[Plugin] Universal Importer - v1.2.3 - 04 June 2023
Re: [Plugin] Universal Importer - v1.2.1 - 31 Mar. 2023
Postby Rich O Brien » Fri Mar 31, 2023 6:47 pm
Still getting errors even on simple cube mesh. No materials, no modifiers and no external files linked or appended to .blend
I never know where I'm headed, just make it up as I go - Box 22:4
User avatar
Rich O Brien
Administrator
Postby samuel_t » Fri Mar 31, 2023 9:48 pm
Rich O Brien wrote:Still getting errors even on simple cube mesh. No materials, no modifiers and no external files linked or appended to .blend
Hi Rich,
Thanks for your quick bug reports.
Does Universal Importer v1.21 allow you to import other formats than .blend?
Can you please attach this very simple .blend file that refuses to be imported?
User avatar
samuel_t
Postby Rich O Brien » Mon Apr 03, 2023 1:32 pm
Here's a simple cube saved in Blender 3.5 that fails to import...
cube.zip
User avatar
Rich O Brien
Administrator
Postby rv1974 » Mon Apr 03, 2023 2:38 pm
U r Da Beast :)
rv1974
Postby Rich O Brien » Mon Apr 03, 2023 4:10 pm
rv1974 wrote:U r Da Beast :)
Beware.....because I do bite
User avatar
Rich O Brien
Administrator
Postby samuel_t » Mon Apr 03, 2023 5:30 pm
Rich O Brien wrote:Here's a simple cube saved in Blender 3.5 that fails to import...
cube.zip
Indeed Rich, Universal Importer passes Blender 3.4.1 cube test but not Blender 3.5.0 one.
Thanks for your report ;)
User avatar
samuel_t
Re: [Plugin] Universal Importer - v1.2.2 - 04 Apr. 2023
Postby samuel_t » Tue Apr 04, 2023 1:13 pm
1.2.2 version deletes temporary hard links and temporary files possibly left after an import fail or a polygon reduction fail.
Download latest Universal Importer plugin from SketchUcation PluginStore.
User avatar
samuel_t
Postby ankitdarda » Tue Apr 11, 2023 6:48 pm
Could you also include Revit .RVT import with textures as well????? Thanks in advance
thank you !!!
ankitdarda
Postby samuel_t » Sun Apr 16, 2023 3:20 pm
ankitdarda wrote:Could you also include Revit .RVT import with textures as well?????
There is little chance that the RVT (Revit) format will ever be supported by the Universal Importer plugin.
However, there is a paid add-in for Revit that allows you to export a Revit model and its textures to SketchUp.
User avatar
samuel_t
Postby M_Schulze » Mon May 01, 2023 10:27 am
Universal Importer V1.2.2 does not import any stl file. Universal Import Error: No such file or directory @ rb_sysopen - C:/3D/bottle-opener/uir-inter.mtl
C:Users/ABC/. . ./SketchUp/Plugins/universal_importer/import.rb:170:in'read'
Please help (Sketchup Make 2017, Windows 10)
M_S
M_Schulze
Postby samuel_t » Mon May 01, 2023 5:04 pm
M_Schulze wrote:Universal Importer V1.2.2 does not import any stl file. Universal Import Error: No such file or directory @ rb_sysopen - C:/3D/bottle-opener/uir-inter.mtl
M_S
Could you please send me this STL file via Dropbox, for example?
User avatar
samuel_t
Postby Poltava » Sun May 28, 2023 11:20 am
Can't download plugin on Sketchucation page...
Poltava
Postby Rich O Brien » Sun May 28, 2023 12:23 pm
Yes, we are working on restoring the amazon server bucket that hold the downloads.
Shouldn't take long.
User avatar
Rich O Brien
Administrator
Postby Poltava » Mon May 29, 2023 10:51 am
Does not want to export FBX and other files. Reinstalling doesn't help
Poltava
Postby samuel_t » Mon May 29, 2023 5:40 pm
Poltava wrote:Does not want to export FBX and other files. Reinstalling doesn't help
Try importing a 3D model stored in a folder to which you have write access.
User avatar
samuel_t
Postby rizkymfadh19 » Wed May 31, 2023 6:11 pm
this amazed me, really thank you for the plugin :thumb: :thumb:
rizkymfadh19
Postby samuel_t » Thu Jun 01, 2023 7:16 am
rizkymfadh19 wrote:this amazed me, really thank you for the plugin :thumb: :thumb:
I'm glad to hear that! :D
User avatar
samuel_t
Postby Sondre_S » Thu Jun 01, 2023 10:58 pm
I'm getting this error too. The only place it would import from was the root of my C drive. I checked and all folders are marked as "Read Only", and I can't change that, but all other programs work correctly.
I opened import.rb and commented out this:
Code: Select all
# Source dir must be writable to host hard links we'll create later.
      #raise "Source dir of model to import is not writable: #{@source_dir}"\
       # unless File.writable?(@source_dir)
and I can now import from my documents folder again. It seems to work correctly even without this check?
I found this in an article from Microsoft:
"The Read-only and System attributes is only used by Windows Explorer to determine whether the folder is a special folder, such as a system folder that has its view customized by Windows (for example, My Documents, Favorites, Fonts, Downloaded Program Files), or a folder that you customized by using the Customize tab of the folder's Properties dialog box. As a result, Windows Explorer does not allow you to view or change the Read-only or System attributes of folders."
https://support.microsoft.com/en-us/top ... 5b49247165
Sondre_S
Postby samuel_t » Sat Jun 03, 2023 1:20 pm
@Sondre_S
Thanks for the technical details. I will solve this problem as soon as possible.
User avatar
samuel_t
Re: [Plugin] Universal Importer - v1.2.3 - 04 June 2023
Postby samuel_t » Sun Jun 04, 2023 8:48 pm
1.2.3 version doesn't display anymore the "Source dir of model to import is not writable" error message.
3
User avatar
samuel_t
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: ArqVictorSpadetto, CmurphyECC, Majestic-12 Bot and 7 guests
