[Plugin] HoverSelect - v1.5a - 07 Oct 17
Re: [Plugin] HoverSelect - v1.1d - 26 Nov 09
Postby irwanwr » Fri Dec 23, 2011 5:46 am
i'll try to learn and use this one too. IA.
thank you Fredo
irwanwr
Postby Swissmountain » Fri May 04, 2012 10:27 pm
Carrozza wrote:I have pretty much the same problems as Dereeei (see above): when I activate the plugin and click-hover on edges nothing get selected.
Hey Fredo, same problem over here on Mac OSX Snowleopard, Sketchup 8.0.11751 & LibFredo6 - v4.4m - 14 Apr 12
I see the menu but can't select anything, there is no selection rectangle either.
Thank you for everything you do
Ciao
Cogito ergo dum-di-dum
Swissmountain
Postby fredo6 » Sat May 05, 2012 5:31 pm
Does this problem happen only with HoverSelect or all my plugins?
If so, this may come from a conflict with some other plugins (like some versions of Podium and Matchbox)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Swissmountain » Tue May 08, 2012 10:58 pm
All your other plugins work like a charm on my machine Fredo, thank you for the update to the round corner and curviloft scripts earlier this year!
The hoverselect sounds like an amazing tool for speeding up more organic modeling approaches which require selection and scaling of splines, I would love to make it a part of my toolbox.
Swissmountain
Re: [Plugin] HoverSelect - v1.2a - 27 Nov 13
Postby fredo6 » Wed Nov 27, 2013 9:52 pm
NEW RELEASE: HoverSelect v1.2a - 27 Nov 13
HoverSelect 1.2a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] HoverSelect - v1.3a - 20 Oct 14
Postby fredo6 » Mon Oct 20, 2014 8:08 am
NEW RELEASE: HoverSelect v1.3a - 20 Oct 14
HoverSelect 1.3a is required for the support of usernames with non-ascii characters in Sketchup 2014.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby greatoe » Tue Nov 17, 2015 5:20 pm
Ciao
This issue still remains. Mac OSX El Capitan 10.11, Sketchup 2015.
greatoe
Re: [Plugin] HoverSelect - v1.4a - 13 Nov 15
Postby fredo6 » Tue Nov 17, 2015 10:45 pm
Could you open the Ruby Console to chcek if there is an error message displayed.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby greatoe » Wed Nov 18, 2015 4:32 pm
fredo6 wrote:Could you open the Ruby Console to chcek if there is an error message displayed.
Fredo
Nothing show up in the console.
greatoe
Postby rilian » Mon Apr 03, 2017 11:07 pm
Recently discovered this plugin. It installs and the menu items are there but I am not seeing the toolbar. It's turned on in the settings for the tool. I'm on SU 2017.
[edit] Clarification Note: It's not showing in the toolbars list nor displaying anything on the screen.
rilian
Postby Dave R » Tue Apr 04, 2017 12:03 am
rilian wrote:Recently discovered this plugin. It installs and the menu items are there but I am not seeing the toolbar. It's turned on in the settings for the tool. I'm on SU 2017.
Did you look for the icon in the Fredo6 Tools toolbar as indicated in the first post of this thread?
It shows up and works just fine for me in SU2017.
Global Moderator
Postby giuliosaoncella » Tue May 30, 2017 6:52 pm
Hi Fredo! I have just now the opportunity to use and appreciate this fantastic plugin... Is it possible to add a Face-HoverSelect mode? Let me try to explain: I often import model from other CAD formats converted in 3ds, so I have a faceted model, no any circle/rect/curve/etc. In order to create sub-groups and/or adding material/color specs to them, I need to select ANY single face one click by another: terrible. Using the selection rectangle, unwanted results occour... If I can hover-select faces, instead, I can group and color them quickly. Do You think You can add this function or maybe create a dedicated plugin?
Thank You very much and many, many, many compliments for your great works!!!
Giulio
giuliosaoncella
Postby fredo6 » Wed May 31, 2017 7:33 pm
giuliosaoncella wrote:Is it possible to add a Face-HoverSelect mode?
Not totally sure, but I think there exists some plugin doing that, possibly Thomthom's Selection Toys.
Maybe some other forum contributors know the options.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby db11 » Wed May 31, 2017 8:03 pm
greatoe wrote:This issue still remains. Mac OSX El Capitan 10.11, Sketchup 2015.
Same here: also Mac OSX El Capitan 10.11, SU Pro 2015. This is a plugin I would use a lot if it worked properly on Mac OS.
db11
Postby giuliosaoncella » Wed May 31, 2017 11:07 pm
Fredo
...no... I have tested many plugins (including thomthom selection toys): all performs either a "filter" or a "search", but no one acts like the eraser tool, which effectively is what I need... thanks anyway to You and to all the plugins developers: You made Sketchup special!!!
Giulio
giuliosaoncella
Re: [Plugin] HoverSelect - v1.5a - 07 Oct 17
Postby fredo6 » Sat Oct 07, 2017 10:37 am
NEW RELEASE: HoverSelect v1.5a - 07 Oct 17
HoverSelect 1.5a is a maintenance release:
  • required for the support of usernames with non-ascii characters.
  • Support of OSX High Sierra
  • Certified for SU2017
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Ahmed0007 » Sun Sep 30, 2018 11:10 pm
Follow mode not working
any solution?
Ahmed0007
Postby fredo6 » Mon Oct 01, 2018 11:40 am
Ahmed0007 wrote:Follow mode not working
any solution?
Can you clarify and explain what is the problem. Follow option works fine for me.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Ahmed0007 » Mon Oct 01, 2018 10:24 pm
any solution?
Fredo
it's select whole. even i set the limit
and please add "Stop at Edge Crossing"( <3 ) feature in hoverselect like in Curvizard.
Ahmed0007
Postby Ahmed0007 » Mon Oct 01, 2018 10:30 pm
try in sketchup 2015,17,18
here is one another Behavior that i don't understand
Ahmed0007
Postby Ahmed0007 » Fri Oct 05, 2018 1:15 am
any solution?
Fredo
hello! fredo6 can you see my above response?
Ahmed0007
Previous
Return to Plugins
Users browsing this forum: badnat62, Einstein, GB68, LuceSsk, Tenedra, thalyshemerson and 16 guests
