[Plugin Library] LibFredo6 - v11.6a - 23 Jan 21
Re: [Plugin Library] LibFredo6 - v4.1a - 11 Sep 11
Postby fredo6 » Sun Sep 11, 2011 6:29 pm
bimbachi wrote:
Fredo6 wrote:NEW RELEASE: LibFredo6 v4.1a - 11 Sep 11
hm, problem persist the same !
Could you try with this patch (drop the attached file into LIBFREDO6_Dir_41 folder)
Lib6WebWdlg.rb
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby bimbachi » Sun Sep 11, 2011 6:34 pm
Lib6WebWdlg.rb
yes - done - unfortunately no change
bimbachi
Postby fredo6 » Sun Sep 11, 2011 6:41 pm
bimbachi wrote:Could you try with this patch (drop the attached file into LIBFREDO6_Dir_41 folder)
Lib6WebWdlg.rb
Then there is another difference between 5.0.6 and 5.1.
In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally". This refresh the web dialog box. Can you then see the images.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby bimbachi » Sun Sep 11, 2011 8:30 pm
[/quote]
<<In the Check of update can you check or uncheck the checkbox "Show only plugins installed locally".>> - yes
<<This refresh the web dialog box.>> - dose not refresh box!
<<Can you then see the images.>> - checkbox yes images no, text only
regards
bimbachi
bimbachi
Postby fredo6 » Sun Sep 11, 2011 8:50 pm
Bimbachi,
Alternatively, click on one of the colored filtering cross box. This should refresh the dialog box.
Also, can you then try with this patch
Lib6WebWdlg.rb
Thanks very much
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Myro21 » Tue Sep 13, 2011 12:24 pm
Iv down loaded the plugin and put it the directory stated above but nothing shows up when i start up sketchup? im using a mac and have followed all the steps but still nothing... any help please
Myro21
Postby fredo6 » Tue Sep 13, 2011 8:12 pm
Myro21 wrote:Iv down loaded the plugin and put it the directory stated above but nothing shows up when i start up sketchup? im using a mac and have followed all the steps but still nothing... any help please
Do you have a menu Windows > LibFredo6 settings....?
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11
Postby fredo6 » Fri Sep 16, 2011 10:49 pm
NEW RELEASE: LibFredo6 v4.2a - 16 Sep 11
LibFredo6 4.2 should fix some issues for recent versions of Mac OS and Safari 5.0.6 and above (images not displayed and check-for-update not working). LibFredo6 4.1 was not fully solving the problem.
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby driven » Fri Sep 16, 2011 11:18 pm
Fred,
Everything now works on Safari 5.0.6.
thanks for all your great plugins and pursuance of cross platform performance.
if I had the money, I'd buy you a mac as a well deserved reward...
john
driven
PluginStore Author
PluginStore Author
Postby thomthom » Fri Sep 16, 2011 11:56 pm
Fredo6 wrote:NEW RELEASE: LibFredo6 v4.2a - 16 Sep 11
Fredo
What was your solution?
PluginStore Author
PluginStore Author
Postby fredo6 » Sat Sep 17, 2011 6:07 am
thomthom wrote:What was your solution?
The solution is to use set_file with a temporary HTML file in the Temp directory. Simply, I had inadvertedly left a piece of code which was still doing a set_html under certain conditions, and set_file did not supersede the set_html (strangely, even if the HTML was taken from the temp file, the web dialog was created with the window.location = about:blank -- only a refresh of the page would make it right).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby mariocha » Mon Sep 19, 2011 3:01 am
Yep, solved it here.
Cookies to Fredo !
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby niks » Tue Sep 20, 2011 11:20 am
thank you Fredo ;)
niks
Postby coolie44 » Fri Sep 30, 2011 3:11 am
I'm trying to install this on a mac. Not clear on how to extract the files into SUplugins.
I unzipped the file on the desktop and can select all the files but unsure what to do next.
coolie44
Postby fredo6 » Fri Sep 30, 2011 6:30 am
coolie44 wrote:Hi
The unzip operation should lead to a simple footprint in the SU plugins directory
- a file: libFredo6.rb
- a folder: LIBFREDO6_Dir_42
Possibly do the extract in a neutral place, and then copy the file and folder to the SU Plugins directory.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby loyflut » Sat Oct 01, 2011 3:17 pm
Hello Fredo6,
I'm on Mac running OS X Snow Leopard and I've DL all your files and don' manage to install it properly despite I've been following your advices on the .pdf or this web site.
I don't know exactly what's wrong with what I'm doing but it's not working...
libFredo6.rb and libFredo6.pluging are in the right (I think) directory "Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins"
I've DL 000_AdditionalPluginFolders.rb and put it in this directory "Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins" but same same, it's not working.
Basically I'm a bit lost and would love to find the solution to make it work.
This tools looks amazing to use and make the work so much easier.
If any one as a idea I will be pleased and really thankful.
loyflut
Postby driven » Sat Oct 01, 2011 3:47 pm
hi,
do you have any working plugins? i.e. others that do work.
can you post a screenshot of the path to your plugins folder.
john
driven
PluginStore Author
PluginStore Author
Postby fredo6 » Sat Oct 01, 2011 5:28 pm
loyflut wrote:Hello Fredo6,
First, I guess you use Sketchup 8. So the standard directory for Plugins should be
"Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins".
I say that as you seem to use also the ...Google Sketchup 7...directory.
Second, LibFredo6 is not really a plugin by itself, but a library supporting other plugins.
At least did you check you have a menu Windows > LibFredo6 settings..... If so, then you have a correct installation and ready to dowload and install my other scripts (like FredoScale, Roundcorner, ...)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby loyflut » Sat Oct 01, 2011 8:41 pm
John,
No i don't have any working plugin yet.
So here the first screenshot where I put all of them.
I don't think I should put it here (second screenshot)
Fredo,
Yes I use SU pro 8 (I copy/past from the first post you give :oops: )
So Where should I put LibFredo6 ?
No I don't see LibFredo6 settings in my menu, I don't get what to do btw LibFredo6, and 000_AdditionalPluginFolders or even FreeScale....
Sorry guys I'm a waist of time...
Thank your help
loyflut
Postby fredo6 » Sat Oct 01, 2011 9:36 pm
loyflut wrote:Hi,
John,
Fredo,
Thank your help
Your footprint is not correct. You don't have a Folder LIBFREDO6_Dir_42 in your SU Plugins folder (and you have a file LibFredo6.plugin which should not be there).
I suggest you download the ZIP file and do the extraction in a separate directory. You hsould have only:
- 1 file, LibFredo6.rb
- 1 folder LIBFREDO6_Dir_42
Then, when it is OK, copy the file and the folder to the SU Plugins Directory, that is, Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby loyflut » Sat Oct 01, 2011 10:38 pm
Ok, that's all working.
I don't know why but I tough the all file would not go by it self in the plugin directory, that was my mistake.
Now I just have to learn how to use them and create great product.
Thank a lot Fredo for your precious help.
The tools you develop are just super important and super efficient.
Thank you so much.
loyflut
Postby tjwilson » Fri Oct 14, 2011 10:56 am
I am having trouble with putting round edges on an inset box, within a box. When I try to round the edges, the inset box disappears. I have attached a very simple model which will illustrate my problem if you select the edges and round them. Any idea what I need to do differently in order to make all the edges (both inside and outside edges) become rounded?
tjwilson
Postby Dave R » Fri Oct 14, 2011 11:26 am
Does it disappear or does it just get skinned over? What settings are you using?
Global Moderator
Postby tjwilson » Fri Oct 14, 2011 11:34 am
Maybe it just gets skinned over. I'm pretty new to SketchUp, so I have not sdjusted any settings from the default settings on Pro8. An outline of the original inset box still shows up when I do the round edges, but it appears to be back in the same plane as the outer box.
If you are referring to the Round Edge settings, I have been using 3/16" radius edges with 6 segments.
tjwilson
Postby tjwilson » Fri Oct 14, 2011 11:40 am
If you meant the settings on RoundEdge,I was using an edge radius of 3/16" and have tried a number of different segments for rounding, but 6 segments would be fine.
tjwilson
Postby Dave R » Fri Oct 14, 2011 11:46 am
I suspected the skinned over thing. I see that on inside round overs, too. Use Intersect Faces and then delete the skin. Keep the segment count low for the curves to avoid holes in the corners due to small faces that could be generated. SketchUp might not fill them in.
Global Moderator
Postby tjwilson » Fri Oct 14, 2011 12:07 pm
That did it!!! Many thanks.
tjwilson
Postby mar k » Fri Nov 04, 2011 3:00 pm
Many thanks Fredo !
You save my black hair :sketchstatic:
mar k
Postby ScoobyDoo92 » Sat Nov 12, 2011 2:01 pm
Everytime i try to download instead of getting a .zip file i get a .php file. Anyone got a solution??
ScoobyDoo92
Postby Gaieus » Sat Nov 12, 2011 2:03 pm
H. I heard this from Mac users in the past. Try to change the extension from php to zip and see what happens.
PreviousNext
Return to Plugins
Users browsing this forum: chahohyeon, cherabdel2021, Google Bot, naakee and 13 guests
