[Plugin] Make Fur v.2.1.0(20140323)
Re: [Plugin] Make Fur (Updated - v.1.3m May 30, 2010 11:53 a
Postby marleus » Wed Jun 02, 2010 6:43 am
Really cool plugin :berserk: :sketchstatic:
thanks a lot :thumb: :thumb:
Markus Sillander
Vantaa, Finland
I'm on FormFonts now
www.formfonts.com
marleus
Premium Member
Premium Member
Postby notareal » Wed Jun 02, 2010 8:05 am
It still amaze me what this plugin can do :sketchstatic:
Perhaps later styling with hair guides? Like in Max or Blender. Not that it have to be so extensive, but in a spirit of those.
notareal
Thea Render Support
Thea Render Support
Postby paulower » Wed Jun 02, 2010 9:27 am
autarchos wrote:Dear Mr. Paulo Wer: That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
Besten Grüßen,
Drazen Petrovic
Yes, sure I can explain:
1 - I created a normal plane in SketchUp and used the Sandbox tool SketchUp to create the topography of the land;
2 - I used two maps (two textures) of different grass. A grass that is normal, and the other is like a bush (do not know how to say it in English).
* Do not forget to apply the texture on both sides, ie, in the back and front face.
3 - Create a component for each texture (one for the grass normal and other to grass bush);
4 - In the Settings Window FUR, I made the adjustments and settings required, such as:
* TopJitter (%): 1
* Direction (X): 0mm
* Direction (Y): 0mm
* Direction (Z): 500m or 5000m (not mm. That in my example)
* In the menu drop down "Make by Component", choose the component that you created;
5 - Click on Make Fur;
6 - I did the render in V-Ray for SketchUp. In V-Ray only applied the map Alpha in Diffuse;
I still do not know for sure the function of all commands, but recommend you do the tests in Make FUR. If you want the maps are on the links below:
File - Map Alpha Mask
File - Map Grass
_______________________________
My Blog
Baú SketchUp
paulower
Postby thomthom » Wed Jun 02, 2010 9:41 am
paulower: that's a nice setup. Thanks for sharing.
:thumb:
PluginStore Author
PluginStore Author
Postby thomthom » Wed Jun 02, 2010 10:08 am
tak2hata wrote:Sorry ,Now I examines the method to remember dialog position.
That demands the javascript knowledge from me.
I will update few day later.
No need for javasscript to remember the window's position. SU does this for you if you specify a preference key.
http://code.google.com/apis/sketchup/do ... g.html#new
pref_key
The registry entry where the location and size of the dialog will be saved. If preferences_key is not included, the location and size will not be stored.
PluginStore Author
PluginStore Author
Postby jaceguay » Wed Jun 02, 2010 3:31 pm
Nothing happend when i click make fur, the ruby console show this:
Error: #<TypeError: no implicit conversion to float from nil>
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in `initialize'
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in `new'
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in `fur_inputbox'
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in `call'
Does anyone know what can be done to adress this error?
jaceguay
Premium Member
Premium Member
Postby jeabdc » Wed Jun 02, 2010 5:09 pm
ThankY ขอบคุณมากครับ :fecstatic:
jeabdc
Postby Didier Bur » Wed Jun 02, 2010 5:46 pm
After taking a look at the code, line 541 has something to do with "Direction (X)" Y and Z factors.
Yours are undefined (nil), so check your values in the dialog box and try to change them with something else than zero and see if it works. Check your decimal "," or "." too.
Hope this helps,
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby jaceguay » Wed Jun 02, 2010 8:00 pm
Thanks for the fast response, changing the values return another error:
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in `initialize'
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in `new'
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in `show_webdialog'
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:792:in `call'
jaceguay
Premium Member
Premium Member
Postby jonorman » Wed Jun 02, 2010 8:52 pm
same problem here. after installing last version..
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in `initialize'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in `new'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in `fur_inputbox'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in `call'
buuuuhuuuuu... miss my fur/grass plugin :cry:
jonorman
Premium Member
Premium Member
Re: [Plugin] Make Fur (Updated - v.1.4 Jun 03, 2010 6:43 am)
Postby tak2hata » Wed Jun 02, 2010 11:02 pm
I uploaded version1.4.
Change is...
    Remember webdialog position.(Thanks thomthom :D )
    Add new mode "Crowd".(Multi Instance scattering.)
jonorman wrote:same problem here. after installing last version..
In this version ,I changed convert string to length method little.
When that error is happened , I want look your dialog parameter.
I think problem is around "s_to_l" method.
thiloo wrote:thanks tak2hata for the quick explanation,
wow, that´s also an powerful feature.
sadly it´s not working if I choose "make by component - yes"!
also, with component activated, the reaction to the force settings are quite unexpected?
I need the components for instancing -> rendering.
again, Thank You for your time and effort
"make by component -- yes" was added after making this plugin.
This plugin originaly use for "make by component -- no".
I do not have good way to componentinstance direction control.
When I find good way,I will change it.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby sloof » Thu Jun 03, 2010 6:05 am
how to use this ?
somebody help me please ?
sloof
Postby jonorman » Thu Jun 03, 2010 8:53 am
screen dump of SU trying to use fur.
jonorman
Premium Member
Premium Member
Postby tak2hata » Thu Jun 03, 2010 11:00 am
jonorman wrote:screen dump of SU trying to use fur.
Hi,jonorman.
I updated version 1.4a.
Sorry,I forgat changing "s_to_l".
now it changed.
It may be work.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin] Make Fur (Updated - v.1.4a Jun 03, 2010 6:55 pm
Postby tak2hata » Thu Jun 03, 2010 11:20 am
sloof wrote:how to use this ?
Hi,sloof.
http://forums.sketchucation.com/viewtopic.php?f=323&t=28092
http://sketchupdate.blogspot.com/
It may help.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby jonorman » Thu Jun 03, 2010 11:24 am
JIPPIIIIII ! ! ! ! Back in bizzniz :berserk: :ecstatic: :thumb: :enlight:
jonorman
Premium Member
Premium Member
Postby tomot » Thu Jun 03, 2010 4:53 pm
WOW! .....another great Plugin,
This pampas grass looks better that the real stuff in my planter :)
Thanks! tak2hata
tomot
PluginStore Author
PluginStore Author
Postby Didier Bur » Thu Jun 03, 2010 9:40 pm
Got this error when using "make crowd" without having a "fur_instance" component in my model:
Error: #<TypeError: wrong argument type (expected Sketchup::ComponentDefinition)>
C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1272:in `add_instance'
I guess the script does not check wether the relevant component is in the model or not ? :idea:
It works OK if a "fur_instance" component is present.
After deleting the fur instance component, hit "CheckOnAll", and it is still there, and the makecrowd doesn't work anymore if I let its checkbox ticked.
Didier Bur
Didier Bur
Postby Stu » Thu Jun 03, 2010 11:15 pm
Ive been using fur for a while ...with good results, and just loving it!! :thumb:
However I've struck a problem as in the attached....it seems to be the cut off angle that is upsetting the geometry.....if I try a square or rectangular plane it behaves normally.
Stu
Postby paulower » Fri Jun 04, 2010 1:31 am
Hi friends. This is the translation of Make Fur to languaje Portuguese-BR (Brasil) by me.
Tak2hata would be possible in the next version, you increase the size of the buttons "Assign Material to" and "Get Stuff From." Is that in Portuguese, we have more characters in the translation and some letters may not appear on the icon (button).
You can see who is running smoothly letters with accents and numerical symbols.
Whenever possible, I will update the new versions in the same post.
fur_lang_pt 1.5a.zip
Outras versões (Other versions):
fur_lang_pt 1.4a.rar
fur_lang_pt 1.4b.rar
thomthom wrote:paulower: that's a nice setup. Thanks for sharing.
:thumb:
That's it thomthom. We are here also for these share.
Is a tip for the staff, if possible to share their techniques and components (maps, textures) of grass and others.
tak2hata wrote:Hi,All.
I update fur plugin to verion1.3j.
Increased translatable words for local language file.
Franch translation by Daredevil.
Persian translation by Majid.
Spanish translation by Oxer.
Thanks you very mush.
Thanks.
paulower
Postby tak2hata » Fri Jun 04, 2010 4:32 am
paulower wrote:This is the translation of Make Fur to languaje Portuguese-BR (Brazil) by me.
Thanks paulowr.
I add language list on first thread.
I will increase the size of Buttons in next version.
Stu wrote:Ive been using fur for a while ...with good results, and just loving it!! :thumb:
Hi , Stu.
That happens in small value of "MaxNumber(/Face)" for the faces.
You should increase "MaxNumber(/Face)" enough.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby Stu » Fri Jun 04, 2010 4:42 am
Thanks Tak2hata, I boosted it up to 12,000!! and its fine now
Stu
Postby tomot » Fri Jun 04, 2010 4:20 pm
Tak2hata I was wondering if you had considered including a random fur height function? I'm currently creating a random height tile/block/city generator... which is not finished yet.
See my RAND code snippet below.
Code: Select all
if( $type == "Random + " )
    group=entities.add_group
    entities=group.entities
    1.upto($vpanes) do |i|
      x = ($vtile*i)+(i*$space)
      1.upto($hpanes) do |j|
       y = ($htile*j)+(j*$space)
   o = $pt3.offset($hVec, y - $space).offset($vVec, x - $space)
    pt1 = o.offset($hVec, -$htile)
   pt2 = o.offset($vVec, -$vtile)
   pt3 = pt1.offset($vVec, -$vtile)
   #entities.add_cpoint o
   #entities.add_cpoint pt1
   #entities.add_cpoint pt2
   #entities.add_cpoint pt3
    face = entities.add_face o, pt1, pt3, pt2
    face.pushpull -($tthick+rand(20))
end #if
cheers!
tomot
PluginStore Author
PluginStore Author
Re: [Plugin] Make Fur (Updated - v.1.4b Sun Jun 06, 2010 12:
Postby tak2hata » Sat Jun 05, 2010 5:05 pm
Hi,all.
I update this to version1.4b.
tomot wrote:Tak2hata I was wondering if you had considered including a random fur height function? I'm currently creating a random height tile/block/city generator... which is not finished yet.
Code: Select all
end #if
cheers!
Thanks tomot.
But this plugin created preset file.
If I add new parameter, compatible with the old one is difficult for me.
If you want to use random size to component instance, please use crowd(webdialog).
and change value of "size jitter" as you like.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby Mauhaus » Sat Jun 05, 2010 8:55 pm
Hi guys,
I lost my dwg-import option after installing the plugin. Any ideas why this happened?
/Thomas :(
Mauhaus
Postby Gaieus » Sat Jun 05, 2010 9:00 pm
Hi Thomas,
re you sure you did not upgrade from SketchUp 7.0 to 7.1 (free) lately?
Postby Mauhaus » Sat Jun 05, 2010 9:09 pm
Hi Gaieus
Thanx for replying 8-)
Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it. Maybe I didn't install it properly?
/Thomas
Mauhaus
Postby SuperSized » Sat Jun 05, 2010 10:37 pm
In the spirit of the SA World Cup.... nice plugin :fecstatic:
SuperSized
Postby Frederik » Sun Jun 06, 2010 8:36 am
Mauhaus wrote:Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it. Maybe I didn't install it properly?
I'm sure the install was made properly, however, the dwg/dxf import has been excluded from ver. 7.1 and onwards...
You need a seperate plugin...
Please check out the DWG/DXF import plugin for SketchUp 7.1 (Free)...
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby hebeijianke » Sun Jun 06, 2010 8:50 am
A Chinese translation.
Thanks to you all !
hebeijianke
PreviousNext
Return to Plugins
cron
Users browsing this forum: Kurt_Norway, mpaplow and 23 guests
