[Plugin] Zorro2 (beta)
Re: [Plugin] Zorro2 (beta)
Postby 2agostosanthi » Tue Apr 26, 2016 12:32 am
ya descargue el zorro, pero ahora no se como lo encuentro en google sketcUp
2agostosanthi
Postby TIG » Wed Apr 27, 2016 12:34 pm
It's in 'Tools'...
Have you read the PDF manual?
Está en 'Herramientas' ...
¿Ha leído el manual en formato PDF?
download/file.php?id=20076
Global Moderator
Postby Kuchcok » Thu May 26, 2016 10:19 am
Hi, I have downloaded and installed plugin as said at the first page. Works 100% (W7, SU2016pro). I would like to thank you for great saving of time :thumb:
Also if there will be some day an update, really helpful would be if plugin can also cuts only visible groups ... now I have to copy and move away from entire model what I want to cut and put it back when done. If I just turn off the layers, for example walls, terrain, windows, etc. and I can "play" only with roof tiles with no need to copy something... it´s just an opinion
It is 8-) and very useful plugin!
Cheers mate
Kuchcok
Postby TIG » Sat May 28, 2016 11:48 am
Zorro2 cuts objects in the model's active_entities context, it also cuts into any nested components/groups in that context is the option is chosen
So to cut only part of your model make a temporary group of the objects you wish to cut.
Edit that group and use Zorro2 within that edit's entities context.
Now anything outside of the group remains unchanged.
Explode the group when you are done - if desired...
In the attached image I cut a component [which is just a specialized kind of group] and deleted the bottom part - note how outside of the context nothing is affected...
Global Moderator
Postby melu » Sat Jun 25, 2016 3:28 am
alguien me podria explicar como descargarlo ?
melu
Postby Dave R » Mon Jun 27, 2016 10:39 am
melu wrote:alguien me podria explicar como descargarlo ?
First page of this thread:
Then:
It's even better if you install the Sketchucation Plugin Store tool and use it to install Zorro2 and other extensions.
Global Moderator
Postby Whaat » Mon Jun 27, 2016 10:13 pm
Kuchcok wrote:Hi, I have downloaded and installed plugin as said at the first page. Works 100% (W7, SU2016pro). I would like to thank you for great saving of time :thumb:
That is so kind of you to say! You are most welcome. Perhaps it is time to take this Project out of beta... :mrgreen:
6
Whaat
PluginStore Author
PluginStore Author
Postby DragonCF » Mon Oct 24, 2016 1:31 pm
wooooow! its so perfect~
DragonCF
Postby Modixxs » Wed Feb 05, 2020 8:59 am
Wish it could also slice in curves and rounded lines...
Modixxs
Postby Arckadia » Fri Mar 20, 2020 12:28 am
I was quietly working with my sketchup friend when the need to cut shapes became a major problem :o . But suddenly in the distance a galloping rider appears in the night and with the tip of his awesome super mega cool PLUGIN Zorro2, all my problems were gone. A thousand thanks Zorro :thumb: :thumb:
Arckadia
Postby mkariman » Fri May 22, 2020 5:04 pm
Hi everybody
I'm having problem with zorro2
i've just installed this plugin on my su2019
but it dose not show up in the toolbars or the zorro(sword) icon in the extensions menu.
does it work with SU 2019 at all?
SOS :?
mkariman
Postby TIG » Mon May 25, 2020 1:33 pm
It should work.
Have you read the 'Zorro2 Tutorial' PDF - which is on the very first post in this thread...
viewtopic.php?p=124862#p124862
Its menu entry is under 'Tools' NOT 'Extensions' [aka Plugins].
This could be your difficulty ?
There's not a toolbar.
Please read up and come back if you still have issues... e.g. if you have your Extension Manager > Loading Policy set to something other than 'Unrestricted' it might not load at start up if its signature is old etc...
Global Moderator
Previous
Return to Plugins
Users browsing this forum: almat182, Google Bot and 14 guests
