[Plugin] Point v1.2
Re: [Plugin] Point v1.2
Postby JClements » Wed Nov 11, 2009 2:22 am
Try one of these.
JClements
Premium Member
Premium Member
Postby JClements » Wed Nov 11, 2009 2:23 am
Or this one.
JClements
Premium Member
Premium Member
Postby JClements » Wed Nov 11, 2009 2:25 am
Or this one :)
JClements
Premium Member
Premium Member
Postby JClements » Wed Nov 11, 2009 2:36 am
and the master file.
Xara format.
Great app. Cheap. Free trial down load at http://www.xara.com
Point Tool Icon for Utiller.zip
JClements
Premium Member
Premium Member
Postby utiler » Wed Nov 11, 2009 2:42 am
You're the man, John!!!! :berserk:
utiler
Top SketchUcator
Postby Edson » Sun Apr 11, 2010 11:50 pm
i have a small problem with this tool: it works fine but does not load at startup even though it was open when i closed sketchup. i always have to go to View>Toolbars to open it before using it.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby derei » Sat Dec 03, 2016 8:10 pm
This simple tool I find it extremely useful yet... too bad is not available trough Extension Warehause or Sketchucation Extension Store... it should be added, so it will be saved in the bundles...easy to reinstall and less likely to lose it.
Cheers!
DESIGNER AND ARTIST DEREI.UK
derei
Postby renatavia » Sat Apr 22, 2017 8:16 am
hi there, i downloaded the point tools plugin, BUT the problem is how to add the plugin to my sketchup 2015
i dont know how to put the plugin point tools into the ruby console
please help !
renatavia
Postby johnwmcc » Thu Jan 30, 2020 7:10 pm
I love this tool for its simplicity and convenience in use.
Unfortunately, it freezes the newly released SU 2020, and needs a Force Quit (on Mac Mojave) and I can't see why. It fails, and freezes SU 2020 when you try to add a point. No error message in Ruby console, either.
Any chance, Matt, you could update it to work in the latest version of SU? It worked fine in 2019.
johnwmcc
PluginStore Author
PluginStore Author
Postby TIG » Thu Jan 30, 2020 7:36 pm
I use this tool in v2020 without issue - PC/Win10
So it looks like a MAC issue...
Not even a newest MAC OS issue !
Matt hasn't supported this tool for some years.
If you run it with the Ruby Console open are there any error messages ?
The tool itself is relatively simple so I am a loss as to why you see this issue ...
Any other MAC users seeing this ??
Global Moderator
Postby slb_jwm » Wed May 20, 2020 3:20 pm
Sorry, TIG, I've only just seen your response, months late.
Tried it again just now.
It downloads and installs via the SketchUcation plugin, apparently without issue.
But when I try to draw a point, the first one appears on screen, but when I try to draw another in the same session of the tool, it just hangs SU indefinitely, with no Ruby console message of any kind at any time.
Great pity.
I remember trying a quick look at the code, and so did Steve Baumgartner. He couldn't see anything amiss in the ruby code, but said it appeared to be triggering some error in an unidentifiable place, deep in the graphics driver code.
Shame - I haven't found as good or as simple an alternative.
slb_jwm
PluginStore Author
PluginStore Author
Postby TIG » Wed May 20, 2020 3:34 pm
Let's see if it's the add_cpoint() method making an issue first...
Easier that dabbling around in the Tool class point picking...
Try this in the Ruby Console with an empty v2020 model... does it add all of the 10 cpoints at 1" x-intervals? Works OK on PC...
Code: Select all
model=Sketchup.active_model
ents=model.active_entities
0.upto(9).each{|x|ents.add_cpoint(Geom::Point3d.new(x,0,0))}
If that works, then perhaps the Tool code is flaky ?
e.g. does it set the active_model up each time it runs, as all current models on MACs use the same SketchUp - unlike PCs ??
Global Moderator
Previous
Return to Plugins
Users browsing this forum: nil batista, oman3000 and 9 guests
