[Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
Postby JClements » Fri Jul 03, 2009 4:59 pm
Daniel, you should create a dozen or so sets of "face profiles" (ie., adult male, adult female, baby, skinny face, fat face, etc.). Combine that with human head face photos (different colored hair, facial hair, makeup, different skin tones..) which then could be projected or mapped onto a lofted surface by the user or maybe done via another script. The user could mix and match. Heck, do the same for torsos.
You and Chris could market this as "Doll Builder". Perhaps gamers would buy it in droves. :enlight:
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
Postby gilles » Wed Jul 08, 2009 9:45 am
Hi Chris, I work on a Mac when I start SU6 I can read this
undefined method `select_tool' for nil:NilClassError Loading File clf_simple_loft_loader.rb
, and your plugin does not appears.
I have some other of your plugins working well, what could be wrong?
gilles
Top SketchUcator
Postby Chris Fullmer » Wed Jul 08, 2009 4:58 pm
Hi Gilles, I am not sure what the problem is. But the first thing that normally goes wrong is:
All the "splines" you use need to have the same segment count. So if the first has 10 segments, all the others also need 10. And so on. I realize its a pain, sorry. I have a fix in the works, but I have been unable to get it ready to post.
Also, the edges selected must not be connected to any faces.
If none of that works, you could also upload the model that you are trying to use it on and I'll look at it to see if I can see what is wrong. Thanks for trying it out!
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby gilles » Fri Jul 10, 2009 11:40 am
the problem is that the plugin does not appears in Chris Fullmer Tools.
I'd like to know if other mac user have the same issue.
gilles
Top SketchUcator
Postby Fletch » Fri Jul 10, 2009 1:39 pm
Thanks Chris! Looks lovely - can't wait to try it. Just for filling in the gaps in places, or for curtains as you showed. Should be handy.
Fletch
Twilight Render
Postby simon le bon » Mon Jul 13, 2009 2:31 pm
Dear Chris,
I take account of this Simple Loft for the first time. Wahoo! :berserk: it is totally amazing: I love it!!! and will love it even much more in plenty of my futur works.
How are we going to call you: Master Chris; Dear Honoured Master Chris; Fullmeinstein ???
8-)
But we know your simplicity and kindness so we'll continue to call you "Dear friendly Chris" :thumb:
+++ :followme: simonlebon
simon le bon
Postby pnorwood13 » Tue Jul 14, 2009 6:41 am
I love the loft tool, but is there any way of giving lofted items depth? I design furniture and use the loft tool for creating complex chair backs. While loft gives me the contours I am looking for, it doesn't give me the thickness I am looking for.
Paul
pnorwood13
Postby watkins » Tue Jul 14, 2009 8:05 am
Dear Paul,
As a simple workaround, select the created surface and then copy and move. Stitch the edges to create the 'solid' surface.
Regards,
Bob
watkins
Postby Jean-Franco » Tue Jul 14, 2009 8:11 am
What watkins said +1
You can maybe also try with JointPushPull plugin from the first surface created with Simple Loft ?
Jean-Franco
Jean-Franco
Postby jamalito » Mon Jul 20, 2009 3:01 pm
wow :berserk: wow :berserk: wow
thatnk you bro to this pulg fprm long time I looking for about like this pulg
this winderful and your Tutorial is amazing
thank you again
:fecstatic:
Albert Einstein:
((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
jamalito
Postby markozeta » Mon Aug 03, 2009 9:58 pm
I don't understand why closed shapes wouldn't work...
Three Surfaces
Except for the 3 surfaces. Which - is kinda cool.
Mark
BSME - Cal Poly Pomona
Sketchup Pipe Maniac
markozeta
Postby Chris Fullmer » Tue Aug 04, 2009 12:02 am
Heh, the only reason closed loops don't work is because how I programmed it. I need to determine a starting point, and then determine how to align the splines so that they will be connected efficiently. At the time, the best way I could think to get the script to work efficiently was to just use an endpoint, then match it up to its enarest endpoint in the next spline, and connect them like that.
I think I have it worked out how to do it better for the next round. Unfortunately, life has taken over and I am extremely busy with trying to secure a job, move my family, etc, etc.
But, hopefully sometime in the future I'll get back into my scripts and re-write them. This one is high on my list to get back to fixing up. Its a bit lame right now. Its sort of cool, but not really useful with all its eccentricities like no closed loops, splines have to have equal segments, etc. I'll get it working better in time...
Chris
SketchUp Team
SketchUp Team
Postby mitcorb » Mon Aug 10, 2009 1:45 pm
Hi, Chris:
I know you are busy.
This is just a heads up. Loft is not working at this time for me. Of course, I have acquired additional plugins since this one.
This is the Error message in the Ruby Console:
Error: #<NoMethodError: undefined method `all_connected' for nil:NilClass>
C:/Program Files/Google/Google SketchUp 6/Plugins/clf_simple_loft/clf_simple_loft.rb:61:in `onLButtonUp'
I saw somewhere, you mentioned that Progressbar seems to be the common factor.
Best Regards,
mitcorb
mitcorb
Top SketchUcator
Postby david_h » Mon Aug 10, 2009 4:42 pm
Another Great tool Chris. Thanks so much! It's . . .dare I say it?? SUPER!
If I make it look easy. . .then it probably is.
david_h
Top SketchUcator
Postby iamarchitecture » Tue Aug 25, 2009 5:55 am
Just wondering if anyone has gotten this to work on SU7 Pro for Mac Version 10.5.7?
iamarchitecture
Postby Chris Fullmer » Tue Aug 25, 2009 6:13 am
I think it should work on a Mac Oscar. The #1 error is normally that you need to make sure that both lines have the same amount of segments. That and they can not be connected to any faces.
Its a bit picky on what it wants so that it will work.
If none of that helps, open the Ruby Console (Window > Ruby Console) and then try running the script. See if it sends any messages to the console. If it does, copy and paste them here and I'll see if I can get to the bottom of it,
Chris
SketchUp Team
SketchUp Team
Postby gilles » Wed Aug 26, 2009 9:51 am
iAMarchitecture wrote:Just wondering if anyone has gotten this to work on SU7 Pro for Mac Version 10.5.7?
I would like to know too, for me the plugin does not even appears.
SU6 OSX 4
gilles
Top SketchUcator
Postby Oaht » Wed Aug 26, 2009 12:53 pm
THANKS FOR YOUR SUPERB RUBY!!!
Oaht
Postby honoluludesktop » Sat Sep 12, 2009 4:16 am
Great tool. I made the attached drapery (left side of fixture), an improvement over the previous ones (right side, and left of new drapery material) as I was able to pinch the row below the top (as it commonly is), and have the folds fall naturally. Thanks Chris.
Sorry about the dark render, didn't want to spend the time adjusting the lights. Anyone know if there is away to edit this surface? Can it be exploded?
honoluludesktop
In Remembrance
Postby Archibum » Fri Oct 16, 2009 12:42 am
This tool is amazing. Definitely helped on some of my school projects. I do have one problem and dont know if its the tool or the system.
So I am on a mac. Leopard updated and all that.
I noticed that on starting sketchup, the red dot in the corner would indicate that the file had not yet been saved. Usually, this only happens when you actually start drawing. So, i removed all my plugins, downloaded sketchup fresh, and went back and added the plugins again one at a time. Found out that it was this tool that was causing sketchup to think that the file needed to be saved, even if nothing had been drawn. This wouldnt be a problem as i could just click "dont save," but doing that caused sketchup to crash every time.
So thats my dilemma. Does it make sense? Am i the only one with this problem?
Archibum
Postby Chris Fullmer » Fri Oct 16, 2009 1:38 am
That is very interesting Kyle. I'll have to look into it. Does anyone else see this?
Chris
SketchUp Team
SketchUp Team
Postby agamemnus » Sat Oct 17, 2009 9:31 pm
I'm trying to use this tool to create a valley curve-- a cross between a bell and an oval. I am having a problem using this tool with closed loops. =(
I did it manually but it was annoying.
agamemnus
Postby Chris Fullmer » Sun Oct 18, 2009 12:51 am
Hi, the script does not work with closed loops. Sorry about that.
And think how much more annoying it would have been to connect those shapes if the script didn't exist at all :)
Chris
SketchUp Team
SketchUp Team
Postby agamemnus » Wed Oct 21, 2009 7:23 am
Chris Fullmer wrote:Hi, the script does not work with closed loops. Sorry about that.
Chris
I did try to split up the loops but I couldn't get an even split... I had to do it manually!!
Actually, I think I could possibly use a different tool but I am not sure what it would be exactly. I had two circles. The bottom and smaller circle already had a quarter sphere inverted and oval in shape that I would later attach to it. The top circle would be attached to a flat surface. The object is to have a smooth transition between the two.
What I did is made a Bezier curve from one segment (on the big circle) to another (on the small circle) (with a perpendicular slant to the blue axis).. there were 24 segments, so I cut out a quarter from the circles. I copied the curve 5 times, then changed the angle and resized so that each curve start/end matched the smaller (and lower) /bigger (and higher) circle. Then it was just a matter of exploding the Bezier curves and drawing lines between them, forming rectangles of various inclines. I then copied this thing 4 times and hid the line segments with smoothing.
Your tool is pretty good but there is no way to specify exactly what type of curve I want... that would be troublesome for anything but a symmetrical spherical or oval shape, though!
I have a suspicious feeling I could have just used the follow-me tool and then stretched the result, though. :lol:
agamemnus
Postby Fletch » Wed Oct 21, 2009 2:02 pm
sandbox tools work on closed curves. :| :?
Fletch
Twilight Render
Postby kwistenbiebel » Sat Oct 31, 2009 6:09 am
Hi Chris,
I am experiencing trouble using your nice Loft plugin.
Below, I attached what is happening. I am trying to connect two closed curves to form a solid. I was hoping the loft tool would connect the points of the two curves with 'the smallest distance between points' as if it was a tensile structure.
Unfortunately I get an error.
First I thought I needed to do this with the soap skin bubble plugin, but that doesn't seem to work.
Any help would be welcome.
[Edit]: the blend.rb seems to 'almost' do this, although it connects existing points on the curves one after the other. That means it generates unwanted diagonals.
I think I would need a loft tool or 'skin tool'for it, as that would work independantly from the location of the control points on the curve and makes a skin (= by smallest distance between curves).....It seems though that the skin.rb is not being further developed.
kwistenbiebel
Postby kwistenbiebel » Sat Oct 31, 2009 7:35 am
This is what the blend.rb spits out (starting curves are slightly different than above).
It looks ok, but I am not sure if the newly generated blend surface follows the shortest distance between the two polylines.
I would like to see it connected independant from the curve's existing control points (skin?) .Does that make sense?
kwistenbiebel
Postby massimo » Sat Oct 31, 2009 8:03 am
Kwist, I think that skin.rb could do the job. I use the 2.2 version which, in my opinion, is the best.
massimo
Postby kwistenbiebel » Sat Oct 31, 2009 9:07 am
Thanks Massimo,
I already have the skin22 in my plugins folder but somehow it never worked. I enabled it in the Preferences panel...but the skin ruby never appeared as icons nor in the tools/plugins menu. A lot of people seem to have trouble with it.
kwistenbiebel
Postby massimo » Sat Oct 31, 2009 10:01 am
Hmmm, that's strange. I have it disabled in the preferences>extentions panel, but the icons are there and the plugin works fine!
massimo
PreviousNext
Return to Plugins
Users browsing this forum: black_hope, naynont004 and 13 guests
