[Plugin] Make Fur v.2.1.0(20140323)
Re: [Plugin] Make Fur (Updated - v.1.4a Jun 03, 2010 6:55 pm
Postby jonorman » Thu Jun 03, 2010 11:24 am
JIPPIIIIII ! ! ! ! Back in bizzniz :berserk: :ecstatic: :thumb: :enlight:
jonorman
Premium Member
Premium Member
Postby tomot » Thu Jun 03, 2010 4:53 pm
WOW! .....another great Plugin,
This pampas grass looks better that the real stuff in my planter :)
Thanks! tak2hata
tomot
PluginStore Author
PluginStore Author
Postby Didier Bur » Thu Jun 03, 2010 9:40 pm
Got this error when using "make crowd" without having a "fur_instance" component in my model:
Error: #<TypeError: wrong argument type (expected Sketchup::ComponentDefinition)>
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1272:in `add_instance'
I guess the script does not check wether the relevant component is in the model or not ? :idea:
It works OK if a "fur_instance" component is present.
After deleting the fur instance component, hit "CheckOnAll", and it is still there, and the makecrowd doesn't work anymore if I let its checkbox ticked.
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby Stu » Thu Jun 03, 2010 11:15 pm
Ive been using fur for a while ...with good results, and just loving it!! :thumb:
However I've struck a problem as in the attached....it seems to be the cut off angle that is upsetting the geometry.....if I try a square or rectangular plane it behaves normally.
Stu
Postby paulower » Fri Jun 04, 2010 1:31 am
Hi friends. This is the translation of Make Fur to languaje Portuguese-BR (Brasil) by me.
Tak2hata would be possible in the next version, you increase the size of the buttons "Assign Material to" and "Get Stuff From." Is that in Portuguese, we have more characters in the translation and some letters may not appear on the icon (button).
You can see who is running smoothly letters with accents and numerical symbols.
Whenever possible, I will update the new versions in the same post.
fur_lang_pt 1.5a.zip
Outras versões (Other versions):
fur_lang_pt 1.4a.rar
fur_lang_pt 1.4b.rar
thomthom wrote:paulower: that's a nice setup. Thanks for sharing.
:thumb:
That's it thomthom. We are here also for these share.
Is a tip for the staff, if possible to share their techniques and components (maps, textures) of grass and others.
tak2hata wrote:Hi,All.
I update fur plugin to verion1.3j.
Increased translatable words for local language file.
Franch translation by Daredevil.
Persian translation by Majid.
Spanish translation by Oxer.
Thanks you very mush.
Thanks.
paulower
Postby tak2hata » Fri Jun 04, 2010 4:32 am
paulower wrote:This is the translation of Make Fur to languaje Portuguese-BR (Brazil) by me.
Thanks paulowr.
I add language list on first thread.
I will increase the size of Buttons in next version.
Stu wrote:Ive been using fur for a while ...with good results, and just loving it!! :thumb:
Hi , Stu.
That happens in small value of "MaxNumber(/Face)" for the faces.
You should increase "MaxNumber(/Face)" enough.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby Stu » Fri Jun 04, 2010 4:42 am
Thanks Tak2hata, I boosted it up to 12,000!! and its fine now
Stu
Postby tomot » Fri Jun 04, 2010 4:20 pm
Tak2hata I was wondering if you had considered including a random fur height function? I'm currently creating a random height tile/block/city generator... which is not finished yet.
See my RAND code snippet below.
Code: Select all
if( $type == "Random + " )
    group=entities.add_group
    entities=group.entities
    1.upto($vpanes) do |i|
      x = ($vtile*i)+(i*$space)
      1.upto($hpanes) do |j|
       y = ($htile*j)+(j*$space)
   o = $pt3.offset($hVec, y - $space).offset($vVec, x - $space)
    pt1 = o.offset($hVec, -$htile)
   pt2 = o.offset($vVec, -$vtile)
   pt3 = pt1.offset($vVec, -$vtile)
   #entities.add_cpoint o
   #entities.add_cpoint pt1
   #entities.add_cpoint pt2
   #entities.add_cpoint pt3
    face = entities.add_face o, pt1, pt3, pt2
    face.pushpull -($tthick+rand(20))
end #if
cheers!
tomot
PluginStore Author
PluginStore Author
Re: [Plugin] Make Fur (Updated - v.1.4b Sun Jun 06, 2010 12:
Postby tak2hata » Sat Jun 05, 2010 5:05 pm
Hi,all.
I update this to version1.4b.
tomot wrote:Tak2hata I was wondering if you had considered including a random fur height function? I'm currently creating a random height tile/block/city generator... which is not finished yet.
Code: Select all
end #if
cheers!
Thanks tomot.
But this plugin created preset file.
If I add new parameter, compatible with the old one is difficult for me.
If you want to use random size to component instance, please use crowd(webdialog).
and change value of "size jitter" as you like.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby Mauhaus » Sat Jun 05, 2010 8:55 pm
Hi guys,
I lost my dwg-import option after installing the plugin. Any ideas why this happened?
/Thomas :(
Mauhaus
Postby Gaieus » Sat Jun 05, 2010 9:00 pm
Hi Thomas,
re you sure you did not upgrade from SketchUp 7.0 to 7.1 (free) lately?
Postby Mauhaus » Sat Jun 05, 2010 9:09 pm
Hi Gaieus
Thanx for replying 8-)
Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it. Maybe I didn't install it properly?
/Thomas
Mauhaus
Postby SuperSized » Sat Jun 05, 2010 10:37 pm
In the spirit of the SA World Cup.... nice plugin :fecstatic:
SuperSized
Postby Frederik » Sun Jun 06, 2010 8:36 am
Mauhaus wrote:Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it. Maybe I didn't install it properly?
I'm sure the install was made properly, however, the dwg/dxf import has been excluded from ver. 7.1 and onwards...
You need a seperate plugin...
Please check out the DWG/DXF import plugin for SketchUp 7.1 (Free)...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby hebeijianke » Sun Jun 06, 2010 8:50 am
A Chinese translation.
Thanks to you all !
hebeijianke
Postby Gaieus » Sun Jun 06, 2010 9:29 am
Mauhaus wrote:Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it...
Frederik wrote:I'm sure the install was made properly, however, the dwg/dxf import has been excluded from ver. 7.1 and onwards...
That would only be the free version Kim. The pro still has the "native" import option.
As you are not supposed to be able to install the free version on top of the pro, there can indeed be some problem.
However we are going off-topic here so Thomas, after you see my post here, I will split these posts and move the new topic created this way to the SketchUp Discussions > Bug reports subforum.
However you could try to reinstall your SU but really make sure to download the Pro version (again) to install it. Also, for the Mac version there was also a maintenance release after the main release of 7.1. A couple of fixes were made there so best is to go for sure...
Postby frv » Mon Jun 07, 2010 12:30 pm
TX for the great plugin, I love the idea of the crowedmaker.
But under OSX it does not work, the dialog panel is empty for the crowed option.
Francois
frv
Postby mariocha » Mon Jun 07, 2010 1:31 pm
frv wrote:....., I love the idea of the crowedmaker.
Francois
Yep, same here. No dialog under MacOX (10.6.3) :?
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby Masoncrowell » Mon Jun 07, 2010 8:43 pm
can someone tell me how i do this on a mac?
i downloaded the file and updated my version of sketchup. the file only shows up in my downloads and i can't open it with sketchup. i also enabled my plugins menu on sketchup and the only option that shows up is a "cost" option. How do i do this? :/
Masoncrowell
Postby tak2hata » Tue Jun 08, 2010 1:03 am
Francois
Hi,Francois and Mario.
It is very regrettable.
I will examine way for working on mac.
Masoncrowell wrote:can someone tell me how i do this on a mac?
This file is compressed by zip.
First, You should extract this file with folder.
It includes
--fur_en.rb
--fur_en(folder include icon images)
and copy created files to plugins folder.
Read here.
http://sketchup.google.com/intl/en/download/rubyscripts.html
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby ktslambieng » Tue Jun 08, 2010 3:44 am
this is this is a new : vietnam translation for fur1.4b
Thanks you for all ! :berserk:
4
ktslambieng
Postby frv » Tue Jun 08, 2010 2:53 pm
TX Tak,
hope you find the time to look into the blanc dialog for crowds.
I love your idea to specialise the furmaker for crowds
Francois
frv
Postby thomthom » Thu Jun 10, 2010 12:57 pm
That is due to some oddness in Geom::Transformation.scaling which I mentioned earlier.
viewtopic.php?f=323&t=28092&p=248300#p248300
But tak2hata said later he's swapped to use .scaling(a,a,a) isntead of .scaling(a) - so that should have taken care of it. Unless there is something else that also creates this scenario.
Oli: are you using the latest version?
PluginStore Author
PluginStore Author
Postby thomthom » Thu Jun 10, 2010 12:58 pm
:?: what happened to Oli's post..?
PluginStore Author
PluginStore Author
Postby drunkengiraffe » Thu Jun 10, 2010 10:13 pm
amazing, thanks.
drunkengiraffe
Postby wanchoke » Sat Jun 12, 2010 12:36 am
I use this plugin to my model, It's help to improve atmosphere a lot.
Thank you very much. :thumb: :thumb:
<model link>
http://sketchup.google.com/3dwarehouse/details?mid=5e3202cae2da28223fc4dc5809e00c5c&prevstart=0
wanchoke
Postby Ninjamaster1470 » Sun Jun 13, 2010 4:48 am
I know this will sound really dumb, but it appears that i set the plugin RB (whatever) file to google sketchup program so that when ever i click it, it opens on sketchup instead on.........um.....what it's supposed to open on--btw, what is the program its on?
Help! do u know how to fix?
Update: I moved it but its still a SU app instead of the supposed text doc.
Last edited by Ninjamaster1470 on Sat Jun 19, 2010 3:09 am, edited 1 time in total.
Ninjamaster1470
Postby Gaieus » Sun Jun 13, 2010 5:02 am
You do not really need to open it just drop into the plugins folder in your SU application.
Otherwise rb files are text files and should be opened with some simple text editor (never with some word processor!).
Postby McGyver » Fri Jun 18, 2010 5:52 pm
I just tried this out on my G5(Power PC) Mac using SU 6 free version... it works like a charm! I look forward to experimenting with this! Awesome job! Thank you!!!
McGyver
Postby angor2005 » Sun Jun 20, 2010 9:35 am
Please Russian translation.
Many Thanks to you all !
angor2005
PreviousNext
Return to Plugins
Users browsing this forum: adamgmace, David2001, Google Bot and 19 guests
