[Plugin Library] LibFredo6 - v8.7f - 10 Jan 19
Re: [Plugin Library] LibFredo6 - v7.7c - 16 Aug 17
Postby filibis » Thu Aug 17, 2017 8:13 am
fredo6 wrote:
  • The support of VRay in Animator.
Sounds good. Real good! :fro:
filibis
Postby thantunoo » Thu Aug 24, 2017 4:27 pm
How to uninstall Libfredo6 and round corner? pls...
thantunoo
Postby fredo6 » Thu Aug 24, 2017 5:53 pm
thantunoo wrote:How to uninstall Libfredo6 and round corner? pls...
In the Sketchup PluginDirectory, you should have 2 folders and 2 ruby files; just remove them!
You have two other methods, in case this is just for deactivation:
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v7.7d - 13 Sep 17
Postby fredo6 » Wed Sep 13, 2017 8:44 pm
NEW RELEASE: LibFredo6 v7.7d - 13 Sep 17
LibFredo6 7.7d is a maintenance release fixing bugs, in particular one that may affect Animator and some FredoTools plugins (DrawAlong, MoveAlong among others)
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v7.7e - 19 Sep 17
Postby fredo6 » Tue Sep 19, 2017 11:13 am
NEW RELEASE: LibFredo6 v7.7e - 19 Sep 17
LibFredo6 7.7e is a maintenance release fixing bugs, in particular one that may affect Animator and some FredoTools plugins (DrawAlong, MoveAlong among others). V7.7e also correct a bug that was introduced in v7.7d affecting TopoShaper.
Fredo
fredo6
PluginStore Author
PluginStore Author
Problème dans les arrondis
Postby fks4466 » Thu Sep 28, 2017 9:05 am
Bonjour,
Quand je fais de tout petits modèle (des composant électroniques), l'outil arrondi me fait des trous aux angles. Par exemple si je dessine une brique de 8 x 14 x 10 mm et que je fais des arrondis de 0,3 mm ça me fait des trous dans tous les coins.
J'ai mis sur le modèle une précision à 4 chiffres après la virgule, et 2 pour les angles et j'ai démarré avec le modèle "Documentation de construction en mm" Sous la dernière version de sketchup make (17.2.2555 64 bit).
Merci
Frank
fks4466
Re: Problème dans les arrondis
Postby fredo6 » Thu Sep 28, 2017 11:26 am
fks4466 wrote:Bonjour,
Merci
Frank
With these very small dimensions, Sketchup is not always able to create faces.
So the trick is to scale up the model by a factor like 10, perform the RoundCorner rounding and then scale back down.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v7.7f - 01 Oct 17
Postby fredo6 » Sun Oct 01, 2017 10:30 pm
NEW RELEASE: LibFredo6 v7.7f - 01 Oct 17
LibFredo6 7.7f is a maintenance release for OSX High Sierra. With previous versions you get dialog boxes popping up at startup time of Sketchup.
Note that you also need to upgrade FredoTools v3.1e; previous versions simply won't load under High Sierra.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby tchiddick » Mon Oct 02, 2017 11:29 pm
just downloaded libfredo6 in sketchup pro 2017, but cannot see any of the icons from the toolbar
tchiddick
Postby Dave R » Tue Oct 03, 2017 12:35 am
tchiddick wrote:just downloaded libfredo6 in sketchup pro 2017, but cannot see any of the icons from the toolbar
LibFredo doesn't have a toolbar so you wouldn't see any icons. LibFredo is a collection of helper files used with a number of Fredo's other extensions.
Global Moderator
Re: [Plugin Library] LibFredo6 - v7.8a - 11 Oct 17
Postby fredo6 » Wed Oct 11, 2017 9:01 pm
NEW RELEASE: LibFredo6 v7.8a - 11 Oct 17
LibFredo6 7.8a is a maintenance release for JointPushPull 4.0 evaluation.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby bondolossi » Sat Oct 21, 2017 5:00 am
thank you fredo you are the best!
bondolossi
Postby hlfunk43 » Mon Oct 23, 2017 11:05 pm
I have been trying for 2 weeks, off and on, to down load anything from LibFredo6 into window 2017. I have disabled add blocking and still get nothing. Also FYI Sketchup make 2017 does not have a plugin folder.
I would sure like to try the scale tool and the round corners. Howver I'm not going to continue to attempt the down load with out furter suggestions from you.
Sincerly,
Herman
funk.herman@yahoo.com
hlfunk43
Postby Dave R » Mon Oct 23, 2017 11:21 pm
hlfunk43 wrote:I have been trying for 2 weeks, off and on, to down load anything from LibFredo6 into window 2017. I have disabled add blocking and still get nothing.
How have you been attempting to get it?
hlfunk43 wrote:Also FYI Sketchup make 2017 does not have a plugin folder.
FYI, yes it does have a Plugins folder. It is in a location that is normally hidden but if extensions are installed correctly, there's no need for direct access to it by the user.
hlfunk43 wrote:I would sure like to try the scale tool and the round corners. Howver I'm not going to continue to attempt the down load with out furter suggestions from you.
Sincerly,
Herman
Again, how are you going about trying to install it?
Global Moderator
Postby TIG » Tue Oct 24, 2017 1:33 pm
Almost all Extensions download as RBZ files.
This is a special kind of ZIP file.
Sketchup's menu item Window > Extension Manager opens a dialog that allows you to manage you extensions.
It has a red button to 'Install an Extension'.
Use that and find the RBZ in the dialog which opens, and Sketchup will automatically install the contents for you in your user Plugins folder.
You rarely need to manually access this hidden folder.
Are you actually managing to download something ?
If you have got it tried putting the RBZ in some other location, or have manually added a Plugins folder I recommend you undo those erroneous actions.
If you are having issues downloading from the SketchUcation PluginStore there could be several issues blocking you...
Are you logged in ?
Sometimes you may be logged in to the main forums but the PluginStore wants a separate login.
You have an ad-blocker running on SketchUcation's pages - this is expressly against the terms of service you agreed to as a member. A modest income from ads helps pay for the up keep of the site and servers etc, you don't need to read the linked ads, but the advertisers expect them to be visible to members...
Another possible issue is that your firewall is blocking SketchUcation.com - if so 'whitelist' it.
Another weird possibility is that you have something set to download and extract ZIPped files automatically - which is useless for an RBZ because Sketchup expects the contents to be intact...
Also note that Lib files like this container 'helpers' for other programs, on its own LibFredo does nothing - you need to also install one or more of Fredo's Extensions for it to be of use to you...
Global Moderator
Postby hlfunk43 » Fri Oct 27, 2017 9:03 pm
Thanks for the reply TIG. I have tried all of the above, I think. The extension manager shows the plug ins there however When I start Sketchup 2017 make I get all kinds of error messages about not being able to read a bunch of files. I have even tried re-installing sketchup and still I get nothing. I'll get rid of every thing I have tried and then start over using your instructions.
hlfunk43
Postby fredo6 » Fri Oct 27, 2017 9:45 pm
hlfunk43 wrote:Thanks for the reply TIG. I have tried all of the above, I think. The extension manager shows the plug ins there however When I start Sketchup 2017 make I get all kinds of error messages about not being able to read a bunch of files. I have even tried re-installing sketchup and still I get nothing. I'll get rid of every thing I have tried and then start over using your instructions.
Could you tell what are those errors (maybe a snapshot of the message dialogbox)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby miir » Sat Oct 28, 2017 9:02 pm
ok
miir
Re: [Plugin Library] LibFredo6 - v7.8d - 01 Nov 17
Postby fredo6 » Wed Nov 01, 2017 9:32 am
NEW RELEASE: LibFredo6 v7.8d - 01 Nov 17
LibFredo6 7.8d is a maintenance release fixing a major bug for MacOS platforms, whereby opening some dialog boxes will provoke a hang when exiting Sketchup.
Thanks to driven, slbaumgartner and mariocha for helping me troubleshooting and fixing the problem.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v7.9a - 02 Nov 17
Postby fredo6 » Thu Nov 02, 2017 11:37 am
NEW RELEASE: LibFredo6 v7.9a - 02 Nov 17
LibFredo6 7.9a is a maintenance release fixing a major bug for MacOS platforms, whereby opening some dialog boxes will provoke a hang when exiting Sketchup.
It is also required for Animator 1.8a, for performance improvement when animating complex models.
Fredo
fredo6
PluginStore Author
PluginStore Author
Libfredo6 toolbars not working
Postby mrplease » Sat Nov 11, 2017 12:14 pm
Hi guys,
my libfredo6 toolbars have stopped working. Am using Win10 and SK2017, everything working fine until yesterday. As of today my Roundcorner and Fredoscale toolbars do nothing. They appear as always, but clicking does nothing. I've restarted, reinstalled, updated, backdated, etc to no avail. Any suggestions?
Cheers,
Mrplease
mrplease
Re: [Plugin Library] LibFredo6 - v8.0a - 12 Nov 17
Postby fredo6 » Sun Nov 12, 2017 6:05 pm
NEW RELEASE: LibFredo6 v8.0a - 12 Nov 17
LibFredo6 8.0a is a maintenance release dedicated to bug fixing and support of JointPushPull 4.2a (shading in preview) and Souvenir 1.5a (Favorites).
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v8.0b - 19 Nov 17
Postby fredo6 » Sun Nov 19, 2017 12:41 pm
NEW RELEASE: LibFredo6 v8.0b - 19 Nov 17
LibFredo6 8.0b is a maintenance release dedicated to improving the circular interpolation of cameras in Animator 1.8b.
_______________________________________________________________________________________
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby desayf » Wed Nov 29, 2017 2:07 pm
Error Loading File C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
Failed to read RBE/RBS file.
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in `process'
C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in `<module:LibFredo6_Loader>'
C:/Users/Fırat Aneyzi/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
how i fix it?
SU 2016
desayf
Postby TIG » Wed Nov 29, 2017 8:37 pm
Fredo will reply definitively, in due course...
However, I suspect that it is the user-name which is causing the issues...
"Fırat Aneyzi"
I guess it is Turkish - where the non-dotted "ı", as opposed to the final dotted "i", is used for the "uh" sound, instead of the "ee" sound...
But using proper UTF8 encoding [as Fredo does?] should trap for such things [we know that older SketchUp versions failed because of this non-standard characters, but the newer version are much more robust !]
Fredo ???
Global Moderator
Postby fredo6 » Thu Nov 30, 2017 4:01 am
I don't think this is the username, except for old versions of SU.
Sometimes, Sketchup cannot read the rbs/rbe file. This seems to come from an installation done without adminsitrator rights.
In general, a reinstallation of SU would solve the problem.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby TIG » Thu Nov 30, 2017 5:37 pm
Thanks Fredo.
Perhaps the odd-characters in the user-name are a "red-herring".
For the avoidance of doubt...
On a PC the only correct way to install any application like SketchUp...
Close that version of SketchUp, if necessary.***
You must then find the SketchUp installer's exe file - it's usually in your "Downloads" folder.
Select its icon.
Right-click > Context-menu >
"Run as administrator"
When prompted choose "Repair".
Let it complete the installation.
When you restart SketchUp it should work properly.
***If it's a new installation [e.g. you have previously uninstalled it, or it's just brand-new] the offered installer's option will just be "Install"...
Global Moderator
Re: [Plugin Library] LibFredo6 - v8.0c - 10 Dec 17
Postby fredo6 » Sun Dec 10, 2017 1:08 pm
NEW RELEASE: LibFredo6 v8.0c - 10 Dec 17
LibFredo6 8.0c is a maintenance release dedicated to the integration of VRay 3.6 in Animator.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby MennaD » Sun Jan 28, 2018 12:53 am
thankx
MennaD
Re: [Plugin Library] LibFredo6 - v8.1a - 23 Feb 18
Postby fredo6 » Fri Feb 23, 2018 10:10 pm
NEW RELEASE: LibFredo6 v8.1a - 23 Feb 18
LibFredo6 8.1a is a maintenance release dedicated to bug fixing and evolutions in other plugins
Fredo
fredo6
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: No registered users and 16 guests
