Spline" With half circles, it is only works if I choose 3 arcs, is it a normal behavior?
There is a bug with this kind of coplanar configuration, for some types of junction.
In your case, just make sure that the junction type is the 'straight line', as shown below:
I'll fix the bug later on.
User avatar
PluginStore Author
PluginStore Author
Postby Mousa_SA » Fri Aug 16, 2019 8:00 am
Thank you for the tips Fredo, it works fine now.
User avatar
Mousa_SA
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot], pinarditeam and 12 guests
Visit our sponsors:
