[Plugin Library] LibFredo6 - v8.8a - 24 Feb 19
Re: [Plugin Library] LibFredo6 - v8.4g - 10 Jun 18
Postby jjbrown » Sat Jun 16, 2018 5:43 pm
TIG wrote:Get the Lib from here: https://sketchucation.com/pluginstore?pln=LibFredo6
Then install it using the SketchUp > Window > Extension Manager dialog "Install Extension" red-button...
Also ensure that the installed extensions show as 'enabled' in the dialog.
Unless you have your Extension Manager's Loading-policy set to 'Unrestricted' you might have issues with older extensions - however, because Fredo's tools are up to date and properly 'signed' that should NOT be an issue... but perhaps try that just in case ?
Remember that the Lib on its own does little, but it vitally supports many of Fredo's other extensions.
Also after its installation [and those of any related extensions], then please close SketchUp and restart it to ensure that the Lib and its related extensions get fully registered and synced.
THIS WORKED .... THANK YOU !!!
jjbrown
Postby thasimakis » Mon Jul 02, 2018 1:22 pm
Hello all
I am having a problem with the toolbar visualisation. I can't find it anywhere. I have installed properly the plugin as seen in fredo's installation tutorial but it doesn't show up on my toolbar list
Any ideas?
thasimakis
Postby fredo6 » Mon Jul 02, 2018 4:32 pm
thasimakis wrote:I am having a problem with the toolbar visualisation. I can't find it anywhere. I have installed properly the plugin as seen in fredo's installation tutorial but it doesn't show up on my toolbar list
LibFredo6, which is simply a shared library, does not have any toolbar and does not do anything alone.
You need to install another of my plugins (like RoundCorner, FredoScale, ...) to see a toolbar for these plugins.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby wriopomba » Tue Jul 03, 2018 3:14 am
v8.4g didn't work on my computer :(. I would like to try a old version but i don't find it to donwload.
wriopomba
Postby fredo6 » Tue Jul 03, 2018 10:32 pm
wriopomba wrote:v8.4g didn't work on my computer :(. I would like to try a old version but i don't find it to donwload.
It would be useful to know what 'does not work'.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby GHira » Wed Jul 04, 2018 3:11 pm
Hello,
V8.4g didn't work well in my pc too.
My sketchup versions are 2018pro and 2014pro, and both of them don't work well.
This is error message. Sorry for two-byte text for I use Japanese version....
First line is just noticing error.
Fredo6_!LibFredo6.rbファイルをロード中にエラー発生
Error: #<ArgumentError: invalid byte sequence in UTF-8>
c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in `gsub'
c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in `get_dir_from_ENV'
c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in `dir_appdata'
c:/users/美穂子/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in `startup'
C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in `process'
C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in `<module:LibFredo6_Loader>'
C:/Users/美穂子/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
I wondered that this occurs because of my two-bite code user dir name(which automatically named when I installed win10),
but when I use older version libFredo, This problem didn't occur.
Does this helps you?
GHira
Postby GHira » Wed Jul 04, 2018 5:39 pm
By way of experiment, I made new windows user named alphabetical, and I newlly installed libfredo. then my probrem on this plugin was solved, It seems to be work well.
Sorry for my impatience and Thanks for wonderfull plugin...
GHira
Postby fredo6 » Wed Jul 04, 2018 7:14 pm
@GHira,
Definitely the error comes from your 2-bytes Windows username.
Your profile indicates that you use Sketchup 2014. Is that correct?
If so, then I suggest you move to Sketchup Make 2017 or Sketchup Pro 2018, which have a better support of Unicode in Ruby.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby guz » Tue Jul 10, 2018 9:00 pm
I'm having a similar issue with Curviloft (see attached image).
Perhaps there is a conflict with VRay? Was trying to troubleshoot why my toolbars wouldn't save their position. Ended up uninstalling / reinstalling plug-ins and received the Curviloft 1.7d: Error starting up plugin (creating menus and icons) error as well as a "lib6core.rbe:1058:in 'rescue in block in effective_load_part2" error.
-guz
Sorry, I just realized that the max size for an image is 2MB and 1600 px. I resized it here.
guz
Postby fredo6 » Wed Jul 11, 2018 10:55 am
guz wrote:I'm having a similar issue with Curviloft (see attached image).
I don't find the attached image.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby guz » Thu Jul 12, 2018 4:36 pm
Apologies for that. I didn't read the image limitations when I made my attachment. It is fixed now.
guz
Re: [Plugin Library] LibFredo6 - v8.5a - 13 Jul 18
Postby fredo6 » Fri Jul 13, 2018 6:42 am
NEW RELEASE: LibFredo6 v8.5a - 13 Jul 18
LibFredo6 8.5a is for Animator 2.2a and bug fixing
_______________________________________________________________________________________
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby penumbra » Fri Jul 13, 2018 8:20 pm
by process of elimination i discovered today that Fredo6 plugins are making my SU 2017 Pro run very very slow at satrtup and when i invoke the toolbards dialog box. I disabled all my plugins to find that sketchup ran fine. i enabled Fredo 6 lpugins again and slowness occurs again. I ahve udpated to latest version of all Fredo 6 plugins but have found the probelm persists.
windows 7 64 bit syste 32GB ram
Video Card Nvidia quadro M1000M
Edit: perhaps not, also disabled Vray and find better performance.
penumbra
Postby fredo6 » Fri Jul 13, 2018 11:05 pm
@penumbra
You have a performance menu entry showing the time to load for my plugins. I am interested by the result.
Is the slowness only for the startup time, and/or after when you model in Sketchup. Do you observe a lag after you see all toolbars displayed?
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v8.5b - 14 Jul 18
Postby fredo6 » Sat Jul 14, 2018 10:53 pm
NEW RELEASE: LibFredo6 v8.5b - 14 Jul 18
LibFredo6 8.5b is for Animator 2.2b (Full Screen option) and bug fixing
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby thaissoares » Wed Jul 25, 2018 4:39 am
Hello, I'm having trouble installing LibFredo6, the error message appears:
Erro ao carregar o arquivo Fredo6_!LibFredo6.rb
c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in `gsub'
c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in `get_dir_from_ENV'
c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in `dir_appdata'
c:/users/thaís/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in `startup'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in `process'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in `<module:LibFredo6_Loader>'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
Erro ao carregar o arquivo Fredo6_JointPushPull.rb
Error: #<TypeError: can't convert nil into an exact number>
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in `-'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in `require'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in `<module:Fredo6>'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in `<top (required)>'
Erro ao carregar o arquivo Fredo6_RoundCorner.rb
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in `<module:Fredo6>'
C:/Users/Thaís/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
It does not open in the window bar, but old versions work.
I use Windows 8 and SketchUp Pro 2017.
thaissoares
Postby TIG » Wed Jul 25, 2018 12:32 pm
The accented "i" in your [Portuguese ?] Windows user name [thaís] is almost certainly causing the issue.
Accented characters broke many scripts, until the newer versions of SketchUp got an updated Ruby installation, with extra tools available to try and circumvent such problems...
However, Fredo's tools have for a long time forced file-path encoding etc into UTF-8 format...
So I am surprised that this issue has occurred, let's wait for Fredo's comments...
Global Moderator
Re: [Plugin Library] LibFredo6 - v8.5c - 31 Jul 18
Postby fredo6 » Tue Jul 31, 2018 6:43 am
NEW RELEASE: LibFredo6 v8.5c - 31 Jul 18
LibFredo6 8.5c fixes issues with non-ascii Windows usernames
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v8.5f - 14 Aug 18
Postby fredo6 » Tue Aug 14, 2018 7:42 pm
NEW RELEASE: LibFredo6 v8.5f - 14 Aug 18
LibFredo6 8.5f increases the timeout for rendering in Vray from Animator. It also fixes other bugs.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Helle » Mon Aug 20, 2018 8:32 pm
SU 8 free. Updating I get this:
Error Loading File Fredo6_!LibFredo6.rb
undefined method `startup' for LibFredo6:ModuleError Loading File Fredo6_FredoScale.rb
no implicit conversion to float from nilError Loading File Fredo6_RoundCorner.rb
aiiii, what's wrong please, please help
regards Helle
Helle
Postby juju » Mon Aug 20, 2018 8:48 pm
Helle wrote:SU 8 free. Updating I get this:
regards Helle
Fredo6 is upgrading his extensions, support for some older versions of SU are being deprecated to facilitate compatibility with newer coding. SU8 would definitely be on the list of no longer supported SU versions.
juju
Premium Member
Premium Member
Postby Helle » Mon Aug 20, 2018 9:28 pm
oh, what a shame. I read it as "pre-8" and thought I could use it. Thanks for the fast reply
Helle
Postby cam_l » Wed Aug 22, 2018 1:01 am
any chance someone has a copy of the last pre-su8-deprecated version of libfredo? not even sure which version that would be..
cam_l
Premium Member
Premium Member
Postby sketchartist023 » Mon Aug 27, 2018 12:15 am
I am still using SU8 and have been for many years. Will not upgrade, been everything I need and more. Any way to upload SU8 compatible versions again for use?
sketchartist023
Re: [Plugin Library] LibFredo6 - v8.5h - 27 Aug 18
Postby fredo6 » Mon Aug 27, 2018 11:14 am
NEW RELEASE: LibFredo6 v8.5h - 27 Aug 18
LibFredo6 8.5h reestablishes the compatibility with SU8 and SU2013, which was broken with the previous version
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v8.6a - 06 Sep 18
Postby fredo6 » Thu Sep 06, 2018 10:39 pm
NEW RELEASE: LibFredo6 v8.6a - 06 Sep 18
LibFredo6 8.6a is dedicated to the first public version of FredoCorner
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Oxer » Fri Sep 07, 2018 3:42 pm
New version of Spanish language file:
LibFredo6_ES.lang.zip
http://www.oxervision.blogspot.com/
Oxer
Re: [Plugin Library] LibFredo6 - v8.6c - 08 Sep 18
Postby fredo6 » Sat Sep 08, 2018 10:30 am
NEW RELEASE: LibFredo6 v8.6c - 08 Sep 18
LibFredo6 8.6c fixes a problem of orbiting in FredoCorner.
It also integrates an update to the Spanish translation by Oxer.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v8.6d - 11 Sep 18
Postby fredo6 » Tue Sep 11, 2018 9:03 pm
NEW RELEASE: LibFredo6 v8.6d - 11 Sep 18
LibFredo6 8.6d includes a full French translation and fixes problems for FredoCorner 1.1c.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Oxer » Tue Sep 18, 2018 2:41 pm
Oxer
PreviousNext
Return to Plugins
Users browsing this forum: No registered users and 11 guests
