[Plugin] MoveAlignMe (MAM) - v1.2a - 14 Nov 21
Postby fredo6 » Sat Oct 23, 2021 5:40 pm
The information on MoveAlignMe is maintained on the Plugin Home Page of MoveAlignMe. This is also where you can download the RBZ file.
REQUIREMENTS:
  • LibFredo6: v12.2a or above
  • Usage: Free for the time being
If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
MoveAlignMe (MAM) performs the move and alignment objects interactively. Objects can be Components, Groups, Faces (and surfaces), Edges (and curves) and Images.
It includes the two tools :
  1. Move-Pivot-Straighten, which performs a translation, folllowed by a free pivoting followed by a planar rotation
  2. Move and Glue, which automatically rotates object(s) when moved over a target face or edge, aligning their blue axis with the face normal or edge direction. It also perform gluing and cut-opening for components, and since SU2021.1, for groups and images.
The user manual of is available interactively in the Instructor window of each tool. This help can also be displayed and printed in a dedicated help panel, which can be called from the contextual menu.
Here are the 2 documentations in PDF.
MAM - Move-Glue - User Manual English - v1.1c.pdf
MAM - Move-Pivot-Straighten - User Manual English - v1.1c.pdf
1) Move-Pivot-Straighten - overview
2) Move & Glue - Overview
3) Move & Glue - Deep Gluing
There is also a good overview by TutorialsUp:
And one by TheSketchupEssentials:
6
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] MoveAlignMe - v1.1a - 23 Oct 21
Postby Rich O Brien » Sat Oct 23, 2021 6:10 pm
That looks very impressive Fredo. Can't wait to try it out.
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Re: [Plugin] MoveAlignMe (MAM) - v1.1a - 23 Oct 21
Postby RLGL » Sun Oct 24, 2021 7:49 pm
Oct 24, 2021 1_45_35 PM.pdf
Oct 24, 2021 12_58_35 PM.pdf
The plug in ghosted me. I have tried multiple times to install, it shows in the Extension Manager but it is not listed in the Fredo6 Collection. The Ruby console is blank. I did get the message that is with this post. There have been multiple trys to get it to show, restarting Sketchup and the computer. The files that are in the AppData folder are also attached.
RLGL
Postby fredo6 » Mon Oct 25, 2021 7:15 am
As indicated in the message, you need to install the latest version of LibFredo6, v12.1.
User avatar
PluginStore Author
PluginStore Author
Postby RLGL » Mon Oct 25, 2021 2:35 pm
My bad, the update checker did not indicate there was an update to Libfredo 6.
RLGL
Postby boofredlay » Wed Oct 27, 2021 3:43 pm
Bravo! Another tool I did not know I needed.
Thank you.
User avatar
boofredlay
Global Moderator
Re: [Plugin] MoveAlignMe (MAM) - v1.1c - 31 Oct 21
Postby fredo6 » Mon Nov 01, 2021 1:32 am
NEW RELEASE: MoveAlignMe v1.1c - 31 Oct 21
Requirements
  • LibFredo6: v12.1a
MoveAlignMe 1.1c includes Deep Gluing, which is the possibility to move a group or instance inside the group or component containing the target face, with gluing and cut-opening.
Home Page of MoveAlignMe for information and Download.
Main post of this MoveAlignMe thread.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Mon Nov 01, 2021 9:10 am
Fredo, thanks for the new tool! I really loved ability to put faces perpendicularly to the edges. However the new 'move inside the group with gluing and cut-opening' doesn't work for me - the cutting component does indeed get glued but stays out of hosting group. no cutting happens.
rv1974
Postby fredo6 » Mon Nov 01, 2021 11:45 am
rv1974 wrote:However the new 'move inside the group with gluing and cut-opening' doesn't work for me - the cutting component does indeed get glued but stays out of hosting group. no cutting happens.
I forgot a few explanations:
Deep Gluing has to be explictely activated by Toogle SHIFT. When activated, the target faces embedded in groups or components will be highlighted in lightgreen, indicating that the object will be moved inside the target group or component and gluing / cut-opening will apply on the target face.
This is illustrated in the video below
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Mon Nov 01, 2021 2:05 pm
Oh now it makes sense, thank you.
Suggestion: Could you implement (via Control key) multiple copying (one click = one copy), similarly to TT's one?
https://sketchucation.com/pluginstore?pln=tt_place_component
rv1974
Postby alvis » Mon Nov 01, 2021 10:00 pm
Thanks :thumb:
User avatar
alvis
Premium Member
Premium Member
Postby attar82 » Sat Nov 06, 2021 4:25 am
I have tried it from a Window model from the 3D Warehouse but it is not working
attar82
Postby Dave R » Sat Nov 06, 2021 2:14 pm
attar82 wrote:I have tried it...
What window from the 3D Warehouse?
You're using SketchUp 8 as indicated in your profile?
User avatar
Global Moderator
Postby attar82 » Sat Nov 06, 2021 2:43 pm
Apologies, this is the first time i am using this platform for quiieres
I updated my profile, I am using Sketchup 2021, I've sent you an email a couple of days before using Extension Warehouse.com. May i contact you via email, it is much easier.
I ve attached a video for my Query did you see it?
attar82
Re: [Plugin] MoveAlignMe (MAM) - v1.2a - 14 Nov 21
Postby fredo6 » Sun Nov 14, 2021 10:42 pm
NEW RELEASE: MoveAlignMe v1.2a - 14 Nov 21
Requirements
  • LibFredo6: v12.2a
MoveAlignMe 1.2a fixes a major bug when processing multiple elements in copy mode. The result was not exploded.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: farukahmet, furkandkesgin, necolaneco and 22 guests
