[Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
Re: [Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
Postby pilou » Sat May 30, 2009 1:45 am
Suggestion (but seems very useful) ;)
perpendicular face tool with selection of some lines !
So no need to click line after line!!! 8-)
Speedy Galerie
Top SketchUcator
Postby Chris Fullmer » Sat May 30, 2009 1:57 am
I like that idea. That is one to implement on the next round. I'd also like to have better support for perpendicular lines coming off of simple arcs and circles.
I realy need a feature request tracker so that I have them all together for when I get ready to re-write some of these scripts! THanks for the great suggestions everyone, on all my scripts.
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby publied » Wed Jun 03, 2009 9:53 am
nice job! very useful plugin. thank you.
publied
Postby utiler » Thu Jun 11, 2009 1:23 am
Hi Chris, another idea....
Have you considered adding components and groups to this tool? as with your custom face tool, another option that I think people would find 'components perpendicular; tool handy....
Maybe another tool though as this is a 'perpendicular face' tool after all.
Cheers,
utiler
Top SketchUcator
Postby Edson » Wed Aug 12, 2009 5:34 pm
chris,
i have downloaded the latest version posted above and am having a number of problems:
1. on the text it says 1.1 not 1.2. could you have posted the wrong script?
2. the custom shape does not explode after it is placed;
3. all the faces get oriented parallel to the red axis;
4. control does not work as described;
5. the up arrow does not work as described.
i am on mac. could there be some incompatibility?
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby Chris Fullmer » Wed Aug 12, 2009 5:53 pm
Hmm, interesting. I know there were problems. Do you have sketchy physics installed? I know Chris implemented some things in SketchyPhysics that clash with the arrow keys. I'm not sure if ever fixed it. Perhaps try removing sketchyphysics if you have it.
If not, there was also a Mac issue, but I fixed that early on I think. But perhaps the wrong version is posted. I'll try to look into today for you.
Chris
SketchUp Team
SketchUp Team
Postby Edson » Wed Aug 12, 2009 8:46 pm
no sketchyphysics installed. the odd thing is that all your other scripts work for me.
Edson
Global Moderator
Postby Chris Fullmer » Wed Aug 12, 2009 9:00 pm
I have a feeling that I never got around to updating this script again after I found out that Macs and PC arrow keys are registered differently. I'll need to look at it again and figure out how to change it. I thought I had already, but it must be another script. Perhaps I remembering that I did it on shapebender, but never got around to fixing this one correctly.
Sorry Edson, I'll try to get it working.
Also, I don't think that I had planned on exploding the face once it gets put on the end of the line. If I explode it in the script, then if there is geometry in the way, it could clash. So I leave it up to the user to explode on their own, once they have verified that the shape does not intersect with other geometry.
And I checked the version number. It is the right script, I just forgot to update that line in the code...sorry!
And as for th3e red axis, there is a good chance that the up arrow keys are messing things up before the script aligns the face. I am really anxious to start coding again, I just need to get in and do it. So give me a few days and I'll see if I can bust out a new version of this.
Chris
SketchUp Team
SketchUp Team
Postby Edson » Wed Aug 12, 2009 9:29 pm
take your time, chris. no hurry. we have a lot to thank you for already.
Edson
Global Moderator
Postby markozeta » Thu Sep 24, 2009 5:32 pm
7.1 bug perhaps? Entering in a fractional value for face size for the circular tool (e.g. 6 3/4") in the VCB results in the circle only coming out to 6" radius.
And I use this thing all the time... help me out!
BSME - Cal Poly Pomona
Sketchup Pipe Maniac
markozeta
Postby Chris Fullmer » Thu Sep 24, 2009 6:50 pm
Is this new to 7.1? Or was it like this before? It might just be me not coding it correctly. Try using a decmial instead of fraction for now. I think that should work. I'll look into when I get a a chance.
And if it is a 7.1 thing, that is very interesting. I know that CadFather found some issue with units. And units and decimals and fractions are all connected.
Chris
SketchUp Team
SketchUp Team
Postby kwistenbiebel » Mon Sep 28, 2009 4:50 am
Hi there,
Just wanted to drop in to say thank you to Chris.
This is a wonderful tool. :thumb:
I use it to position mesh lights perpendicular to the camera line (for rendering).
The video in the first post is great. I especially like the sound of your wife doing the dishes while you recorded it. :)
kwistenbiebel
Postby mervin » Tue Sep 29, 2009 1:58 pm
I found a bug. Nothing happened when I use "perpendicular circle" tool to place a circle whose radius is smaller enough, for example 10mm. Because of nothing happened, I did it many times, then it crash. Is there any way to fix this??
mervin
Postby choppir » Wed Oct 07, 2009 2:10 pm
amazing! thanks!
choppir
Postby Vicspa » Wed Oct 07, 2009 4:01 pm
Another great tool, Thanks Chris,...keep'em coming. :thumb:
Vicspa
Postby Chris Fullmer » Wed Oct 07, 2009 9:50 pm
Thanks again for all the great comments. Devloping these scripts is a lot of fun, but it is sure helpful when there is also people letting you know they appreciate the work and time that has been put into these scripts - THANKS!
Chris
SketchUp Team
SketchUp Team
Postby skkor9y » Wed Oct 28, 2009 8:58 pm
BIG Thanx...
skkor9y
Postby AcesHigh » Tue Nov 10, 2009 2:33 pm
Chris, does it only works with FACES?? Why not with 3d objects too?
I then tried to create SINGLE faces, and make them into a component, so I would place them with your plugin and then replace ONE component with a more complex 3D object... but it also didnt accept using the component... the face must be exploded :(
Cant you change that?
AcesHigh
Postby Chris Fullmer » Tue Nov 10, 2009 4:56 pm
I don't have time right now to fix it how you would like, but as a work around, you could also install my components to faces plugin. That will apply your component to all selected faces, which would probably do what your looking for, for now.
Chris
SketchUp Team
SketchUp Team
Postby AcesHigh » Tue Nov 10, 2009 5:18 pm
Thanks for the suggestion... in fact, I already had your two plugins installed, I guess I just hadnt used them yet! :)
AcesHigh
Postby Ben Ritter » Wed Apr 07, 2010 4:00 pm
Hi Chris,
I installed v1.2 and the script doesn't show up anywhere, not under the Plugins pull-down, or your separate sub-list under Plugins.
I'd appreciate your help.
Thank you. Ben
Ben Ritter
Postby Chris Fullmer » Wed Apr 07, 2010 5:04 pm
Hi Ben, sounds like it is not getting put in the correct place somehow. There should be a single file called clf_perpendicular_face_tools_loader.rb in the main plugins folder. And a folder called clf_perpendicular_face_tools that has all the other files it in (clf_perpendicular_face_tools.rb, circle_xx.png(2), square_xx.png(2), and star_xx.png(2)). So make sure everything is in the right spot and let me know if that helps. If not, we'll keep trying,
Chris
SketchUp Team
SketchUp Team
Postby Ben Ritter » Wed Apr 07, 2010 5:45 pm
Chris,
My folders are configured just as you say and no-go. I even deleted all the files and reinstalled the zip file.
I'm puzzled too, because on another computer it works just fine. :?:
I appreciate your help and love your script (on the other computer ;) )
Ben Ritter
Postby Chris Fullmer » Wed Apr 07, 2010 6:22 pm
OK, one last thing to try before we dive into deep troublshoot mode.
This is one of the few scripts that I wrote where I toyed around with the idea of disabling it by default. So just go try to enable it in the preferences menu - Window > Prefences > Extensions and make sure it is turned on. If that does not do it, then I'll PM you a new tweaked script that will output errors for me to look at.
Chris
SketchUp Team
SketchUp Team
Postby Ben Ritter » Wed Apr 07, 2010 7:14 pm
Chris, well there it is.
Thank you. I forgot to check the preferences all the while thinking there we one place like that to check. I'll have to remember that for future problems.
Ben
Ben Ritter
Postby taurus195 » Sat Apr 10, 2010 7:56 pm
Amazing plug-in! I've been looking for something like this for quite some time. It really is a time saver, thank you.
taurus195
Postby snowflake » Mon Jun 07, 2010 12:02 pm
Hi Chris, I've had some trouble with your tool.
Using a millimeter template i was not able to get under 25,4mm radius for the circle tool
for your information, here is the code from the console.
Error: #<TypeError: reference to deleted Entity>
(eval):895:in `get_attribute'
(eval):895:in `onActivePathChanged'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:396
Error: #<ArgumentError: Not enough edges - at least 3 required>
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:396:in `add_face'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:396:in `make_face'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:306:in `onUserText'
(eval):895
Not sure what it means, but when i draw a circle (even bellow 25mm) on the ground plane and then use the star tool there is no problem. It works.
snowflake
Postby Chris Fullmer » Mon Jun 07, 2010 3:38 pm
hmm, interesting. I'll set up to a mm template and try it to se if I get the same error.
SketchUp Team
SketchUp Team
Postby charly2008 » Sun Jul 11, 2010 1:36 pm
Dear Chris,
I used your tool extensively in the beta test of fredos Curviloft. It's a great combination. but at times appears a little error. Some objects are rotated to 180 degrees. At two or three objects, this is not a problem to turn the objects by hand.
Charly
charly2008
Postby Chris Fullmer » Sun Jul 11, 2010 2:14 pm
Hi Charly, I never did quite get some of that stuff worked out. When I wrote this I knew very little about vectors/ But, I was aware of the possibility of it adding unwanted rotation to faces. So I built in the ability to rotate a face immediatly after placing it by using the up arrow key.
So if a face is rotated wrong, hit the up arrow key to rotate it 90 degrees. Hope that helps,
Chris
SketchUp Team
SketchUp Team
PreviousNext
Return to Plugins
Users browsing this forum: gunerarici, ilyas123, jeraldinejimenez, sta2f and 15 guests
