Re: SCFLicense: Extension Licensing on Sketchucation
Postby CDRDA » Wed Jul 07, 2021 6:50 pm
Rich O Brien wrote:
CDRDA wrote:Just wondering what is going on here...
PayPal should not apply VAT to UK based on Irish VAT Laws. Are you using a VPN?
Since July 1st we have removed the VAT to UK.
https://www.revenue.ie/en/tax-professio ... y-2021.pdf
Can you CTRL+F5 to clear your browsers cache and see if the VAT is still applied?
Hi Rich,
Many thanks for that suggestion. As it turns out, I do use a VPN. The first time I tried paying it was set to Sweden, then I realised, but did not clear the browsers cache. Having done that, everything worked fine and I have now made the purchase. Must remember that for the future, cheers!
CDRDA
Postby VallviFly » Thu Jul 29, 2021 1:40 pm
IMPOSIBLE activar licencia... estoy muy perdido, he hecho todo cómo indicais, pero no funciona, he seguido el hilo de otros casos pero tampoco.... ¿cómo lo soluciono?
Urgente
Gracias
VallviFly
Premium Member
Premium Member
Postby zigie » Wed Aug 04, 2021 3:28 am
All three seats in my license are in use, so I can't register my license.
Can you delete my license file registration details?
zigie
Postby dom10g » Tue Aug 10, 2021 11:33 am
Лицензия выдает ошибку! Что не так?
dom10g
Postby Rich O Brien » Tue Aug 10, 2021 1:04 pm
License throws an error! What's wrong
Update your Sketchucation Tools, clear your Edge cache
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby demon51011 » Fri Aug 20, 2021 11:04 pm
Hi Fredo. I have a little problem. I bought your license. Everything worked out, there are 2 uses left. After a while, my SSD M2 died. I had to reinstall everything. I downloaded the sketch again, put your license, and I have 1 use left: ((and just recently my new SSD M2 died again. I had to change it to another one and now I install the sketch again. There is a license, but you cannot use it anymore. This is very not fair, physically I am still on the same computer. I feel sorry for the money spent, because I will no longer be able to license your product, just because my drives are failing. Is there anything you can do about it? I am very upset: (
demon51011
Postby Da1qtupu3d5 » Mon Aug 23, 2021 8:21 pm
I have to pay the license again if I format my pc
Da1qtupu3d5
Postby Dave R » Mon Aug 23, 2021 9:03 pm
Da1qtupu3d5 wrote:I have to pay the license again if I format my pc
No you don't.
User avatar
Global Moderator
Postby skuser259 » Thu Aug 26, 2021 3:55 pm
I Paid for a license for Fredocorner over 24 hours ago but have not been sent a download link. Can you help please?
skuser259
Postby Rich O Brien » Thu Aug 26, 2021 6:49 pm
@skuser can you send an email too support@sketchucation.com?
Also check your Spam folder just in case it went there.
User avatar
Rich O Brien
Administrator
I can't Validate License : Error A04
Postby clinexgrim » Sun Aug 29, 2021 4:10 am
I purchased license, but can't Validate it because of Error A04
Error message :
msg_validation_error
Request to Sketchucation = ERROR_A04
I've already installed Sketchucation store v4.1.0.
how can I solve it???? :cry:
clinexgrim
Postby skuser259 » Sun Aug 29, 2021 11:33 am
Thanks Rich, followed your advice but they have not responded, I am desperate to user this plugin and my project is being held up by this. I may need to ask PayPal for a refund.
skuser259
Postby Rich O Brien » Sun Aug 29, 2021 12:28 pm
@skuser you should be sorted now. Check your inbox when you get a chance
User avatar
Rich O Brien
Administrator
Re: I can't Validate License : Error A04
Postby Rich O Brien » Sun Aug 29, 2021 12:29 pm
clinexgrim wrote:I purchased license, but can't Validate it because of Error A04
Can you let me know the what plugin you need help with?
User avatar
Rich O Brien
Administrator
Postby clinexgrim » Sun Aug 29, 2021 2:15 pm
oh, I'm trying to validate Fredocorner.
clinexgrim
Postby 13thRebel » Fri Oct 01, 2021 11:04 pm
Hello.
Are there other payment methods besides PayPal?
13thRebel
Postby Rich O Brien » Sat Oct 02, 2021 2:22 pm
Not at the moment. Stripe support planned.
User avatar
Rich O Brien
Administrator
Postby gazzato70 » Fri Oct 08, 2021 5:09 pm
Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
gazzato70
Postby irachica » Wed Oct 27, 2021 9:28 pm
licence problem with fredo corner
irachica
Postby Rich O Brien » Wed Oct 27, 2021 9:45 pm
irachica wrote:licence problem with fredo corner
Got more info?
User avatar
Rich O Brien
Administrator
Postby rwilliamson » Tue Nov 02, 2021 8:25 pm
Thank you very much. This solved my error also. :fro:
rwilliamson
Postby kimga » Wed Nov 03, 2021 10:58 am
I just downloaded Fredo Spline - to try out for 15 day, but it already said that the license has expired in February 2021...
User avatar
kimga
Postby fredo6 » Wed Nov 03, 2021 11:06 am
kimga wrote:I just downloaded Fredo Spline - to try out for 15 day, but it already said that the license has expired in February 2021...
I don't think it says 'the license has expired', but most probably 'the trial period has expired'.
It is likely because you already installed FredSpline sometimes in Februrary.
User avatar
PluginStore Author
PluginStore Author
Postby helenbzilka » Fri Nov 05, 2021 11:12 am
I bought a license Fredo Corner and I can’t load it. I have already reinstall my program for a few times.
helenbzilka
Postby Rich O Brien » Fri Nov 05, 2021 11:56 am
helenbzilka wrote:Hi
Install latest version of SketchUcation Tools...
https://sketchucation.com/resources/plu ... e-download
If that won't fix issue, erase your signature file and reactivate your license.
Code: Select all
C:\Users\[SomeName]\AppData\Local\SCF Licenses
User avatar
Rich O Brien
Administrator
Validation fails. ERROR_A04
Postby langis » Sun Nov 07, 2021 5:14 pm
Just like some others here I get the following error message when trying to validate my FredoCorner license.
"msg_validation_error
Request to Sketchucation = ERROR_A04"
I tried to find the soultion in this thread but couldn't find an answer adressing this specific error code
I have Sketchucation extension store v4.1.3 installed and I have tried to delete the SFCLicenseSignature file and reactivate the license. Still get the error message. Can you help me with a solution for ERROR_A04?
langis
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Panda_lover and 12 guests
