by Box » Sat Mar 16, 2013 10:28 am
TS200010 wrote:Just installed them - however, no icons on the buttons and an almost immediate Bug Splat. Lost all my work.
This suggests you installed the plugin while working on a file. Generally speaking you should install plugins with SU closed, or at the very least close and reopen SU before using the plugin for the first time. Also worth trying it out on a junk file before anything important. So having said that, if you did install it with SU open, try installing it again with SU closed.
- Name: Box
- Operating system: Windows
- SketchUp version: 2020
- License type: Pro
- SketchUp use: other
by Dave R » Sat Mar 16, 2013 1:39 pm
TS200010 wrote:Dave, Thanks - I am a RubyNewbe ... there were no installation instructions so I just guessed - apparantly incorrectly.
There are multiple threads here explaining how to install plugins. The basic thing which would apply to any ZIP folder is to maintain the file structure as shipped in the compressed folder. Since the icons don't appear on the toolbar, it is safe to assume that the icon images are not in the colder called clf_perpendicular_face_tools which is where the related loader file would be looking for them. If you didn't keep those image files in that folder, you probably also don't have clf_perpendicular_face_tools.rb in that folder either. You should explore through the Plugins folder and find the .rb and the six image files and put them where they belong. It would probably be easier to delete those files and reinstall the plugin correctly. I wopuld suggest you download and use 7-zip to do this. It won't destroy the folder structure as the Windows native unzipper is wont to do.
- Global Moderator
- Name: Dave R
- SketchUp version: 2021
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Advanced
by Chris Fullmer » Sun Mar 17, 2013 4:47 am
I also have problems with winzip destroying the folder structure, depending on the winzip version. Also from what I understand Macs add an extra folder to the mix. For most of my plugins, I have a single file that just goes into the plugins folder. If there are additional files, they get loaded into a subfolder.
- SketchUp Team
- Name: Chris Fullmer
- SketchUp version: 2013
- License type: Pro
- SketchUp use: landscape architecture
by HornOxx » Thu Jun 20, 2013 10:11 am
Great - Thank you so much !!! I discovered this great tool so late
HornOxx
- Name: HornOxx
- SketchUp version: 2019
- License type: Pro
- SketchUp use: architecture
by stpauljason » Mon Jul 01, 2013 3:32 am
Chris,
I love your plugins.
However I've just recently added your plugins (Extended Views and Perpendicular Faces to Sketchup 2013. When I check the box for the toolbars, they seem to create a unique toolbar just below the normal context menu (File, edit, etc). This toolbar is hidden if any other toolbar is there, and the unique toolbar can not be moved. Additionally only one of the toolbars either Exteneded Views, or Perpendicular Faces displays at one time, hiding the other one.
stpauljason
- Name: jason
- License type: Pro
- SketchUp use: education
- Level of SketchUp: Beginner
by thomthom » Mon Jul 01, 2013 9:10 am
Jason: That's a bug in the first release of SketchUp 2013 - install the update that was released some weeks ago and it should work fine.
- PluginStore Author
- Name: Thomas Thomassen
- License type: Pro
by vojo » Mon Jul 01, 2013 4:06 pm
I want to take a quick minute to point out that this plugin works VERY WELL. I have not had one problem with this and have used it quite extensively. This is a plugin I would recommend
vojo
by stpauljason » Mon Jul 01, 2013 8:10 pm
Thanks Thomas,
I updated Sketchup 2013 and the plugin has its own toolbar now.
stpauljason
- Name: jason
- License type: Pro
by Hammerhead64 » Thu Nov 14, 2013 11:52 am
Chris this is such a good tool, I have spent years using a combination of the standard tools in SU to get elements perpendicular to a path. Thx for sharing.
....... Quicker models here I come.
Hammerhead64
- Name: Paul Gardner
- SketchUp version: 8
- License type: Pro
by gonashvili » Wed Dec 11, 2013 4:49 pm
Just wanna say that this plugin is them bananas. Super, SUPER useful.
Cheers.
gonashvili
- Name: Hamlet G
- License type: Pro
by sicksickisck » Thu Oct 16, 2014 9:22 am
still does not work inside a component
sicksickisck
- Name: sickx3
- SketchUp version: 2016
- License type: Pro
- SketchUp use: product design
by cotty » Thu Oct 16, 2014 9:29 am
sicksickisck wrote:still does not work inside a component
What do you mean here? Do you have an example?
cotty
- Top SketchUcator
- Name: Carsten
- License type: Pro
- SketchUp use: hobby
by Dave R » Thu Oct 16, 2014 10:12 am
Yes. What do you mean? I just tried it and it works fine inside a component. I made a component of the Bezier curve, opened the component for editing and ran the tool. It put the face on the end where I clicked. Screenshot - 10_16_2014 , 4_18_46 AM.png
- Global Moderator
- Name: Dave R
- License type: Pro
by djohnson.nz » Wed Oct 18, 2017 12:31 am
Thanks Chris, extremely useful time saver. I did have trouble creating a circle in a group, it didn't seem to work but after closing the group I found the circles outside the group. I was able to remedy this by changing your "Perpendicular Circle" script to read entities=model.active_entities which I found was the only thing different from your Perpendicular Square script. Thanks for all your great work...
nO fiKst ideas
djohnson.nz
- Name: djohnson.nz
- License type: Pro
by designerbursa » Wed May 22, 2019 12:11 pm
still does not create circles of less than 30 mm
I'm working in mm, 2540 is the default by default. Changed by changing the r.b code thanks for the plugin
my edit:
def activate @ip = Sketchup::InputPoint.new @iptemp = Sketchup::InputPoint.new @displayed = false @sp = [] @end_pos = [] @ctrlflag = 0 @group = nil if @@ls.to_s == "" @@ls = 100.mm end Sketchup.set_status_text @@ls.to_l, SB_VCB_VALUE Sketchup.vcb_label = "Face Width x Height" end
designerbursa
- Name: sami bayram
- License type: Pro
- SketchUp use: interior design
by thegoodguy » Wed Nov 11, 2020 5:12 pm
I just installed this on Sketchup 2016. It worked well and was super-useful when I had Sketchup 8, but is not working on 2016. There are no notes I can find saying which versions this plugin is compatible with. Am I missing something?
Thanks.
thegoodguy
- Name: thegoodguy
- License type: Pro
by Dave R » Wed Nov 11, 2020 5:21 pm
It works fine in SU2016 as well as every version up through SU2020.
You might try restarting SketchUp to make sure the plugin loads.
Are you sure it's not working? Is it possible the face it's creating is just so large its edges are outside the view of the camera?
- Global Moderator
- Name: Dave R
- License type: Pro
- Robot
Return to Plugins
