SCFLicense: Extension Licensing on Sketchucation  Topic is solved
Re: SCFLicense: Extension Licensing on Sketchucation
Postby Dave R » Sat Mar 18, 2023 12:25 pm
numerobis wrote:Being forced to reactivate FredoCorner every few days is enough.
Clearly you have something set up incorrectly on your computer. There should be no reason you would have to reactivate the licenses at all unless there's a problem with permissions on your computer. We've seen the permissions issue with other things, not just extension licenses, that came from incorrect installation of SketchUp on Windows. After repairing the installation correctly the permissions issues were solved. Perhaps you could try repairing the installation of SketchUp to see if that fixes it. To do that correctly, close SketchUp and find the downloaded installer file. Get it from [url]sketchup.com/download/all[/url] if you haven't got it. Right click on the installer, choose Run as administrator, and then Repair.
numerobis wrote:Really sad and beyond my understanding that Fredo did it this way after all his outstanding work.
I assure you that Fredo did not set up his extensions to require that the user reactivate the licenses at all.
User avatar
Global Moderator
Postby numerobis » Sat Mar 18, 2023 4:19 pm
Dave R wrote:There should be no reason you would have to reactivate the licenses at all
Maybe i should've been more precise... the license is getting checked every few days (5? 6? 7?) and this requires a connection to the internet. If there is no connection available the plugin stops working and then i have to reactivate it. I need to be connected to the internet every few days, so there is almost no offline usage possible.
Dave R wrote:I assure you that Fredo did not set up his extensions to require that the user reactivate the licenses at all.
He has set the timeframe - or who else did it? And as i said, when the time is up it needs to be reactivated.
numerobis
Postby Dave R » Sat Mar 18, 2023 5:51 pm
numerobis wrote:Maybe i should've been more precise... the license is getting checked every few days (5? 6? 7?) and this requires a connection to the internet.
That's not the same as having to reactivate the license as you intially wrote.
User avatar
Global Moderator
Postby vitorvieiraar » Wed Mar 22, 2023 3:11 pm
I need help with my license, ive formated my computer due to some issues and now i cant activate the license again, its like i lost it, it says license seats have exceded. is there a way to delete the activation i made before formating by computer so i can use it now?
vitorvieiraar
Postby Dave R » Wed Mar 22, 2023 3:27 pm
vitorvieiraar wrote:I need help with my license, ive formated my computer due to some issues and now i cant activate the license again
Install the latest versions of the Sketchucation ExtensionStore tool, LibFredo6, and the licensed extensions you have. Then you should be able to release the seats.
What version of SketchUp are you using? You put SketchUp 2020 Free/Make in your forum profile but there is no such version.
User avatar
Global Moderator
Postby Rich O Brien » Wed Mar 22, 2023 3:27 pm
vitorvieiraar wrote:is there a way to delete the activation i made before formating by computer so i can use it now?
Yes, visit https://sketchucation.com/webshop/my-licences.php to online release.
BTW, you've no licenses associated to this account so there's that hurdle to clear too.
I never know where I'm headed, just make it up as I go - Box 22:4
User avatar
Rich O Brien
Administrator
Postby abatari » Thu Mar 23, 2023 7:52 am
I bought a license for Fredo Scale and it worked from January 10th, 2023 until yesterday. Today it's giving me an error "computer name mismatch error_AOC."
LICENSE 101292 user : abatari
abatari
Postby Gábor » Thu Mar 23, 2023 10:57 am
@abatari: This error message is typically thrown after the computer name has been changed. A possible fix is to erase the C:\Users\user1\AppData\Local\SCF Licenses\SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file and re activate the licence.
Make sure you have the latest SketchUcationTools installed
Reason: Edited without reason on 23/03/2023
Gábor
SketchUcation IT
Postby RayW » Mon Mar 27, 2023 9:48 pm
dalebailey wrote:
Yes, very annoying and the point why i haven't bought the full package yet. Being forced to reactivate FredoCorner every few days is enough. When i imagine that i would have to do this routine every few days for all the plugins... not possible.
I would've bought them all right away, but with this limitation it's just not working for me.
It's annoying to be forced to work without them again, but there are workarounds. Really sad and beyond my understanding that Fredo did it this way after all his outstanding work.
I don't understand why it was necessary in the first place. Perhaps there should be two levels? An 'A' grade paid level for people who do use SKP professionally and a 'B' grade free level for hobbyists like myself who get nothing from SKP except the joy of creating something; then sharing that with everyone, oh and yes for free. I will not do commissions, I think that is just going down a level. If I can create something for someone because they like my work, then I'm happy to do so. My daughter does the same and she may spend months on a creation.
User avatar
RayW
Postby xudognik_rus » Tue Mar 28, 2023 4:52 am
Hi Fredo6! Can you releasing my licenses? I do not have access to the computers on which I installed them
xudognik_rus
Postby tpghks874 » Tue Mar 28, 2023 9:33 pm
After changing the computer, the licensing problem continues
sketchupUcation and all fredo6 plugins
(FredoCorner, JointPushPull, Curviloft, FredoScale, TopoShaper, Curvizard, VisuHole, ToolsOnSurface)
are up to date. However, the ERROR_A04 error continues. If you delete the signature file and try again, the B03 error appears and the same ERROR_A04 occurs.
how can i solve this problom??
tpghks874
Postby fredo6 » Tue Mar 28, 2023 10:35 pm
xudognik_rus wrote:Hi Fredo6! Can you releasing my licenses? I do not have access to the computers on which I installed them
This is done.
User avatar
Premium Member
Premium Member
Postby brksnr » Wed Mar 29, 2023 3:28 pm
Hey everybody,
I unfortunately forgot to release my license before I formatted my laptop, can you help me out on that one please?
Thanks.
brksnr
Postby fredo6 » Wed Mar 29, 2023 3:48 pm
brksnr wrote:I unfortunately forgot to release my license befor i formatted mut laptop, can you help me out on that one please?
You have first to indicate which plugin and which seat number.
Send me a PM with this information.
User avatar
Premium Member
Premium Member
Postby woah0129 » Sat Apr 01, 2023 5:57 pm
My license doesn't works.
Error message says :
Error in the License Validation
Request to Sketchucation : ERROR_A04
Worng Signature File - You may have changed the computer name
It is advised to erase the Signature file and revalidate
Do you wnat to open the folder containing the Signature file?
How can i solve this problem?
woah0129
Postby TIG » Sun Apr 02, 2023 12:53 pm
The error A04 means the licensing system can't decode the signature-file.
Which is somehow unreadable...
So perhaps you have renamed your computer, or it has a name that doesn't follow the Microsoft Windows requirements - e.g. perhaps it contains non ASCII letters/numbers or unusual punctuation or foreign characters etc...
Follow the instructions of the error-message...
Click the button to open the folder containing your signature-file and delete that signature-file.
You can now try to re-activate the license[s] and the current computer-name should be recognized...
If the problem continues look at renaming your computer sensibly and deleting the signature-file and re-activating the license[s] again...
Reason: Edited without reason on 02/04/2023
User avatar
Global Moderator
Postby yeoul » Wed Apr 12, 2023 11:38 am
I bought it twice, but there is an error
yeoul
Postby Rich O Brien » Wed Apr 12, 2023 1:37 pm
yeoul wrote:I bought it twice, but there is an error
Send an email to support@sketchucation.com with your PayPal Transaction ID
User avatar
Rich O Brien
Administrator
Postby TIG » Wed Apr 12, 2023 1:45 pm
@yeoul
Please explain yourself better...
You bought what twice ?
Was one purchase a mistake and you want a refund ? [see Rich's reply before]
Or did the purchase fail twice ??
Or does something not work properly with the license.
You need to install the newest SketchUcation toolset for the up to date licensing set up.
Make sure you have the newest versions of the
If it's a Fredo tool also make sure you have the newest LibFredo6 version.
After installing everything ensure you restart SketchUp to sync things.
If you have copies of licenses on your computer the extension's entry under the Tools submenu as a 'License...' link that opens a dialog... where you can activate / remove licenses...
You also have your own page at SketchUcation where you can view/manage your licenses...
If you get errors when managing your licenses please report the full error-message as its code is helpful to us in helping you...
User avatar
Global Moderator
Postby sanjang » Wed Apr 19, 2023 2:40 pm
Hi Fredo6!
PLEASE releasing my licenses? I RESET my computer, help me please
sanjang
Postby fredo6 » Wed Apr 19, 2023 6:27 pm
sanjang wrote:Hi Fredo6!
This is done. But you still had 2 more setas available anyway.
User avatar
Premium Member
Premium Member
Postby natejesus » Thu Apr 20, 2023 11:02 pm
I bought roundcorner. I activated it and used it. Later I run SketchUp, roundcorner isn't activated. I activate again and use it. 5 minutes later, still running the same SketchUp instance, roundcorner isn't activated again. Now I activate it, it says it's activated, but when I click roundcorner to use it, it says not activated. It is stuck in this loop.
I am disappointed. I was willing to give my money for the roundcorner tool, but the DRM is broken and I can no longer use the tool I bought. Needless to say this does not encourage me to buy any more tools. I understand DRM is needed, but it must not get in the way of paid users and absolutely must not prevent people from using what they have paid for.
natejesus
Postby xyhcwu » Fri Apr 21, 2023 6:21 am
I used the Fredo tool yesterday and was prompted with an expired license, I selected the purchased license radical file to activate it and it still prompted an expired license, I activated it again and again and ohhhh, Seats running out!
I come to - https://sketchucation.com/webshop/my-licences.php
and found no option to release them, please help me release them!!!
•Seat ID: 93950; HW ID: TH1681976919.0A; Date of activation: 20/04/2023
•Seat ID: 93961; HW ID: ZO1681976919.0D; Date of activation: 20/04/2023
•Seat ID: 93991; HW ID: ST1681982550.0Z; Date of activation: 20/04/2023
xyhcwu
Postby Dave R » Fri Apr 21, 2023 12:28 pm
xyhcwu wrote:I come to - https://sketchucation.com/webshop/my-licences.php
Do you have the current version of the Sketchucation ExtensionStore installed? And the current version of LibFredo6? Make sure they are up to date and then restart SketchUp.
What version of SketchUp are you using? Your profile shows 2020 Free/Make which is impossible.
User avatar
Global Moderator
Postby fredo6 » Fri Apr 21, 2023 1:35 pm
xyhcwu wrote:I used the Fredo tool yesterday and was prompted with an expired license, I selected the purchased license radical file to activate it and it still prompted an expired license, I activated it again and again and ohhhh, Seats running out!
You need to upgrade to the latest version of Sketchucation ExtensionStore (v4.3.1). You probably called the License dialog box without an Internet connection.
I also freed up the 3 seats for ToolsOnSurface.
User avatar
Premium Member
Premium Member
Postby fredo6 » Fri Apr 21, 2023 1:44 pm
natejesus wrote:I bought roundcorner. I activated it and used it. Later I run SketchUp, roundcorner isn't activated. I activate again and use it. 5 minutes later, still running the same SketchUp instance, roundcorner isn't activated again. Now I activate it, it says it's activated, but when I click roundcorner to use it, it says not activated. It is stuck in this loop.
Could you upgdare to the latest version of Sketchucation ExtensionStore (v4.3.1) and also make sure that you are connected to Internet when you invoke the License dialog box.
User avatar
Premium Member
Premium Member
Postby xyhcwu » Sat Apr 22, 2023 8:58 am
I have updated to Sketchup Pro 2022.
LibFredo6_v13.9a
Now it works fine, thanks!
I found that when using a VPN connection, the activated license does not release itself! :?:
xyhcwu
Postby Dave R » Sat Apr 22, 2023 1:13 pm
xyhcwu wrote:I found that when using a VPN connection, the activated license does not release itself! :?:
That shouldn't be a surpise. The license is assigned to your computer but you're using the VPN to hide your computer from the outside world so the lcense server can't see your machine.
User avatar
Global Moderator
Postby fredo6 » Sat Apr 22, 2023 1:47 pm
Dave R wrote:That shouldn't be a surpise. The license is assigned to your computer but you're using the VPN to hide your computer from the outside world so the lcense server can't see your machine.
Actually, the server only sees a token, HW ID, which is generated randomly for the computer and not related to the true computername. The server does not 'see' machines, but just receive text messages from the computer, as any web site.
Instead, I think that the Sketchup Http API has some problem and may not like VPN, or more exactly, may consider that there is no connection, especially if the VPN is activated after Sketchup is started. The API tends to freeze its status when it opens Sketchup.
User avatar
Premium Member
Premium Member
Postby Dave R » Sat Apr 22, 2023 2:05 pm
SketchUp doesn't specifically support virtualized networks though. So it amounts to the same thing.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: akjazeelucat, angga999, ikhsanaidilazhar, tiar69 and 8 guests
