[Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
Postby sepo » Fri May 15, 2009 5:46 pm
Hmmm... I am getting Bugsplat on anything with loft tool... To be precise I draw arc (12 segments) I draw second arc (12 segments) I press loft select both arcs, hit enter choose 5 grom GUI. press OK ....bugsplat. SU7...will try now on SU6.
sepo
Postby sepo » Fri May 15, 2009 5:59 pm
Interesting...it works no problem on SU6 with 2 or more arcs.
sepo
Postby Chris Fullmer » Fri May 15, 2009 6:00 pm
@dtrarch - Lofting 3 equal arcs in SUv6 gives bug splats? But 2 equal arcs do not, correct? Could you post a model that splats?
I'll look into it and I have a pretty good idea where in the code to start looking. I can't think of anything I've done that should splat though. Oh well, I'll try to check it out.
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby sepo » Fri May 15, 2009 6:03 pm
If you are refering to my case ....they had only same number of segments but not same curves.
sepo
Postby Chris Fullmer » Fri May 15, 2009 6:05 pm
Bummer Sepo, your getting splats on any loft in v7?
Could you attach a file with shapes that splat? I'm not sure if this is a script conflict splat or if you guys are using it in ways that never crossed my mind (like with shape bender, I'm amazed at what people make that script do!).
So perhaps attach some example models and I'll take a look. Thanks!
Chris
EDIT: Sorry, in that previous post I was answering dtrarch - I'll edit it to make it more clear.
SketchUp Team
SketchUp Team
Postby watkins » Fri May 15, 2009 6:08 pm
Dear Chris,
I cannot seem to get your plugin to work. The loft icon appears in my toolbar, and seems to work: it changes when selected and allows the selection of the two curves (simple arcs with the same number of segments), but then nothing. I even tried exploding the arcs, but still nothing.
As usual, I put the simple_loft folder and loader in my plugin folder. Is it possible that one of my other plugins is causing a problem? I have tried your plugin on two different computers (home laptop and office desktop), but with the same result. Both have the same plugins. Curious.
Kind regards,
Bob
watkins
Postby sepo » Fri May 15, 2009 6:09 pm
This is console . I start loft and have this
--> New Definition Added:
--> 0
--> nil
I select arcs,press ok in GUI have this for 1 second
--> 0
--> nil
and than bugsplat....now this happens in SU7 even with simple curves.
sepo
Postby watkins » Fri May 15, 2009 6:16 pm
Dear Chris,
I do apolgise. I had a senior moment, or to be more precise, I failed to read your instructions to the end. Hit ENTER was the missing step. Seems to work just fine now.
Kind regards,
Bob
watkins
Postby Click Draw » Fri May 15, 2009 6:21 pm
Hey Chris,
Been playin' a bit...so far no probs. I'm on SU7 Pro, Vista if that helps.
Jeff
Have I mentioned how much of a laugh I get out of some of the Signatures on here!
Click Draw
Postby dtrarch » Fri May 15, 2009 6:26 pm
Chris
I checked V6 with only loft installed.
It is bumping into another script or ?
The same script set is on V7 and loft is OK there.??
BTW the number of arcs 2-whatever still bombed.
Dave
dtrarch
Premium Member
Premium Member
Postby watkins » Fri May 15, 2009 6:36 pm
Made using simple_loft
watkins
Postby kwistenbiebel » Fri May 15, 2009 6:39 pm
Hi Chris,
You and Fredo can have the Nobel Prize, whatever the category.
Marvelous in all ways !!! :thumb:
Google, eat your heart out (again)!
kwistenbiebel
Postby sepo » Fri May 15, 2009 6:39 pm
Quite bizzare. On Vista comp SU7 works fine but not on XP SU7, However on same XP SU6 it works. I will now try on my XP laptop.
sepo
Postby Chris Fullmer » Fri May 15, 2009 6:59 pm
Sepo, your issue to me looks very much like an observers problem - specifically a collision with another script that is watching the selection set being added to. I'm sorry for the hassle, but you might need to remove plugins a few at a time until you find the culprit.
@Bob, glad you found the problem. That was going to be my suggesion, but I'm glad you got it working! The bowl looks great. I'm guessing you made it using half circles and then combined them together? Very nice!
@Dave, weird that it is splatting on version 6. You tried it with nothing else installed? Are you on Vista? Is there a chance you have any hidden plugins in the compatibility folders? That has ruined my scripts for more than one person already....grrr. Could you open the Ruby console (Window>Ruby Console) and see if you are getting any notices in there when running the script?
@Jeff, thanks! Glad to hear its working good for someone.
I really don't know whats causing some of these splats. We'll keep trying to troubleshoot it.
Thanks for the feedback,
Chris
SketchUp Team
SketchUp Team
Postby sepo » Fri May 15, 2009 7:35 pm
OK good news is it works on my laptop on both SU7 and SU6.
On my other XP I found culprit. It is tt_double_cut.rb.... As soon as I removed it(as this was only one which was not on all comps) loft started to work.
I know Tom's script is only alpha but it seems to clash with yours.
sepo
Postby Chris Fullmer » Fri May 15, 2009 7:38 pm
Heehe, Thom is really digging deep into observers in that script. I'll PM him and let him know that he's got a leak. Thanks for taking the time to find it Sepo!
Chris
SketchUp Team
SketchUp Team
Postby sepo » Fri May 15, 2009 7:50 pm
Is it possible to make circles or elipses to be lofted?
sepo
Postby Chris Fullmer » Fri May 15, 2009 8:02 pm
Not yet. I started with open splines only. I have to rethink some pieces of the script to get closed splines to work.
Chris
SketchUp Team
SketchUp Team
Postby sepo » Fri May 15, 2009 8:07 pm
Sounds promissing....Thanks for the script...It looks like there is a less and less reason to leave SU...
sepo
Postby AcesHigh » Fri May 15, 2009 8:45 pm
sepo wrote:Is it possible to make circles or elipses to be lofted?
so far, it seems the best option is to create two halfs of the closed loop you want (be it a circle, elipse or anything else). Than you loft and join them.
If you want to loft a circle to a line, MAYBE its possible to cut the circle in two. Then you loft half the circle to the line, and then you loft the other half of the circle to the same line. Then you join the two sides.
AcesHigh
Postby jmmad » Fri May 15, 2009 9:04 pm
Well i was thinking about leaving SU and one of those reasons where no loft support.
Until now.
You are really making Great Plugins you are very generous an talented man.
Thxs a lot Chris.
Get Upa !
jmmad
Postby ely862me » Fri May 15, 2009 9:24 pm
This is something that can improve my workflow ..Thanks a lot,for a well done job,Chris.. :thumb:
Elisei
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
ely862me
Top SketchUcator
Postby thomthom » Fri May 15, 2009 9:24 pm
sepo wrote:OK good news is it works on my laptop on both SU7 and SU6.
Double-cut should not be used in a production environment. It makes SU unstable, liable to bug-splats and interferes with the observer events. It will need major rebuilding to make it work, so I won't be looking to track down bugs in in the alpha. It is in it's current state FUBAR. I need to get my thinking-cap on first before I start on re-writing it. (I also need a minor break from it as well as my frustration level increases just by looking at it as it is now :( )
Sorry for the inconvenience.
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Fri May 15, 2009 9:41 pm
Sorry to hear it Thom, its a plugin with a lot of potential. Hopefully the observers situation will get worked out and stabilized in future releases.
Good luck with it when you feel like getting back to it!
Chris
SketchUp Team
SketchUp Team
Postby moujiik » Fri May 15, 2009 9:46 pm
Hi Chris, and all the others (my first post)
I find the first version of your script (0.1a) is realy a good start. The loft tool in moi 3d have the same result with two curves. The bezier connection seems only necessary with tree or more curves. It makes a smooth connection between curves. Anyway. This is the tool missing in sketchup. How brave you are! Thank you for your script, and all of you who keep sketchup fascinating.
Moujiik.
moujiik
Postby Chris Fullmer » Fri May 15, 2009 9:53 pm
Hey moujiik, that is a great image that clearly shows what I was asking about. Indeed it just makes straight connections from point to point with only 2 splines. Its not until you add a 3rd spline that it starts to use a bezier connection.
In the current version, I faked in a bezier curve even on 2 curves, and I think I'll leave it in place. Partially because I've also now added the ability to control the amount of curve. So if a user selects just 2 splines and wabts the straight straight connections, with multiple segments, it will be possible in the next version I release.
Thanks for the image and the kind words!
Chris
SketchUp Team
SketchUp Team
Postby dtrarch » Fri May 15, 2009 9:58 pm
Chris
It was DoubleCut all right. :enlight:
Dave
dtrarch
Premium Member
Premium Member
Postby AcesHigh » Fri May 15, 2009 10:40 pm
I think this may already be enough to allow me to create my uplifted neo-dolphin suit!
AcesHigh
Postby watkins » Fri May 15, 2009 10:53 pm
Dear Chris,
What I actually did to get the bowl was to:
* start with a circle about the origin, and on the X-Y plane
* explode the circle
* delete one segment
* move and copy the modified circle in the Z direction
* scale the upper circle about its centre
* use simple_loft
* stitch the open part using the line tool
Regards,
Bob
watkins
Postby watkins » Fri May 15, 2009 11:21 pm
What happens if one tries to use two half circles to create a bowl (see image). The edges are not suitable for joining.
watkins
PreviousNext
Return to Plugins
Users browsing this forum: ming740418, OcielDiblain, Sol_moses and 7 guests
