by fredo6 » Wed Dec 02, 2020 4:09 pm
NEW RELEASE: LibFredo6 v11.4f - 02 Dec 20LibFredo6 11.4d provides fixes - for handling some cases of non-ascii Windows username
- for a bug in some tools (MoveAlong and a few others)
_______________________________________________________________________________________ Requirements: SU2017 and aboveSee plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 threadFredo
fredo6
- PluginStore Author
- Name: Fredo6
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: interior design
by 1409 douglas » Mon Dec 28, 2020 11:23 pm
I have your latest version as of 02 december 2020 of libFredo6. I have SketchupPRO 2021. I believe I have followed your instructions to load libFredo6 and Curvizard v2.4b. There is libFredo6 under Window, but no Curvizard under Extensions. I have restarted (several times). Any Ideas? Thank you rj
1409 douglas
- Name: Randy J Cloud
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
by Dave R » Tue Dec 29, 2020 8:37 pm
1409 douglas wrote:but no Curvizard under Extensions. I have restarted (several times).
No matter how many times you restart SketchUp, Curvizard isn't supposed to show up under Extensions. It shows up in Tools>Fredo6 Collection. Or you can turn on its toolbar button under View>Toolbars. Screenshot - 12_29_2020 , 1_35_32 PM.png Screenshot - 12_29_2020 , 1_38_35 PM.png
- Global Moderator
- Name: Dave R
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Advanced
by Aiden900 » Sat Jan 02, 2021 3:58 am
Hello fredo, Hope you're fine, I have tried everything in order to make the fredo tools work and it still not workingm the tool bare's aren't even showing up. I even uninstalled and installed sketchup 2019 pro, installed the extensions several times but still no fix, could you or someone please help me out.
Kind regards A.F
Aiden900
- Name: Aiden
- SketchUp version: 2019
- License type: Pro
by TIG » Sat Jan 02, 2021 3:18 pm
@Aiden900
A few things to consider...
Did you install SketchUp correctly ? You can repair it and avoid a full re-installation... While you are logged into Windows as your normal user account, ensure SketchUp is closed. Find the v2019 installer exe file - usually in your Downloads folder ? Select its icon, right-click > context-menu > "Run as administrator" When prompted choose "Repair"... After it completes restart SketchUp and retest...
I assume you are installing from the RBZ using the Extension Manager > Install... button ??
Fredo's extensions [almost all] need his latest LibFredo RBZ installing - available separately from the PluginStrore. Have you downloaded and installed that too ? On its own a Lib does nothing - but it adds vital support for his other extensions... So have you downloaded and installed the latest Fredo Tools from the PluginStore ?
Are you aware where the Fredo Tools menu is ? [i.e. under Tools] The FredoTools toolbar button might need activating in your View > Toolbars... dialog's list ?
When clicked that toolbar button opens a second dialog listing many of Fredo's tools - click on the name of one of them and it launches... Are the two expected Fredo entries listed in the Extension Manager dialog ? Are they activated in the listing ?
- Global Moderator
- Name: TIG
- License type: Pro
by Box » Sat Jan 02, 2021 3:58 pm
Just checking, libfredo doesn't do anything on it's own. It is a helper folder for various Fredo extensions. So installing just LibFredo does nothing.
- Name: Box
- SketchUp version: 2020
- License type: Pro
- SketchUp use: other
by Aiden900 » Sat Jan 02, 2021 5:04 pm
Hello TIG, I've been using Fredo for almost all my projects and work and it was working fine, but i had to get a newer version of Sketchup 2019 pro so i got that and yes i've followed the tutorial and everything but still nothing. Also one thing i've noticed is that when i install the extension from the extension manager specially Libfredo 6 and check the version it still says 1.0. I am signed into trimble and stuff and other extensions are working fine except for all the plugin related to Libefredo, like scel corner rounds etc. I've checked under the tools bar and i cannot find the fredo or Lib at all.
If you would like to directly contact me you can. Just let me know what would be suitable.
Aiden900
- Name: Aiden
- License type: Pro
by TIG » Sat Jan 02, 2021 5:59 pm
Here's what my current Extension Manager lists in v2019... Capture.PNG If yours shows something else [and you've installed the latest versions] then it's broken... Have you tried the "Repair" idea ? The Lib doesn't appear, except as a 'helper' - the FredoTools is in Tools submenu and a Toolbar of the same name...
- Global Moderator
- Name: TIG
- License type: Pro
by Aiden900 » Sat Jan 02, 2021 6:18 pm
Hello TIG,
I've tried repair in administrator mode, Yes i am signed into my windows account as a genuine user. I tried installing the extension again from the beginning by downloading them again and it still not working, Maybe i could be doing something wrong.. It's a suggestion so tell me if it's okay for you. How about you just make a zip file of the Libfredo 6 Rbz file with fredo scale the max and share with me. And i'll let you know if it works by sharing a screenshot. ?
Aiden900
- Name: Aiden
- License type: Pro
by Dave R » Sat Jan 02, 2021 6:48 pm
Before you install the current version of these extensions, go to the Plugins folder and delete all related files.
Also please update your profile. It says you are using SU2016.
- Global Moderator
- Name: Dave R
- License type: Pro
by Aiden900 » Sat Jan 02, 2021 9:48 pm
Hello , I gave it a go and did everything as you said. it still didn't work. I keep on getting the message to install Librefredo 6.9 or higher. Ran the setup and even repaired the file but it still didn't help. Here's is the screen shot of the version that it's showing me
Aiden900
- Name: Aiden
- License type: Pro
by TIG » Sat Jan 02, 2021 11:24 pm
Your LibFredo files' installation is obviously FUBAR... Delete all files and subfolders in your Plugins folder which relate to LibFredo [i.e. Fredo6_!LibFredo6.rb file and Fredo6_!LibFredo6 subfolder and its contents ], then restart SketchUp and install the latest LibFredo RBZ as I linked... Fredo might be able to advise on very old legacy files messing things up - but you would have to have copied those over from a much older set up...
- Global Moderator
- Name: TIG
- License type: Pro
by Aiden900 » Wed Jan 13, 2021 1:45 am
hello, Well i've tried almost everything to fix, all other extensions work. but this is the only extension that's not working at all, it's not appearing in the tools bar neither in the extensions options, i am attaching screenshot just to show you that i have installed the latest version as you linked above.
Aiden900
- Name: Aiden
- License type: Pro
by juju » Wed Jan 13, 2021 7:05 am
Aiden900 wrote:hello, Well i've tried almost everything to fix, all other extensions work. but this is the only extension that's not working at all, it's not appearing in the tools bar neither in the extensions options, i am attaching screenshot just to show you that i have installed the latest version as you linked above.
It is not an extension in itself. It is a library required by Fredo's extensions.
juju
- Premium Member
- Name: Juju
- License type: Pro
by Aiden900 » Thu Jan 14, 2021 12:07 am
Yes sir, I know that but it's not being show in extensions window as well.. it just aint there at all. And i have no idea what to do to fix. I have tried every possible way trying to somehow fix this thing. if someone wants to help me by connecting to team viewer or anything like that please please do. I urgently need it so that i can finish my model for interior. Please PM me or something.
bundle of thanks Aiden
Aiden900
- Name: Aiden
- License type: Pro
by fredo6 » Thu Jan 14, 2021 6:07 am
Aiden900 wrote:Yes sir, I know that but it's not being show in extensions window as well.. it just aint there at all. And i have no idea what to do to fix.
You just need to install LibFredo6 (it seems to be missing in your current setup). - Download the RBZ at the LibFredo6 Plugin Page - Go to the Extension Manager of Sketchup - Install LibFredo6 from the LibFredo6 RBZ (button 'Install Extension') Once done, the other plugins, FredoScale and FredoTools will work.
fredo6
- Name: Fredo6
- License type: Pro
by Aiden900 » Thu Jan 14, 2021 11:02 pm
OK, Just to be clear and as i am sort of telling the same thing again and again. I've never had issues installing extensions, i know how easy the process is, but it just ain't seem to be working so guess what, i am actually going to be pasting the error that i am getting maybe that way you'll be able to see what the fault is as i am not that expert. And you shall find the attachment of my extensions manager again.
Error Loading File C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe Failed to read RBE/RBS file. Error Loading File Fredo6_!LibFredo6.rb Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6> C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:in `process' C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in `<module:LibFredo6_Loader>' C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>' Error Loading File Fredo6_FredoScale.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:83:in `-' C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:83:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoScale.rb:47:in `<module:Fredo6>' C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in `<top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:83:in `-' C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:83:in `<top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require' C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in `<module:Fredo6>' C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in `<top (required)>' Error Loading File C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_advancedcameratools/actloader.rbe Failed to read RBE/RBS file. Error Loading File C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_dynamiccomponents/ruby/dcloader.rbe Failed to read RBE/RBS file. Error Loading File C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_sandbox/sandboxmenus.rbe Failed to read RBE/RBS file. Error Loading File C:/Users/Afara/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/su_trimble_connect/boot.rbe Failed to read RBE/RBS file.
Aiden900
- Name: Aiden
- License type: Pro
by Dave R » Thu Jan 14, 2021 11:09 pm
Go back to TIG's post when he wrote the following: Did you install SketchUp correctly ? You can repair it and avoid a full re-installation... While you are logged into Windows as your normal user account, ensure SketchUp is closed. Find the v2019 installer exe file - usually in your Downloads folder ? Select its icon, right-click > context-menu > "Run as administrator" When prompted choose "Repair"... After it completes restart SketchUp and retest...
Do that and repair the installation of SketchUp.
- Global Moderator
- Name: Dave R
- License type: Pro
by Aiden900 » Thu Jan 14, 2021 11:28 pm
Tried that a million times, I even installed sketchup all over again just to see if that would help, still nothing. it's showing me the error. I even deleted my plugin folder, and tried installing only fredo tools still nothing comes up
Aiden900
- Name: Aiden
- License type: Pro
by TIG » Thu Jan 14, 2021 11:55 pm
Installing just Fredo's Tools on its own won't work !
Almost all of Fredo's Extensions will also need his latest LibFredo installing.
Download that Lib's RBZ, install it and restart SketchUp...
After that Fredo's Tools and the vital LibFredo should appear in the Extension Manager list ??
- Global Moderator
- Name: TIG
- License type: Pro
by Aiden900 » Fri Jan 15, 2021 12:07 am
TIG, If you check the screen shot above, I've install the tools and the Libfredo6 latest version from the website. I've done it. and it's still not appearing and yet it shows me errors. See i've been struggling with this since i dont know weeks, and i really do appreciate everyone on this page trying to help me out. but it's just not working at all. So If it's possible for anyone of you to help me through teamviwer or skype or anything, please please please let me know. I've tried all the steps above, everything. even i have tried download the RBZ file again and installing them but it just wouldn't appear or work. I am dropping my email below, please if any of you would be kind enough to assist me please do. Kind Regards A.F Email : darkcore900@gmail.com
Aiden900
- Name: Aiden
- License type: Pro
by TIG » Fri Jan 15, 2021 12:55 am
Your statement isn't logical. If your Plugins folder were empty then the Extension Manager would show only some 'Shipped-Extensions' which always load. If You install Fredo Tools it does nothing without having LibFredo installed. You screen shots don't show us this... Your earlier screen shot of the Extension Manager showed LibFredo v1.0 - this is clearly wrong... Let's step back a bit... Can you please post the following results... Use the Ruby Console to type or copy/paste the following, individually... SCF::PLUGINSSketchup.find_support_file('Plugins')Sketchup.temp_dirThese might help us narrow in on some OS issues ??
- Global Moderator
- Name: TIG
- License type: Pro
by Aiden900 » Fri Jan 15, 2021 1:12 am
okay so i typed them individually and this is what i got
Aiden900
- Name: Aiden
- License type: Pro
by Aiden900 » Fri Jan 15, 2021 1:39 am
And yeah even after installing the plugin from your preferred links, for some reason it still shows version 1.0 which is quite odd..
Aiden900
- Name: Aiden
- License type: Pro
by TIG » Fri Jan 15, 2021 2:18 pm
This is indeed very strange ! The paths that you tested are all as expected...
I trust that you emptied your Plugins folder of anything 'Fredo' related in the recent re-setting ? Before reinstalling the Fredo Lib and Extensions...
Can you try this last test for me... Find the folder named: C:\ProgramData\SketchUp\SketchUp 2019\SketchUp Is there a \Plugins subfolder in it ? If so, then look at its contents - are there any old Fredo files incorrectly installed in there ? If so delete them and restart SketchUp and see if that has helped
Fredo needs to chip in here - I'm running out of ideas !
- Global Moderator
- Name: TIG
- License type: Pro
by fredo6 » Fri Jan 15, 2021 2:28 pm
The problem seems to come from the infamous "Failed to read RBE/RBS file".
Usually, this is fixed with a full reinstallation of Sketchup, using 'Run as Administrator' on the Install executable.
Fredo
fredo6
- Name: Fredo6
- License type: Pro
by TIG » Fri Jan 15, 2021 3:25 pm
The issue is widespread, not just with Fredo tools / lib but also relates to the su_ 'shipped-extensions' rbe files, which SketchUp copies into the User's Plugins folder as needed... Looks like there's a major file / folder read/write problem with permissions - usually fixed by installing SketchUp 'properly' using 'Run as administrator'...
Can you check the security permissions for your User's Plugins folder...
Select the Plugins folder's icon, right-click > context-menu > Properties > Security tab > Edit
There might be several 'users' listed. Go through the list and under the Allow column give 'Full control' to each one in turn [i.e. all permissions should appear ticked, except 'special permissions'] If you are resetting any permissions allow the changes to cascade through all nested files and subfolders... None of the entries under the Deny column should be ticked at all.
- Global Moderator
- Name: TIG
- License type: Pro
by fredo6 » Fri Jan 15, 2021 4:11 pm
NEW RELEASE: LibFredo6 v11.5a - 15 Jan 21LibFredo6 11.5a includes - Various bug fixing and adjustments
- Changes to Animator (Move Along Path with upright orientation)
fredo6
- Name: Fredo6
- License type: Pro
by Aiden900 » Fri Jan 15, 2021 11:54 pm
Hello, I've done what you've asked as well, i am also posting a screenshot.. Everything seems to fine there. and as Tig also uploaded a new RBZ file as i can see below. It's still not installing the RBZ. I mean when i click on install extension it doesn't show up in the extension manager list
Aiden900
- Name: Aiden
- License type: Pro
- Robot
Return to Plugins
