[Plugin Library] LibFredo6 - v11.6a - 23 Jan 21
Re: [Plugin Library] LibFredo6 - v9.5g - 09 Feb 20
Postby Beaver99 » Tue Feb 11, 2020 5:22 pm
Thank you so much for creating these tools, extremely valuable to my work flow.
You are
Awesome & Amazing !
Beaver99
Re: [Plugin Library] LibFredo6 - v9.5h - 13 Feb 20
Postby fredo6 » Thu Feb 13, 2020 8:00 pm
NEW RELEASE: LibFredo6 v9.5h - 13 Feb 20
LibFredo6 9.5h is a minor release necessary for Animator. It corrects a problem when Easing functions.
_______________________________________________________________________________________
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Jeff Mack Designs » Wed Feb 19, 2020 7:18 pm
can you use this plug in with sketch up for web? like the free version?
when I go to Window the options outlined are not there.
ty.
Jeff Mack Designs
Postby Dave R » Thu Feb 20, 2020 3:05 pm
Jeff Mack Designs wrote:can you use this plug in with sketch up for web? like the free version?
ty.
No. As I told you elsewhere yesterday, the web versions of SketchUp have no implementation for using extensions.
Global Moderator
Re: [Plugin Library] LibFredo6 - v9.5i - 25 Feb 20
Postby fredo6 » Tue Feb 25, 2020 1:09 pm
NEW RELEASE: LibFredo6 v9.5j - 25 Feb 20
LibFredo6 9.5j is a minor release for fixing a bug in some rare situations where the model has no attribute at all.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v9.5j - 25 Feb 20
Postby Sunxl » Mon Mar 02, 2020 6:34 pm
Hi Fredo,
Do you know how to fix the problem shown as below,
[img]file:///C:/Users/SUN/Desktop/%E9%98%BF%E9%87%8C%E6%97%BA%E6%97%BA%E5%9B%BE%E7%89%8720200303012702.jpg[/img]
I tried the su2019 and 2020, But the SU still failed to load the Fredo6
Please help
Thank you
Sunxl
Postby TIG » Mon Mar 02, 2020 7:40 pm
The image is missing you cannot link to a file that is on your own PC !
Try copy/paste ?
Global Moderator
Postby Sunxl » Mon Mar 02, 2020 10:52 pm
TIG wrote:The image is missing you cannot link to a file that is on your own PC !
Try copy/paste ?
Sorry,this is my first time to use this.
载入文件 C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe 时出错
Failed to read RBE/RBS file.
载入文件 Fredo6_!LibFredo6.rb 时出错
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in `process'
C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in `<module:LibFredo6_Loader>'
C:/Users/SUN/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
thank you
Sunxl
Postby fredo6 » Tue Mar 03, 2020 12:04 am
This 'failed to load RBS/RBE' seems to be a problem related to the installation of Sketchup.
Could you reinstall it, with 'run as administrator'.
-1
fredo6
PluginStore Author
PluginStore Author
Postby Sunxl » Tue Mar 03, 2020 5:37 am
fredo6 wrote:This 'failed to load RBS/RBE' seems to be a problem related to the installation of Sketchup.
Yes, I did. But the error still exist.
I didn’t find any available solutions to deal with it.
Sunxl
Re: [Plugin Library] LibFredo6 - v9.5k - 14 Mar 20
Postby fredo6 » Sat Mar 14, 2020 3:50 pm
NEW RELEASE: LibFredo6 v9.5k - 14 Mar 20
LibFredo6 9.5k is a major release
  1. Fixes a bug preventing all my plugins to work with some configurations of MacOS Catalina
  2. Introduces a 'toolbar visibility' button in all the QuickLauncher dialogs of my plugins. This makes it easier to manage the visibility of icons in the toolbar, which was already available in the Default Parameters. You need to restart Sketchup for the changes to be effective.
As an example, here is the new layout of the FredoScale QuickLauncher, with the visibility toggle buttons on the right (small eye).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JDW Interiors » Sun Mar 15, 2020 6:16 pm
Hi all,
I've downloaded Fredoscale for my MacBook Pro 2018 but I can't seem to open it. I am running sketchup 2020.
I firstly downloaded it from sketchUcation and then I went to 'Window>Extension manager>Install extension'
In the extension manager it says the app is signed but I can't see how I can open the window and use the fredoscale tools.
Can anyone help?
Thanks in advance!
Jack
JDW Interiors
Postby Dave R » Sun Mar 15, 2020 8:00 pm
Have you quit out of SketchUp and reopened it to make sure both extensions load completely? After you do that you should be able to see the FredoScale tool palette in View>Tool palettes.
Global Moderator
Postby Elrodrules » Wed Mar 25, 2020 2:51 am
Hi -
I had installed LibFredo6 9.5j and that was working fine. Today I tried to update to LibFredo6 9.5k and now I'm getting the following error(s). I'm using SketchUp Make 17.3.116 on a MacBook Air running macOS Catalina. I have quit and reopened SketchUp several times and the result is the same. Any suggestions?
The first error window says:
Curviloft 1.8a: Error starting up plugin (creating menus and icons)
undefined method `declare_topmenu' for #<Traductor::Plugin:0x007faf20183c70> [in bootstrap_curviloft.rbe: - #`startup(): line 87]
/users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1058:in `rescue in block in effective_load_part2'
I click 'OK' and a second error window opens with these strings:
Error: #<NameError: uninitialized constant Traductor::Plugin::T6>
/users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1072:in `effective_load_part2'
/users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1003:in `effective_load'
/users/ll/library/application support/sketchup 2017/sketchup/plugins/fredo6_curviloft/__loader__curviloft.rbe:1:in `<main>'
/Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `eval'
/Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `require'
/Applications/SketchUp 2017/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in `load'
/Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:57:in `register_extension'
/Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:57:in `<module:Fredo6>'
/Users/ll/Library/Application Support/SketchUp 2017/SketchUp/Plugins/Fredo6_Curviloft.rb:26:in `<top (required)>'
Elrodrules
Postby maotine » Mon Mar 30, 2020 6:17 am
Thank
maotine
Error message Re: [Plugin Library] LibFredo6 - v9.5k - 14 Ma
Postby BjR55 » Mon Mar 30, 2020 9:58 pm
I've logged into Sketchucation and have been trying to download the Round Corner extension and I've tried several times after viewing the video and I keep getting this error message pop up after it downloads:
[img]
[/img]
BjR55
Postby TIG » Mon Mar 30, 2020 10:23 pm
When you Download any file you can specify where to 'save it' OR what app will 'open it'.
A SketchUp RBZ archive is NOT 'opened' by anything when you download it.
In its case you need to 'save' it into your Downloads folder...
This is part of your browser's settings, and what options you choose in the download settings for each file-type...
When the RBZ is saved you can now install it using SketchUp...
Open the Window > Extension Manager and use the red-button 'Install Extension'.
When prompted, navigate to the RBZ's location and select it.
SketchUp now automatically installs the archive's contents into the correct locations in your ../Users/.../Plugins folder etc.
You posted this in the LibFredo6 thread...
BUT in the case of almost all of Fredo's Extensions you do need to have the LibFredo installed.
This 'helper' adds vital functions to other Fredo Extensions you install.
So first install the LibFredo RBZ as outlined above, then install the other Fredo Extensions' RBZ files as you want - like RoundCorner or FredoCorner etc...
Note that unlike 'standalone' ones, with Extensions that use a 'Lib' - like Fredo's [& thomthom's] you should restart SketchUp after the installations to ensure that everything gets synced properly...
Global Moderator
Postby Jas13 » Wed Apr 01, 2020 10:38 am
Bonjour!
Merci pour votre tuto d'installation qui était assez clair et pour les extensions.
Cependant j'ai la version pro 2018 et quand je vais dans fenêtre -> préférences, il n'y a pas extensions dans les options, de ce fait je ne peux pas installer complètement l'extension.
Si vous aviez une solution svp
merci beaucoup!
bien à vous
Jas13
Postby fredo6 » Wed Apr 01, 2020 1:46 pm
Jas13 wrote:Merci pour votre tuto d'installation qui était assez clair et pour les extensions.
Le menu est au premier niveau, sous l'entrée Extension Manager, pas dans Preferences
fredo6
PluginStore Author
PluginStore Author
Postby Jas13 » Sat Apr 04, 2020 5:26 pm
désolé, je n'ai pas été suffisamment précise. Le problème que je rencontre est:
je vais dans fenêtre -> gestionnaires d'extension -> installer l'extension choisissant donc le fichier et l'ouvrant
il se situe bien dans le gestionnaire mais bien qu'activer je ne vois aucun changement dans mes barres d'outils même en fermant et rouvrant l'application.
Dans le gestionnaire l'icône de l'extension est sous la forme d'un diamant gris.
je ne sais pas si je suis assez claire, mais du coup voilà.
Désolé de vous embêter,mais c'est que j'ai d('besoin de vos extensions pour réaliser mes maquettes en 3D et après faire du rendu
bien à vous.
Jas13
Postby fredo6 » Sun Apr 05, 2020 2:26 pm
Jas13 wrote:il se situe bien dans le gestionnaire mais bien qu'activer je ne vois aucun changement dans mes barres d'outils même en fermant et rouvrant l'application.
LibFredo6 n'ajoute aucune barre d'outils. C'est juste une librarie, qui n'a d'intérêt que si un autre de mes plugins est installé (comme RoundCorner, FredoScale, ...).
Toutefois, LibFredo6 ajoute un menu Window > LibFredo6 Settings... s'il est bien installé.
fredo6
PluginStore Author
PluginStore Author
Postby AARo » Mon Apr 06, 2020 2:27 pm
Bonjour,
J'ai télécharge ce jour le Plug "Libfredo6" et "joinPushPull" sur Sketch'up 2020; suivant indications du tuto. Téléchargement, installation par le gestionnaire.
A l'ouverture de SketchUp le message suivant s'affiche
Erreur de chargement du fichier Fredo6_!LibFredo6.rb
Error: #<ArgumentError: invalid byte sequence in UTF-8>
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in `match'
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:806:in `block (2 levels) in load_from_config'
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in `each'
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:805:in `block in load_from_config'
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in `foreach'
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:803:in `load_from_config'
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in `block in load_all_plugins'
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in `each'
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1218:in `load_all_plugins'
c:/users/sylvain/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:254:in `startup'
C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in `process'
C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in `<module:LibFredo6_Loader>'
C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
Erreur de chargement du fichier Fredo6_JointPushPull.rb
Error: #<TypeError: can't convert nil into an exact number>
C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in `-'
C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2020/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in `require'
C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in `<module:Fredo6>'
C:/Users/sylvain/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
Par avance merci de votre aide.
AARo
Postby AARo » Mon Apr 06, 2020 4:17 pm
J'ai résolu au final le problème, il traînait un vieux fichier "ZLoader__OnSurface" dans le dossier Plugins.
J'ai réalisé un grand nettoyage et réinstallé Plug par Plug et cela marche !
AARo
Postby fedser » Wed Apr 08, 2020 7:10 am
Hi Fredo6, I have a little problem with your plugins in SketchUp 2020
"FredoTools 3.8c" plugin does not display "svg" icons. Color palettes in "Color Paint" do not work. Window size is not saved in all your plugins. In SketchUp 2019, everything was great. (Installed LibFredo6 9.5k). Perhaps this information will help make your plugins perfect. Thank you for your work.
P.S. Sorry for my English :-)
fedser
Postby fredo6 » Wed Apr 08, 2020 11:54 pm
fedser wrote:Hi Fredo6, I have a little problem with your plugins in SketchUp 2020
Which Windows system do you have?
Do you always get the problem on SU2020 or since you moved to LibFredo6 9.5k?
fredo6
PluginStore Author
PluginStore Author
Postby fedser » Thu Apr 09, 2020 7:10 am
Windows 10 Home (v.1903 single language)
Installed LibFredo6 9.5k when switching to SU2020 (clean installation) another version of the plugin is no longer available. I tried a set of SU2019 + LibFredo6 9.5k works fine.
fedser
Postby fredo6 » Thu Apr 09, 2020 2:33 pm
There is something wrong with SU2020 as it seems to use settings for the embedded API to HTML which is not HTML5, explaining no SVG support and all other sorts of visual problems.
I have heard of the problem, but do not remember where.
fredo6
PluginStore Author
PluginStore Author
Postby fedser » Thu Apr 09, 2020 3:06 pm
I tried to say this. But I am not a developer and I can not express myself correctly. I wanted to convey this information to you because you began to use svg often and in SU2020 you will run into a problem. Your plugins are wonderful and we all hope that they will be even better, thank you.
fedser
Postby TIG » Thu Apr 09, 2020 3:26 pm
@fedser
When you installed SketchUp v2020 did you do it correctly ?
An incorrect installation can cause unexpected and weird issues...
This is the correct way to do it - when it's already installed you can do a "Repair", which shouldn't affect your personal set up...
While logged into your usual Windows user-account ensure SketchUp is not running.
Fine the SketchUp installer's exe file - usually in your Downloads folder ?
Select that exe file's icon, right-click > context-menu > "Run as administrator"
When prompted choose "Repair"
When it's completed restart SketchUp and see if it's any better...
Installing a complex app's installer's exe file in any other way will cause unpredictable issues.
So never double-click on the installer's exe file to "Run" it... even if your normal-user has admin-powers it is NOT the same as doing it as I outlined above...
Global Moderator
Postby fedser » Wed Apr 15, 2020 8:55 am
@TIG
This action does not solve the problem. I always install SU with administrator rights. I tried to install it on another computer. Problem still exists. The "Portrait" plugin also has a problem with svg. The plugin itself is working properly. SU2019 doesn't have this problem. Maybe this problem is only with me, I wanted to know how it works on your SU2020?
fedser
PreviousNext
Return to Plugins
Users browsing this forum: dskit870, glro, HNK1511, railwaxking, zeroserss and 15 guests
