Version 3.0.8 - 01.03.2023
- Added ICF options in to the Insulation tab of the Global Settings.
- Added an ICF wall framing option for all wall types.
- Added four additional ICF parameters into the wall Draw and Edit menus.
- Fixed a bug with the plan view auto-dimensioning module.
- Enabled trim, ext. wainscoting and quoins for CMU Core and ICF wall types.
ALERT! - CRITICAL BUG FIX
The bug associated with the upgrade that brought you plan view dimensions will cause the plugin to abort during regeneration when installing garage doors into a wall. It is highly recommended that you install this latest update which addresses this bug and a couple more minor bugs with the plan view dimension feature.
Medeek Wall Plugin
Re: Medeek Wall PluginVersion 3.0.8b - 01.03.2023
- Added a "Concrete" layer to the Layers tab of the Global Settings.
Re: Medeek Wall PluginWell this is interesting:
These versions they have hacked are quite old so I'm not too worried but it is interesting that my plugins are useful enough to warrant hacking by someone.
Re: Medeek Wall PluginVersion 3.0.9 - 01.05.2023
- Enabled beam pockets (in-wall columns) for CMU, CMU Core and ICF walls. - Fixed a bug within the plan view auto-dimensioning module having to do with in-wall columns. - Fixed a minor typo in the Draw menu for in-wall columns.
Re: Medeek Wall Pluginany thoughts on exterior parging / waterproofing like a partial thin surface (stucco, poly, etc) added on the exterior side above grade and below grade contact? fancy would be terrain following (approximated) versus a set level per wall.
e.g. https://www.amvicsystem.com/products/ic ... d-parging/ https://www.parge.ca/services/ https://solidacon.com/parging-over-icf/
Re: Medeek Wall PluginVersion 3.1.0 - 01.11.2023
- Enabled layer control integration with the Medeek Project extension. - Moved the Medeek Estimating module to the Medeek Project extension. - Moved the Medeek Documents module to the Medeek Project extension.
Re: Medeek Wall PluginVersion 3.1.1 - 01.19.2023
- Fixed a bug with ICF Walls. - Fixed a type in the HTML of the General tab of the Global Settings. Tutorial 32 - Auto-Dimensioning (9:31 min.) Tutorial 33 - ICF Walls (5:51 min.)
Re: Medeek Wall PluginVersion 3.1.2 - 02.05.2023
- Fixed a bug with metric templates that propagated from Version 3.0.8. - Fixed a specific bug with auto-loading wall presets. ! ATTENTION ! Critical bug fix, especially for metric templates. I highly recommend upgrading to Version 3.1.2 if you have installed Version 3.0.8 or later. The auto-load bug has to do with enabling the auto-load preset option in the Global Settings and then subsequently deleting the preset that was selected as the default auto-load preset.
Re: Medeek Wall PluginVersion 3.1.2b - 02.07.2023
- Fixed a minor bug with the Wall Selector Matrix (Gable, Shed and Hip walls). This bug was due to some consolidation and general house cleaning I did with the code a few cycles back. Even when a gable wall was selected it would automatically revert to a rectangular wall. I just noticed this yesterday but the bug probably has been around for at least a month.
Re: Medeek Wall PluginVersion 3.1.3 - 02.16.2023
- Fixed a bug with door presets within the Edit Door menu.
Re: Medeek Wall PluginVersion 3.1.4 - 03.12.2023
- Added the following door types: flat one panel (single and double). This update per customer request.
Re: Medeek Wall PluginVersion 3.1.5 - 03.17.2023
- Added a fluting number parameter for classical columns. Really wasn't wanting to dig into this right now but after a quick inspection of my code I realized it would only take me a few minutes to add in this additional parameter so that one could fine tune the look of the fluting of classical columns. This update per customer request.
Re: Medeek Wall PluginI thought I would circle back to inclined walls since I had some questions on shed dormers over the weekend.
I’ve updated the wall menus to include these new parameters now I just need to create the boolean logic to modify the wall geometry accordingly: This feature should give the user the flexibility to modify rectangular, hip, shed or gable walls as needed when an inclined bottom plate is required.
Re: Medeek Wall PluginVersion 3.1.6 - 03.26.2023
- Added inclined walls for all wall types: rectangular, shed, gable and hip. This new feature can also be used on CMU, ICF and CMU CORE walls.
Who is online
Users browsing this forum: johnwingston72, kamaluze and 21 guests
