[Plugin Library] LibFredo6 - v14.3d - 21 Apr 24
Hello LibFredo6,
I recieved your message showing me your Pic2Shape plugin.
I tried it with a couple of images and it works great.
However, I would like to use this for cutting out the contours of 2D trees, so i can cast a more realistic shadow.
And here I ran into some troubles.
For complex trees (with a lot of tiny holes between the branches) the plugin says he can't generate any contours.
I wonder if you could help me with the right filter settings so that the plugin can still work ?I attached a tree (png) that doesn't generate a boundary when using the plugin.
All the png trees i'm using are available (for free) as high quality PNG’s with transparent background from this website : https://meye.dk/info/
Many thanks in advance !
Boris
Since this thread is about LibFredo6, I created a dedicated thread here.
Very efficient plugin thank you.
The only issue is that the colour of action icons are extremely difficult to read against the white background.
I am using SUP2021 on a MacBoo pro 2018 running under MacOS Mojave.Is it just me or a common issue that could be resolved easily on the developer's end?
Thank you.
T
This will be fixed in the next version of LibFredo6. This seems to happen for some Mac configurations.
NEW RELEASE: LibFredo6 v11.7a - 12 May 21
LibFredo6 11.7a includes
- bug fixing and various technical adjustments
NEW RELEASE: LibFredo6 v11.7c - 16 May 21
LibFredo6 11.7c includes
- bug fixing and various technical adjustments, mainly for Mac
I get no confirmation that my installation of updates (through the Extension Manager) does anything.
Is this to be expected?
SU Make 2017 -
Is this to be expected?What are you expecting to see? Extension Manager will show you the currently installed version of LibFredo6.
Fredo6's own Check for Updates will show you the currently installed version, too.
If you were using the Sketchucation tool to install it, you would get a notification through the tool that there is an update to be installed when there is.
@gregors said:
SU Make 2017
Your profile says you are using SketchUp 2015. Perhaps you would take a moment to update it?
Thanks I had not noticed the ">" which shows the version. All is good!
NEW RELEASE: LibFredo6 v11.8a - 02 Jun 21
LibFredo6 11.8a includes
- Support of the new extension LordOfTheToolbars v1.3a
HI Fredo ,
Have not been able to run the libfredo6 plugin successfully on Pro 2021
, tried reinstalling sketchup and re-down loading the plugin as per all the post feedback i could find on the web . Ps also no security access issues just to mention .I receive the following error message .
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:inprocess' C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in
module:LibFredo6_Loader'
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'Any assistance would be appreciated .
I think you have a wrong installation of LibFredo6.
Can you check you have a subfolder Fredo6_!LibFredo6 in your plugin directory, with a size of around 7 Mb.
NEW RELEASE: LibFredo6 v11.9a - 06 Jul 21
- Evolutions for LordOfTheToolbars v1.4a
NEW RELEASE: LibFredo6 v11.9b - 08 Jul 21
LibFredo6 11.9b includes
- Evolutions for LordOfTheToolbars v1.4c
NEW RELEASE: LibFredo6 v11.9c - 10 Jul 21
LibFredo6 11.9c includes
- Evolutions for LordOfTheToolbars v1.4d
NEW RELEASE: LibFredo6 v12.0a - 17 Sep 21
LibFredo6 12.0a includes
- Bug fixing and evolutions for LordOfTheToolbars v1.5a
NEW RELEASE: LibFredo6 v12.0b - 30 Sep 21
- Bug fixing for calculation of volumes in several plugins
- Other fixes
NEW RELEASE: LibFredo6 v12.1a - 23 Oct 21
LibFredo6 12.1a is mainly dedicated to the new plugin MoveAlignMe
I need some help. I am running SU 15.3.330 32 bit for now.
I'm getting a new 64 bit PC in a month or so and will upgrade to SU latest.Why is irrelevant at this time, but if you need to know, ask me.
I ran SU 15 from my old installation but the Fredo Lib was partially corrupted and many tools do not work. I lived with it till now when a tool I really needed was not working.
I want to reload Fredo Lib but the only one I can find is for SU 17+.Where can I find a copy of Fredo Lib for SU 15 32 bit?
If you'd search in the Sketchucation PluginStore--link at the top right of the forum page--you could find the older version for pre-2017 versions of SketchUp. Same with other extensions that Fredo6 offers for the older versions of SketchUp.
https://sketchucation.com/pluginstore?pln=PRIOR_SU2017_LibFredo6
