[Plugin] LordOfTheToolbars - v1.5b - 20 Sep 21
Re: [Plugin] LordOfTheToolbars - v1.5a - 17 Sep 21
Postby rv1974 » Fri Sep 17, 2021 12:51 pm
Wow! This is truly remarkable release! Thank you so much your efforts!
rv1974
Postby fredo6 » Fri Sep 17, 2021 1:16 pm
rv1974 wrote:Wow! This is truly remarkable release! Thank you so much your efforts!
For the compact palette, I did not find a way to remove the small top frame, while keeping the window resizable. Apparently, this is Windows 10 focing this appearance.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Sat Sep 18, 2021 8:42 am
Fredo, I guess there's some limitation inside the plugin that won't let the user to stretch a toolbar horizontally further than 150* icons (my idea is to use the display's bottom area 100% - from left to right edge) Could you extend this limitation please?
*- I don't quite understand the meaning of 'Nb of columns' in the toolbar's properties. While it set to it's possible maximum value of 20 (why?) it still allows me to have 150 icons in a row.
P.S. Double Spasebar for last command is so nice!
rv1974
Postby fredo6 » Sat Sep 18, 2021 9:02 am
rv1974 wrote:Fredo, I guess there's some limitation inside the plugin that won't let the user to stretch a toolbar horizontally further than 150* icons (my idea is to use the display's bottom area 100% - from left to right edge) Could you extend this limitation please?
Ok. The limit for a palette is width < 2000 pixels. I will extend it to 4000 px.
rv1974 wrote:I don't quite understand the meaning of 'Nb of columns' in the toolbar's properties. While it set to it's possible maximum value of 20 (why?) it still allows me to have 150 icons in a row.
The number of columns (and rows) corresponds to the nominal size of the palette, which you can restore via its context menu. However, if you dimension palettes manually, you can have any size.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Sun Sep 19, 2021 7:23 am
That explains.. I've got 2560x1440 ones
rv1974
Postby ltchest » Mon Sep 20, 2021 1:30 am
Does anyone know of a way to add the VRAY commands to a toolbar in LOTTB ? I'm using 1.5a & vray 5.10.06 in Sketchup pro 2021 v.21.1.299. VRAY is does not appear anywhere as an option for adding to LOTTB
Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
RTX2070 + GTX1080, Driver 472.12
ltchest
Re: [Plugin] LordOfTheToolbars - v1.5b - 20 Sep 21
Postby fredo6 » Mon Sep 20, 2021 12:02 pm
NEW RELEASE: LordOfTheToolbars v1.5b - 20 Sep 21
Requirements
  • LibFredo6: v12.0a or above
LordOfTheToolbars 1.5a is a minor release
  • Increase the maximum width of palettes to 5000 pixels
Home Page of LordOfTheToolbars for information and Download.
Main post of this LordOfTheToolbars thread.
User avatar
PluginStore Author
PluginStore Author
Postby fredo6 » Wed Sep 22, 2021 9:49 am
ltchest wrote:Does anyone know of a way to add the VRAY commands to a toolbar in LOTTB ? I'm using 1.5a & vray 5.10.06 in Sketchup pro 2021 v.21.1.299. VRAY is does not appear anywhere as an option for adding to LOTTB
You may have to restart Sketchup twice after installation of LOTT. The reason is that VRay installs in a special directory and arranges that its toolbars are not really accessible by program.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Sep 22, 2021 10:13 am
Some bug hunting here:
*)The precision of long toolbar stretching (horizontally) is extremely poor, its up to 3-4 icons error. It's nearly impossible to arrange icons precisely - very irritating. On middle size toolbars it's almost OK - only 1 icon error.
*)Sometimes some icons just don't show right click menu and the icons can't be deleted. They'd disappear only after SU restart.
*)Locked toolbars and vignette can't keep their locked position when SU window get relocated from monitor to monitor and back. In this regard, would it be possible to implement true docking?
Thank you
rv1974
Postby fredo6 » Wed Sep 22, 2021 10:19 am
rv1974 wrote:*)The precision of toolbar stretching (horizontally) is extremely poor, its 3-4 icons error.
It's nearly impossible to arrange icons precisely- very irritating.
How many icons do you have in the row?
rv1974 wrote:*)Sometimes some icons just don't show right click menu and the icons can't be deleted. They'd disappear only after SU restart.
Do you mean that you get the cursor showing as if you were doing a drag and drop?
rv1974 wrote:*)Locked toolbars and can't keep their locked position when SU window get relocated from monitor to monitor and back. In this regard, would it be possible to implement true docking?
True docking is not possible. When you move SU from one monitor to another, something happens which I don't understand. It might be that the API to dialog is buggy. Unfortunately, I have currently only one monitor (a laptop), so I cannot test.
User avatar
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Sep 22, 2021 10:36 am
~90. all bottom area, from edge to edge.
I mean the menu attached below. Sometimes I grag new icons to my toolbar, then decide to say delete some of them, but nothing could be done because the right click menu is gone.
P.S. Another glitch I forgot to mention: Sometimes adding a separator would put it 3 icons to the left :)
rv1974
Postby ltchest » Sat Sep 25, 2021 3:57 am
[/quote]
You may have to restart Sketchup twice after installation of LOTT. The reason is that VRay installs in a special directory and arranges that its toolbars are not really accessible by program.[/quote]
Could you say a little more about this - i mean i have restarted Sketchup many times since installing LOTT. Should i uninstall LOTT, and then reinstall LOTT and then quite and start Sketchup twice, and then Bobs your Uncle ? thx
(Any news on the ability to make the vignette stay in position on the monitor where i want it ?)
ltchest
Postby simoncbevans » Mon Sep 27, 2021 1:30 pm
Great extension. I wonder if it is possible to make a custom made toolbar fly out? Would save getting in the way when you have it in the work area.
simoncbevans
Postby coreyfox » Thu Sep 30, 2021 6:03 am
This is an amazing plugin! I have moved my workflow into using it, but as of yesterday it has been crashing my sketchup, before it can fully load, every time. See attachment - any suggestions on what might be happening here?
coreyfox
Postby fredo6 » Thu Sep 30, 2021 11:39 am
coreyfox wrote:This is an amazing plugin! I have moved my workflow into using it, but as of yesterday it has been crashing my sketchup, before it can fully load, every time. See attachment - any suggestions on what might be happening here?
Which version of Sketchup are you running? If SU2021, please migrate to the latest version, because it solves issues related to menus.
User avatar
PluginStore Author
PluginStore Author
Postby ltchest » Sat Oct 02, 2021 8:22 pm
OK so i realise now that there is a switch to "Exclude" vray from the options, so i turned that off and it solved my problem. Amazing ! The only thing i really would appreciate would be to have control over where the vignette appears every time i start sketchup. Currently, i have to move it from Screen 2 onto Screen 1 every time :(
ltchest
Postby ltchest » Sat Oct 02, 2021 8:27 pm
simoncbevans wrote:Great extension. I wonder if it is possible to make a custom made toolbar fly out? Would save getting in the way when you have it in the work area.
that is exactly what the vignette gives you
ltchest
Postby coreyfox » Sun Oct 03, 2021 1:41 am
I'm on sketchup 2021.1.332
coreyfox
Postby ltchest » Wed Oct 06, 2021 10:34 pm
one more thing about the Vignette. I am finding that, even without closing Sketchup, the Vignette jumps back over to the second screen (monitor). This doesnt happen all the time - just happens sometimes / occasionally. I will open a different drawing from Sketchup and the vignette moves back to where it was at startup :(
ltchest
Postby SingulArita » Fri Oct 08, 2021 10:05 am
Thank you for a great extension. Unfortunately, I have a few bugs. Line breaks are lost for some favorite vignettes. Icons rearrange and arrangement lose clarity. There is a problem with the line break for sure. Sometimes it happens to me that the icon duplicates and the original cannot be deleted, moved - right-clicked or removed the break before. I have not yet discovered the exact cause or procedure. But it's happening significantly and it's incredibly annoying.
SketchUp 2020 20.0.363. Martin
SingulArita
Postby hsy7758258 » Thu Oct 14, 2021 9:33 am
on master toolbar manager,i can do noting,cant click or move the icon...
show page dev tools,there are bug reporter
hsy7758258
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: No registered users and 14 guests
