[Plugin] Flattery papercraft tools
Re: [Plugin] Flattery papercraft tools
Postby TIG » Sun Mar 02, 2014 1:38 pm
@jbb
You have a typo in the update.
It no longer works in <v14
You have added
vertecies = Set.new --> vertecies = Set.new
when it should be
vertecies = Set.new --> RUBY_VERSION.to_i < 2 ? vertecies = Set.new : vertecies = Sketchup::Set.new
I'll correct it and add it to the PluginStore later...
Global Moderator
Postby jiminy-billy-bob » Sun Mar 02, 2014 1:45 pm
Oh? Sorry, I must have mixed up the files...
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby TIG » Sun Mar 02, 2014 2:06 pm
I've just added v1.0.2 files to the PluginStore [previously it had linked to the author's site where the incompatible file still resides].
If the original author [who still has full credit] wants to remove it let us know.
He is also free to take the corrected version and use it on his own site if he wishes...
Under the clear terms of the (c) notice at the top of each of his files, he allows changes and reissue, provided his (c) is kept intact - which it is...
Global Moderator
Postby shafir_am » Sun Mar 02, 2014 2:18 pm
Thank you jiminy...
It's working now (-:
shafir_am
Postby mcgully » Sat Mar 29, 2014 11:48 pm
Can anyone please help me? On my old laptop flattery worked just fine. Now WIN8 , SU2013 version and installed flattery, all worked correctly but I just can't export the drawing. I click save but it wont appear in the folder. Also tried SU8 but didn't work neither.
mcgully
Postby Jim » Sun Mar 30, 2014 2:05 pm
A working version for 2014 is in the Plugin Store:
http://sketchucation.com/pluginstore?pln=Flattery
Jim
Global Moderator
Postby mcgully » Sun Mar 30, 2014 2:52 pm
Thank you very much, in 2014 all works alright
mcgully
Postby magna2 » Thu May 08, 2014 10:28 am
I copyed the file into the extension folder, but it doesn't show up on the menu bar on SU2014. Anyone could help me out?
Thanks!
kind regards,
Magnar Totland
magna2
Postby Dave R » Tue May 13, 2014 9:11 pm
What do you mean you "copyed [sic] the file into the extension folder"?
Did you just download the .rbz file and copy it? And what extension folder? Did you place the .rbz file into the Plugins folder? If so, that's not the correct way to install plugins/extensions. Find the .rbz file and remove it back to Downloads or the desktop. Open SketchUp and go to Window>Preferences>Extensions. click on Install Extension, navigate to where you put the file, select it and choose Open. Continue with the installation. You should then see the toolbar for it under View>Toolbars.
Global Moderator
Postby magna2 » Wed May 14, 2014 7:58 am
Thank you! :)
magna2
Postby TIG » Fri Jul 04, 2014 9:42 am
Please complete your SCF User Profile, we don't know your OS or SUp version.
We can offer more targeted advice if you had...
Most Plugins are available in the PluginStore:
The RBZ archive can be automatically installed with any SketchUp >= v8 using Preferences > Extensions > Install.... button...
If you installed the RBZ version of the SketchUcation PluginStore toolset, then you'll be able to AutoInstall from the PluginStore without even worrying about the RBZ download - every step is doe automatically...
Don't forget that most Plugins are 'free', so carping on about inadequacies is not constructive...
Perhaps the author is a code whizz who can't explain himself well?... but you as an erudite chap could help by sharing knowledge and make the work a better place - rather that making people feel bad.
Post a useful tip, like, "Flattery Tip: After selecting and indexing, you'll need to deselect and reselect before 'unfolding'..."
Global Moderator
Postby sgisler » Wed Jul 30, 2014 7:34 pm
I need some help;I've tried installing this plugin and cant seem to get it to work. (Sketchup (Make) 2014, Win8). following the procedure: Window>Preferences>Extensions. click on Install Extension, navigate to where you put the file, select it and choose Open. the toolbar doesn't show up and upon closing/reopening Sketchup I get the error dialog:
Error Loading File C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/toolbar.rb
Error: #<SyntaxError: C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:238: syntax error, unexpected ':', expecting keyword_then or ';' or '\n'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:276: syntax error, unexpected ':', expecting keyword_then or ';' or '\n'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:287: syntax error, unexpected ':', expecting keyword_then or ';' or '\n'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/tabtool.rb:291: syntax error, unexpected keyword_end, expecting end-of-input>
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in `require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery/toolbar.rb:24:in `<top (required)>'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `require'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in `load'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery.rb:28:in `register_extension'
C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/flattery.rb:28:in `<top (required)>'
sgisler
Postby Dave R » Wed Jul 30, 2014 9:06 pm
Where did you get the version of Flattery that you downloaded? It shouldn't be installed in the Tools folder but from the error messages, it appears it has been installed there. It would appear you have an outdated version. You should first navigate to the tools folder and delete any all files related to Flattery and start from scratch with a fresh copy. The correct version is in the Plugin Store. Use it to auto-install the plugin correctly.
Global Moderator
Postby sgisler » Wed Jul 30, 2014 10:03 pm
Thanks Dave R,
just tried that. deleted all instances of Flattery and auto-installed from inside Sketchup. The toolbar still does not appear. Window>Preferances>Extensions shows it in the active list. but no joy. The Plugins Manager shows it as loaded, however the Extensions Manager show it as Disabled.
sgisler
Postby Dave R » Wed Jul 30, 2014 10:39 pm
What does the following mean exactly?
...and auto-installed from inside Sketchup
How did you install it? Did you download a fresh copy? Or did you use the Sketchucation Plugin Store to install it?
What happens when you attempt to enable it in the Extensions Manager? Is there an entry for Flattery in the toolbars list? If you close SketchUp and reopen it, are there any messages? What are they?
Global Moderator
Postby sgisler » Wed Jul 30, 2014 10:54 pm
I've deleted every instance I could find ad will try again.
I installed with the Sketchucation plugin store; searched the plugin store within Sketchup, click autoinstall,
well, I was doing it as I was typing a blow-by-blow and lo and behold it worked. Don't know what I did differently this time. I've tried at least a dozen times to install it both manually and thru the plugin store. Hmm, dunno. At least its working now.
thanks for your help!
Stan
sgisler
Postby madebyme » Mon Aug 18, 2014 12:26 pm
Can you specify material thickness with this plugin? Thanks
madebyme
Postby frankenpaper » Tue Aug 19, 2014 4:33 am
I tried following the instructions provided by http://www.pumpkinpirate.info/flattery/
which did not result in a toolbar. The email address provided does not work either.
My wife found the answer that works. I could not get along without her!
Go to the Menu
Window> Preferences> Extensions>
Click the Install Extensions... button
Browse to your downloads folder
Select the file
Flattery_v1.0.2.rbz
Click the Open Button
Follow the usual "Yes, OK, I Agree" type options.
Now Flattery is correctly installed and you will have the menu bar you expected.
I Hope this helps you too!
frankenpaper
Postby Dave R » Tue Aug 19, 2014 1:11 pm
Or you could just use the Sketchucation Plugin Store to install it automatically and not have to go through all those steps.
Global Moderator
Postby Porkobosso » Wed Sep 23, 2015 4:09 am
Its almost 2016. Please make it work with SU2015
Porkobosso
Postby Dave R » Tue Sep 29, 2015 10:09 am
Porkobosso wrote:Its almost 2016. Please make it work with SU2015
It already works with SU2015.
Global Moderator
Postby TIG » Tue Sep 29, 2015 12:50 pm
As DaveR says, it was fixed sometime ago to work with the newer SketchUp versions [ i.e. >= v2014 ].
The original download on the author's website is old, and therefore incompatible with anything > v2013.
I do not believe the author is supporting this tool any longer...
However, under the terms of the tool's (c) license I updated it in April this year, and so that version of it is available from the PluginStore [but not elsewhere!]...
Global Moderator
Postby chri » Sat Oct 24, 2015 8:08 pm
hi
please find after a small animated explanation.
( done with GifCam : http://blog.bahraniapps.com/gifcam/ )
Chri
chri
Postby BRG » Sun Nov 08, 2015 6:14 am
I have installed your Flattery plugin and it is doing a great job unfolding designs. However, when I click on the SVG button, I get the pop up menu to select where to save the file but the svg file type does not appear in the lower box. In fact, no file type appears. Any idea how I can fix this?
BRG
Postby TIG » Mon Nov 09, 2015 2:44 pm
@BRG
I assume you have the latest version from the PluginStore, which has some compatibility issues fixed:
Download
The SVG export works fine for me.
Have you got a 'Flattery' group?
It must be the only thing selected when you activate the Flattery-SVG exporter ?
Then you get the export-dialog with a named.svg etc...
Global Moderator
Postby Mic2012 » Tue Feb 14, 2017 11:00 pm
I've translated the Flattery plugin Doc in French look at the Download link for PDF
J'ai traduit le plugin Flattery en Français voir le lien Download pour le PDF
Download: https://1drv.ms/f/s!AFl38Tl2pzx-g-gv
Mic2012
Postby JSA_SJ » Sun Mar 26, 2017 5:19 pm
What I downloaded was only a .php file, not .rbz as normal plug-ins are.
Please help.I got 'pluginserv_joomla.php', did I do anything wrong??
JSA_SJ
Postby Dave R » Sun Mar 26, 2017 5:24 pm
JSA_SJ wrote:What I downloaded was only a .php file, not .rbz as normal plug-ins are.
Evidently you did do something wrong. If you'd followed TIG's link it would have taken you to the Sketchucation Extension Store page for Flattery. When you get there, click the Download button. You might need to sign in first. When you click Download, the RBZ file should download to your computer.
Why not install the Sketchucation Extension Store? Then you can let it automatically download and install extensions and help you keep them up to date when they get revised.
Global Moderator
Postby facer » Mon Mar 27, 2017 2:49 am
SketchUcation Extension Store
Yes, this is a helpful tool that aids in keeping extensions/plugins updated after install.
The use of plugin Sets is another helpful tool.
Thank you SketchUcation team!
facer
Premium Member
Premium Member
Postby Tabycz » Tue Apr 11, 2017 5:54 am
I use SU 2017 and Flattery doesn´t work well. I can unwrap but I cannot change edges and add tabs too.
Any idea what I must do wrong?
Tabycz
Previous
Return to Plugins
Users browsing this forum: deephobby, fredo6, glro, onesimo, Otna Vicky and 16 guests
