[Plugin] Tools On Surface - v2.3a - 06 Oct 17
Re: [Plugin] Tools On Surface - v1.5 (Refresh - 17 Sep 09)
Postby fredo6 » Thu Sep 17, 2009 10:07 pm
NEW VERSION 1.5a - 17 Sep 09
The main evolution is the addition of a Button palette for better visualizing and modifying the various options of each tool. Freehand also gets a Point & Click mode, which makes it equivalent to a Polyline On Surface, With and Without inferences (easier to draw over images).
See attachment and documentation in main post of this thread at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212#p76625
ToolsOnSurface 1.5 requires to install LibFredo6 3.4 or higher.
See post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178 for download and installation.
Fredo
PS: Many thanks to Takeshi who helped to troubleshoot some issues on Mac.
fredo6
PluginStore Author
PluginStore Author
Postby Ben Ritter » Thu Sep 17, 2009 10:11 pm
Fredo6,
I can't find the attachment.
Ben Ritter
Postby fredo6 » Thu Sep 17, 2009 10:14 pm
Ben Ritter wrote:I can't find the attachment.
It is at the end of the first post of this thread.
fredo6
PluginStore Author
PluginStore Author
Postby Ben Ritter » Thu Sep 17, 2009 10:15 pm
Never mind, I found it. My settings were preventing me from going back to the first page.
By the way, thank you very much.
Ben Ritter
Postby Daniel S » Thu Sep 17, 2009 10:23 pm
Fredo:
I think that ZLoader__OnSurface.rb is missing in the .zip
Daniel S
Daniel S
Postby solo » Thu Sep 17, 2009 10:33 pm
Yeah, I'm having an issue with z-loader also
www.solos-art.com
I'm a social vegan, I avoid meet.
solo
Global Moderator
Re: [Plugin] Tools On Surface - v1.5b (Refresh - 17 Sep 09)
Postby CadFather » Thu Sep 17, 2009 10:37 pm
wow, Fredo is back - better sit down...
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
CadFather
PluginStore Author
PluginStore Author
Postby fredo6 » Thu Sep 17, 2009 10:37 pm
Daniel S wrote:Fredo:
Thanks Daniel, you are the best tester!
I included the file in the main post (v1.5b)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby utiler » Thu Sep 17, 2009 11:39 pm
Thanks in advance, Fredo. You ROCK!!!! :berserk: :berserk: :berserk:
utiler
Top SketchUcator
Postby xrok1 » Thu Sep 17, 2009 11:47 pm
KUDO'S :ecstatic:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby EarthMover » Fri Sep 18, 2009 12:41 am
Wow Fredo. That freehand tool looks incredible. I'm wondering if a similar algorithm could be used to automatically extract a traced cutout from a transparent .png image....by locating the pixel data. Make a rectangle, drop a .png texture on it, run the plugin and be left with a polygon the shape of the transparent image.
Sorry for the digression, just thinking of how amazing that pixel identification technique is and what other purposes it could serve.
Thanks for the update for TOS!!! :thumb: :thumb:
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby fredo6 » Fri Sep 18, 2009 1:19 am
EarthMover wrote:Wow Fredo. That freehand tool looks incredible. I'm wondering if a similar algorithm could be used to automatically extract a traced cutout from a transparent .png image....by locating the pixel data. Make a rectangle, drop a .png texture on it, run the plugin and be left with a polygon the shape of the transparent image.
No clue whether this can be done (but this would be very different from Freehand). The minimum would be to be able to read a PNG encoded file. There is a Ruby library for that (RMagick by Tim Hunter) but it's probably a lot of processing.
fredo6
PluginStore Author
PluginStore Author
Postby Ken » Fri Sep 18, 2009 3:04 am
Fredo
I believe Page 13, "Drawing without a surface" one of the following lines is incorrect.
LEFT: for vertical plane defined by Red and Blue axis
RIGTH: for vertical plane defined by Red and Blue axis - I think this should be Green and Blue axis
So thanks for the great plugin
Ken
Ken
Premium Member
Premium Member
Postby Daniel S » Fri Sep 18, 2009 3:50 am
Thank you Fredo!!!
Great update!!
Here I made alternative icons and cursors
Download from:
IMAGES_DanielS.zip
Tools On Surface has 13 tools... I'm not superstitious but I vote for a new tool :berserk: :berserk: :berserk: (Tape measure on Surface?)
Daniel S
Daniel S
Re: [Plugin] Tools On Surface - v1.5c (Refresh - 18 Sep 09)
Postby fredo6 » Fri Sep 18, 2009 6:17 am
Thanks Daniel,
I integrated them in the version 1.5c, updated in the main post
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby solo » Fri Sep 18, 2009 6:29 am
Marvelous set of tools, Thanks a ton Fredo, these will empower me to push SU even further.
www.solos-art.com
solo
Global Moderator
Postby thomthom » Fri Sep 18, 2009 8:15 am
Can the TOS_Dir_13 folder be removed?
PluginStore Author
PluginStore Author
Postby thomthom » Fri Sep 18, 2009 8:31 am
The Any button is brilliant! Save so much precious space. :thumb:
btw, how are you drawing the icons for your viewport toolbar? most of them looks like simple line drawinsgs - but some, like the exit button looks more complicated? bitmap?
And how do you draw coloured filled areas?
PluginStore Author
PluginStore Author
Postby notareal » Fri Sep 18, 2009 8:52 am
:berserk: :berserk:
notareal
Thea Render Support
Thea Render Support
Postby CadFather » Fri Sep 18, 2009 9:04 am
to delete the old TOS_Dir_13 folder, it seems you must copy LibTraductor_20.rb from TOS_Dir_13 folder to your new TOS_Dir_15
also need to change the line TOS_Dir_13 to TOS_Dir_15 in libfredo6.rb
[require 'TOS_Dir_15/LibTraductor_20.rb' if Sketchup.find_support_file('TOS_Dir_13/LibTraductor_20.rb', "Plugins") #Compatibility]
Fredo (Thanks) will know better but this works here
CadFather
PluginStore Author
PluginStore Author
Postby j_forrester » Fri Sep 18, 2009 9:15 am
Had a look and cant see anyone with similar problem. On startup I get the below dialogue box. Any ideas? Installed Fredo 3.4c and run Mac Pro.
Many thanks.
j_forrester
Postby dylan » Fri Sep 18, 2009 11:22 am
Thanks, really nice improvement :thumb:
Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
dylan
Postby fredo6 » Fri Sep 18, 2009 12:33 pm
thomthom wrote:Can the TOS_Dir_13 folder be removed?
YES, I forgot to say it.
Anyway, the folder is passive, as no loader is pointing at it.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Frederik » Fri Sep 18, 2009 1:13 pm
Thanks for this, Fredo...! :)
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Postby Dan » Fri Sep 18, 2009 1:52 pm
Dylan wrote: Can't get Daniels icons to show. If I choose them from Default Parameters and ok it, nothing happens. If I open again, the tick in the box is gone.
I replaced the icons in "IMAGES_Standard" subfolder with the icons set of choice and all went ok.
Dan
Postby Dan » Fri Sep 18, 2009 2:01 pm
I don't remember if I gave thanks to you, Fredo, but if I did, I repeat them: THANK YOU VERY MUCH for your life saving, incredible tools! :ecstatic:
A wish, though: can you make the additional TOS palette to remember its position on screen from a SU session to another?
Dan
Postby takesh h » Fri Sep 18, 2009 2:24 pm
Dan wrote:I replaced the icons in "IMAGES_Standard" subfolder with the icons set of choice and all went ok.
Yes the trick did the job, thanks Dan. :thumb:
takesh h
Postby dylan » Fri Sep 18, 2009 2:37 pm
Thanks Dan, perfect!
I was trying to replace them in images DanielS.
dylan
Postby olishea » Fri Sep 18, 2009 3:48 pm
I love this tool, I use it all the time.
Endless thanks :ecstatic: :ecstatic: :ecstatic:
oli
olishea
Premium Member
Premium Member
Postby fredo6 » Fri Sep 18, 2009 4:02 pm
Dan wrote:A wish, though: can you make the additional TOS palette to remember its position on screen from a SU session to another?
You can specify the default position in the SeTtings dialog box of LibFredo6 (so in the Windows > LibFredo6 Settings menu).
Fredo
fredo6
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: IVOVIEIRA and 6 guests
