by TIG » Wed Jan 25, 2023 1:27 pm
If you have installed the latest version of the extension & LibFredo, AND the SketchUcation toolset [which deals with the licensing] and restarted SketchUp... then you might be able to release/manage you licenses on the SketchUcation.com website - use the menu item Extensions/SketchUcation/SCFLicense: Global Status... and click the button in the dialog My Licenses at SketchUcation which should open your own page at SketchUcation.com [you might need to log in...
- Global Moderator
- Name: TIG
- Operating system: Windows
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by GM2013 » Wed Jan 25, 2023 3:30 pm
TIG wrote:It's really not rocket science. Have you read the licensing guide ? You seem to be making something from nothing !
Try this...
Download your license file and store it somewhere safe on your computer. Open Sketchup and find the extension you have now got a license for [usually under its own submenu under Tools]. In that extension's submenu there's a 'license' sub-item. Use that which will open a dialog. Validate its license by clicking the appropriate button... Then find the saved license file and validate it. From there on your extension should be licensed... You can do this for up to three licenses on used different computers...
A few steps to do it properly [once]...
Did so "properly once" and have used it repeatedly in the past. And yet this error message popped up once again when I went to use the tool. Hopefully it remains stable this time and I don't have to waste time messing around with licensing.
GM2013
- Name: Gord Metcalfe
- License type: Pro
- SketchUp use: interior design
- Level of SketchUp: Beginner
by fredo6 » Wed Jan 25, 2023 3:35 pm
GM2013 wrote:Did so "properly once" and have used it repeatedly in the past. And yet this error message popped up once again when I went to use the tool. Hopefully it remains stable this time and I don't have to waste time messing around with licensing.
What is the problem exactly. And what is the message popping up?
- Premium Member
- Name: Fredo6
- License type: Pro
- Level of SketchUp: Intermediate
by Dave R » Wed Jan 25, 2023 4:07 pm
GM2013 wrote:I don't have to waste time messing around with licensing.
What version of SketchUp? What operating system? Please complete your forum profile.
- Global Moderator
- Name: Dave R
- SketchUp version: 2022
- License type: Pro
- SketchUp use: woodworking
by eunic3 » Sat Jan 28, 2023 4:11 am
No me deja utilizar la prueba gratis, que ya acabó el 31 de octubre 2022 y lo acabo de instalar, ¿a fuerzas tengo que comprar una licencia?
eunic3
- Name: eunice
- SketchUp version: 2021
- License type: Pro
by jaroslavz » Sat Jan 28, 2023 5:04 pm
Dear, Fredo6. Can you please release my seats from my purchased license? Thank you. I can not release them because missing check box on this site https://sketchucation.com/webshop/my-licences.php. - Code: Select all
Round corner: Seat ID: 32411; HW ID: UH1651220680.0W; Date of activation: 29/04/2022 Seat ID: 48087; HW ID: KK1653811604.0K; Date of activation: 29/07/2022
Fredo Scale: Seat ID: 34002; HW ID: UF1651996781.0B; Date of activation: 08/05/2022 Seat ID: 37819; HW ID: KK1653811604.0K; Date of activation: 29/05/2022
jaroslavz
- Name: Jaroslav Žembera
- SketchUp version: 2020
- License type: Pro
by RBChimneyRock » Mon Jan 30, 2023 1:12 am
I have used Fredo6 when it was free and it was great. Back to SketchUp again with latest version Pro 2022. Bought the Fredo6 Bundle to get Toposhaper but I can't get it to load into Sketchup even though it shows in Extension Manager. Went through the instructions meticulously but the licenses are not activating. Even bought TopoShaper standalone and it isn't loading, Flawless Purchase process (as usual) but really frustrating activation process. How can I get the bundle to load? RB
RBChimneyRock
- Premium Member
- Name: Rich Becks
- License type: Pro
by Rich O Brien » Mon Jan 30, 2023 11:44 am
RBChimneyRock wrote:but I can't get it to load into Sketchup even though it shows in Extension Manager.
Did you also install Libfredo ? https://sketchucation.com/pluginstore?pln=LibFredo6If there are error messages please share them.
Rich O Brien
- Administrator
- SketchUp version: 2023
- License type: Pro
- SketchUp use: engineering and mechanical design
by RBChimneyRock » Wed Feb 01, 2023 1:16 am
I did attempt to load Fredo6 13.7b both directly in Sketchup installing pointing to the RBZ file and also using the direct installer in Sketchucation Extension store.
I can see the Libfredo6 settings page in Sketchup under the Window menu. There is reference to About LibFredo6 v13.7. It even shows up in the Extenions>Sketucation>Plugin Manager and Extensions Manager submenus.
I have stored the licenses in a folder and when I go to SCF Global Status the page it is blank and no way to point it to the license folder. I have confirmed Sketchucation shows all of the licenses.
The only thing I can think of is that I finnally got the standalone TopoShaper plugin to load and it works great. Since TopoShaper is part of the LibFredo6 Bundle could that be preventing it from loading the whole toolset?
Sorry for the newbie question but this is the first plugin I have had trouble with. Have at least 6 or 7 that loaded fine through SketchUp Extension Manager. Love Fredos tools but the activation process is a bit confusing. Rich
RBChimneyRock
- Premium Member
- Name: Rich Becks
- License type: Pro
by studiodod » Wed Feb 01, 2023 2:25 am
Please, how can I fix this problem? I have SCF License RoundCorner and connect the internet and all plug-in update but the windows show "Sorry - An error occured in the communication with Sketchucation" many thanks.
studiodod
- Name: Boonchai
- SketchUp version: 2018
- License type: Free/Make
by Dave R » Wed Feb 01, 2023 2:29 am
studiodod wrote:Please, how can I fix this problem?
What version of SketchUp? Your profile lists a non-existent version.
- Global Moderator
- Name: Dave R
- License type: Pro
by studiodod » Wed Feb 01, 2023 4:37 am
Dave R wrote:studiodod wrote:Please, how can I fix this problem?
What version of SketchUp? Your profile lists a non-existent version.  my version is 2022 (22.0.354) 64 bit Thanks
studiodod
- Name: Boonchai
by fredo6 » Wed Feb 01, 2023 9:55 am
RBChimneyRock wrote:I did attempt to load Fredo6 13.7b both directly in Sketchup installing pointing to the RBZ file and also using the direct installer in Sketchucation Extension store.
First you need to install the 8 individual plugins. Then you need to activate the license for each of them, using the purchased license files you received by email after you bought the Bundle license. The best is to have a look at the PDF instructions in the first post of this thread.
- Premium Member
- Name: Fredo6
- License type: Pro
by fredo6 » Wed Feb 01, 2023 9:57 am
studiodod wrote:Please, how can I fix this problem? I have SCF License RoundCorner and connect the internet and all plug-in update but the windows show "Sorry - An error occured in the communication with Sketchucation" many thanks.
I think this is simply a problem of Interent communication to the Sektchucation server. It might come from your configuration (proxy, ...). In any case, try to whitelist the Sketchucation domain Sketchucation.com.
- Premium Member
- Name: Fredo6
- License type: Pro
by studiodod » Wed Feb 01, 2023 3:43 pm
fredo6 wrote:studiodod wrote:Please, how can I fix this problem? I have SCF License RoundCorner and connect the internet and all plug-in update but the windows show "Sorry - An error occured in the communication with Sketchucation" many thanks.
OK, I will try to do that. Thanks
studiodod
- Name: Boonchai
by kang young sang » Fri Feb 03, 2023 1:25 am
Hello I purchased a license, but the following error occurred: I would appreciate it if you could tell me the solution.
kang young sang
- Name: KANG JAE MOON
- SketchUp version: 2017
- License type: Pro
- SketchUp use: landscape architecture
by fredo6 » Fri Feb 03, 2023 3:15 pm
kang young sang wrote:Hello I purchased a license, but the following error occurred: I would appreciate it if you could tell me the solution.
You must have changed something in your computer. Just follow the instruction, clicking on OK and erase the Signature file.
- Premium Member
- Name: Fredo6
- License type: Pro
by janosik1 » Sat Feb 04, 2023 8:51 am
edit : all licenses working now big thanks to TIG !
janosik1
- Name: jan
- SketchUp version: 2019
- License type: Pro
by jaroslavz » Sat Feb 04, 2023 2:04 pm
Hi Fredo6, Can you please release my seats? THX. jaroslavz wrote:Dear, Fredo6. Can you please release my seats from my purchased license? Thank you. I can not release them because missing check box on this site https://sketchucation.com/webshop/my-licences.php. - Code: Select all
jaroslavz
- License type: Pro
by fredo6 » Sat Feb 04, 2023 6:01 pm
jaroslavz wrote:Can you please release my seats?
This is done.
- Premium Member
- Name: Fredo6
- License type: Pro
by matsuo_lano » Sat Feb 04, 2023 11:05 pm
I payed for the 8 plugin bundle, but I received an email from PayPal telling me that the order couldn't be completed and that I will receive a refund. I'd like to continue using the plugins! What could have gone wrong?
You try to rearrange me 'till I'm sane
matsuo_lano
- Name: matsuo_lano
- License type: Pro
by janosik1 » Sun Feb 05, 2023 9:42 am
2 matsuo : you can pay via debet card directly if pay pal method failed , i did it this way but my bank support unique card number for one internet purchase so my real card number was never used directly .
janosik1
- Name: jan
- License type: Pro
by matsuo_lano » Sun Feb 05, 2023 12:57 pm
janosik1 wrote:2 matsuo : you can pay via debet card directly if pay pal method failed , i did it this way but my bank support unique card number for one internet purchase so my real card number was never used directly .
I used the iDeal method, when the money is refunded I'll try directly with PayPal. edit: also, who can I message to find out what went wrong in the first place?
matsuo_lano
- Name: matsuo_lano
- License type: Pro
by Rich O Brien » Sun Feb 05, 2023 4:08 pm
matsuo_lano wrote:who can I message to find out what went wrong in the first place?
The transaction failed between PayPal and your bank. So I would start with your bank. An easier option would be to create a PayPal account and lodge some funds into it so you can purchase online without the extra hurdle of your bank.
Rich O Brien
- Administrator
- License type: Pro
by matsuo_lano » Sun Feb 05, 2023 4:47 pm
Rich O Brien wrote:matsuo_lano wrote:who can I message to find out what went wrong in the first place?
Went the PayPal way, everything worked out. Got all the files within a few minutes.
matsuo_lano
- Name: matsuo_lano
- License type: Pro
by hayssa_nunes » Sun Feb 05, 2023 8:19 pm
Baixei o RoundCorner Plugin e comprei a licença, porém não estou conseguindo ativar!!!!!
hayssa_nunes
- Name: Hayssa Nunes
- License type: Pro
- SketchUp use: education
by Dave R » Sun Feb 05, 2023 9:26 pm
hayssa_nunes wrote:I downloaded the RoundCorner Plugin and bought the license, but I can't activate it!!
Translated by Google. Did you also install the current version of LibFredo6 and the Sketchucation Tool? Are you sure the license is for RoundCorner and not FredoCorner?
- Global Moderator
- Name: Dave R
- License type: Pro
by TIG » Sun Feb 05, 2023 9:33 pm
I downloaded the RoundCorner Plugin and bought the license, but I can't activate it!!!!!
Check that you have the license for the correct extension - there's RoundCorner and FredoCorner - similar, but needing separate licenses. What error messages do you get ? You should have a license file saved somewhere on your computer. After you install the extension - and in the case of Fredo's extensions you also need the helper LibFredo6 installing. You also need the latest SketchUcation toolset installing, which sets up licnesing... When all are installed restart SketchUp to sync everything. Now you need to activate the license... Tools menu > Fredo-Collection > EXTENSION-NAME > License submenu... In the dialog choose Activate and then find the license file...
Verifique se você tem a licença para a extensão correta - há RoundCorner e FredoCorner - semelhantes, mas precisam de licenças separadas. Que mensagens de erro você recebe? Você deve ter um arquivo de licença salvo em algum lugar do seu computador. Depois de instalar a extensão - e no caso das extensões do Fredo, você também precisa do ajudante LibFredo6 instalando. Você também precisa instalar as ferramentas SketchUcation mais recentes, que configuram o licenciamento... Quando todos estiverem instalados, reinicie o SketchUp para sincronizar tudo. Agora você precisa ativar a licença... Menu Ferramentas > Fredo-Collection > EXTENSION-NAME > Submenu License... Na caixa de diálogo, escolha Ativar e localize o arquivo de licença...
Reason: Edited without reason on 05/02/2023
- Global Moderator
- Name: TIG
- License type: Pro
by maraluke » Mon Feb 06, 2023 10:45 pm
Anyway we can release license from old machines we don't have access to anymore? Support told me to install the latest pluginstore which I did but on the web I still can't release the old machines. Ever since our office start using virtual cloud computers everytime I open sketchup it's as if I'm opening from a new machine... Thank you!
maraluke
- Name: Jun Wang
- License type: Pro
by maraluke » Tue Feb 07, 2023 1:49 am
can you help me release the license below: Thank you! RoundCorner - Code: Select all
Seat ID: 47908; HW ID: ET1647292837.0A; Date of activation: 28/07/2022 Seat ID: 57974; HW ID: BV1664483368.0R; Date of activation: 29/09/2022
JointPushPull - Code: Select all
Seat ID: 47860; HW ID: ET1647292837.0A; Date of activation: 28/07/2022 Seat ID: 57973; HW ID: BV1664483368.0R; Date of activation: 29/09/2022 Seat ID: 59541; HW ID: BB1664483368.0R; Date of activation: 11/10/2022
Curviloft - Code: Select all
Seat ID: 57977; HW ID: BV1664483368.0R; Date of activation: 29/09/2022
Curvizard - Code: Select all
Seat ID: 47946; HW ID: ET1647292837.0A; Date of activation: 29/07/2022 Seat ID: 57975; HW ID: BV1664483368.0R; Date of activation: 29/09/2022
ToolsOnSurface - Code: Select all
Seat ID: 47885; HW ID: ET1647292837.0A; Date of activation: 28/07/2022
maraluke
- Name: Jun Wang
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Plugins
