new plugin found at ferrari architecture
Re: new plugin found at farrari architecture
Postby pilou » Wed Jun 05, 2013 1:45 pm
Sure and it has better results in many cases! :ugeek: :)
Speedy Galerie
User avatar
Top SketchUcator
Postby Statler » Sun Mar 29, 2015 4:29 pm
Tried to install, followed the instructions, I believe, but it just gives me a long list of errors.
Maybe Mr. Filou has any idea what I did wrong? Error text attached.
Thank you!
errors.txt
User avatar
Statler
Postby pilou » Sun Mar 29, 2015 4:50 pm
http://de.sergeferrari.com/serge-ferrari-sketch-3/
It's a plugin created in 2010 so maybe not able to run on the 2015! ;)
Try it with old versions http://help.sketchup.com/en/article/60107
Speedy Galerie
User avatar
Top SketchUcator
Re: new plugin found at ferrari architecture
Postby Einstein » Sun Apr 11, 2021 1:06 pm
I installed Ferrari on SketchUp 2020 and it gets me an error at SketchUp lauchup:
Error: #<SyntaxError: c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:335: syntax error, unexpected tINTEGER, expecting ']'
g = [Geom::Point3d.new 0, 0, 0]
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:752: invalid multibyte char (UTF-8)
c:/users/user/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/ferrarisketch/ferrarisketchcode.rbs:879: invalid multibyte char (UTF-8)>
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in `eval'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in `require'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2020/Tools/extensions.rb:197:in `load'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch.rb:17:in `register_extension'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/FerrariSketch.rb:17:in `<top (required)>'
The Ferrari toolbar appears in the UI but if I select some edge loops to try to create a tensile structure, nothing happens.
Can someone help me, please?
Einstein
Postby pilou » Sun Apr 11, 2021 1:43 pm
You must select a welded closed curve...
if that not works
As it's an old plugin there is not adapted to the new versions!
Load the 2017 Make linked to the previous post...
It's working perfectly! :)
Else try the Soap Bubble Tensile Structure
Speedy Galerie
User avatar
Top SketchUcator
Postby TIG » Sun Apr 11, 2021 1:44 pm
As you can deduce from this thread it's an old script, and appears to be incompatible with newer SketchUp versions...
Because it's scrambled [RBS] you cannot get it fixed without the author's input and I think he been inactive for some time...
So I suspect you're out of luck...
BUT there are newer extensions which will probably do what you want ?
e.g. the PluginStore has Fredo's CurviLoft and my ExtensionTools...
User avatar
Global Moderator
Postby Einstein » Sun Apr 11, 2021 9:10 pm
Yes, I know it's old. Just wanted to give it a chance hoping it would work.
TIG, I use all the plugins you pointed, but Ferrari looks so cool that I'll use the old SketchUp just for it. I think it's worth it.
Einstein
Postby pilou » Sun Apr 11, 2021 10:54 pm
Install the 2017 make! :enlight:
Speedy Galerie
User avatar
Top SketchUcator
Postby majid » Mon Apr 12, 2021 11:01 am
So there won't be any update?
My perspective shortcuts book: https://bit.ly/30Tdbce
User avatar
majid
Top SketchUcator
Postby Einstein » Mon Apr 12, 2021 11:07 am
Rather not.
But try contacting the developer, maybe they will help you. And let us know if you find something out:
https://www.sergeferrari.com/
Einstein
Postby pilou » Mon Apr 12, 2021 11:10 am
Why you don't want Install the free 2017 Make ?
Because I don't believe that plugin is follow-up by their creators.
Speedy Galerie
User avatar
Top SketchUcator
Postby Einstein » Mon Apr 12, 2021 2:06 pm
pilou wrote:Why you don't want Install the free 2017 Make ?
Ok, I installed SU Make 2017 and Ferrari. I get this error at SketchUp launch:
Error: C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in `eval'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in `require'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch/FerrariSketchmenus.rb:3:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2017/Tools/extensions.rb:197:in `load'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch.rb:17:in `register_extension'
C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/FerrariSketch.rb:17:in `<top (required)>'
Nothing happens when I select a welded outline and try to create a structure :(
Einstein
Postby pilou » Mon Apr 12, 2021 5:05 pm
Seems I have FerrariSketchV1.1
From your error messages try these files
here mine in Windows 10 (it's not the "install" it's the files or folders where you have problems)
"C:\Users\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\FerrariSketch"
- Folder FerrariSketch
- FerrariSketch.rb
"C:\Program Files\SketchUp\SketchUp 2017\Tools\extensions.rb"
- extensions.rb
Speedy Galerie
User avatar
Top SketchUcator
Postby Einstein » Mon Apr 12, 2021 6:07 pm
Oh my, it finally works!
I wish these old sketchup gems were a bit better documented. It's a wasted potential lying in these little scripts that most people are not even aware of, or they are not determined enough to dig and ask others for help to barely launch them.
Thank you, Pilou, a lot for your help!
Einstein
Postby pilou » Mon Apr 12, 2021 7:33 pm
You have some basic pdf here! ;) (and you are lucky in English )
Speedy Galerie
User avatar
Top SketchUcator
Postby Einstein » Mon Apr 12, 2021 9:08 pm
pilou wrote:You have some basic pdf here! ;) (and you are lucky in English )
I mean, yes, the instructions are good. The usage of this plugin is well documented.
What I wanted to say is, there are lots of valuable tools spread across forums and hidden in the darkness of the internet that could make work so much easier for many people, and there's no unique place to store them and keep them organized, with proper files kept in the way they are easy to find. You really have to dig deep sometimes, or just luckily stumble upon some gem (as I did yesterday). In this competition I find Blender and its addons better organized than SketchUp. But it's just my impressions and thoughts, and maybe I'm just polluting this thread :P
Einstein
Postby pilou » Mon Apr 12, 2021 9:10 pm
You must take it as an adventure game! :)
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Mon Apr 12, 2021 9:25 pm
Ps I have said "Welded" : absolutly not necessary! :puke:
And can have any number of curves...
Just closed! ;)
Speedy Galerie
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Endmostnebula and 25 guests
Visit our sponsors:
