[Plugin] extrudeEdgesByLathe
Re: [Plugin] Lathe v1.1
Postby Ben Ritter » Wed Sep 16, 2009 7:07 pm
Ben Ritter
Postby TIG » Wed Sep 16, 2009 7:10 pm
Ben Ritter wrote:TIG,
That is the process I used, however, without having a short line to define the radius point.
In my attachment, you can see the result with and without a reference line for the radius point. The inference was indicating that I was going up in the blue axis direction, but I still got the result shown.
Thanks. Ben
Did the VCB say [0.0,0.0,1.0] - i.e. Z-axis... If you start off in the blue Z-direction and hold down the shift-key the interference is locked to blue and when you pick it should definitely be axial... You don't need the short line - I added it for clarity. You can start to move off in the blue direction, hold-down shift to lock in the blue and pick any point above the center and it should snap to vertical ?
Global Moderator
Postby Ben Ritter » Wed Sep 16, 2009 10:17 pm
The VCB doesn't say anything in the process, but the screen shows that I'm on the blue axis. For some reason, it only works when I lock down the inferencing with the shift key. Even though it says I'm pointing on the blue axis, somehow it must not lock on without holding the shift.
Thanks TIG
Ben Ritter
Postby Jim » Wed Sep 16, 2009 10:34 pm
TIG - thanks for another fine plugin.
report - not sure where you're getting the definition for round - Float.round does not take an argument.
Also, version 7 users would find a nice speed-up by modifying the start_operation statement:
model.start_operation("Lathe", true)
Code: Select all
Error: #<ArgumentError: wrong number of arguments(1 for 0)>
C:/Program Files/Google/Google SketchUp 7.1b3/Plugins/lathe1.1.rb:146:in `round'
C:/Program Files/Google/Google SketchUp 7.1b3/Plugins/lathe1.1.rb:146:in `onMouseMove'
Jim
Global Moderator
Postby simon le bon » Wed Sep 16, 2009 11:22 pm
HeyHey!
this time (V1.1) Lathe Tool is "carrément génial" :berserk:
++simon
simon le bon
Postby tomasz » Thu Sep 17, 2009 7:50 am
Tig, thanks for the plugin!
tomasz
SU2TH & SU2KT Developer
Postby TIG » Thu Sep 17, 2009 9:27 am
Jim wrote:TIG - thanks for another fine plugin.
Code: Select all
I'll add the version 7 speed up [forgotten during its speedy initial creation] and my float.round(n) does work for me !!! - although I don't know where I'm got that from [Edit: I grepped my rubies and found that 'Demeter.rb' and 'sunposition.rb' both redefine float.round(n=0) to take an argument [defaults to 0 if not set]]... I've written a similar method too float.roundup(n) to keep it separate... An update v1.2 will be issued shortly...
Global Moderator
Re: [Plugin] Lathe v1.2
Postby TIG » Thu Sep 17, 2009 9:47 am
v1.2 now available here viewtopic.php?p=184477#p184477
'Round' error fixed.
Operation optimized for v7 users.
Following Jim's comments... :geek:
Global Moderator
Postby RustyShack » Thu Sep 17, 2009 6:00 pm
Very nice to have this function as a pseudo-built in rather than the clunky workaround previously required to make lathed objects. Thanks!
RustyShack
Postby MALAISE » Fri Sep 18, 2009 4:33 pm
Wow ! Many thanks TIG.
SU becomes really powerfull when boosted with all theses plugins...
MALAISE :thumb:
MALAISE
Re: [Plugin] Lathe v1.3
Postby TIG » Fri Sep 18, 2009 6:16 pm
Here's v1.3 with Soft/Smooth Option in dialog
Global Moderator
Postby dedmin » Fri Sep 18, 2009 8:07 pm
:fecstatic: :sketchstatic: :berserk:
dedmin
Postby simon le bon » Fri Sep 18, 2009 10:24 pm
Lathe V1.3 *** more and more a true complement to FollowMe. I love this tool.
Unsoften ./. Soften ./. Soften+Smooth
:thumb: TIG,
simon
simon le bon
Re: [Plugin] Lathe v1.4
Postby TIG » Sat Sep 19, 2009 11:01 am
v1.4 now available - fixed inference-locking glitch on repeated lathes...
Global Moderator
Postby DIEGO-RODRIGUEZ » Sat Sep 19, 2009 1:42 pm
HI TIG, is a small BUG.
THANKS FOR THE PLUGINS
DIEGO-RODRIGUEZ
Banned
Postby Dan » Sat Sep 19, 2009 4:24 pm
TIG wrote:Version:
20090915 1.0 First issue
20090916 1.1 Pick cursor/inferencing improved, choose 'axis' added.
20090917 1.2 'Round' error fixed. Operation optimized for v7 users.
20090918 1.3 Soft/Smooth Edges option added.
20090919 1.4 Inference-locking glitch fixed on repeated lathes.
Tig, I'm tired trying to follow your daily updates... so I'll be waiting for a week to jump directly to "Lathe V 3.0" :D
Just kidding!
Awesome work, thank you again!
Dan
Postby xrok1 » Sat Sep 19, 2009 7:41 pm
very nice!
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Re: [Plugin] Lathe v1.5
Postby TIG » Sun Sep 20, 2009 8:19 pm
v1.5 available here viewtopic.php?p=184477#p184477
Smooth bug with Reverse Faces fixed.
Global Moderator
Postby cyan.archnet » Mon Sep 21, 2009 8:54 am
SUPERB Plugin indeed!, THANKS A LOT!
cyan.archnet
Postby jwlyon1 » Wed Sep 23, 2009 2:11 pm
ZOMG :o
This is fantastic!!
TIG, your plugins are amazing.
Added to my work flow and saved so much time!
Macbook Pro/ iMac
OSX 10.7.2 Sketchup 8
rogue-z is here!
jwlyon1
Postby Ruturaj » Thu Sep 24, 2009 2:10 am
This tool are very nice tool
Good Job
please sketchup " boolean " rb or plugin
:sketchstatic: :enlight:
Thanks,
RuturaJ
Ruturaj
Postby Gaieus » Thu Sep 24, 2009 10:48 am
Hi Ruturaj
Oscarlok released a boolen plugin (which is free) however it has stuck in its beta version and does not always work as expected:
viewtopic.php?f=180&t=14773
Postby mitcorb » Thu Sep 24, 2009 3:05 pm
There is also BoolTools on Smustard. Commercial plugin.
mitcorb
Top SketchUcator
Re: [Plugin] Lathe v1.6
Postby TIG » Thu Sep 24, 2009 11:18 pm
Here's v1.6 viewtopic.php?p=184477#p184477
Removal of Coplanar Edges now Optional. Superfluous face removal improved. :ugeek:
Global Moderator
Postby mariocha » Tue Sep 29, 2009 11:04 pm
Hey I like this plugins a lot !
How many times did I have to trim the start and end of shapes done with Follow Me.
Btw, If you do not end up with a smooth shape even when asked for, just unhide Hidden Geometry, unsoften one edge and then soften it again. All edges are now smooth. :)
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby Blackpercula » Thu Oct 01, 2009 4:31 pm
Thanks... :P
Blackpercula
Postby justinbae » Sat Nov 07, 2009 8:54 am
ITS SIMPLY AMAZING!!!!
THANX!!!
justinbae
Re: [Plugin] extrudeEdgesByLathe v2.0
Postby TIG » Tue Jan 19, 2010 5:44 pm
Here's v2.0
With v2.0 it's been renamed as 'extrudeEdgesByLathe' - it's been deBabelized and appears on a combined Toolbar - 'Extrusion Tools', plus various minor tweaks...
Global Moderator
Postby Nixy_janus! » Wed Jan 20, 2010 7:00 am
thank you,i get so much help from you!
Nixy_janus!
Postby cmoreink » Wed Jan 20, 2010 7:43 am
Respect TIG! :D
by the way, any news on a new version of EEbR?
cmoreink
PreviousNext
Return to Plugins
Users browsing this forum: craigcampbell66, Nemopolymer, nguyenconghuan94, williamvj and 5 guests
