[Plugin] RoundCorner - v3.3a - 18 Dec 18
Re: [Plugin] RoundCorner - v2.6a - 27 Nov 13
Postby frankflafy » Fri Feb 28, 2014 6:44 pm
is it compatible with su2014? im trying and still get error.
frankflafy
Postby Dave R » Sat Mar 01, 2014 12:14 pm
frankflafy wrote:is it compatible with su2014? im trying and still get error.
Round Corner is indeed compatible with SU2014. What error do you get? Just saying you get an error is useless.
Make sure you've installed the current version of Round Corner AND Libfredo6.
Global Moderator
Postby frankflafy » Sat Mar 01, 2014 7:18 pm
sorry i just copy paste old plugins to a new plugins folder. and i got screwed.
but it fixed. thanx community.
frankflafy
Postby Dave R » Sat Mar 01, 2014 7:43 pm
Frank, it has been posted all over Sketchucation that copying and pasting plugins from an older installation is not advised.
Global Moderator
Postby keramare » Wed Mar 05, 2014 7:49 pm
THANX again
keramare
Postby Antonius43 » Sat Mar 15, 2014 10:20 am
Just do not understand, do I need to pay for this plugin to work? After following the instructions I cannot find the toolbar? What a waste!!!
Antonius43
Postby massimo » Sat Mar 15, 2014 1:20 pm
No.
What a waste!!!
Waste? this is a great and must have plugin and many people use it successfully.
Correct.
massimo
Postby pilou » Sat Mar 15, 2014 1:52 pm
Maybe you wil be more lucky with this!
Now there is a sort of integration of it inside Join PusPushPull Interactive!
Speedy Galerie
Top SketchUcator
Postby TIG » Sat Mar 15, 2014 2:01 pm
Antonius43 wrote:Just do not understand, do I need to pay for this plugin to work? After following the instructions I cannot find the toolbar? What a waste!!!
It is free to download, install and use [but of course you are free to donate to authors]...
If you have installed the Plugin properly [and how did you do that?]... then you might need to restart SketchUp and activate the it under Preferences > Extensions... and then activate its Toolbar...
Also having read the Plugin's installation instructions... you will be aware that you also need to have 'LibFredo' downloaded and installed to make this work [that's free too ;) ]
:roll:
Global Moderator
Postby synthkim1 » Tue Mar 25, 2014 8:31 am
Thank u so much,,,it's amazing
synthkim1
Postby ZRaupp » Fri Apr 04, 2014 6:01 pm
took me a few minutes to get it working, had to run Sketchup as administrator..
ZRaupp
Postby Dave R » Fri Apr 04, 2014 7:35 pm
ZRaupp wrote:took me a few minutes to get it working, had to run Sketchup as administrator..
Why? Where and how did you install the plugin?
Global Moderator
Postby ZRaupp » Fri Apr 04, 2014 9:53 pm
I installed plug-ins before i followed the steps and it works... .. ..
ZRaupp
Postby Dave R » Sat Apr 05, 2014 2:33 am
Whatever works, I guess, but you didn't really answer the question.
You shouldn't have to run SketchUp 2014 as administrator to get plugins to work unless you aren't installing them in the correct location.
Global Moderator
Postby ZRaupp » Sat Apr 05, 2014 4:00 pm
Dave R wrote:Whatever works, I guess, but you didn't really answer the question.
There is only one place to install plugins and its in the plugins folder ...
ZRaupp
Postby bsusala » Sun Apr 06, 2014 10:54 pm
Hi Fredo, folks, thanks for this very useful plugin.
I am asking from a rendering perspective. And woodworking, where straight rectangular edges are very common.
- would RC in a future version work on multiple groups selection? For a furniture piece with many parts, that would be a real time-saver.
- would RC in a future version allow for native undo-ing (not SU's undo) Maybe even with some form of Ghost integration.
bsusala
Postby gizmotoy » Mon Apr 21, 2014 12:12 am
Has anyone else had trouble with edges of planes that have had RoundCorner applied? I have a model that I unfortunately need to temporarily undo the rounded corner in order to make other modifications to the plane. I thought it would be as easy at re-drawing the corner and using Push/Pull to apply that across the whole edge, but Sketchup refuses to redraw the corner correctly.
Take the following images, for example. Here I attempt to use the rectangle tool to create a nice new corner. However, as soon as I click to create the rectangle, the lines I need are distorted. The same occurs if I create guides and use simple lines. It appears to be impossible to redraw the corner!
Any ideas on what I can do?
gizmotoy
Postby Dave R » Mon Apr 21, 2014 10:23 am
I've seen this sort of thing before but it has nothing specifically to do with this plugin. The same sort of thing might happen if you use a simple arc to do the roundover. This must be a pretty tiny radius corner and it appears you are running up against SketchUp's tolerance settings. One option would be to scale the geometry up by a factor of 10 or 100 and proceed with what you're trying to do. The other would be to delete the curves at the end of the roundover and draw in the lines to complete the corner.
Global Moderator
Postby gizmotoy » Tue Apr 22, 2014 2:30 am
Dave R wrote:I've seen this sort of thing before but it has nothing specifically to do with this plugin. The same sort of thing might happen if you use a simple arc to do the roundover. This must be a pretty tiny radius corner and it appears you are running up against SketchUp's tolerance settings. One option would be to scale the geometry up by a factor of 10 or 100 and proceed with what you're trying to do. The other would be to delete the curves at the end of the roundover and draw in the lines to complete the corner.
Thank you. I had not considered that. I suppose I should have posted this elsewhere, then. It is a small part. Those planes are 1mm thick, and the corner has a radius of 0.25mm. I'll try scaling it up and back as suggested. Thanks again!
gizmotoy
Postby n8mills » Sun Apr 27, 2014 1:05 am
Pretty interesting, but for all the effort to create a login here, download the library, the plugin and install manually I find that I am getting this kind of thing over and over
Not a single rounded corner. It probably needs some auto-detection of the commonly desired parameters. My concern is that when the shortcut is more work than learning to do it myself then it is not worthwhile.
I'll be uninstalling now.
n8mills
Postby Dave R » Sun Apr 27, 2014 6:18 pm
It works fine if you use it correctly. Unfortunately there's no plugin to read your mind to know what radius you want for the roundovers. You have to enter them manually in the box provided. A few moments actually learning how to use the tool would go a long way. Too bad you can't be bothered to learn how to use it. :roll:
Global Moderator
Postby bsusala » Sun Apr 27, 2014 8:13 pm
Sorry n8, lots of people are using it just fine. For the sake of receiving something worth hundreds of hours (= a free useful plugin), at least don't be an *&#%hole. A thankyou must be more appropiate. And some apologies, btw.
bsusala
Postby bjlinville1 » Wed Apr 30, 2014 12:04 am
Amazing plug in! Thanks so much to the creators! I've run into a snag and have spent to much time failing to figure it out myself, so I thought I'd just come here and ask for help. Could someone demonstrate how to round the corners on this model, or direct me to a tutorial that can show me how? https://3dwarehouse.sketchup.com/model. ... 35b062aca7
I want to put a .25" Radius on a .75" thick piece of plywood (we have small children and need very smooth edges!) and every time I run the plug in, both the rounded corners and the pointed ends of curves come out with incongruous faces. Its very likely that others have already solved this problem, but I haven't found it anywhere. If so, by all means just post a link to the forum or video and I'll check it out. Thanks for your help, and Thank you so much for this plug in!
bjlinville1
Postby Dave R » Wed Apr 30, 2014 10:32 am
How many segments are you using for the rounding? You might find it better to take care of the points in one step and rounding the edges in another. Also, I would scale the component up by a factor of 100 or 1000 and do the rounding on it there. I expect you'll get cleaner results. If the radius of the round over is greater than the radius of the "corner" you're going around, you'll have problems too. You might want to think about that with the point at the end of the loop and the sharp corners on the insides. You'd have a similar problem rounding over that corner with a router in real material, too, though.
Before you get to rounding, though, do you really want these curves as you've drawn them? The curves aren't tangent to their neighbors. that might create some problems when it comes time to cut this thing out for real. There are more of these spots than the few I indicated.
Another thing you might find helpful is to weld some of the edges together.
Global Moderator
Postby sophia2662 » Wed Apr 30, 2014 3:07 pm
i cant download the ROUNDCORNER.
sophia2662
Postby Dave R » Wed Apr 30, 2014 3:49 pm
Why not? How are you trying to download it? If you want some help you have to give us some useful information. Make it possible for us to help you.
Global Moderator
Postby PapaBear60 » Mon May 19, 2014 3:29 pm
I love Sketchup - well, did love it. But I'm finding that it's not wise to upgrade every time a new version comes out. Take these extensions, for example. I went to SU14 and now can't for the life of me figure out how to install (or even if I can install) this extension. For me, SU14 is pretty useless without it. I can't even find the Plugins root directory in SU14. What gives?
PapaBear60
Postby Dave R » Mon May 19, 2014 3:51 pm
There's plenty written about installing plugins in SU2014 and it doesn't take much to find it.
If you download the rbz file from the first post in this thread, you can use Install Extension under Preferences>Extensions to install it automatically. Or you could install the Sketchucation Plugin Store using Install Extension (there's even a video to show you how to install it) and then download and install the plugin from there. In either case the files will get installed correctly into the proper location. Make sure you also get the current LibFredo6 files installed, too.
Don't just copy files from your old Plugins directory to the one for SU2014. That's a sure way to create a headache.
Global Moderator
Postby eddybo » Fri Jul 11, 2014 7:58 pm
First of all, thanks for the cool plugin!
I'm running into what I would think is a fairly common problem though: RoundCorner seems to "destroy" any concave insets I create. Instead of trying to explain in words I've created a 2 minute video which demonstrates an easy way for me to reproduce the problem.
https://www.youtube.com/watch?v=Y7IlbQF ... e=youtu.be
Any ideas or help would be appreciated!
Thanks,
Eddy
eddybo
Postby massimo » Fri Jul 11, 2014 8:22 pm
That is a well known behaviour. At the end, pick the select tool and just click on the created surface where you should have a hole and press del.
massimo
PreviousNext
Return to Plugins
Users browsing this forum: ddar, Fino Bahru, nicvall, SIIX, snella, vamoshacer3d and 11 guests
