[Plugin Library] LibFredo6 - v11.8a - 02 Jun 21
Re: [Plugin Library] LibFredo6 - v11.6a - 23 Jan 21
Postby Dave R » Tue Mar 23, 2021 12:59 pm
If you type 6'.8 and hit Enter or type 6'.8" and hit Enter you'll get a line that is 72.8 inches long. It's correct and expected behavior as far as I am seeing here. Fredo, I don't see that any change is needed.
Units set to decimal inches to show the .8.
Global Moderator
Postby tlehman914 » Tue Mar 23, 2021 8:39 pm
fredo6 wrote:
tlehman914 wrote:Looking for help..!? When loading any Fredo plugin, I can not see the dialog box(s).
Could you check the version of LibFredo6 you have installed.
Did you play with FredoTools ColorPaint?
LibFredo6
11.6a
23 Jan 21
ColorPaint will not open.
Error: #<ArgumentError: invalid byte sequence in UTF-8>
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in `strip'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in `load_from_file'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in `block in load_all_colors'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in `each'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in `load_all_colors'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in `initialize'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in `new'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in `instantiate'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:256:in `color_palette_init'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:456:in `prepare_html'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:404:in `reload_html'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:361:in `dialog_create'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6colorscale.rbe:337:in `dialog_invoke'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:98:in `dialog_launch'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:87:in `initialize'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in `new'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:56:in `initialize'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in `new'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/body_fredotools__colorpaint.rbe:44:in `_execution'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:187:in `execute_command'
tlehman914
Postby Robotopera » Wed Mar 31, 2021 4:16 pm
Getting this error when installing on 2021.
Error Loading File Fredo6_!LibFredo6.rb
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in `match'
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:820:in `block (2 levels) in load_from_config'
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in `each'
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:819:in `block in load_from_config'
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in `foreach'
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:817:in `load_from_config'
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in `block in load_all_plugins'
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in `each'
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1232:in `load_all_plugins'
c:/users/robotopera/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:302:in `startup'
C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:in `process'
C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in `<module:LibFredo6_Loader>'
C:/Users/robotopera/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
Robotopera
Postby fredo6 » Wed Mar 31, 2021 8:44 pm
How did you install LibFredo6?
- Copying files?
- Sketchup Extension manager from a rbz
- Sketchucation ExtensionStore?
It seems one file is altered.
fredo6
PluginStore Author
PluginStore Author
Postby tlehman914 » Fri Apr 02, 2021 8:59 pm
I am still not able to use most all of the Fredo extensions. I have removed ALL Fredo plugins and reinstalled LibFredo6 v11.6a from SketchUcation PluginStore and still get the following error:
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in `color_parse'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in `color_luminance'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in `color_is_dark?'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in `draw_button_text'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in `draw_button'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in `block in draw'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in `each'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in `draw'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in `draw'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_toolsonsurface/shapeonsurface.rbe:575:in `draw'
tlehman914
Postby fredo6 » Fri Apr 02, 2021 9:12 pm
I don't know what happened during the installation, but there is clearly a problem in a few files which lost their UTF8 encoding.
Could you try the following
- Open the Ruby Console
- copy the following command in red and type Enter:
UI.openURL LibFredo6.path + '/Ancillary'
- This will open a subfolder of LibFredo6
- Delete the file Colors_RAL_classic.txt
- restart Sketchup to see if this improves the situation
- Otherwise, delete all files with names beginning with Colors_ and extension txt.
Then restart Sketchup to see if this improves the situation.
fredo6
PluginStore Author
PluginStore Author
Postby tlehman914 » Mon Apr 05, 2021 2:21 pm
fredo6 wrote:I don't know what happened during the installation, but there is clearly a problem in a few files which lost their UTF8 encoding.
I did try to copy the following command in red and type Enter:
Result:
false
I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
I then deleted all files with names beginning with Colors_ and extension txt. - restarted and tried to use the only PlugIn installed: ToolsOnSurface - result:
tlehman914
Postby fredo6 » Mon Apr 05, 2021 2:39 pm
tlehman914 wrote:I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
What is left in the directory?
Just type in the Ruby console:
Dir[LibFredo6.path + '/Ancillary/*.*']
fredo6
PluginStore Author
PluginStore Author
Postby tlehman914 » Mon Apr 05, 2021 3:04 pm
Nothing is left in the directory...?
No change after typing the above.
tlehman914
Postby fredo6 » Mon Apr 05, 2021 3:08 pm
Did you define a custom color file?
If so, do you remember where you save it?
In the Ruby Console, could you type
Traductor::Marshall.new.decode(Traductor::Registry.load "Fredo6_ColorFan_Custom")
This should be the list of custom color files.
fredo6
PluginStore Author
PluginStore Author
Postby tlehman914 » Mon Apr 05, 2021 3:14 pm
fredo6 wrote:Did you define a custom color file?
{"/Users/toddlehman/Dropbox (Cre8Play)/SketchUp/Materials/Archive/Bark/Tree Tex8.jpg"=>true}
tlehman914
Postby tlehman914 » Mon Apr 05, 2021 4:02 pm
I deleted the material 'Tree Tex8.jpg', and all is working!!!! :thumb: :fro: :bounce:
THANK YOU!!!!
tlehman914
Postby fredo6 » Mon Apr 05, 2021 4:04 pm
tlehman914 wrote:I deleted the material 'Tree Tex8.jpg', and all is working!!!! :thumb: :fro: :bounce:
In ColorPaint, you are supposed to load only plain text file (tabular value of colors: name, R, G, B), not images or material.
fredo6
PluginStore Author
PluginStore Author
Postby Robotopera » Mon Apr 05, 2021 4:14 pm
fredo6 wrote:How did you install LibFredo6?
- Copying files?
Tried all 3 with full uninstalls in between each. Sadly no luck.
Success! Running a repair on the sketchup installation seemed to fix it!
Robotopera
Postby tlehman914 » Mon Apr 05, 2021 4:51 pm
Understood. I didn't even know that I had done that...!? Thanks again!
tlehman914
Postby atrasnap » Fri Apr 09, 2021 1:58 pm
Bonjour à tous,
Je viens d'installer l'extension FredoTools via le gestionnaire d'extension,
Elle apparait bien dans mon gestionnaire d'extension mais nul part ailleurs ?
Je ne peut donc pas l'utiliser.
Il ya t-il une raison ou une manip particulière à effectuer ?
Je suis sur SketchUp 21pro
Merci d'avance
atrasnap
Postby TIG » Fri Apr 09, 2021 3:41 pm
Have you also installed LibFredo ?
Have you restarted SketchUp ?
Have you looked in the Tools menu's submenus ?
Avez-vous également installé LibFredo?
Avez-vous redémarré SketchUp?
Avez-vous regardé dans les sous-menus du menu Outils [Tools]?
Global Moderator
Postby martychristoffel » Sat Apr 17, 2021 1:56 am
I'm seeing some UI problems, specifically buttons at the bottom of various dialog boxes being completely washed out. I'm on MacOS Big Sur.
I don't have this problem in other applications, only here in SketchUp and with these dialog box buttons.
Any thoughts? Is it a SketchUp thing, an extension thing, or an OS thing?
Please see image examples.
Thanks.
martychristoffel
Postby fredo6 » Sat Apr 17, 2021 8:33 pm
@martychristoffel
Thanks for signaling this problem. You are the first one.
Big Sur seems to be a master in term of non-backward compatibility, at least for Sketchup...!
I will see if I can find a workaround in a next version of LibFredo6.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Dekorte » Sun Apr 25, 2021 1:41 pm
Hello LibFredo6,
I recieved your message showing me your Pic2Shape plugin.
I tried it with a couple of images and it works great.
However, I would like to use this for cutting out the contours of 2D trees, so i can cast a more realistic shadow.
And here I ran into some troubles.
For complex trees (with a lot of tiny holes between the branches) the plugin says he can't generate any contours.
I wonder if you could help me with the right filter settings so that the plugin can still work ?
I attached a tree (png) that doesn't generate a boundary when using the plugin.
All the png trees i'm using are available (for free) as high quality PNG’s with transparent background from this website : https://meye.dk/info/
Many thanks in advance !
Boris
Dekorte
Postby fredo6 » Sun Apr 25, 2021 2:55 pm
Since this thread is about LibFredo6, I created a dedicated thread here.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Tibonator » Fri May 07, 2021 10:30 am
Very efficient plugin thank you.
The only issue is that the colour of action icons are extremely difficult to read against the white background.
I am using SUP2021 on a MacBoo pro 2018 running under MacOS Mojave.
Is it just me or a common issue that could be resolved easily on the developer's end?
Thank you.
T
Tibonator
Postby fredo6 » Sun May 09, 2021 7:55 pm
This will be fixed in the next version of LibFredo6. This seems to happen for some Mac configurations.
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v11.7a - 12 May 21
Postby fredo6 » Wed May 12, 2021 2:24 pm
NEW RELEASE: LibFredo6 v11.7a - 12 May 21
LibFredo6 11.7a includes
  • bug fixing and various technical adjustments
_______________________________________________________________________________________
Requirements: SU2017 and above
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v11.7c - 16 May 21
Postby fredo6 » Sun May 16, 2021 9:10 pm
NEW RELEASE: LibFredo6 v11.7c - 16 May 21
LibFredo6 11.7c includes
  • bug fixing and various technical adjustments, mainly for Mac
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby GregorS » Tue May 25, 2021 7:02 am
I get no confirmation that my installation of updates (through the Extension Manager) does anything.
Is this to be expected?
SU Make 2017
GregorS
Postby Dave R » Tue May 25, 2021 9:07 pm
GregorS wrote:I get no confirmation that my installation of updates (through the Extension Manager) does anything.
What are you expecting to see? Extension Manager will show you the currently installed version of LibFredo6.
Fredo6's own Check for Updates will show you the currently installed version, too.
If you were using the Sketchucation tool to install it, you would get a notification through the tool that there is an update to be installed when there is.
GregorS wrote:SU Make 2017
Your profile says you are using SketchUp 2015. Perhaps you would take a moment to update it?
Global Moderator
Postby GregorS » Wed May 26, 2021 7:12 am
Thanks I had not noticed the ">" which shows the version. All is good!
GregorS
Re: [Plugin Library] LibFredo6 - v11.8a - 02 Jun 21
Postby fredo6 » Wed Jun 02, 2021 7:23 am
NEW RELEASE: LibFredo6 v11.8a - 02 Jun 21
LibFredo6 11.8a includes
  • Support of the new extension LordOfTheToolbars v1.3a
Fredo
fredo6
PluginStore Author
PluginStore Author
Previous
Return to Plugins
Users browsing this forum: Bing [Bot], mugdha1234 and 21 guests
