[Plugin Library] LibFredo6 - v12.9a - 13 May 22
NEW RELEASE: LibFredo6 v11.7a - 12 May 21
LibFredo6 11.7a includes
- bug fixing and various technical adjustments
NEW RELEASE: LibFredo6 v11.7c - 16 May 21
LibFredo6 11.7c includes
- bug fixing and various technical adjustments, mainly for Mac
I get no confirmation that my installation of updates (through the Extension Manager) does anything.
Is this to be expected?
SU Make 2017 -
Is this to be expected?What are you expecting to see? Extension Manager will show you the currently installed version of LibFredo6.
Fredo6's own Check for Updates will show you the currently installed version, too.
If you were using the Sketchucation tool to install it, you would get a notification through the tool that there is an update to be installed when there is.
@gregors said:
SU Make 2017
Your profile says you are using SketchUp 2015. Perhaps you would take a moment to update it?
Thanks I had not noticed the ">" which shows the version. All is good!
NEW RELEASE: LibFredo6 v11.8a - 02 Jun 21
LibFredo6 11.8a includes
- Support of the new extension LordOfTheToolbars v1.3a
HI Fredo ,
Have not been able to run the libfredo6 plugin successfully on Pro 2021
, tried reinstalling sketchup and re-down loading the plugin as per all the post feedback i could find on the web . Ps also no security access issues just to mention .I receive the following error message .
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:inprocess' C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in
module:LibFredo6_Loader'
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'Any assistance would be appreciated .
I think you have a wrong installation of LibFredo6.
Can you check you have a subfolder Fredo6_!LibFredo6 in your plugin directory, with a size of around 7 Mb.
NEW RELEASE: LibFredo6 v11.9a - 06 Jul 21
- Evolutions for LordOfTheToolbars v1.4a
NEW RELEASE: LibFredo6 v11.9b - 08 Jul 21
LibFredo6 11.9b includes
- Evolutions for LordOfTheToolbars v1.4c
NEW RELEASE: LibFredo6 v11.9c - 10 Jul 21
LibFredo6 11.9c includes
- Evolutions for LordOfTheToolbars v1.4d
NEW RELEASE: LibFredo6 v12.0a - 17 Sep 21
LibFredo6 12.0a includes
- Bug fixing and evolutions for LordOfTheToolbars v1.5a
NEW RELEASE: LibFredo6 v12.0b - 30 Sep 21
- Bug fixing for calculation of volumes in several plugins
- Other fixes
NEW RELEASE: LibFredo6 v12.1a - 23 Oct 21
LibFredo6 12.1a is mainly dedicated to the new plugin MoveAlignMe
I need some help. I am running SU 15.3.330 32 bit for now.
I'm getting a new 64 bit PC in a month or so and will upgrade to SU latest.Why is irrelevant at this time, but if you need to know, ask me.
I ran SU 15 from my old installation but the Fredo Lib was partially corrupted and many tools do not work. I lived with it till now when a tool I really needed was not working.
I want to reload Fredo Lib but the only one I can find is for SU 17+.Where can I find a copy of Fredo Lib for SU 15 32 bit?
If you'd search in the Sketchucation PluginStore--link at the top right of the forum page--you could find the older version for pre-2017 versions of SketchUp. Same with other extensions that Fredo6 offers for the older versions of SketchUp.
https://sketchucation.com/pluginstore?pln=PRIOR_SU2017_LibFredo6
Would you please update the installation video? Some changes have taken place between that and SketchUp2021, and I am unable to follow the instructions as given...and am still stuck and unable to install and use your plugins. Thank you.
NEW RELEASE: LibFredo6 v12.2a - 01 Nov 21
LibFredo6 12.2a includes
- Evolutions for FredoSpline v2.3a
- Technical adjustments
Bonjour je n'arrive pas à télécharger libfredo6 pouvez m'aider ?
Télécharger ou installer ?
