[Plugin Library] LibFredo6 - v11.6a - 23 Jan 21
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11
Postby mitcorb » Sat Nov 12, 2011 2:18 pm
In my experience, it may be that the page? loads too fast to pick up the zip, so you get a php temporary placeholder. So, what I have done is cancel the call, wait a short while, and try again until I see the .zip This has worked for me. If you are getting persistent php, then perhaps your security settings are too strong? I am not sure.
mitcorb
Top SketchUcator
Postby Dave R » Sat Nov 12, 2011 2:21 pm
On my MacBook Pro, zip files don't display an extension. The just look like a folder. In fact the icon is a folder. Perhaps you could eliminate the extension altogether. Installing the files consists of simply opening the folder, copying the contents and pasting them into Plugins.
Global Moderator
Postby n000bie » Mon Dec 19, 2011 4:51 am
Hi guys, this is my first time posting here but I got a problem that I'm not sure if that's already solved or not, still I've just installed the new LibFredo6 - v4.2a days ago and this is what I get whenever I start Sketchup :
And this is the how my Plugin folder looks like :
I'm using Sketchup 8.0.4811, via Windows 7. Can someone plz tell me what I do wrong or just how to fix this, I've been using Joint Push Pull, Round Corner and Tools On Surface for times and there's no problem until this.
Thnx alot. I always appreciate you and your works, Fredo6.
n000bie
Postby fredo6 » Mon Dec 19, 2011 8:16 am
Not sure if this will solve the problem, but you have a very old version of FredoScale, called FreeScale.
Could you remove:
- ZLoader__Freescale.rb
- FreeScale_dir_20 folder
Thanks.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby n000bie » Mon Dec 19, 2011 3:26 pm
My greatful thnx to you and your quick respond, problem solved :D . Looks like I have to update my Fredo Scale.
Thnx again, Fredo, you're the one. :thumb:
n000bie
Re: [Plugin Library] LibFredo6 - v4.3a - 19 Dec 11
Postby fredo6 » Tue Dec 20, 2011 7:22 pm
NEW RELEASE: LibFredo6 v4.3a - 19 Dec 11
LibFredo6 4.3 is a new release which essentially support the publishing of FredoTools suite of Plugins
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby tspco » Wed Dec 21, 2011 4:08 am
Don't know if this is a problem or not, just installed the 20dec11 update of fredo 6
tspco
Postby fredo6 » Wed Dec 21, 2011 9:44 am
tspco wrote:Don't know if this is a problem or not, just installed the 20dec11 update of fredo 6
These are binary files.
It is strange that your unzip utility (I guess 7-zip) tries to open them. It should not.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v4.3b - 22 Dec 11
Postby fredo6 » Thu Dec 22, 2011 11:52 pm
NEW RELEASE: LibFredo6 v4.3b - 22 Dec 11
Release 4.3b includes (on top of 4.3a)
  • a fix to the numeric buttons in Palettes (not visible in Curviloft)
  • the updated Spanish translation (thanks to Defisto)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby eyffel65girl » Fri Dec 30, 2011 12:56 pm
Fredo your plugin is awesome, but I can't use it! I run Skethcup Pro 7 on my Mac Book Pro. I've installed your plugin (LibFredo6 first, and then RoundCorner) following your detailed instructions; I thought it were an easy things to do, but they don't work! :cry:
Can you please help me?? I'll always be graitfull !!
eyffel65girl
Postby oldswinger » Sun Jan 01, 2012 9:44 pm
Dear Fredo
I have downloaded the first 4 plugins from your Plugin Library list "Libfredo6 v4.3b - 22Dec11 but cannot get any toolbar icons appearing when I open my SU8Pro programme.
I note your Important Paragraph about the downloading of LibFredo6 in respect of the appearance of the plugin toolbars but inspite of following the download instructions precisely I can only access the 4 plugins via the entry "Fredo6 Collection" in the Tools menu.
I have ticked off the plugins Fredo Scale & Tools on Surface in the VIEW/TOOLBAR menu but Curiloft & Roundcorner are not shown in the dropdown menu.
I would be extremely gratefull if you could suggest where I am going wrong as without the plugin icons showing in the main toolbar it becomes rather difficult to use the plugins to their best advantage.
Best regards
OldSwinger
oldswinger
Premium Member
Premium Member
Postby fredo6 » Sun Jan 01, 2012 11:33 pm
eyffel65girl wrote:Fredo your plugin is awesome, but I can't use it! I run Skethcup Pro 7 on my Mac Book Pro. I've installed your plugin (LibFredo6 first, and then RoundCorner) following your detailed instructions; I thought it were an easy things to do, but they don't work! :cry:
It might come from the Unzip operation, which is a frequent problem, especially on Mac.
Please make sure that in the SU Plugins directory you have the right footprint, that is:
- LibFredo6.rb
- LIBFREDO6_Dir_43 folder
- ROUNDCORNER_Dir_23 folder
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby rjjvirusx » Fri Jan 06, 2012 7:27 pm
:berserk: hooooory
rjjvirusx
Postby tspco » Sat Jan 07, 2012 3:24 am
Is the LibFredo6-34 supposed to stay in the di
rectory after extracting?
SU make 2017, /Twilight Render Hobby
Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
tspco
Postby Dave R » Sat Jan 07, 2012 3:40 am
You should have a folder called "LIBFREDO6_Dir_43" and a file called "LibFredo6.rb" If you installed the current version you shouldn't have "LibFredo6-34" at all.
Global Moderator
Postby tspco » Sat Jan 07, 2012 4:37 am
Well it was there, not now now it just shows 4.3
tspco
Postby gullfo » Sun Jan 08, 2012 9:58 pm
not sure if it is the LibFredo 4.3b or the BezierSpline 1.4f plugin, but if the LibFredo 4.3b is enabled, the BezierSpline 1.4f does not work. i get a Ruby console error for line 592 cannot convert nil to float.
Error: #<TypeError: no implicit conversion to float from nil>
C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in `-'
C:/Program Files/Google/Google SketchUp 8/Plugins/BZ_Dir_14/bezierspline_main.rb:592:in `onMouseMove'
Fredo tools works regardless of BezierSplines being enabled or not.
NOTE: I only encountered this error since updating to 4.3b and prior to that it was working correctly.
gullfo
Postby wt00320371 » Tue Jan 17, 2012 1:10 am
I can't download?
wt00320371
Postby TIG » Tue Jan 17, 2012 10:54 am
wt00320371 wrote:I can't download?
What file?
What problem/error messages?
More information, please...
Global Moderator
Postby supercylon » Mon Jan 30, 2012 2:49 am
I think that I've installed LibFredo6 v.4.3 and the Round corner plugins correctly. But when I launch SketchUp (I'm using Version 7 on Mac OS 10.4.11) is get this error message: Error Loading File LibFredo6.rb
can't convert nil into String
What does this mean and how can I fix it? Can someone assist me.
Thanks!
supercylon
Postby supercylon » Mon Jan 30, 2012 5:48 am
I'm running SketchUp 7 on Mac OS 10.4.11. I've downloaded and installed both LibFredo6 v4.3 and Round Corner plugin and both are not working. When I start up SU7 I get the error message: "Error Loading File LibFredo6.rb
can't convert nil into String". I have no idea what this means. Can someone help?
Thanks a million!
Here is a screen shot of my plugins folder
supercylon
Postby fredo6 » Mon Jan 30, 2012 1:36 pm
@supercylon
Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby TIG » Mon Jan 30, 2012 1:52 pm
Fredo
I use
tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP'
tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
Global Moderator
Postby thomthom » Mon Jan 30, 2012 2:31 pm
This is what I use to detect temp path:
TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
PluginStore Author
PluginStore Author
Postby fredo6 » Mon Jan 30, 2012 4:50 pm
TIG wrote:Fredo
I use
TIG,
Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
@supercylon
Can you type ENV["TMPDIR"] in the Ruby console
Fred
fredo6
PluginStore Author
PluginStore Author
Postby supercylon » Mon Jan 30, 2012 6:01 pm
Fredo6 wrote:@supercylon
Fredo
Hello Fredo,
Thanks for your assistance. I did what you asked and here is a screenshot of the result.
Thanks Supercylon
supercylon
Postby supercylon » Mon Jan 30, 2012 6:07 pm
Fredo6 wrote:
TIG wrote:Fredo
I use
TIG,
@supercylon
Fred
I didn't notice this message, here is the screen shot of the result of your second request.
Thanks,
Supercylon
supercylon
Postby thomthom » Mon Jan 30, 2012 6:11 pm
And ENV['TMP'] ?
PluginStore Author
PluginStore Author
Postby fredo6 » Mon Jan 30, 2012 7:41 pm
@supercylon
Can you try withe attached file to see if your error disappear and SU starts OK.
EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby supercylon » Mon Jan 30, 2012 10:22 pm
LibFredo6.rb
Fredo
Fredo,
Thank you!Thank you! It works!
Supercylon
supercylon
PreviousNext
Return to Plugins
Users browsing this forum: gillianvv, Google Bot, salihsiddiq and 19 guests
