[Plugin Library] LibFredo6 - v14.2a - 26 Aug 23
Re: [Plugin Library] LibFredo6 - v11.6a - 23 Jan 21
Postby tlehman914 » Mon Apr 05, 2021 2:21 pm
fredo6 wrote:I don't know what happened during the installation, but there is clearly a problem in a few files which lost their UTF8 encoding.
Could you try the following
- Open the Ruby Console
- copy the following command in red and type Enter:
UI.openURL LibFredo6.path + '/Ancillary'
- This will open a subfolder of LibFredo6
- Delete the file Colors_RAL_classic.txt
- restart Sketchup to see if this improves the situation
- Otherwise, delete all files with names beginning with Colors_ and extension txt.
Then restart Sketchup to see if this improves the situation.
I did try to copy the following command in red and type Enter:
Result:
false
I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
I then deleted all files with names beginning with Colors_ and extension txt. - restarted and tried to use the only PlugIn installed: ToolsOnSurface - result:
Error: #<ArgumentError: invalid byte sequence in UTF-8>
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in `strip'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9318:in `load_from_file'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9221:in `block in load_all_colors'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in `each'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9216:in `load_all_colors'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9164:in `initialize'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in `new'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:9151:in `instantiate'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:3830:in `color_parse'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4007:in `color_luminance'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:4017:in `color_is_dark?'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2797:in `draw_button_text'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:2699:in `draw_button'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3203:in `block in draw'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in `each'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3196:in `draw'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:78:in `draw'
/users/toddlehman/library/application support/sketchup 2021/sketchup/plugins/fredo6_toolsonsurface/shapeonsurface.rbe:575:in `draw'
User avatar
tlehman914
Postby fredo6 » Mon Apr 05, 2021 2:39 pm
tlehman914 wrote:I did however, go to that folder in 'Finder' and Delete the file Colors_RAL_classic.txt - restarted and no change.
What is left in the directory?
Just type in the Ruby console:
Dir[LibFredo6.path + '/Ancillary/*.*']
User avatar
Premium Member
Premium Member
Postby tlehman914 » Mon Apr 05, 2021 3:04 pm
Nothing is left in the directory...?
No change after typing the above.
User avatar
tlehman914
Postby fredo6 » Mon Apr 05, 2021 3:08 pm
Did you define a custom color file?
If so, do you remember where you save it?
In the Ruby Console, could you type
Traductor::Marshall.new.decode(Traductor::Registry.load "Fredo6_ColorFan_Custom")
This should be the list of custom color files.
User avatar
Premium Member
Premium Member
Postby tlehman914 » Mon Apr 05, 2021 3:14 pm
fredo6 wrote:Did you define a custom color file?
{"/Users/toddlehman/Dropbox (Cre8Play)/SketchUp/Materials/Archive/Bark/Tree Tex8.jpg"=>true}
User avatar
tlehman914
Postby tlehman914 » Mon Apr 05, 2021 4:02 pm
I deleted the material 'Tree Tex8.jpg', and all is working!!!! :thumb: :fro: :bounce:
THANK YOU!!!!
User avatar
tlehman914
Postby fredo6 » Mon Apr 05, 2021 4:04 pm
tlehman914 wrote:I deleted the material 'Tree Tex8.jpg', and all is working!!!! :thumb: :fro: :bounce:
In ColorPaint, you are supposed to load only plain text file (tabular value of colors: name, R, G, B), not images or material.
User avatar
Premium Member
Premium Member
Postby Robotopera » Mon Apr 05, 2021 4:14 pm
fredo6 wrote:How did you install LibFredo6?
- Copying files?
- Sketchup Extension manager from a rbz
- Sketchucation ExtensionStore?
It seems one file is altered.
Tried all 3 with full uninstalls in between each. Sadly no luck.
Success! Running a repair on the sketchup installation seemed to fix it!
Robotopera
Postby tlehman914 » Mon Apr 05, 2021 4:51 pm
Understood. I didn't even know that I had done that...!? Thanks again!
User avatar
tlehman914
Postby atrasnap » Fri Apr 09, 2021 1:58 pm
Bonjour à tous,
Je viens d'installer l'extension FredoTools via le gestionnaire d'extension,
Elle apparait bien dans mon gestionnaire d'extension mais nul part ailleurs ?
Je ne peut donc pas l'utiliser.
Il ya t-il une raison ou une manip particulière à effectuer ?
Je suis sur SketchUp 21pro
Merci d'avance
atrasnap
Postby TIG » Fri Apr 09, 2021 3:41 pm
Have you also installed LibFredo ?
Have you restarted SketchUp ?
Have you looked in the Tools menu's submenus ?
Avez-vous également installé LibFredo?
Avez-vous redémarré SketchUp?
Avez-vous regardé dans les sous-menus du menu Outils [Tools]?
User avatar
Global Moderator
Postby martychristoffel » Sat Apr 17, 2021 1:56 am
I'm seeing some UI problems, specifically buttons at the bottom of various dialog boxes being completely washed out. I'm on MacOS Big Sur.
I don't have this problem in other applications, only here in SketchUp and with these dialog box buttons.
Any thoughts? Is it a SketchUp thing, an extension thing, or an OS thing?
Please see image examples.
Thanks.
martychristoffel
Postby fredo6 » Sat Apr 17, 2021 8:33 pm
@martychristoffel
Thanks for signaling this problem. You are the first one.
Big Sur seems to be a master in term of non-backward compatibility, at least for Sketchup...!
I will see if I can find a workaround in a next version of LibFredo6.
User avatar
Premium Member
Premium Member
Postby Dekorte » Sun Apr 25, 2021 1:41 pm
Hello LibFredo6,
I recieved your message showing me your Pic2Shape plugin.
I tried it with a couple of images and it works great.
However, I would like to use this for cutting out the contours of 2D trees, so i can cast a more realistic shadow.
And here I ran into some troubles.
For complex trees (with a lot of tiny holes between the branches) the plugin says he can't generate any contours.
I wonder if you could help me with the right filter settings so that the plugin can still work ?
I attached a tree (png) that doesn't generate a boundary when using the plugin.
All the png trees i'm using are available (for free) as high quality PNG’s with transparent background from this website : https://meye.dk/info/
Many thanks in advance !
Boris
Dekorte
Postby fredo6 » Sun Apr 25, 2021 2:55 pm
Since this thread is about LibFredo6, I created a dedicated thread here.
User avatar
Premium Member
Premium Member
Postby Tibonator » Fri May 07, 2021 10:30 am
Very efficient plugin thank you.
The only issue is that the colour of action icons are extremely difficult to read against the white background.
I am using SUP2021 on a MacBoo pro 2018 running under MacOS Mojave.
Is it just me or a common issue that could be resolved easily on the developer's end?
Thank you.
T
Tibonator
Postby fredo6 » Sun May 09, 2021 7:55 pm
This will be fixed in the next version of LibFredo6. This seems to happen for some Mac configurations.
User avatar
Premium Member
Premium Member
Re: [Plugin Library] LibFredo6 - v11.7a - 12 May 21
Postby fredo6 » Wed May 12, 2021 2:24 pm
NEW RELEASE: LibFredo6 v11.7a - 12 May 21
LibFredo6 11.7a includes
  • bug fixing and various technical adjustments
_______________________________________________________________________________________
User avatar
Premium Member
Premium Member
Re: [Plugin Library] LibFredo6 - v11.7c - 16 May 21
Postby fredo6 » Sun May 16, 2021 9:10 pm
NEW RELEASE: LibFredo6 v11.7c - 16 May 21
LibFredo6 11.7c includes
  • bug fixing and various technical adjustments, mainly for Mac
User avatar
Premium Member
Premium Member
Postby GregorS » Tue May 25, 2021 7:02 am
I get no confirmation that my installation of updates (through the Extension Manager) does anything.
Is this to be expected?
SU Make 2017
GregorS
Postby Dave R » Tue May 25, 2021 9:07 pm
GregorS wrote:I get no confirmation that my installation of updates (through the Extension Manager) does anything.
What are you expecting to see? Extension Manager will show you the currently installed version of LibFredo6.
Fredo6's own Check for Updates will show you the currently installed version, too.
If you were using the Sketchucation tool to install it, you would get a notification through the tool that there is an update to be installed when there is.
GregorS wrote:SU Make 2017
Your profile says you are using SketchUp 2015. Perhaps you would take a moment to update it?
User avatar
Global Moderator
Postby GregorS » Wed May 26, 2021 7:12 am
Thanks I had not noticed the ">" which shows the version. All is good!
GregorS
Re: [Plugin Library] LibFredo6 - v11.8a - 02 Jun 21
Postby fredo6 » Wed Jun 02, 2021 7:23 am
NEW RELEASE: LibFredo6 v11.8a - 02 Jun 21
LibFredo6 11.8a includes
  • Support of the new extension LordOfTheToolbars v1.3a
User avatar
Premium Member
Premium Member
Postby CTruter » Mon Jun 28, 2021 10:25 am
HI Fredo ,
Have not been able to run the libfredo6 plugin successfully on Pro 2021
, tried reinstalling sketchup and re-down loading the plugin as per all the post feedback i could find on the web . Ps also no security access issues just to mention .
I receive the following error message .
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:67:in `process'
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:74:in `<module:LibFredo6_Loader>'
C:/Users/Christo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
Any assistance would be appreciated .
CTruter
Postby fredo6 » Mon Jun 28, 2021 4:49 pm
@CTruter,
I think you have a wrong installation of LibFredo6.
Can you check you have a subfolder Fredo6_!LibFredo6 in your plugin directory, with a size of around 7 Mb.
User avatar
Premium Member
Premium Member
Re: [Plugin Library] LibFredo6 - v11.9a - 06 Jul 21
Postby fredo6 » Tue Jul 06, 2021 9:50 pm
NEW RELEASE: LibFredo6 v11.9a - 06 Jul 21
User avatar
Premium Member
Premium Member
Re: [Plugin Library] LibFredo6 - v11.9b - 08 Jul 21
Postby fredo6 » Thu Jul 08, 2021 6:27 pm
NEW RELEASE: LibFredo6 v11.9b - 08 Jul 21
LibFredo6 11.9b includes
User avatar
Premium Member
Premium Member
Re: [Plugin Library] LibFredo6 - v11.9c - 10 Jul 21
Postby fredo6 » Sat Jul 10, 2021 11:14 am
NEW RELEASE: LibFredo6 v11.9c - 10 Jul 21
LibFredo6 11.9c includes
User avatar
Premium Member
Premium Member
Re: [Plugin Library] LibFredo6 - v12.0a - 17 Sep 21
Postby fredo6 » Fri Sep 17, 2021 7:50 am
NEW RELEASE: LibFredo6 v12.0a - 17 Sep 21
LibFredo6 12.0a includes
User avatar
Premium Member
Premium Member
Re: [Plugin Library] LibFredo6 - v12.0b - 30 Sep 21
Postby fredo6 » Thu Sep 30, 2021 6:45 pm
NEW RELEASE: LibFredo6 v12.0b - 30 Sep 21
  • Bug fixing for calculation of volumes in several plugins
  • Other fixes
User avatar
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: cheesecakelux, Deonx, Emanuel2104, insigniarq, JLPG1969, joel_098, LucioCorbus, robertWan and 13 guests
