[Plugin Library] LibFredo6 - v12.9a - 13 May 22
Fredo,
Never mind. I uninstalled and reinstalled the Fredo6 library and it's all back to normal.
Fredo,
This is happening again with the same Ruby console errors and work around only this time uninstalling and reinstalling LibFredo didn't work. The rest of your plugins are working fine.
@gus r said:
Fredo,
When I click on check for updates nothing happens.
Window: Libfredo6 Setting: Check Fredo6 Plugins for Updates. Nothing under there works until I click on Default Parameters and then is starts working.
This is the error from the Ruby Console:
Error: #<NoMethodError: undefined method
wdlg_from_key' for Traductor::Wdlg:Class>
c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:36:incheck_instance_displayed' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:58:in
top_dialog'
c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:336:inblock in populate_support_menu' c:/users/z590-e/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in
block in add_command'` -
This bug is normally fixed in LibFredo6 v13.3a, just published.
NEW RELEASE: LibFredo6 v13.3a - 27 Sep 22
LibFredo6 13.3a includes:
- Major bug fixing (error about wdlg_from_key undefined)
- Bug fixing for FredoSpline (when drawing splines over an image)
Thanks Fredo.
@fredo6 said:
LibFredo6 See plugin home page of LibFredo6 for Download of LibFredo6.
The download link seems to be broken for me, for the latest update. When I click on download, I get this error:
/pluginrepo/rbz/
/var/www/html/pluginrepo/rbz/LibFredo6.rbz
File does not exist. Make sure you specified correct file name. -
That link is not a direct download link, but it takes you to a page explaining what LibFredo is...
from where you can then download its RBZ.
It's perhaps more sensible to go directly through the PluginStore, via two clicks...
https://sketchucation.com/pluginstore?pln=LibFredo6
Or even easier... use the SketchUcation Toolset's ExtensionStore³ ?? -
NEW RELEASE: LibFredo6 v13.4a - 30 Sep 22
LibFredo6 13.4a includes:
- bug fixing
- Support for ThruPaint v2.1a
I have issues when i upgrade to libfredo6 my jointpushpull and my roundcorner doesn't do anything when i click. is there anyway that i could download to the previous version, like version 12.9a i think that is the last one that is working
well never mind, it works now i just needed to restart my computer i guess..
The LibFredo6 update from Sept 22 just won't update. So I deleted it to try to reinstall. It simply does nothing when I use extension manger to install it.
Help!
NEW RELEASE: LibFredo6 v13.5a - 10 Nov 22
LibFredo6 13.5a includes:
- bug fixing for potential problems at startup
- support for future compatibility
Could you do the following, assuming you have Sketchup 2021 or 2022.
- Open the Ruby Console (menu Extension > Developer)
- Close Sketchup
- Open Sketchup - The Ruby console should open automatically and potentially display error messages.
- Keep the Ruby console opened when launching my plugins.
Still having the same issues with this version,i cant use most of your plugins, im having this problem
path=C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/1001bit_freeware no language file. tb_mode,single tb_Settingout,true tb_Draw,true tb_Edit,true tb_Array,true tb_Wall,true tb_Staircase,true tb_Win,true tb_Roof,true point_on_face,true divide,true align,true perpendicular_line,true fonplane,true bestface,true extrude1,true extrude2,true move_vertex,true fillet,true chamfer,true extend,true offset_edge,true hline_faces,true slopeedges,true linear_array,true rect_array,true polar_array,true vx_wall,true opening,true hgroove,true staircase1,true staircase2,true staircase3,true staircase4,true spiralstair,true escalator,true wframe,true dframe,true paneldivide,true screen1,true hlouvres,true vlouvres,true rafter1,true roof1,true hiproof,true revsurf,true rgrille,true cgrille,true loading 1001bitmenu >> true "English" I, [2022-11-11T09:26:56.049506 #6024] INFO -- datasmith: Loading 'C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/plugin_main.rb'... I, [2022-11-11T09:26:56.053087 #6024] INFO -- datasmith: Loading plugin binary module from C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/UnrealDatasmithSketchUp/DatasmithSketchUp.so I, [2022-11-11T09:26:56.063538 #6024] INFO -- datasmith: Engine Path: 'C:\ProgramData\Epic\Exporter\SketchUpEngine\', Enable UI: true I, [2022-11-11T09:26:56.436781 #6024] INFO -- datasmith: Activate DirectLink exporter for Model: 'boidior'('D:\SKETCHUPMODEL\boidior.skp') License expiration: 2022-09-15 15:21:59 UTC, Left: -57 days INFO: container(features) created... [Plugin.Application] INFO: app created... [Plugin.Application] IsLoaded: false C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:17: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:18: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:19: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:20: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:21: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:22: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:23: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:24: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:25: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:26: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:27: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:28: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:29: warning: encountered \r in middle of line, treated as a mere space C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/Zhouxi_Magiz.rb:30: warning: encountered \r in middle of line, treated as a mere space true E:/2022/Tools/RubyStdLib/SecureRandom.rb:309: warning: already initialized constant Random::Formatter::ALPHANUMERIC E:/2022/Tools/RubyStdLib/securerandom.rb:309: warning: previous definition of ALPHANUMERIC was here c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/f3d_flextools/main.rbe:4362: warning: Win32API is deprecated after Ruby 1.9.1; use fiddle directly instead [D5 Converter] light data restored from attribute. I, [2022-11-11T09:27:02.901161 #6024] INFO -- datasmith: Activate DirectLink exporter for Model: 'boidior'('D:\SKETCHUPMODEL\boidior.skp') c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_rotate/utils.rbe:358: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/curic_space/utils.rbe:374: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open Error: #<ArgumentError: wrong number of arguments (given 1, expected 0)> C:/Users/igora/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/rhino_inside_su.rb:148:in `load' eval:1:in `block in use_libraries' eval:1:in `each' eval:1:in `use_libraries' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:87:in `general_init' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:87:in `use_libraries' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6chromiumwdlg.rbe:73:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe:837:in `new' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6upgrade.rbe:837:in `initialize__' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:160:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in `new' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:153:in `show' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6upgrade.rbe:66:in `time_for_check?' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:453:in `block in after_startup' Error: #<NoMethodError: undefined method `wdlg_from_key' for Traductor::Wdlg:Class> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:37:in `check_instance_displayed' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in `invoke' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:445:in `invoke_quick_launcher' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:291:in `block in configure' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in `command_invoke' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in `block (2 levels) in build_config_commands' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command' LAUNCHER TEM 9196708826.464672 "Add help menu!" "create new" "created" #<Sketchup::Menu:0x00000234debaa670> (eval):23: warning: calling URI.open via Kernel#open is deprecated, call URI.open directly or use URI#open "Add help menu!" "created" #<Sketchup::Menu:0x00000234debaa670> Error: #<NoMethodError: undefined method `add_item' for nil:NilClass> (eval):40:in `block in <module:Help>' "created" #<Sketchup::Menu:0x00000234debaa670> Error: #<NoMethodError: undefined method `add_item' for nil:NilClass> (eval):199:in `block in <module:Notification>' LAUNCHER TEM 9196708866.898788 Error: #<NoMethodError: private method `load' called for #<Traductor::ParameterManager:0x00000234bfe10cd0>> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:876:in `param_load' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:366:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:240:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:196:in `new' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:196:in `launch' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:176:in `action__mapping' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in `call' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:103:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:119:in `block in startup' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in `command_invoke' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in `block (2 levels) in build_config_commands' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command' Error: #<NoMethodError: private method `load' called for #<Traductor::ParameterManager:0x00000234bdc51a90>> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:876:in `param_load' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:366:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:246:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:198:in `new' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:198:in `launch' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:176:in `action__mapping' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in `call' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:103:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:120:in `block in startup' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in `command_invoke' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in `block (2 levels) in build_config_commands' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command' Error: #<NoMethodError: private method `load' called for #<Traductor::ParameterManager:0x00000234bfbc7b40>> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:876:in `param_load' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:366:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:240:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:196:in `new' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:196:in `launch' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/fredocornertool.rbe:176:in `action__mapping' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in `call' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:103:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_fredocorner/bootstrap_fredocorner.rbe:119:in `block in startup' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in `command_invoke' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in `block (2 levels) in build_config_commands' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command' Error: #<NoMethodError: undefined method `wdlg_from_key' for Traductor::Wdlg:Class> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:37:in `check_instance_displayed' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in `invoke' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe:132:in `invoke_quick_launcher' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curvizard/bootstrap_curvizard.rbe:103:in `block in startup' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in `command_invoke' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in `block (2 levels) in build_config_commands' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command' LAUNCHER TEM 9196708988.201132 Error: #<NameError: undefined local variable or method `accept_current_selection' for #<Traductor::EdgePicker:0x00000234c007c820> Did you mean? validate_current_selection> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:553:in `notify_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:584:in `terminate_current_selection' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:745:in `notify_from_vbox' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:3987:in `call' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:3987:in `onLButtonUp' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:2486:in `onLButtonUp' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:1152:in `onLButtonUp' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:508:in `onLButtonUp' LAUNCHER TEM 9196709028.635246 Error: #<NameError: undefined local variable or method `accept_current_selection' for #<Traductor::EdgePicker:0x00000234bf204068> Did you mean? validate_current_selection> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:553:in `notify_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:584:in `terminate_current_selection' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:279:in `execute_validate' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:450:in `onReturn' Error: #<NameError: undefined local variable or method `accept_current_selection' for #<Traductor::EdgePicker:0x00000234bf204068> Did you mean? validate_current_selection> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:553:in `notify_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:584:in `terminate_current_selection' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:279:in `execute_validate' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:450:in `onReturn' Error: #<NameError: undefined local variable or method `accept_current_selection' for #<Traductor::EdgePicker:0x00000234bf204068> Did you mean? validate_current_selection> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:553:in `notify_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6edgepicker.rbe:584:in `terminate_current_selection' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:279:in `execute_validate' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:450:in `onReturn' LAUNCHER TEM 9196710848.170437 Error: #<NameError: undefined method `notify_by_otpicker' for class `Traductor::FaceSelector'> c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:in `method' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/body_lib6faceselector.rbe:66:in `initialize__' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6faceselector.rbe:35:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:in `new' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:409:in `init_face_selector' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:151:in `initialize' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:in `new' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/jointpushpulltool.rbe:85:in `action__mapping' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in `call' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:143:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:240:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:87:in `launch_action' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:135:in `block in declare_command' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1464:in `command_invoke' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1444:in `block (2 levels) in build_config_commands' c:/users/igora/appdata/roaming/sketchup/sketchup 2022/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in `block in add_command'
Do you have the newest versions of LibFredo and the SketchUcation toolset installed and SketchUp restarted ?
Other extensions loading seem to be having issues, so they could be causing problems with Fredo's files loading subsequently...
Have you tried disabling the other extensions named, and restarting SketchUp to see if that helps ? -
Have you tried disabling the other extensions named, and restarting SketchUp to see if that helps ?it worked, thanks
Bonjour,
Les plugins de Fredo6 n’affiches plus les icônes puis j'ai remarqué que ExtensionStore V.429 n’ été plus branché à internet avec mes identifiants, Cela est résolu mais c'est étonnant.Autre soucis depuis la mise à jour de FredoLib V3.5a l'utilisation de Curviloft provoque un Plantage systématique de Sketchup.
Avez vous des explications ?
Cordialement
Hello,
The Fredo6 plugins no longer display the icons then I noticed that ExtensionStore V.429 was no longer connected to the internet with my credentials, This is resolved but it's surprising.Another concern since the update of FredoLib V3.5a the use of Curviloft causes a systematic crash of Sketchup.
Do you have any explanations?
Cordially
NEW RELEASE: LibFredo6 v13.6a - 29 Nov 22
LibFredo6 13.6a includes:
- Bug fixing about selection contextual menu (for LOTT and FredoSpline)
It is strongly advised to upgrade to this version
Hello,
PayPal is forbidden in our country, Turkey. How can I buy these plugins with another payment method?
Thank you.
See https://sketchucation.com/forums/viewtopic.php?f=323&t=75165
