[Plugin] ExtrudeTools - Full Set
Re: [Plugin] ExtrudeTools - Zipped Set 20111113
Postby Meisterdrow » Fri Dec 02, 2011 12:18 pm
Hi TIG,
thanks for your support, that's not self-evident!
You have been right, it was a 'Compatibility Files' issue as you recommended. Your plugin 20111113 is not working if sketchyphysics 3.2 is also installed. The older version of your plugin in combination with an older sketchyphysics version worked. Now I deleted sketchyphysics and your plugin is working fine! :ecstatic:
Greetings
Meisterdrow
Postby TIG » Fri Dec 02, 2011 5:52 pm
There is a known problem with several scripts being incompatible with SP - which messes, ill-advisedly with some base-classes...
We await its resolution.
The 'Compatibility Files' often catches users out on new systems -one of Windows dafter ideas...
Global Moderator
Postby gudio83 » Tue Dec 06, 2011 9:30 am
Hi everybody,
i have installed the TIG extrusion tools, but the most of them don't work.
I make:
2 arcs, after make a groupe - it's the first groupe.
2 arcs for the second groupe.
I select the 2 groupes and start EXTRUDE EDGES BY EDGES
Sketchup show me : MULTIPLYING EDGES.....
.... waiting 5 minutes and nothing.
the same is with other tools
I have no problem with tools like ARTISAN and others
Where is the problem?
gudio83
Postby TIG » Tue Dec 06, 2011 12:21 pm
Run EEbyEdges with the Ruby Console open and post any error messages.
Are your arcs of a reasonable size etc ?
Why not post the SKP that's not working, or at least a screenshot - you might have made the bits wrongly ?
We can't tell unless we have more information...
Works for me and thousands of others... :?
Are you sure it's the tool you want? If you welded the arcs into curves and the used EEbyRails would that perhaps give the expected result ??
Global Moderator
Postby gudio83 » Wed Dec 07, 2011 12:42 am
that's on ruby console:
Error: #<TypeError: wrong argument type (expected Sketchup::Entity)>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:228:in `add_group'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:228:in `activate'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:384:in `select_tool'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:384:in `extrudeEdgesByEdges'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:399
gudio83
Postby TIG » Wed Dec 07, 2011 11:40 am
Still doesn't help a lot!
However, I now suspect that it's a clash with another script that's ill-advisedly interfering with the built-in group.copy method. One known culprit is Sketchy-Physics, another is Driving-Dimensions. If you have those install tools please try disabling them - to do that find the relevant .rb or .rbs file[s] in the Plugins folder, that will load the tool[s] and add a '!' to the end of the file-extension [you need your folder options set to let you see the extensions] so they are .rb! or .rbs! files. Restart Sketchup and see if EEbyEdges works now...
I am looking at a workaround for this kind of issue - but it's these rogue tools who's code is wrongly messing with built-in methods though !
It it continues after the disablement, then post the SKP or at the very least a screenshot, with instructions on what you pick, how etc, so we can test it ourselves...
Global Moderator
Re: [Plugin] ExtrudeTools - Zipped Set 20111207
Postby TIG » Wed Dec 07, 2011 2:06 pm
Here's an updated zipped set.
viewtopic.php?p=217663#p217663
Six of the tools that used the built-in method 'group.copy' have been rewritten to avoid using it [you will now get a warning that 'make-unique-is-deprectaed' in the Ruby Console but that's a glitch with the way Sketchup is written and not an error per se].
This has been forced on us because there are still a few rogue scripts out there where the authors have messed around with some built-in base-class methods like this, and then the expected result is not returned...
Global Moderator
Postby gudio83 » Thu Dec 08, 2011 10:35 pm
It's great. all tools without EXTRUDE EDGES BY EDGES work.
EXTRUDE EDGES BY EDGES still don't work. now every time tells me: select 2 groups of edges. 1st profile 2nd path.
i have no idea why, there is no error message.
gudio83
Postby TIG » Thu Dec 08, 2011 11:33 pm
gudio83 wrote:It's great. all tools without EXTRUDE EDGES BY EDGES work.
Please post your SKP that's not working so we can see...
Global Moderator
Postby sameer_engi » Sat Dec 17, 2011 6:57 pm
i like it; it so easy to use and save time thinks :thumb:
sameer_engi
Postby lazybones » Thu Jan 05, 2012 2:05 pm
As it is my first post - hi everyone;)
I've got question about Arc's tutorial.
What plugin do i need to move up this middle arc, like Arc did? I mean, how to control this arc so i can drag ending point up like it is shown on this tutorial...
lazybones
Postby TIG » Thu Jan 05, 2012 4:20 pm
lazybones wrote:As it is my first post - hi everyone;)
Sorry lazybones but you're making as much sense as a 'sack full of cornels' [=private-joke!].
This is really about basic Arc drawing and so it probably belongs elsewhere ?
BUT assuming this isn't going to get into a long off-topic ping-pong game... then please read this carefully...
Find and read the Help function for Arc.
Consider using the Instructor window for info on unfamiliar tools - like the Arc one, which has several links off the web-pages for specialized Arc making...
There are specific useful inferencing tips for tangents, half-circle etc
You can snap the ends of the Arc and 'bulge' to anywhere you like; so snap to existing things or make guides to snap to.
You can constrain the direction/plane of an Arc using Shift keys when picking points.
You can also type in precise values for chord and bulge sizes...
Once the Arc is made you can Scale it in one or both axes of its plane.
You can also Move/Rotate it into another orientation.
TIP: to prevent it sticking to other geometry, Group it temporarily do the Move/Rotate, then Explode it when you are done tweaking... :geek:
Global Moderator
Postby lazybones » Fri Jan 06, 2012 5:11 pm
TIG wrote:Sorry lazybones but you're making as much sense as a 'sack full of cornels' [=private-joke!].(...)
:P
As I'am not SU beginner, i feel quite stupid about my question right now;) I've never used that 'bulge' by point before - and now i'm wondering (and will for o moment) how is that possible :fro: genius...
Anyway, thanks a lot for help, cheers!
lazybones
Postby Dave R » Fri Jan 06, 2012 6:01 pm
When you use the Arc tool, you set the end points by clicking and drag out the"bulge". Try it and look at the Measurements box. You'll see it is labeled "Bulge". Some of that stuff, because it is always there, is easy to overlook.
Global Moderator
Postby yaza » Wed Jan 18, 2012 9:40 am
Dear TIG thanks for a wonderful tool.
I was using it for more than a year with no issues with it's siblings in the plugin folder, until yesterday when it started to crash SU.
I have no ... idea what the commpatibility file means. Please advise.
Thank you and have a nice day
yaza
Postby TIG » Wed Jan 18, 2012 10:20 am
There are a few overlapping issues...
The 'Compatibility Files' button means that you do not have full permissions to the Plugins folder, AND although it might look like you have successfully installed files/subfolders into the 'Plugins' folder, actually the OS [Vista?] has put them into a 'side folder' to protect you from yourself - an annoying feature because it doesn't tell you this except for displaying this unobtrusive button - the missing bits can cause issues when things only half-auto-load when SUp starts.
Click on the 'Compatibility Files' button and see what's up, move things back as needed.
To stop a recurrence ensure that you have full permissions to the 'Plugins' folder [and the Materials/Components/Styles folders too] - select the folder's icon, right-click, properties, security, select user[s], edit etc...
You also have a "tool-bar collection" folder installed - there are warnings about this posted on its download page, it puts old copies of some 'system' files into the 'Plugins' folder, which then load before the newer versions that were made in the 'Tools' folder by the SUp installer, and which SUp MUST find and use !
It then breaks SUp in subtle ways !
The two files that jump out at me, and MUST be removed from your 'Plugins' folder are sketchup.rb and extensions.rb - see the "collection's" download page for more details...
The Ruby Console reports seem OK.
I'm unsure what the '20' lines are - were you perhaps running another tool before this ?
The 'make_unique...deprecated...' message IS expected, as the tools use that API method which IS needed when copying groups in certain ways, but which SUp wrongly advises against, things it's 'deprecated' = 'no longer used'... [IF the API 'safely' made unique copies of groups by default it wouldn't be used]. I reintroduced the make_unique method after it became apparent that some other authors' scripts were ill-advisedly rewriting base-classes/methods and thereby adversely affecting the API's 'group' methods, and causing issues with some users - e.g. cgp=group.copy should return a reference to the newly made [hopefully unique] group, but some third-party scripts mess that up and it returns 'nil', therefore making it impossible to keep track of copied groups, the safest way is to use
cgp=entities.add_instance(group.entities.parent, group.transformation)
cgp.make_unique
So that 'cgp' is then properly returned as a reference to the new unique copy of the 'group'...
Incidentally if you are going to display your folders' contents without 'details'. then please have your 'Folder Options' set to display ALL file-types, so we see .rb, .skp etc, it's much easier to grasp what's what in a screenshot...
Global Moderator
Postby yaza » Wed Jan 18, 2012 11:00 am
Thanks for your immediate!!! answer, don't you ever sleep?
The OS is Windows7.
I don't get it, why does this stupid machine gives me administrator prerogative to install and run from one hand and takes it back from the other by overighting on it's own.
yaza
Postby yaza » Wed Jan 18, 2012 11:12 am
can you please direct me to the link?
thank you
yaza
Postby TIG » Wed Jan 18, 2012 11:41 am
Global Moderator
Postby rv1974 » Mon Apr 30, 2012 8:08 am
Hi TIG,
I could not find the 'ExtrudeAlongPath.rb' thread, so let me spam here.
You know what would make my sketchup life complete?
Being able to ExtrudeAlongPath on multiple\not connected edges.
I use this .rb constantly and it'd save a LOT of time.
Thank you in advance
P.S. yet another wish:
the default alignment: centroid, width\length: 5\5.
rv1974
Postby TIG » Mon Apr 30, 2012 9:58 am
There are three of my older extrusion tools that are not in the zipped set.
Two are still available from Didier's crai Ruby Depot
ExtrudeAlongPath and TubeAlongPath
The other one PipeAlongPath is also available here at SCF viewtopic.php?p=7547#p7547
The zipped set's ExtrudeEdgesByFace tool effectively replaces them all: with it you can draw any 'flat' face shape desired and use a cpoint to fine-tune its initial setting-out: it also follows multiple selected paths [unlike most other tools where branching etc stops the operation]...
However, PipeAlongPath does allow circular 'pipe-like' extrusions with variable int/ext.diameters set by dialog, so that tool does still have its own uses...
Global Moderator
Postby rv1974 » Mon Apr 30, 2012 11:17 am
Indeed 'extrude edges by face' works smoothly.I'll adopt it for sure. Thank you!
though.. the oldie 'ExtrudeAlongPath' is a bit faster to execute in boring rectangular situations
(which are 99% in my practice)
rv1974
Postby gherkin » Mon May 21, 2012 10:41 pm
Hi, I'm an architecture student... these tools will really helped me visualise my ideas! They are similar to Rhino's 'Panelling Tools' plugin, but this is not free. I've had a play with extrude tools for an hour or so... I'm addicted! Thanks TIG:
gherkin
Postby gherkin » Tue May 22, 2012 12:31 am
Another couple:
gherkin
Postby zxinfinity » Wed Jul 25, 2012 11:04 pm
FYI, I LOVE your extrude tools, TIG, but I wanted to let you know that I get consistent crashes with almost all of the extrude tools when I have SU Podium installed. Any way to know what the offending functions are?
zxinfinity
Postby Dave R » Wed Jul 25, 2012 11:18 pm
Podium is the "offending function".
Global Moderator
Postby TIG » Wed Jul 25, 2012 11:25 pm
There are several scripts that mess with native class/methods.
These cause several legitimate scripts to fail, because they will illegitimately cause some methods [particularly with 'groups'] to return the wrong values.
These include SketchyPhysics, DrivingDimensions, SunTools, MatchBox and some versions of Podium...
Global Moderator
Postby publied » Sat Aug 04, 2012 2:36 pm
i don't have many words about this plugin... only one: amazing. is listed in the 'must have list plugin'!
ciao and tnx!
publied
Postby Laudibau » Mon Aug 06, 2012 11:55 pm
You made my day! Thank you
Laudibau
Postby camsoccer2 » Fri Aug 31, 2012 3:05 pm
Hey Tig, in the lattice tool, is it possible to have the material choices include the material layers I have created in the project instead of the generic red, green, etc.?
Cam
camsoccer2
PreviousNext
Return to Plugins
Users browsing this forum: gks0608, liangzhukun and 10 guests
