[Plugin] SmartPushPull v0.26 (05 nov)
Re: [Plugin] SmartPushPull v0.26 (05 nov)
Postby urgen » Fri Nov 06, 2009 8:53 pm
...very usefull! :thumb: thank you!:)
--pupil forever...------
urgen
Postby utiler » Sat Nov 07, 2009 12:15 am
CADAddict wrote:Very nice,
I noticed the original lines remain, hahe you though of using smething like "remove cplanar edges" to eliminate thos elines after the push/pull operation?
Great job anyways!
I like that idea, CADAddict!
Maybe something similar to the standard Pushpull with 'Ctrl' Pushpull leaving original face and edges....
What do you think a4chitect?
utiler
Top SketchUcator
Postby a4chitect » Sat Nov 07, 2009 9:19 am
i think you are talking about thd first entry in the todo list in the first post; such feature is planned.
a4chitect
PluginStore Author
PluginStore Author
Postby pilou » Sat Nov 07, 2009 12:24 pm
Tricky! :enlight:
Speedy Galerie
Top SketchUcator
Postby halroach » Sat Nov 07, 2009 10:19 pm
Great and useful Plugin!
I've got a few more to do's:
1. What makes sketchup a great and fast program to use, is mainly the easy inferencing!
As with the regular push-pull tool, you should be able to indicate exactly where the pulled plane will arrive to. The pulled plane should stick to existing lines/points which may intersect with it.
[right now, I've noticed it only sticks if I start pulling the plain from a point (which is very difficult to determine if it's sticking or not) which is on a line (perpendicular to the pulled plain) which reaches the point I want to get to... (I imagine that's isn't very clear, I can add an image if needed) ]
2. If two, or more of the side planes merge into a single point or a single line, it ought to stick there too.
geometrically that would happen when one any one of the side planes gets to n-1 edges.
3. when using the VCB - entering a number, pressing enter, and then entering another number, should act like other sketchup tools. It should act as though you're still pulling the same plane once. currently it keeps making more and more faces.
4. when pressing TAB WHILE using the tool - at times it's like double clicking, other times it repeats the last doubleclick... behavior inconsistent and confusing. It should just change the behaviour without committing any changes.
I would have loved to help solve these issues myself, but scripting is Chinese to me... 8-)
halroach
Postby boofredlay » Sun Nov 08, 2009 6:05 am
Well done. Thank you.
boofredlay
Global Moderator
Postby halroach » Sun Nov 08, 2009 10:01 am
Halroach wrote:Great and useful Plugin!
I forgot to mention a very important detail. :D
I was testing the script on Mac OSX with sketchup 7.0! so all the points above relate to sketchup on OSX.
testing it on a PC with sketchup 7.1 returned very nice results! Though points 2 and 3 above are still problematic.
halroach
Postby push » Fri Nov 13, 2009 10:38 pm
thank you!
push
Postby mics_54 » Sat Nov 14, 2009 2:39 am
very cool, thanks!
mics_54
Postby serena » Sun Nov 15, 2009 3:29 pm
:berserk:
serena
Postby DIEGO-RODRIGUEZ » Sun Nov 15, 2009 5:12 pm
can you add, pushpull for multiple faces?¿
maybe pressing> shift <
Last edited by DIEGO-RODRIGUEZ on Sun Nov 15, 2009 5:26 pm, edited 1 time in total.
DIEGO-RODRIGUEZ
Banned
Postby boofredlay » Sun Nov 15, 2009 5:17 pm
Diego, this is what you want:
viewtopic.php?p=42783#p42783
boofredlay
Global Moderator
Postby DIEGO-RODRIGUEZ » Sun Nov 15, 2009 5:25 pm
I use the plugins, Joint Push Pull
but not works as SmartPushPull v0.26
idea for icons
DIEGO-RODRIGUEZ
Banned
Postby monkeybss » Mon Nov 16, 2009 7:31 am
Very good! And in time, too.Thanks!
monkeybss
Postby plot-paris » Mon Nov 16, 2009 10:13 am
DIEGO-RODRIGUEZ wrote:can you add, pushpull for multiple faces?
that would be great indeed. but I think a modifier key is unnecessary. simply apply the tool to more than one faces, if they have been pre-selected...
plot-paris
Postby brookefox » Tue Nov 17, 2009 11:41 pm
I had occasion to use it a few times today and found it quite handy. As a matter of chance, I was grateful for the lingering edges as they made it easier to make progressive pulls in which intermediate sections could be readily deleted, as desired. Face colors did not track the original, which would have been preferred, and as, no doubt, you are aware.
Thanks much for sharing.
~ Brooke
brookefox
Postby Panga » Wed Nov 18, 2009 5:52 pm
Thanks a lot for this plugin !! Keep going !
Panga
Premium Member
Premium Member
Postby a4chitect » Thu Nov 19, 2009 11:23 am
thanks to all for leaving nice comments!
I read all suggestions and will definitely try to develop this plugin further. Please be patient...
a4chitect
PluginStore Author
PluginStore Author
Postby Trev » Mon Nov 23, 2009 9:45 am
spp.skp
Re thomthom's problem, this can never be solved, as the corner causing the problem has 4 edges/faces not three, so the program does not know which edge/face should be top priority. Only happens if lines meet at corner, as even a couple of pixels on one edge/face is enough to ascertain direction.
Hopefully the file returned altered will point this out better, one item prioritises the green face, the other the red. When the green is used, as seems to be happening when I tried it, you need to physically add a line to complete the edges/faces as shown in the blue faces in the diagram.
Hope this helps clear this up.
Trev. (total newbie)
Trev
Postby Trev » Mon Nov 23, 2009 9:50 am
By the way, forgot to say thanks for this great plugin, a4chitect.
Trev
Postby ken28875 » Mon Dec 28, 2009 10:22 pm
Awesome plugin, a4chitect.
Thank you very much! :sketchstatic:
Follow Your Dreams.
ken28875
Postby liveevil » Tue Dec 29, 2009 10:28 am
i like it....:fecstatic:
liveevil
Postby romain210 » Thu Dec 31, 2009 3:37 pm
that's realy cool
thanks a lot
romain210
Postby donpter » Fri Jan 01, 2010 5:58 am
thank you for your application!
donpter
Postby pilou » Wed Jan 13, 2010 5:01 pm
Use it and it's very brilliant :fro:
but a little remark :roll:
you call it "Smart Push Pull" but seems it's only "Smart Pull" or I miss something? :?:
Speedy Galerie
Top SketchUcator
Postby plot-paris » Thu Jan 14, 2010 11:09 am
well spottet, Pilou :D
plot-paris
Postby xrok1 » Sun Feb 07, 2010 12:18 am
is it possible to not leave internal faces with this plug??
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby thomthom » Fri Aug 13, 2010 9:20 am
I finally got around to use this plugin. Very nice.
Are you still developing it?
I noticed a couple of things:
1. It does not draw the input points
2. It does not invalidate the view when the tool is activated
PluginStore Author
PluginStore Author
Postby caleb_barclay » Thu Sep 23, 2010 11:14 pm
I love this script. It is perfect for roofs. I was wondering if there was anyway to enable it to "Snap" to a reference point. I have CAD drawings that I would like the extrusion to snap to.
caleb_barclay
Postby plot-paris » Mon Oct 11, 2010 6:18 am
thomthom wrote:Are you still developing it?d
indeed, a4chitect. do you intend to do some further work on this plugin?
plot-paris
PreviousNext
Return to Plugins
Users browsing this forum: dpaul, Nao Uematsu and 6 guests
