[Plugin] Sculpt Tools v 1.0...
Re: [Plugin] Sculpt Tools v 1.0 (23/07/09)
Postby mitcorb » Wed Dec 14, 2011 3:43 am
If you have downloaded the zip file and extracted it correctly, you should have a Folder [btm_Sculpt_Tools of 76.5kB] and a file [btm_Sculpt_Tools_Loader.rb] both located in your Sketchup 8 Plugins folder.
I am having trouble with Winzip in my Windows 7 machine, so I simply copy pasted these two items from my Sketchup 7 Plugins folder.
The attachment is a good faith attempt to show you it worked, but this is a Scene, not a screen capture, so I can't show you the icons toolbar. And it was very responsive. The mesh/grid was created on the top surface using the line tool and move/copy multiple in both x and y directions.
EDIT: My copy of Sk8 is not fully loaded with all of the plugins I have collected through Sk7. So, I am just guessing some other plugin you have may be interfering? maybe not? or it is the problem with your original download and deploy?
mitcorb
Top SketchUcator
Postby peter_shaw » Wed Dec 14, 2011 8:39 am
ok, i got it to work now! by deleting all my plugins and copying them again with a fresh download :)
peter_shaw
Postby irwanwr » Sat Dec 17, 2011 5:33 am
is this plugin still available to download and to use for current/latest SketchUp?
it seems good to help making curvy surface i think.
irwanwr
Postby JuanV.Soler » Mon Oct 22, 2012 11:29 am
I found this video which explains how to use the sculpt tools,
drawing first from scratch in sandtools that I never knew ¡
Though it is explained in Turkish, i think, it is clear enough .
Cheers
_,_)))_,_
JuanV.Soler
Postby naginarch » Fri May 17, 2013 3:56 am
This Plugin is great , thanks bro
naginarch
Postby Christmended » Sun Jan 05, 2014 12:11 pm
Cool plugin. Working in Sketcup 2013.
Thanks!!!!
Christmended
Postby SKYWAYS128 » Tue Jan 28, 2014 7:12 am
Got a bit of a problem using Sculpt Tools here, as I'm using Sketchup 8, which I've heard is supposedly incompatible with the plugin. After reading some earlier posts, it seems that I have to uninstall all my plugins and then reinstall them for Sculpt Tools to work.
Thing is, it loads just fine, but it does nothing when I select bulge/smooth/drag whatever. I tried left/right clicking and pressing the arrow keys. It does absolutely nothing.
Am I using it right, or do I have to uninstall and then reinstall my other plugins?
BTW, if I simply cut and pasted all my plugins from the Sketchup folder to a backup folder, installed Sculpt tools and then re-pasted the plugins back into Sketchup plugin folder, would that work?
Thanks in advance for any advice.
SKYWAYS128
Postby Sauronbloo » Mon Mar 24, 2014 9:45 pm
SKYWAYS128 wrote:Got a bit of a problem using Sculpt Tools here, as I'm using Sketchup 8, which I've heard is supposedly incompatible with the plugin. After reading some earlier posts, it seems that I have to uninstall all my plugins and then reinstall them for Sculpt Tools to work.
I have the same issue in SU2014, is this plugin outdated now? The only other free sculpt tool I can find seems to only work with pro (DM_artisan). It seems quite hard to browse the plugin wh, as people may use different terms, languages, or even misspellings to classify their work. Can anyone point me to a plugin that is similar, or how to get this to work with SU 2013 or (preferably) 2014? thx
Sauronbloo
Postby Jim » Mon Mar 24, 2014 10:37 pm
I would say it is outdated. Last updated in 2009, and the author hasn't added to this thread since Oct 2010.
Has anyone tried to contact the the author?
Jim
Global Moderator
Postby Sauronbloo » Mon Mar 31, 2014 7:48 pm
Jim wrote:I would say it is outdated. Last updated in 2009, and the author hasn't added to this thread since Oct 2010.
So, what does everyone use to sculpt? I need to make a bush/hedge. I don't want it to be all boxy, what can I use?
Sauronbloo
Postby mitcorb » Tue Apr 01, 2014 12:23 am
Many use Artisan by whaat, or ThomThom's Vertex Tools. These are both very reasonably priced, and, I think Artisan has a demo offer.
mitcorb
Top SketchUcator
Postby Sauronbloo » Tue Apr 01, 2014 5:51 pm
mitcorb wrote:Many use Artisan by whaat, or ThomThom's Vertex Tools. These are both very reasonably priced, and, I think Artisan has a demo offer.
TT's vertex has a trial, thx. Waanna learn how to use these things, and see if they will work for me/my project before paying $40, and I had problems getting artisan to do anything, it just stayed grey like i had already used up the trial. I'm gonna try Vertex tools, which I had no idea were similar to artisan
Sauronbloo
Postby Sauronbloo » Tue Apr 01, 2014 7:37 pm
While looking for directions on the use of vertex tools, I realized that the sandbox tools seem to be at least a minimal version for doing this type of work. Anyone like me, that didn't know this, use the free and native tool by enabling it in window/preferences/extensions, then enable the toolbar in view.
Sauronbloo
Postby mitcorb » Wed Apr 02, 2014 3:05 am
The Sandbox tools work only in the Z direction. But you can do your "sculpting" on the ground group, then tilt it up when you need to.
mitcorb
Top SketchUcator
Postby bwantedstar » Thu Jul 31, 2014 11:10 am
the Sculpt Tools plugin is in .rb, but sketchup pro can't install it. It seems that I can only install .rbz...
Can anyone teach me how to install .rb file in sketch up pro? Thanks a lot!
bwantedstar
Postby Bep » Thu Jul 31, 2014 1:03 pm
bwantedstar wrote:the Sculpt Tools plugin is in .rb, but sketchup pro can't install it. It seems that I can only install .rbz...
Change the .zip extension into .rbz ,then install it
"History is written by the winners"
Bep
Postby bwantedstar » Fri Aug 01, 2014 4:38 pm
Installed successfully!! Thank you very much!! :sketchstatic:
bwantedstar
Postby free agent » Mon Nov 17, 2014 12:35 pm
Does anyone know if there is a script that works like the smooth tool in this, almost like a relax brush? i use this alot but its non responsive in 2015 :(
free agent
Postby Box » Mon Nov 17, 2014 12:52 pm
Artisan
Not free but well worth the money.
http://sketchucation.com/plugin/828-dm_artisan
Postby free agent » Mon Nov 17, 2014 1:14 pm
Thanx
free agent
Postby free agent » Mon Nov 17, 2014 1:46 pm
checking artisan it only seems to have a relax selection function is it possible for anyone who is savy with ruby script to pull the smooth brush out of this set and make it available for 2015??
free agent
Postby free agent » Tue Jun 02, 2015 6:12 pm
will this plugin ever be updated for 2014?
free agent
Postby TIG » Tue Jun 02, 2015 6:23 pm
free agent wrote:will this plugin ever be updated for 2014?
Almost certainly NOT :(
Global Moderator
Postby free agent » Tue Jun 02, 2015 6:40 pm
poo, is there any way to get the relax brush out? i do a lot of site work and it super helpful for fixing ugly meshes :(
free agent
Postby thomthom » Tue Jun 02, 2015 6:44 pm
There is no license attached to this which allows anyone to extract or reuse any code.
You might try to contacting the author directly via email and ask if he'd be willing to open source it.
Short of that... grab a copy of SU2013 Make.
PluginStore Author
PluginStore Author
Postby TIG » Tue Jun 02, 2015 6:53 pm
What function includes this 'Relax Brush' ?
There are several candidates...
Global Moderator
Postby free agent » Tue Jun 02, 2015 7:02 pm
In the initial post by BTM he seems to give permission for alteration/fixes.
the specific tool i want is the smooth brush, which works very much like the 3ds max relax brush, essentially just averaging out the distance between vertices to variable strengths.
free agent
Postby pbacot » Tue Jun 02, 2015 7:22 pm
What's the difference from Artisan sculpt smooth setting?
Top SketchUcator
Re: [Plugin] Sculpt Tools v 1.0...
Postby TIG » Tue Jun 02, 2015 7:32 pm
I looked at the code and it was a simple fix to make its loader >= v2014 compatible...
The updated version is in the PluginStore
Download
Although I suspect after six years there will be more up to date / better Plugins - like 'Artisan' ...
Please test and report back I have NOT tested it intensively :o
Global Moderator
Postby free agent » Wed Jun 03, 2015 4:11 am
TIG you are awesome, i actually meant 2015, but loaded it and still works, thank you so much!!
free agent
PreviousNext
Return to Plugins
Users browsing this forum: goodwani, Halim Bilgin, riteshpandu and 16 guests
