[Plugin Library] LibFredo6 - v8.7m - 15 Feb 19Re: [Plugin Library] LibFredo6 - v8.6e - 19 Sep 18NEW RELEASE: LibFredo6 v8.6e - 19 Sep 18
LibFredo6 8.6e includes a Spanish French by Oxer and fixes problems for FredoCorner 1.1d. _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.6f - 23 Sep 18NEW RELEASE: LibFredo6 v8.6f - 23 Sep 18
LibFredo6 8.6f fixes problems for FredoCorner 1.1e. _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.6f - 23 Sep 18Hi there,
Up: Sorry, probably the wrong place to post that... With Curviloft - Loft by spline, I'm getting this when selecting the "Junction by orthogonal bezier curves" as Spline method. The modifying spline style seems to stop at the third edge. Just ask me the file or screenshots if needed. Error: #<ArgumentError: Cannot create unit vector from zero length vector> c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in `axes' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in `compute_by_offset' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:58:in `compute_by_vectors2' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:86:in `compute_by_normals' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:357:in `block in spline_profiling_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in `each' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in `each_with_index' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in `spline_profiling_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:249:in `spline_junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in `generic_junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in `junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in `block in link_construct_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in `each' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in `link_construct_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in `link_calculate_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:530:in `option_set_prop' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:206:in `option_set_prop' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in `call' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in `block in pal_family_spline_method' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in `call' ... You're doing amazing job! Re: [Plugin Library] LibFredo6 - v8.6g - 27 Sep 18NEW RELEASE: LibFredo6 v8.6g - 27 Sep 18
LibFredo6 8.6f fixes problems for Curviloft and includes a full Chinese translation by guanjin. _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.6g - 27 Sep 18hello , my sketchup doesnt appear anything .....
its installed libfredo but doesnt make any change :< how should i do ? Re: [Plugin Library] LibFredo6 - v8.6g - 27 Sep 18hello im having trouble with installing all your rubies..
my sketchup version is 2018 and in extension manager, your file all goes 'unvalid signature' i really wonder what is problem.. of course i installed your newest version, 8.6g plz let me know how i can fix this thank you Re: [Plugin Library] LibFredo6 - v8.6h - 15 Oct 18NEW RELEASE: LibFredo6 v8.6h - 15 Oct 18
LibFredo6 8.6h if for FredoCorner 1.2b (Fixes in Radius offset mode). _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Invalid Signature doesn't indicate there are any problems with the extension. It only means it hasn't been "signed" by the extensibility folks at SketchUp. It has nothing to do with the functionality of the extension. %
(THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
All my plugins are duly signed and scrambled by the Extension Warehouse. So there must be something else. Fredo
Re: [Plugin Library] LibFredo6 - v8.6h - 15 Oct 18hi Fredo6,
I have downloaded the latest version of fredo6 animator and the library. I am coming up with an issue I think. I have transitioning parts in my model, I select where my model starts transitioning from. However the origin of where my model is transitioning from keeps changing. Is there something I would need to adjust in my model? I very much appreciate your help! Re: [Plugin Library] LibFredo6 - v8.6h - 15 Oct 18
It s difficult to avise without the model. Could you please post it. Also, there is a dedicated subforum for Animator. The best would be that you open a new thread with your problem there. Thanks Fredo
Re: [Plugin Library] LibFredo6 - v8.6i - 21 Oct 18NEW RELEASE: LibFredo6 v8.6i - 21 Oct 18
LibFredo6 8.6i is for bug fixing and FredoTools 3.3a. _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.6i - 21 Oct 18Hi
I have problems with all fredo6 plugins Have Sketchup 18 pro, uses sketchup extension manager to install all plugins are updated and are in the same directory. When I press an icon, it does not respond. Do not get menu and no selections around the object. Someone who can help me. Re: [Plugin Library] LibFredo6 - v8.6j - 30 Oct 18NEW RELEASE: LibFredo6 v8.6j - 30 Oct 18
LibFredo6 8.6j is for bug fixing and small GUI adjustments (size of toolbar icons for high-DPI screens). _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.6k - 03 Nov 18NEW RELEASE: LibFredo6 v8.6k - 03 Nov 18
LibFredo6 8.6k provides new instructions for downloading FFmeg on Mac-OS platforms. IMPORTANT: the previous documentations included a link that is no longer supported and, worse, may have been hacked. So if you use Animator, please use the new link, https://www.ffmpeg.org/download.html Attached are the new PDF instructions _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.6k - 03 Nov 18How does one update LibFredo6? Do I have to delete and reinstall?
Re: [Plugin Library] LibFredo6 - v8.6m - 18 Nov 18NEW RELEASE: LibFredo6 v8.6m - 18 Nov 18
LibFredo6 8.6m is for Animator 2.3c (transparent background) and for the size of icons on hi-res screens. _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.6n - 05 Dec 18NEW RELEASE: LibFredo6 v8.6n - 05 Dec 18
LibFredo6 8.6n fixes occasional problems in Orbiting, in FredoTools::ThruPaint and possibly in some others of my plugins. _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.6p - 05 Dec 18NEW RELEASE: LibFredo6 v8.6p - 05 Dec 18
LibFredo6 8.6p fixes a random bug in Animator when using Movement Along Path. _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.7a - 18 Dec 18NEW RELEASE: LibFredo6 v8.7a - 18 Dec 18
LibFredo6 8.7a is a maintenance release providing adjustments to several of my plugins. _______________________________________________________________________________________ See plugin home page of LibFredo6 for Download of LibFredo6. Main Post of the LibFredo6 thread Fredo
Re: [Plugin Library] LibFredo6 - v8.7a - 18 Dec 18Hi Fredo,
I installed the last version of LibFredo v8.7a, there is an issue, I can't access to your plugins through the icons, it appears the options window and it disappears immediately. When I access through plugins Menu or Contextual Menu they work. When the tool (ex. JointPushPull) is running and I push the Tool Settings icon it happens the same, the settings window appears and it disappears immediately. macOS 10.13.6 & SU2017 Re: [Plugin Library] LibFredo6 - v8.7a - 18 Dec 18
Can you open the Ruby Console. Thanks Fredo
Re: [Plugin Library] LibFredo6 - v8.7a - 18 Dec 18Nothing in Ruby Console.
![]() I open for example Window Menu> LibFredo Options> Check Updates for Plugins and the window appears but it closes immediately. EDIT: After that I can use another Skechup Tools but if I press Cmd+Q (exit SU on Mac) SketchUp doesn't close, I have to force the exit. Last edited by Oxer on Wed Dec 19, 2018 8:35 pm, edited 1 time in total.
Re: [Plugin Library] LibFredo6 - v8.7a - 18 Dec 18Do you have the problem with the button palette of my plugins (like JointPushPull or FredoCorner) or is it just for the dialog boxes?
Re: [Plugin Library] LibFredo6 - v8.7a - 18 Dec 18It's with the dialogs (popup windows) only, the palletes works fine.
How I said you before to access to yours plugins I can do this through the Tool & Extensions Menu or Contextual Menu only.
Re: [Plugin Library] LibFredo6 - v8.7a - 18 Dec 18I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
MacOSX Mojave ShetchUp Pro v16...v19? Layout Twilight Pro v2 M2 Kerkythea PowerCADD
Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper. Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File... Another user has signaled me an anomaly with popup messages. Thanks Fredo
I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be. MacOSX Mojave ShetchUp Pro v16...v19? Layout Twilight Pro v2 M2 Kerkythea PowerCADD
Re: [Plugin Library] LibFredo6 - v8.7a - 18 Dec 18hmm... check for updates doesn't work either.
Users browsing this forum: Fabisala03 and 19 guests
