[Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Re: [Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Postby rv1974 » Mon Jul 19, 2021 1:38 pm
works perfectly here.
try direct:
https://www.racoon-artworks.de/resource_extendborders.php
p.s. his ShapeConnect is also interesting:
rv1974
Postby panixia » Mon Jul 19, 2021 7:35 pm
rv1974 wrote:try direct:
Yes, the page works, but the download button does nothing. :?
User avatar
panixia
Postby rv1974 » Mon Jul 19, 2021 8:09 pm
Everything works here, maybe its your ad blocker- try DL via smart phone. Let's discuss it in PMs, not in the thread
rv1974
Postby Box » Fri Jul 23, 2021 3:44 pm
Hi Fredo
There seems to be an issue with JPP Normal.
It doesn't produce sides.
This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
User avatar
Postby boofredlay » Fri Jul 23, 2021 4:16 pm
I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
User avatar
boofredlay
Global Moderator
Postby panixia » Fri Jul 23, 2021 5:23 pm
Box wrote:Hi Fredo
That's 100% because you set "borders" to "none". :thumb:
User avatar
panixia
Postby Box » Sat Jul 24, 2021 2:31 am
panixia wrote:That's 100% because you set "borders" to "none". :thumb:
I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
Sorry Fredo, all good.
User avatar
Postby panixia » Sat Jul 24, 2021 7:28 am
Glad that it helped.
User avatar
panixia
Postby Box » Sat Jul 24, 2021 7:52 am
panixia wrote:Glad that it helped.
One for the D'oh book.
User avatar
Postby panixia » Sat Jul 24, 2021 12:29 pm
Lol! :roflmao:
User avatar
panixia
Postby EvilBoris » Wed Oct 13, 2021 3:43 pm
Can anybody help?, I get this error with any object using round
Date: 13-Oct-21 15:39:35
An error occurred in Round Push Pull
Error in Analysis of model
undefined method `normalize' for nil:NilClass
jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
jointpushpullalgo.rbe: 1406 -- each
jointpushpullalgo.rbe: 1406 -- round_compute_direction
jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
jointpushpullalgo.rbe: 1353 -- each
jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
jointpushpullalgo.rbe: 1111 -- each
jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
jointpushpulltool.rbe: 837 -- dragging_start
jointpushpulltool.rbe: 1527 -- onLButtonDown
I can do this with a new document and a cube and I get this error or in an existing model.
EvilBoris
Postby Dave R » Wed Oct 13, 2021 3:47 pm
EvilBoris wrote:Can anybody help, I get this error with any object using round
This is in SketchUp 8 as your profile indicates you are using?
User avatar
Global Moderator
Postby JQL » Thu Dec 02, 2021 6:13 pm
Cheers,
I just found out about JPP Thickening. I use JPP for ages and never noticed it there and now it just solved an issue I had. Great! Just great!
User avatar
JQL
Premium Member
Premium Member
Postby fredo6 » Thu Dec 02, 2021 6:39 pm
JPP Thickening is just Joint Push Pull without a button palette. Which issue did it solve?
User avatar
PluginStore Author
PluginStore Author
Postby JQL » Thu Dec 02, 2021 7:45 pm
I was trying to offset all faces of a surface exactly 20cm and both the regular JPP and Normal JPP failed while thickening seemed to work.
User avatar
JQL
Premium Member
Premium Member
Postby Peter Czy » Wed Jan 12, 2022 10:11 am
Hello, I've been working with this plugin for a long time.
This question comes up in our German forum:
Almost all surfaces (objects) can be thickened.
Is it also possible to make an object thinner
without leaving the side edges and surfaces remaining? If it is possible, please write us how it works.
Many Thanks
Peter
User avatar
Peter Czy
Postby Box » Wed Jan 12, 2022 1:53 pm
One of the setting with JPP is the second face, if you untick the that then moving inward will make things 'thinner' if that's what you mean.
If not, you need to show an example of what you mean.
User avatar
Postby Peter Czy » Wed Jan 12, 2022 2:25 pm
It's right, the objects get thinner when I push inward. However, edges and surfaces remain that have to be laboriously erased on a complicated object.
I mean those edges and lines marked with red arrows.
Peter
User avatar
Peter Czy
Postby Box » Wed Jan 12, 2022 2:42 pm
Many questions, many possibilities.
Can you not Scale the object or Move the face.
The problem with questions like this is there is no single answer, so much depends on the shape and what you want the result to be.
Attaching a model would help.
User avatar
Postby Peter Czy » Wed Jan 12, 2022 2:55 pm
Joint Push Pull.skp
It's just one question.
Use Joint Push Pull to thin an object without creating edges and faces.
If I just move the face, the thickness won't stay even. The same applies to scaling.
User avatar
Peter Czy
Postby Box » Wed Jan 12, 2022 3:22 pm
Often the tool you think you need isn't, a simple offset and follow me is another way to do what you want, PP to correct the ends if necessary.
The main point being that there are many ways to do things and some times it pays to think simply.
User avatar
Postby Peter Czy » Wed Jan 12, 2022 4:02 pm
Ok, thanks for the other option to change a model. That was of course a very simple test model.
The time required for your option is similar to that of deleting these surfaces / edges according to JPP.
In principle, we don't have an exact answer as to why these edges and faces remain when the object is thinned.
I am sure that only the developer fredo6 can answer that.
I will post this result in our German forum.
Thanks again.
Peter
User avatar
Peter Czy
Postby Box » Wed Jan 12, 2022 4:11 pm
The reason the edges and faces exist is the nature of the tool, it is pushing back following the face and therefore creating extra geometry.
This is not a bug of a fault in the software, it is doing what is expected.
Use the undo option and jpp less.
User avatar
Postby Dave R » Wed Jan 12, 2022 4:22 pm
Pay attention to what is actually happening when you use JPP. It's extruding in the direction of the normals of the faces as it is designed to do. As Box indicates, it's doing what it is supposed to do even though that's not what you want. If you must use JPP to add the thickness and you want a different thickness, the easy thing to do would be to copy the original surface and run JPP to extrude to the desired thickness.
User avatar
Global Moderator
Postby Peter Czy » Wed Jan 12, 2022 4:36 pm
Hello Dave and Box,
Yes, I think the best option is to erase the face that has already been made too thick and recreate the reduced thickness.
Thank you!
Peter
User avatar
Peter Czy
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: pspook and 9 guests
