Medeek Wall Plugin
Re: Medeek Wall Plugin
Postby medeek » Fri Oct 22, 2021 10:27 pm
Version 2.4.6 - 10.22.2021
- Added two additional advanced options for in-wall columns: Top Plt. Cut, Btm Plt. Cut.
- Added two additional parameters into the Columns tab of the global settings.
- Fixed a critical bug with the wall copy tool that was created with the prior update.
- Added error checking code into the rectangular wall edit menu for sheathing, cladding, and gypsum materials.
- Added error checking code into the window edit menu for the shutter material.
With the in-wall columns I've also changed the draw and edit tool so that the columns can be drawn at the end of the walls, there is no longer the one-stud limitation, not even sure why I added that in originally.
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Oct 25, 2021 5:33 am
Version 2.4.7 - 10.24.2021
- Fixed a bug with shed walls for the following end configurations: Inside Corner, Inset Inside Corner.
This fix should resolve the issues we were seeing with the shed wall. I probably missed these bug(s) initially because the inside corner with a shed wall is not very common and sometimes I don't test every possible permutation even though I should.
I may need to go back into the gable and hip wall modules and test them a bit further.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Oct 25, 2021 6:18 pm
Version 2.4.7b - 10.25.2021
- Added the following additional Wide Flange (W) beams to the beam module: W10X22, W10X26, W10X30, W10X33, W10X39, W10X45, W12X26, W12X30, W12X35, W12X40.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Oct 30, 2021 12:29 pm
Version 2.4.8 - 10.30.2021
- Added an end cripples option for all window types.
I will probably also need to add in this option for doors and garage doors.
!!! WARNING !!!
This update will require deleting and recreating any window presets. This update will not affect any other preset types (ie. wall, door, garage door etc...)
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Nov 01, 2021 3:04 am
Version 2.4.9 - 10.31.2021
- Added an end cripples option for all man doors.
- Added an end cripples option for all garage doors.
- Fixed a bug with exterior trim for arched garage doors when the "trim union" option is enabled.
!!! WARNING !!!
This update will require deleting and recreating any door and garage door presets. This update will not affect any other preset types (ie. wall, window etc…)
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Nov 06, 2021 10:49 am
Version 2.5.0 - 11.06.2021
- Added a rainscreen option for rectangular walls (vertical furring strips).
!!! WARNING !!!
This update will require deleting and recreating any rectangular wall presets. This update will not affect any other preset types (ie. gable wall, shed wall, hip wall, door, window etc…)
This feature has been requested multiple times lately so I thought I might try and get a rudimentary rainscreen feature put together. Note that the current rainscreen module is fairly simple and does not trim around openings. If you want the furring strips to line up with the studs you can set the offset value to 1/2 of the stud spacing (or any other value for a different alignment).
I consider this feature more representational at this point but please give me additional feedback with regards to future improvements or additional options/requirements.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Nov 14, 2021 11:09 am
Version 2.5.1 - 11.14.2021
- Added a horizontal rainscreen option for rectangular walls (horizontal furring/girt boards).
- Added an option for top and bottom furring/girt boards for horizontal rainscreens.
If you set the top or bottom sizes to "zero - 0.0" then it will eliminate that respective option.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Nov 15, 2021 12:29 am
In recognition of the overwhelming support I have received from the SketchUp community during 2021 I will be immediately offering 35% off of the mdkBIM bundle price (permanent license) using the coupon code **GIVETHANKS21** . (promotion ends Dec. 1, 2021).
This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer also ends on Dec. 1 and no rain checks will issued thereafter.
4
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Nov 16, 2021 3:24 am
Version 2.5.2 - 11.15.2021
- Fixed a bug with exterior trim (corners) for shed walls.
- Fixed a bug with rectangular wall presets.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Nov 24, 2021 10:56 pm
Version 2.5.3 - 11.23.2021
- Added a Custom Column Library/Manager in the Columns tab of the Global Settings.
- Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) columns.
- Created the Medeek Wall API: wall_regen
- Enabled an additional wall justification option for all wall types: Sheathing.
*Note: Just a reminder that the Alt key is the hotkey for toggling the wall justification.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Nov 25, 2021 6:47 am
Note: To call the wall_regen method:
Code: Select all
Medeek_Engineering_Inc_Extensions::MedeekWallPlugin::Wall::MedeekMethods.wall_regen entity
where the entity is the Medeek wall group.
The column update required modifying at least 10 files and took about five days of concerted effort, some of it quite tedious and I will say boring, but yeah, it is always worth it. Basically an entire rewrite of the in-wall column module, a lot of the code under the hood was reviewed and updated to bring it up to speed with the highly efficient beam module. Now all of the menus are HTML as well.
The addition of the API took all of 15 minutes to add.
The wall justification was only about another 1.5 hours of work.
Mostly it was me deciding whether it would muddy the waters too much to go from three options to four (front, center back → front, center, back, sheathing). You will notice that when you use the draw wall tool now it will show a small text near the wall length dimension letting you know which justification mode that you are in. The placement and the size of this specific text may yet require some fine tuning, I want that information to be available to the user but I don’t want it to be so obtrusive that it is annoyingly so. Feedback required…
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri Nov 26, 2021 9:34 pm
Version 2.5.4 - 11.26.2021
- Improved the organization of the HTML draw and edit menus for rectangular walls.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Nov 27, 2021 7:06 pm
Version 2.5.5 - 11.27.2021
- Updated the SSW draw menu with an HTML menu.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Nov 29, 2021 6:19 pm
Just a reminder that the Thanksgiving promotion (Black Friday/Cyber Monday) is still ongoing and will be active until Dec. 1st:
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: ArayaCAD, Baaarb and 7 guests
